PXF40-48D15
PXF40-48D15
    TDK(东电化)
    DIP9 模块
    隔离模块 直流转换器 2 输出 15V -15V 1.4A,1.4A 36V - 75V 输入
PXF40-48D15 数据手册
PXF40-xxDxx Dual Output DC/DC Converter 9 to 18 Vdc and 18 to 36 Vdc and 36 to 75 Vdc input, 3.3 to 15 Vdc Dual Output, 40W Features • Dual output current up to 8A • 40 watts maximum output power • 2:1 wide input voltage range • Six-sided continuous shield • High efficiency up to 89% • Low profile: 2.00 x 2.00 x 0.40 inch (50.8 x 50.8 x 10.2 mm) • Fixed switching frequency • RoHS directive compliant • Input to output isolation: 1600Vdc,min • Over-temperature protection • Input under-voltage protection • Output over-voltage protection • Over-current protection, auto-recovery • Output short circuit protection, auto-recovery • Remote ON/OFF Options • Heat sinks available for extended operation APPLICATIONS Wireless Network Telecom/Datacom Industry Control System Measurement Semiconductor Equipment General Description The PXF40-xxDxx series offers 40 watts of output power from a 2 x 2 x 0.4 inch package. This series has a 2:1 wide input voltage of 9-18VDC,18-36VDC or 36-75VDC and features 1600VDC of isolation, short-circuit and over-voltage protection. Table of Contents Absolute Maximum Rating Output Specification Input Specification General Specification Characteristic Curves Testing Configurations EMC Considerations Input Source Impedance Output Over Current Protection Output Over Voltage Protection Short Circuit Protection P2 P2 P3 P4 P5 P23 P24 P26 P26 P27 P27 Thermal Consideration Heat Sink Consideration Remote ON/OFF Control Mechanical Data Recommended Pad Layout Output Voltage Adjustment Soldering and Reflow Consideration Packaging Information Part Number Structure Safety and Installation Instruction MTBF and Reliability P27 P28 P29 P30 P31 P32 P33 P34 P34 P35 P35 Jun. 20, 2011 40W, Dual Output Absolute Maximum Rating Parameter Model Input Voltage Continuous Transient (100ms) Operating Ambient Temperature (with derating) Operating Case Temperature Storage Temperature 12Dxx 24Dxx 48Dxx 12Dxx 24Dxx 48Dxx All All All Min Max Unit 18 36 75 36 50 100 85 100 105 -40 -55 Vdc °C °C °C Output Specification Parameter Output Voltage (Vin = Vin(nom) ; Full Load ; TA=25°C) Voltage Adjustability Model xxD12 xxD15 Min Typ Max 11.88 12 12.12 14.85 15 3.3/5 15.15 Unit Vdc xxD3305 3.267/4.95 3.333/5.05 All -10 +10 % All -0.5 +0.5 % -1.0 +1.0 Output Regulation Line (Vin(min) to Vin(max) at Full Load) Load (Min. to 100% of Full Load) Output Ripple & Noise Peak-to-Peak (20MHz bandwidth) (Measured with a 0.1μF/50V MLCC) (Measured with a 1μF/50V MLCC) Temperature Coefficient Output Voltage Overshoot (Vin(min) to Vin(max) ; Full Load ; TA=25°C) xxD12 120 xxD15 150 xxD3305 All mVp-p 100 -0.02 +0.02 %/°C 3 % Vo All 0 All 250 mV All 250 μS Dynamic Load Response (Vin = Vin(nom) ; TA=25°C) Load step change from 75% to 100% or 100 to 75% of Full Load Peak Deviation Setting Time (VOUT<10% peak deviation) Output Current (Any condition of dual output (3.3V/5V) rated Iout current, not to exceed 8A of total output currents. The product safety approval pending) Output Over Voltage Protection (Zener diode clamp) xxD12 ±144 ±1800 xxD15 ±112 ±1400 mA xxD3305 0 4/4 A xxD12 15 xxD15 18 xxD3305 3.9/6.2 Output Over Current Protection All Output Short Circuit Protection All Vdc 150 % FL. Hiccup, automatic recovery VER:00 Page 2 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Input Specification Parameter Operating Input Voltage Input Current (Maximum value at Vin = Vin(nom); Full Load) Model Min Typ Max 12Dxx 9 12 18 24Dxx 18 24 36 48Dxx 36 48 (Typical value at Vin = Vin(nom); No Load) Under Voltage Lockout Turn-on Threshold Under Voltage Lockout Turn-off Threshold Input Reflected Ripple Current (5 to 20MHz, 12μH Source Impedance) Vdc 75 12D12 4444 12D15 4321 12D3305 3416 24D12 2169 24D15 2108 24D3305 1689 48D12 1084 48D15 1054 48D3305 Input Standby Current Unit mA 823 12D12 30 12D15 35 12D3305 325 24D12 20 24D15 20 24D3305 80 48D12 15 48D15 15 48D3305 45 mA 12Dxx 9 24Dxx 17.8 48Dxx 36 12Dxx 8 24Dxx 16 48Dxx 34 All 40 Vdc Vdc mAp-p Start Up Time (Vin = Vin(nom) and Constant Resistive Load) Power Up All 25 Remote ON/OFF 25 Remote ON/OFF Control Vdc (The ON/OFF pin voltage is referenced to -VIN) Positive Logic DC-DC ON mS All DC-DC OFF Remote Off Input Current All Input Current of Remote Control Pin All 3.5 12 0 1.2 2.5 -0.5 VER:00 Page 3 of 35 mA 0.5 mA Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output General Specification Parameter Efficiency (Vin = Vin(nom) ; Full Load ; TA=25°C) Model Min Typ 12D12 85 12D15 85 12D3305 85 24D12 87 24D15 87 24D3305 86 48D12 87 48D15 87 48D3305 88 Max Unit % Isolation Voltage Input to Output All Input to Case, Output to Case All Isolation Capacitance All Weight GΩ 1 1000 pF xxD12 xxD15 master (5Vo) 300kHz slave (3.3Vo) 500kHz Vdc 1600 Isolation Resistance Switching Frequency 1600 300 xxD3305 kHz All 60 g All 1.398×106 3.585×105 hours All 115 °C MTBF Bellcore TR-NWT-000332, TC=40°C MIL-HDBK-217F Over Temperature Protection VER:00 Page 4 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves All test conditions are at 25°C.The figures are for PXF40-12D12 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 5 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-12D12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 6 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-12D15 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 7 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-12D15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 8 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-12D3305 Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 9 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-12D3305 Typical Output Ripple and Noise. Vin = Vin(nom), Full Load +5Vo: Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) +3.3Vo:Full load Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 10 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-24D12 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 11 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-24D12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 12 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-24D15 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 13 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-24D15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 14 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-24D3305 Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 15 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-24D3305 Typical Output Ripple and Noise. Vin = Vin(nom), Full Load +5Vo: Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) +3.3Vo:Full load Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 16 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-48D12 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 17 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-48D12 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 18 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-48D15 Efficiency Versus Output Current Efficiency Versus Input Voltage. Full Load Power Dissipation Versus Output Current Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 19 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-48D15 Typical Output Ripple and Noise. Transient Response to Dynamic Load Change from Vin = Vin(nom), Full Load 100% to 75% to 100% of Full Load ; Vin = Vin(nom) Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 20 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-48D3305 Efficiency Versus Output Current Power Dissipation Versus Output Current Efficiency Versus Input Voltage. Full Load Derating Output Current Versus Ambient Temperature and Airflow Vin = Vin(nom) Derating Output Current Versus Ambient Temperature with Heat-Sink and Airflow ,Vin = Vin(nom) VER:00 Page 21 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Characteristic Curves (Continued) All test conditions are at 25°C.The figures are for PXF40-48D3305 Typical Output Ripple and Noise. Vin = Vin(nom), Full Load +5Vo: Transient Response to Dynamic Load Change from 100% to 75% to 100% of Full Load ; Vin = Vin(nom) +3.3Vo:Full load Typical Input Start-Up and Output Rise Characteristic Using ON/OFF Voltage Start-Up and Vo Rise Characteristic Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load Conduction Emission of EN55022 Class A Conduction Emission of EN55022 Class B Vin = Vin(nom), Full Load Vin = Vin(nom), Full Load VER:00 Page 22 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Test Configurations Input reflected-ripple current measurement test: Component L C Value 12μH 220μF Voltage ---100V Reference ---Aluminum Electrolytic Capacitor Peak-to-peak output ripple & noise measurement test: Output voltage and efficiency measurement test: Note: All measurements are taken at the module terminals.  V × Io   × 100% Efficiency =  o  Vin × I in  VER:00 Page 23 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output EMC Considerations Suggested Schematic for EN55022 Conducted Emission Class A Limits Recommended Layout with Input Filter To meet conducted emissions EN55022 CLASS A needed the following components: PXF40-12Dxx Component C1 C3, C4 Value 6.8uF 1000pF Voltage 50V 2KV 1812 MLCC 1808 MLCC PXF40-24Dxx Component C1 C3, C4 Value 6.8uF 1000pF Voltage 50V 2KV 1812 MLCC 1808 MLCC PXF40-48Dxx Component C1 C3, C4 Value 2.2uF 1000pF Voltage 100V 2KV 1812 MLCC 1808 MLCC Reference Reference Reference VER:00 Page 24 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output EMC Considerations (Continued) Suggested Schematic for EN55022 Conducted Emission Class B Limits Recommended Layout with Input Filter To meet conducted emissions EN55022 CLASS B needed the following components: PXF40-12Dxx Component C1, C3 C5, C6 L1 Value 4.7uF 1000pF 450uH Voltage 50V 2KV ---- Reference 1812 MLCC 1808 MLCC Common Choke PXF40-24Dxx Component C1, C3 C5, C6 L1 Value 6.8uF 1000pF 450uH Voltage 50V 2KV ---- Reference 1812 MLCC 1808 MLCC Common Choke PXF40-48Dxx Component C1, C2 C3, C4 C5, C6 L1 Value 2.2uF 2.2uF 1000pF 830uH Voltage 100V 100V 2KV ---- Reference 1812 MLCC 1812 MLCC 1808 MLCC Common Choke VER:00 Page 25 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output EMC Considerations (Continued) Common Choke L1 is defined as follows: ■ L: 450μH±35% / DCR: 25mΩ, max A height: 9.8 mm, Max ■ L-830μH±35% / DCR- 1mΩ, max A height: 8.8 mm, Max ■ Test condition: 100KHz / 100mV ■ Recommended through hole: Φ0.8mm ■ All dimensions in millimeters Input Source Impedance The converter should be connected to a low impedance input source. Highly inductive source impedance can affect the stability of the converter. Input external L-C filter is recommended to minimize input reflected ripple current. The inductor is a simulated source impedance of 12μH and capacitor is Nippon chemi-con KY series 220μF/100V. The capacitor must be located as close as possible to the input terminals of the converter for lowest impedance. Output Over Current Protection When excessive output currents occur in the system, circuit protection is required on all power supplies. Normally, overload current is maintained at approximately 150 percent of rated current for PXF40-xxDxx series. Hiccup-mode is a method of operation in a converter whose purpose is to protect the power supply from being damaged during an over-current fault condition. It also enables the converter to restart when the fault is removed. There are other ways of protecting the converter when it is over-loaded, such as the maximum current limiting or current foldback methods. One of the problems resulting from over current is that excessive heat may be generated in power devices; especially MOSFET and Schottky diodes and the temperature of these devices may exceed their specified limits. A protection mechanism has to be used to prevent these power devices from being damaged. The operation of hiccup is as follows. When the current sense circuit sees an over-current event, the controller shuts off the converter for a given time and then tries to start up the converter again. If the over-load condition has been removed, the converter will start up and operate normally; otherwise, the controller will see another over-current event and will shut off the converter again, repeating the previous cycle. Hiccup operation has none of the drawbacks of the other two protection methods, although its circuit is more complicated because it requires a timing circuit. The excess heat due to overload lasts for only a short duration in the hiccup cycle, hence the junction temperature of the power devices is much lower. VER:00 Page 26 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Output Over Voltage Protection The output over-voltage protection consists of an output Zener diode that monitors the voltage on the output terminals. If the voltage on the output terminals exceeds the over-voltage protection threshold, then the Zener diode clamps the output voltage. Short Circuitry Protection Continuous, hiccup and auto-recovery mode. During a short circuit the converter shuts down. The average current during this condition will be very low. Thermal Consideration The converter operates in a variety of thermal environments. However, sufficient cooling should be provided to help ensure reliable operation of the unit. Heat is removed by conduction, convection, and radiation to the surrounding environment. Proper cooling can be verified by measuring the point as shown in the figure below. The temperature at this location should not exceed 100°C. When operating, adequate cooling must be provided to maintain the test point temperature at or below 100°C. Although the maximum point temperature of the power module is 100°C, limiting this temperature to a lower value will increase the reliability of the unit. VER:00 Page 27 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Heat Sink Consideration Optional heat-sink (HAPXF) and optional heat sink clip (HAPXFCLIP); two clips required when used. All dimensions in millimeters VER:00 Page 28 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Remote ON/OFF Control The Remote ON/OFF Pin is used to turn on and off the DC-DC converter. The user must use a switch to control the logic voltage (high or low level ) of the ON /OFF pin, referenced to Vi (-). The switch can be a open collector transistor, FET, or Opto-Coupler, that is capable of sinking up to 0.5 mA at a low-level logic Voltage. For high-level logic of the ON/OFF signal (maximum voltage): the allowable leakage current of the switch at 12V is 0.5 mA. Remote ON/OFF Implementation Circuits Isolated-Control Remote ON/OFF Level Control Using TTL Output Level Control Using Line Voltage Positive logic: PXF40 module is turned off at PXF40 module is turned on at Low-level logic High-level logic VER:00 Page 29 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Mechanical Data 1. All dimensions in Inches (mm) Tolerance: X.XX±0.02 (X.X±0.5) X.XXX±0.01 (X.XX±0.25) 2. Pin pitch tolerance ±0.01(0.25) 3. Pin dimension tolerance ±0.004 (0.1) PIN 1 2 3 4 5 6 7 8 9 PIN CONNECTION EXTERNAL OUTPUT TRIMMING DUAL +INPUT -INPUT CTRL NO PIN +OUTPUT COMMON COMMON -OUTPUT TRIM Output can be externally trimmed by using the method shown below. DUAL POSITIVE +INPUT -INPUT CTRL 3.3V COMMON NC NC 5V COMMON TRIM UP TRIM DOWN 8 9 RU 9 RD 5 VER:00 Page 30 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Recommended Pad Layout TOP VIEW 1.All dimensions in Inches (mm) Tolerance: X.XX±0.02 (X.X±0.5) 2. Pin pitch tolerance ±0.014(0.35) VER:00 Page 31 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Output Voltage Adjustment Output voltage set point adjustment allows the user to increase or decrease the output voltage set point of a module. This is accomplished by connecting an external resistor between the TRIM pin and either the Vo(+) or Vo(-) pins. With an external resistor between the TRIM and Vo(-) pin, the output voltage set point increases. With an external resistor between the TRIM and Vo(+) pin, the output voltage set point decreases. TRIM DOWN TRIM UP 9 8 RU RD 5 9 TRIM TABLE PXF40-xxD12 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= ±12.12 ±12.24 ±12.36 ±12.48 ±12.6 ±12.72 ±12.84 ±12.96 ±13.08 ±13.2 RU (K Ohms)= 218.21 98.105 58.07 38.052 26.042 18.035 12.316 8.026 4.69 2.021 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= ±11.88 ±11.76 ±11.64 ±11.52 ±11.4 ±11.28 ±11.16 ±11.04 ±10.92 ±10.8 RD (K Ohms)= 273.44 123.02 72.874 47.803 32.76 22.732 15.568 10.196 6.017 2.675 PXF40-xxD15 Trim up (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= ±15.15 ±15.3 ±15.45 ±15.6 ±15.75 ±15.9 ±16.05 ±16.2 ±16.35 ±16.5 RU (K Ohms)= 268.29 120.64 71.429 46.822 32.058 22.215 15.184 9.911 5.81 2.529 Trim down (%) 1 2 3 4 5 6 7 8 9 10 VOUT (Volts)= ±14.85 ±14.7 ±14.55 ±14.4 ±14.25 ±14.1 ±13.95 ±13.8 ±13.65 ±13.5 RD (K Ohms)= 337.71 152.02 90.126 59.178 40.609 28.23 19.387 12.756 7.598 3.471 VER:00 Page 32 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Soldering and Reflow Consideration Lead free wave solder profile for PXF40-xxDxx DIP type Zone Reference Parameter Preheat zone Rise temp. speed : 3°C / sec max. Actual heating Peak temp. : 250~260°C Preheat temp. : 100~130°C Peak time (T1+T2 time) : 4~6 sec Reference Solder: Sn-Ag-Cu /Sn-Cu Hand Welding: Soldering iron-Power 90W Welding Time: 2-4 sec Temp.:380-400 °C VER:00 Page 33 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Packaging Information 10 PCS per TUBE Part Number Structure PXF 40 – 48 D 12 Max. Output Power 43.2Watts Output Voltage 3.3/05 : 3.3/05 Vdc 12 : 12Vdc 15 : 15Vdc Input Voltage Range 12 : 9 ~ 18V 24 : 18 ~ 36V 48 : 36 ~ 75V Dual Output Model Number Input Range Output Voltage Output Current Input Current Eff (4) Min. load Full load No load (2) Full Load(3) (%) PXF40-12D12 9 – 18 VDC ± 12 VDC ± 144mA ± 1800mA 30mA 4444mA 85 PXF40-12D15 9 – 18 VDC ± 15 VDC ± 112mA ± 1400mA 35mA 4321mA 85 PXF40-12D3305 9 – 18 VDC 3.3 / 5 VDC 0mA 3416mA 85 4A / 4A (total 8A) (1) 325mA PXF40-24D12 18 – 36 VDC ± 12 VDC ± 144mA ± 1800mA 20mA 2169mA 87 PXF40-24D15 18 – 36 VDC ± 15 VDC ± 112mA ± 1400mA 20mA 2108mA 87 PXF40-24D3305 18 – 36 VDC 3.3 / 5 VDC 0mA 80mA 1689mA 86 4A / 4A (total 8A) (1) PXF40-48D12 36 – 75 VDC ± 12 VDC ± 144mA ± 1800mA 15mA 1084mA 87 PXF40-48D15 36 – 75 VDC ± 15 VDC ± 112mA ± 1400mA 15mA 1054mA 87 PXF40-48D3305 36 – 75 VDC 3.3 / 5 VDC 0mA 45mA 823mA 88 4A / 4A (total 8A) (1) Note 1. Any condition of dual output (3.3V/5V) rated Iout current, not to exceed 8A of total output currents. The product safety approval pending. Note 2. Typical value at nominal input voltage and no load. Note 3. Maximum value at nominal input voltage and full load Note 4. Typical value at nominal input voltage and full load. VER:00 Page 34 of 35 Issued Date:2009/03/02 Jun. 20, 2011 40W, Dual Output Safety and Installation Instruction Fusing Consideration Caution: This converter is not internally fused. An input line fuse must always be used. This encapsulated converter can be used in a wide variety of applications, ranging from simple stand-alone operation to an integrated part of a sophisticated power architecture. To maximum flexibility, internal fusing is not included; however, to achieve maximum safety and system protection, always use an input line fuse. The safety agencies require a slow-blow fuse with maximum rating of 8A. Based on the information provided in this data sheet on Inrush energy and maximum DC input current; the same type of fuse with lower rating can be used. Refer to the fuse manufacturer’s data for further information. MTBF and Reliability The MTBF of PXF40-xxDxx dual output DC/DC converters has been calculated using Bellcore TR-NWT-000332 Case I: 50% stress, Operating Temperature at 40°C (Ground fixed and controlled environment ). The resulting figure for MTBF is 1.398×106 hours. MIL-HDBK-217F NOTICE2 FULL LOAD, Operating Temperature at 25°C ℃. The resulting figure for MTBF is 3.585×105 hours. VER:00 Page 35 of 35 Issued Date:2009/03/02
PXF40-48D15 价格&库存
很抱歉,暂时无法提供与“PXF40-48D15”相匹配的价格&库存,您可以联系我们找货
PXF40-48D15
  • 1+1002.730791+129.54500
  • 10+949.6482410+122.68715
  • 25+929.2664225+120.05398
  • 50+914.1170950+118.09680
  • 100+758.62909100+98.00897
库存:4
