PXE30-12S12
PXE30-12S12
    TDK(东电化)
    DIP6 模块
    隔离模块 直流转换器 1 输出 12V 2.5A 9V - 18V 输入
PXE30-12S12 数据手册
PXE30xxSxx Single Output DC/DC Converters 9 to 18 Vdc, 18 to 36 Vdc, or 36 to 75 Vdc input, 1.5 to 15 Vdc Single Output, 30W Features  30 watts maximum output power  Output current up to 6A  Standard 2” x 1.6” x 0.4” package  High efficiency up to 90%  2:1 wide input voltage range  Six-sided continuous shield  Fixed switching frequency  Offer single output  CE MARK meets 2006/95/EC, 93/68/EEC and 2004/108/EC  UL60950-1, EN60950-1 and IEC60950-1 licensed  Iso9001 certified manufacturing facilities  Compliant to ROHS EU directive 2002/95/EC Options  Heat sinks available for extended operation APPLICATIONS Wireless Network Telecom/Datacom Industry Control System Measurement Equipment Semiconductor Equipment General Description The PXE30xxSxx series offers 30 watts of output power from a 2 x 1.6 x 0.4 inch package. It has a 2:1 wide input voltage range of 9-18VDC, 18-36VDC and 36-75VDC and features 1600VDC of isolation, short-circuit and over-voltage protection. Table of Contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Test Configurations EMC Considerations Input Source Impedance Output Over Current Protection Output Over Voltage Protection Short Circuit Protection Thermal Consideration P2 P2 P3 P5 P6 P48 P49 P51 P51 P52 P52 P52 Heat Sink Consideration Remote ON/OFF Control Mechanical Data Recommended Pad Layout Output Voltage Adjustment Soldering and Reflow Consideration Packaging Information Part Number Structure Safety and Installation Instruction MTBF and Reliability P53 P54 P55 P56 P57 P59 P59 P60 P61 P61 DataSheet 30W, Single Output Absolute Maximum Rating Parameter Model Input Voltage Continuous Transient (100mS) Input Voltage Variation (complies with EST300 132 part 4.4) Operating Ambient Temperature (with derating) Operating Case Temperature Storage Temperature Min Max Unit 12Sxx 24Sxx 48Sxx 12Sxx 24Sxx 48Sxx 18 36 75 36 50 100 All 5 V/mS 85 100 105 °C °C °C All All All -40 -55 VDC Output Specification Parameter Output Voltage (Vin = Vin(nom) ; Full Load ; TA=25°C) Voltage Adjustability Model Min Typ Max xxS1P5 1.485 1.5 1.515 xxS1P8 1.782 1.8 1.818 xxS2P5 2.475 2.5 2.525 xxS3P3 3.267 3.3 3.333 xxS05 4.95 5 5.05 xxS12 11.88 12 12.12 xxS15 14.85 15 15.15 Unit VDC All -10 +10 % All -0.2 +0.2 % -0.5 +0.5 Output Regulation Line (Vin(min) to Vin(max) at Full Load) Load (Min. to 100% of Full Load) Output Ripple & Noise xxS1P5 50 Peak-to-Peak (20MHz bandwidth) xxS1P8 50 (Measured with a 0.1μF/50V MLCC) xxS2P5 50 xxS3P3 50 xxS05 50 xxS12 75 xxS15 75 Temperature Coefficient Output Voltage Overshoot (Vin(min) to Vin(max) ; Full Load ; TA=25°C) All -0.02 mVp-p +0.02 %/°C 5 % VOUT All 0 All 250 mV All 300 μS Dynamic Load Response (Vin = Vin(nom) ; TA=25°C) Load step change from 75% to 100% or 100 to 75% of Full Load Peak Deviation Setting Time (VOUT-10% peak deviation) Output Current xxS1P5 0 xxS1P8 0 xxS2P5 0 6000 6000 6000 xxS3P3 0 6000 xxS05 0 6000 xxS12 0 2500 xxS15 0 2000 mA VER:00 Page 2 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Output Specification(Continued) Parameter Output Over Voltage Protection (Zener diode clamp) Model Min Typ xxS1P5 3.9 xxS1P8 3.9 xxS2P5 3.9 xxS3P3 3.9 xxS05 6.2 xxS12 15 xxS15 18 Output Over Current Protection All Output Short Circuit Protection All Max Unit VDC 150 % FL. Hiccup, automatics recovery Input Specification Parameter Operating Input Voltage Input Current (Maximum value at Vin = Vin(nom); Full Load) Model Min Typ Max 12Sxx 9 12 18 24Sxx 18 24 48Sxx 36 48 12S1P5 36 Unit VDC 75 1014 12S1P8 1169 12S2P5 1582 12S3P3 2037 12S05 3012 12S12 2976 12S15 2976 24S1P5 439 24S1P8 580 24S2P5 780 24S3P3 1010 24S05 1490 24S12 1470 24S15 1470 48S1P5 244 48S1P8 290 48S2P5 390 48S3P3 500 48S05 740 48S12 730 48S15 730 mA VER:00 Page 3 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Input Specification (Continued) Parameter Input Standby Current (Typical value at Vin = Vin(nom); No Load) Under Voltage Lockout Turn-on Threshold Model Min Typ 12S1P5 100 12S1P8 100 12S2P5 110 12S3P3 115 12S05 95 12S12 170 12S15 210 24S1P5 50 24S1P8 35 24S2P5 45 24S3P3 50 24S05 50 24S12 80 24S15 90 48S1P5 20 48S1P8 20 48S2P5 25 48S3P3 30 48S05 35 48S12 35 48S15 55 Input Reflected Ripple Current (5 to 20MHz, 12μH Source Impedance) Unit mA 12Sxx 9 24Sxx 17.8 48Sxx Under Voltage Lockout Turn-off Threshold Max VDC 36 12Sxx 8 24Sxx 16 48Sxx 33 All 30 VDC mAp-p Start Up Time (Vin = Vin(nom) and Constant Resistive Load) Power Up All 25 Remote ON/OFF mS 25 Remote ON/OFF Control (The ON/OFF pin voltage is referenced to -VIN) Positive Logic DC-DC ON All DC-DC OFF 3.0 12 0 Remote Off Input Current All Input Current of Remote Control Pin All 1.2 2.5 -0.5 VDC mA 0.5 mA VER:00 Page 4 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output General Specification Parameter Efficiency (Vin = Vin(nom) ; Full Load ; TA=25°C) Model Min Typ 12S1P5 78 12S1P8 81 12S2P5 83 12S3P3 85 12S05 87 12S12 88 12S15 88 24S1P5 80 24S1P8 82 24S2P5 84 24S3P3 86 24S05 88 24S12 89 24S15 89 48S1P5 81 48S1P8 83 48S2P5 85 48S3P3 87 48S05 89 48S12 90 48S15 90 Max Unit % Isolation Voltage Input to Output All Input to Case, Output to Case VDC 1600 1600 Isolation Resistance All 1 GΩ Isolation Capacitance All Switching Frequency All 300 KHz Weight All 48 g All 1.316×106 3.465×105 Hours All 115 °C 1000 pF MTBF Bellcore TR-NWT-000332, TC=40°C MIL-HDBK-217F Over Temperature Protection VER:00 Page 5 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves All test conditions are at 25°C.The figures are for PXE30-12S1P5 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 6 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S1P5 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 7 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S1P8 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 8 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S1P8 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 9 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S2P5 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 10 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S2P5 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 11 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S3P3 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 12 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S3P3 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 13 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are identical for PXE30-12S05 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 14 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S05 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 15 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S12 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output CurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 16 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 17 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S15 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 18 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-12S15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 19 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S1P5 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 20 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S1P5 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 21 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S1P8 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 22 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S1P8 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 23 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S2P5 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 24 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S2P5 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 25 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S3P3 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 26 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S3P3 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 27 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S05 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 28 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S05 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 29 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S12 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 30 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 31 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S15 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 32 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-24S15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 33 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S1P5 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output CurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 34 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S1P5 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 35 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S1P8 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 36 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S1P8 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 37 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S2P5 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 38 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S2P5 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 39 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S3P3 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 40 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S3P3 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 41 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S05 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 42 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S05 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 43 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S12 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 44 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 45 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S15 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating OutputCurrentVersusAmbientTemperature andAirflow Vin=Vin(nom) Derating OutputCurrentVersusAmbientTemperature with Heat-Sink andAirflow,Vin = Vin(nom) VER:00 Page 46 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXE30-48S15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin=Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin=Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin=Vin(nom), Full Load Vin=Vin(nom), Full Load VER:00 Page 47 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Test Configurations Input reflected-ripple current measurement test: Component L C Value 12 μH 220 μF Voltage ---100V Reference ---Aluminum Electrolytic Capacitor Peak-to-peak output ripple & noise measurement test: Output voltage and efficiency measurement test: Note:All measurements are taken at the module terminals.  V  Io Efficiency   o  Vin  I in    100%  VER:00 Page 48 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output EMC Considerations Suggested Schematic for EN55022 Conducted Emission Class A Limits Recommended Layout with Input Filter To meet conducted emissions EN55022 CLASS A needed the following components: PXE30-12Sxx Component C1 C3, C4 Value 6.8μF 1000pF Voltage 50V 2KV 1812 MLCC 1808 MLCC Reference Component C1 C3, C4 Value 6.8μF 1000pF Voltage 50V 2KV 1812 MLCC 1808 MLCC PXE30-48Sxx Component C1 C3, C4 Value 2.2μF 1000pF Voltage 100V 2KV 1812 MLCC 1808 MLCC PXE30-24Sxx Reference Reference VER:00 Page 49 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output EMC Considerations (Continued) Suggested Schematic for EN55022 Conducted Emission Class B Limits Recommended Layout with Input Filter To meet conducted emissions EN55022 CLASS B needed the following components: PXE30-12Sxx Component C1, C3 C5, C6 L1 Value 4.7μF 1000pF 450μH Voltage 50V 2KV ---- Reference 1812 MLCC 1808 MLCC Common Choke PXE30-24Sxx Component C1, C3 C5, C6 L1 Value 6.8μF 1000pF 450μH Voltage 50V 2KV ---- Reference 1812 MLCC 1808 MLCC Common Choke PXE30-48Sxx Component C1, C2 C3, C4 C5, C6 L1 Value 2.2μF 2.2μF 1000pF 450μH Voltage 100V 100V 2KV ---- Reference 1812 MLCC 1812 MLCC 1808 MLCC Common Choke VER:00 Page 50 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output EMC Considerations (Continued) Common Choke L1 is defined as follows: ■ L: 450μH±35% / DCR: 25mΩ, max A height: 9.8 mm, Max ■ All dimensions in millimeters Input Source Impedance The converter should be connected to a low impedance input source. Highly inductive source impedance can affect the stability of the converter. An input external L-C filter is recommended to minimize input reflected ripple current. The inductor has a simulated source impedance of 12μH and the capacitor is Nippon chemi-con KY series 220μF/100V. The capacitor must be located as close as possible to the input terminals of the power module for lowest impedance. Output Over Current Protection When excessive output currents occur in the system, circuit protection is required on all converters. Normally, overload current is maintained at approximately 150 percent of rated current for PXF40-xxSxx series. Hiccup-mode is a method of operation in a converter whose purpose is to protect the power supply from being damaged during an over-current fault condition. It also enables the converter to restart when the fault is removed. There are other ways of protecting the converter when it is over-loaded, such as the maximum current limiting or current foldback methods. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of these devices may exceed their specified limits. A protection mechanism has to be used to prevent these power devices from being damaged. The operation of hiccup is as follows. When the current sense circuit sees an over-current event, the controller shuts off the converter for a given time and then tries to start up the converter again. If the over-load condition has been removed, the converter will start up and operate normally; otherwise, the controller will see another over-current event and will shut off the converter again, repeating the previous cycle. Hiccup operation has none of the drawbacks of the other two protection methods, although its circuit is more complicated because it requires a timing circuit. The excess heat due to overload lasts for only a short duration in the hiccup cycle, hence the junction temperature of the power devices is much lower. VER:00 Page 51 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Output Over Voltage Protection The output over-voltage protection consists of an output Zener diode that monitors the voltage on the output terminals. If the voltage on the output terminals exceeds the over-voltage protection threshold, then the Zener diode clamps the output voltage. Short Circuit Protection Continuous, hiccup and auto-recovery mode. During a short circuit condition the converter will shut down. The average current during this condition will be very low. Thermal Consideration The converter operates in a variety of thermal environments. However, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding environment. Proper cooling can be verified by measuring the point as the figure below. The temperature at this location should not exceed 100°C. When operating, adequate cooling must be provided to maintain the test point temperature at or below 100°C. Although the maximum point temperature of the converter is 100°C, limiting this temperature to a lower value will yield higher reliability. VER:00 Page 52 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Heat Sink Consideration Use heat-sink (7G-0011C-F) f for lowering temperature and higher reliability of the module. All dimensions in millimeters VER:00 Page 53 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Remote ON/OFF Control The Remote ON/OFF Pin is used to turn on and off the DC-DC converter. The user must use a switch to control the logic voltage (high or low level) of the ON/OFF pin, referenced to -Vi. The switch can be an open collector transistor, FET or Opto-Coupler that is capable of sinking up to 0.5 mA at low-level logic Voltage. High-level logic of the ON/OFF signal (maximum voltage): the allowable leakage current of the switch at 12V is 0.5mA. Remote ON/OFF Implementation Circuits Isolated-Control Remote ON/OFF Level Control Using TTL Output Level Control Using Line Voltage Positive logic: PXE30 module is turned off PXE30 module is turned on Using Low-level logic using High-level logic VER:00 Page 54 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Mechanical Data PIN 1 2 4 5 6 7 8 PIN CONNECTION FUNCTION +INPUT -INPUT CTRL NO PIN +OUTPUT -OUTPUT TRIM EXTERNAL OUTPUT TRIMMING Output can be externally trimmed by using the method shown below. TRIM UP TRIM DOWN 7 8 RU 8 RD 6 VER:00 Page 55 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Recommended Pad Layout VER:00 Page 56 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Output Voltage Adjustment Output voltage set point adjustment allows the user to increase or decrease the output voltage set point of a module. This is accomplished by connecting an external resistor between the TRIM pin and either the Vo(+) or Vo(-) pins. With an external resistor between the TRIM and Vo(-) pin, the output voltage set point increases. With an external resistor between the TRIM and Vo(+) pin, the output voltage set point decreases. TRIM UP TRIM DOWN 7 8 RU RD 6 8 TRIM TABLE PXE30-xxS1P5 Trim up (%) 1 2 3 VOUT (Volts)= RU (K OhmS)= 4 5 1.515 1.53 4.578 2.605 6 7 8 9 1.545 1.56 1.227 0.808 10 1.575 1.59 1.605 1.62 1.635 1.65 0.557 0.389 0.27 0.18 0.11 0.054 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 1.485 1.47 1.455 1.44 1.425 1.41 1.395 1.38 1.365 1.35 RD (K OhmS)= 5.704 2.571 1.527 1.005 0.692 0.483 0.334 0.222 0.135 0.065 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 1.818 1.836 1.854 1.872 1.89 1.908 1.926 1.944 1.962 1.98 PXE30-xxS1P8 RU (K OhmS)= 11.639 5.205 3.06 1.988 1.344 0.915 0.609 0.379 0.2 0.057 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 1.782 1.764 1.746 1.728 1.71 1.692 1.674 1.656 1.638 1.62 RD (K OhmS)= 14.66 6.57 3.874 2.525 1.716 1.177 0.792 0.503 0.278 0.098 PXE30-xxS2P5 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 2.525 2.55 2.575 2.6 2.625 2.65 2.675 2.7 2.725 2.75 RU (K OhmS)= 37.076 16.675 9.874 6.474 4.434 3.074 2.102 1.374 0.807 0.354 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 2.475 2.45 2.425 2.4 2.375 2.35 2.325 2.3 2.275 2.25 RD (K OhmS)= 49.641 22.481 13.428 8.902 6.186 4.375 3.082 2.112 1.358 0.754 PXE30-xxS3P3 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 3.333 3.366 3.399 3.432 3.465 3.498 3.531 3.564 3.597 3.630 RU (K OhmS)= 57.930 26.165 15.577 10.283 7.106 4.988 3.476 2.341 1.459 0.753 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 3.267 3.234 3.201 3.168 3.135 3.102 3.069 3.036 3.003 2.970 RD (K OhmS)= 69.470 31.235 18.490 12.117 8.294 5.745 3.924 2.559 1.497 0.647 VER:00 Page 57 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Output Voltage Adjustment(Continued) PXE30-xxS05 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 5.050 5.100 5.150 5.200 5.250 5.300 5.350 5.400 5.450 5.500 RU (K OhmS)= 36.570 16.580 9.917 6.585 4.586 3.253 2.302 1.588 1.032 0.588 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 4.950 4.900 4.850 4.800 4.750 4.700 4.650 4.600 4.550 4.500 RD (K OhmS)= 45.533 20.612 12.306 8.152 5.660 3.999 2.812 1.922 1.230 0.676 PXE30-xxS12 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 12.120 12.240 12.360 12.480 12.600 12.720 12.840 12.960 13.080 13.200 RU (K OhmS)= 367.910 165.950 98.636 64.977 44.782 31.318 21.701 14.488 8.879 4.391 2 3 4 5 6 7 8 9 10 Trim down (%) VOUT (Volts)= 1 11.880 11.760 11.640 11.520 RD (K OhmS)= 460.990 207.950 123.600 81.423 11.400 56.118 11.280 11.160 11.040 39.249 27.199 18.162 10.920 10.800 11.132 5.509 PXE30-xxS15 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 15.150 15.300 15.450 15.600 15.750 15.900 16.050 16.200 16.350 16.500 RU (K OhmS)= 404.180 180.590 106.060 68.796 46.437 31.531 20.883 12.898 6.687 1.718 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= 14.850 14.700 14.550 14.400 14.250 14.100 13.950 13.800 13.650 13.500 RD (K OhmS)= 499.820 223.410 131.270 85.204 57.563 39.136 25.974 16.102 8.424 2.282 VER:00 Page 58 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Soldering and Reflow Consideration Lead free wave solder profile for PXE30-xxSxx DIP type Zone Preheat zone Reference Parameter Rise temp. speed : 3°C / sec max. Preheat temp. : 100~130°C Actual heating Peak temp. : 250~260°C Peak time (T1+T2 time) : 4~6 sec Reference Solder: Sn-Ag-Cu / Sn-Cu Hand Welding: Soldering iron - Power 90W Welding Time: 2-4 sec Temp.:380-400 °C Packaging Information 12 PCS per TUBE VER:00 Page 59 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Part Number Structure PXE 30 – 24 S 15 Max. Output Power 30Watts Input Voltage Range 12 : 9 ~ 18V 24 : 18 ~ 36V 48 : 36 ~ 75V Output Voltage 1P5 : 1.5Vdc 1P8 1.8 Vdc 2P5 2.5 Vdc 3P3 3.3 Vdc 05 : 5Vdc 12 : 12Vdc 15 : 15Vdc Single Output Model Number Input Range Output Voltage PXE30-12S1P5 9 – 18 VDC 1.5 VDC PXE30-12S1P8 9 – 18 VDC 1.8 VDC PXE30-12S2P5 9 – 18 VDC 2.5 VDC PXE30-12S3P3 9 – 18 VDC 3.3 VDC PXE30-12S05 9 – 18 VDC 5 VDC PXE30-12S12 9 – 18 VDC 12 VDC PXE30-12S15 9 – 18 VDC 15 VDC PXE30-24S1P5 18 – 36 VDC 1.5 VDC PXE30-24S1P8 18 – 36 VDC 1.8 VDC PXE30-24S2P5 18 – 36 VDC 2.5 VDC PXE30-24S3P3 18 – 36 VDC 3.3 VDC PXE30-24S05 18 – 36 VDC 5 VDC PXE30-24S12 18 – 36 VDC 12 VDC PXE30-24S15 18 – 36 VDC 15 VDC PXE30-48S1P5 36 – 75 VDC 1.5 VDC PXE30-48S1P8 36 – 75 VDC 1.8 VDC PXE30-48S2P5 36 – 75 VDC 2.5 VDC PXE30-48S3P3 36 – 75 VDC 3.3 VDC PXE30-48S05 36 – 75 VDC 5 VDC PXE30-48S12 36 – 75 VDC 12 VDC PXE30-48S15 36 – 75 VDC 15 VDC Note 1. Typical value at nominal input voltage and no load. Note 2. Maximum value at nominal input voltage and full load. Note 3. Typical value at nominal input voltage and full load. Output Current Min. load 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA 0mA (3) Input Current (1) Full Load No load 6000mA 100mA 6000mA 100mA 6000mA 110mA 6000mA 115mA 6000mA 95mA 2500mA 170mA 2000mA 210mA 6000mA 50mA 6000mA 35mA 6000mA 45mA 6000mA 50mA 6000mA 50mA 2500mA 80mA 2000mA 90mA 6000mA 20mA 6000mA 20mA 6000mA 25mA 6000mA 30mA 6000mA 35mA 2500mA 35mA 2000mA 55mA (2) Full Load 1014mA 1169mA 1582mA 2037mA 3012mA 2976mA 2976Ma 493mA 580mA 780mA 1010mA 1490mA 1470mA 1470mA 244mA 290mA 390mA 500mA 740mA 730mA 730mA Eff (%) 78 81 83 85 87 88 88 80 82 84 86 88 89 89 81 83 85 87 89 90 90 VER:00 Page 60 of 61 Issued Date:2009/03/02 DataSheet 30W, Single Output Safety and Installation Instruction Fusing Consideration Caution: This converter is not internally fused. An input line fuse must always be used. This encapsulated converter can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of a sophisticated power architecture. For maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a slow-blow fuse with maximum rating of 6A. Based on the information provided in this data sheet on Inrush energy and maximum DC input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXE30-xxSxx DC/DC converters has been calculated using: Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40°C (Ground fixed and controlled 6 environment ). The resulting figure for MTBF is 1.316×10 hours. MIL-HDBK-217F NOTICE2 FULL LOAD, Operating Temperature at 25°C ℃. The resulting figure for MTBF is 5 3.465×10 hours. VER:00 Page 61 of 61 Issued Date:2009/03/02
PXE30-12S12 价格&库存
很抱歉,暂时无法提供与“PXE30-12S12”相匹配的价格&库存,您可以联系我们找货
PXE30-12S12
  • 1+887.236171+114.87055
  • 10+840.2843510+108.79169
  • 25+822.2537125+106.45726
  • 50+808.8500250+104.72189
  • 100+795.65442100+103.01345
库存:24
