RSAL-2002AL
RSAL-2002AL
    TDK(东电化)
    RSAL-2002AL
RSAL-2002AL 数据手册
RSAL SERIES Compact Multipurpose Type Compatible with High-Voltage Pulse ■ FEATURES ● ● ● Amorphous core is used for common mode core to help prevent failure due to pulse noise. Wire type and lug terminal type are available with the same shape. Optional low-leakage characteristic type is also available. ■ SAFETY STANDARDS UL1283 CSA C22.2 No.8 EN60939-1/-2 (ENEC14) ■ PRODUCT IDENTIFICATION RSAL ‒2 *** □ □ L :Low-leakage current characteristic type W :Wire type (AWG20) A :Lug terminal type (Faston #110) Rated current Number indicating the rated voltage Series name ■ CONFORMITY TO RoHS Directive ■ CIRCUIT DIAGRAMS RSAL-2 *** W RSAL-2 *** A RSAL-2 *** WL RSAL-2 *** AL 1 4 1 4 2 3 2 3 ● Faston® is a registered trademark of TE Connectivity. web231206 ・All specifications are subject to change without notice. 1 ■ ELECTRICAL CHARACTERISTICS Part No. Rated Rated Withstand voltage current voltage (AC/DC)(AC/DC) Insulation resistance Leakage current Operating temperature range With derating over DC resistance (mΩ) Attenuation frequency range (MHz) Weight Common mode Differential mode at 25dB at 25dB (g) RSAL-20R5W 0.5A 700 max. 0.3 to 8 0.4 to 30 58 RSAL-2001W 1A 600 max. 0.3 to 8 0.5 to 30 58 RSAL-2002W 2A 250 max. 0.5 to 8 0.7 to 30 61 RSAL-2003W 3A AC.2500V 150 max. 1 to 7 0.8 to 30 61 RSAL-2006W 6A 60s 80 max. 3 to 7 1 to 30 61 0.5A [Between line 700 max. 0.3 to 8 0.4 to 30 43 RSAL-2001A 1A to ground] 600 max. 0.3 to 8 0.5 to 30 43 RSAL-2002A 2A 250 max. 0.5 to 8 0.7 to 30 46 RSAL-2003A 3A 150 max. 1 to 7 0.8 to 30 46 RSAL-2006A 6A 80 max. 3 to 7 1 to 30 46 Part No. Rated Rated Withstand voltage current voltage (AC/DC)(AC/DC) RSAL-20R5A 250V 100MΩmin. 1.0mA [DC.500V/ max. 1min] [250V/60Hz] Insulation resistance Leakage current -25 to +85℃ Operating temperature range 55℃ With derating over DC resistance (mΩ) Attenuation frequency range (MHz) Weight Common mode Differential mode at 15dB at 25dB (g) RSAL-20R5WL 0.5A 700 max. 0.1 to 5 0.4 to 30 56 RSAL-2001WL 1A 600 max. 0.1 to 5 0.5 to 30 56 RSAL-2002WL 2A 250 max. 0.1 to 5 0.7 to 30 59 RSAL-2003WL 3A AC.2500V 150 max. 0.2 to 5 0.8 to 30 59 RSAL-2006WL 6A 60s 80 max. 1 to 30 1 to 30 59 700 max. 0.1 to 5 0.4 to 30 41 600 max. 0.1 to 5 0.5 to 30 41 250V 100MΩmin. 10μA [DC.500V/ max. 1min] [250V/60Hz] -25 to +85℃ 55℃ 0.5A [Between line RSAL-2001AL 1A to ground] RSAL-2002AL 2A 250 max. 0.1 to 5 0.7 to 30 44 RSAL-2003AL 3A 150 max. 0.2 to 5 0.8 to 30 44 RSAL-2006AL 6A 80 max. 1 to 30 1 to 30 44 RSAL-20R5AL ■ DERATING GRAPH 120 Rated current (%) 100 80 60 40 20 0 –25 –10 0 10 20 30 40 50 60 70 80 90 Ambient temperature Ta (˚C) ・All specifications are subject to change without notice. 2 ■ MECHANICAL RSAL-20R5/2001/2002/2003/2006W(L) A E B D F C G1 RSAL-20R5/2001/2002/2003/2006A(L) A E B D F C G2 Dimensions in mm Part No. RSAL-20R5W(L) RSAL-2001W(L) RSAL-2002W(L) RSAL-2003W(L) RSAL-2006W(L) RSAL-20R5A(L) RSAL-2001A(L) RSAL-2002A(L) RSAL-2003A(L) RSAL-2006A(L) A B C D E F G1 G2 45 50 20 40 3.5 4.5 300 - 45 50 20 40 3.5 4.5 - 9 ・All specifications are subject to change without notice. 3 ■ ATTENUATION vs. FREQUENCY CHARACTERISTICS RSAL-2001W/A 0 0 –10 –10 –20 –20 –30 –30 –40 Attenuation(dB) Attenuation(dB) RSAL-20R5W/A Common mode –50 –60 –70 –80 –100 0.1 1 Frequency(MHz) 10 100 –70 –100 Differential mode 0.1 0 –10 –10 –20 –20 –30 –30 –40 Common mode –50 –60 –70 –40 10 100 10 100 –60 –70 1 Frequency(MHz) Differential mode –90 Differential mode 0.1 Frequency(MHz) Common mode –50 –80 –80 –90 1 RSAL-2003W/A 0 Attenuation(dB) Attenuation(dB) –60 –90 RSAL-2002W/A –100 Common mode –50 –80 Differential mode –90 –40 10 100 –100 0.1 1 Frequency(MHz) RSAL-2006W/A 0 –10 Attenuation(dB) –20 –30 Common mode –40 –50 –60 Differential mode –70 –80 –90 –100 0.1 1 Frequency(MHz) 10 100 ・All specifications are subject to change without notice. 4 RSAL-2001WL/AL 0 0 –10 –10 –20 –20 –30 Attenuation(dB) Attenuation(dB) RSAL-20R5WL/AL Common mode –40 –50 –60 –70 Differential mode –80 –30 –50 –60 –70 –90 –90 –100 1 Frequency(MHz) 10 100 0 0 –10 –10 –20 –20 –30 Common mode –40 –50 –60 Differential mode –80 Frequency(MHz) 10 100 Common mode –40 –50 –60 –70 Differential mode –90 0.1 1 –30 –80 –90 –100 0.1 RSAL-2003WL/AL Attenuation(dB) Attenuation(dB) RSAL-2002WL/AL –70 Differential mode –80 –100 0.1 Common mode –40 1 Frequency(MHz) 10 100 –100 0.1 1 Frequency(MHz) 10 100 RSAL-2006WL/AL 0 –10 Attenuation(dB) –20 –30 Common mode –40 –50 –60 –70 –80 Differential mode –90 –100 0.1 1 Frequency(MHz) 10 100 ・All specifications are subject to change without notice. 5 ■ PULSE ATTENUATION CHARACTERISTICS RSAL-20R5W/A RSAL-2001W/A Pulse width:1μs 800 600 400 200 0 Common mode Differential mode 0 500 1000 Input voltage(V) 1500 Pulse width:1μs 400 200 Common mode Differential mode 0 500 1000 Input voltage(V) 1500 2000 600 Common mode 400 200 Differential mode 500 1000 Input voltage(V) 1500 2000 Pulse width:1μs 1000 Output voltage(V) Output voltage(V) 800 0 600 RSAL-2003W/A 1000 0 800 0 2000 RSAL-2002W/A Pulse width:1μs 1000 Output voltage(V) Output voltage(V) 1000 800 Common mode 600 400 200 0 Differential mode 0 500 1000 Input voltage(V) 1500 2000 RSAL-2006W/A Pulse width:1μs Output voltage(V) 1000 800 Common mode 600 400 Differential mode 200 0 0 500 1000 Input voltage(V) 1500 2000 ・All specifications are subject to change without notice. 6 RSAL-20R5WL/AL RSAL-2001WL/AL Pulse width:1μs 800 600 Common mode 400 200 0 Differential mode 0 500 1000 Input voltage(V) 1500 Output voltage(V) Common mode 600 400 Differential mode 0 500 Common mode 400 200 Differential mode 0 500 1000 Input voltage(V) 1500 2000 1000 Input voltage(V) 1500 2000 Pulse width:1μs 1000 Output voltage(V) Pulse width:1μs 800 0 600 RSAL-2003WL/AL 1000 200 800 0 2000 RSAL-2002WL/AL Pulse width:1μs 1000 Output voltage(V) Output voltage(V) 1000 800 Common mode 600 400 200 0 Differential mode 0 500 1000 Input voltage(V) 1500 2000 RSAL-2006WL/AL Pulse width:1μs Output voltage(V) 1000 800 Common mode 600 400 Differential mode 200 0 0 500 1000 Input voltage(V) 1500 2000 ・All specifications are subject to change without notice. 7
RSAL-2002AL 价格&库存
很抱歉,暂时无法提供与“RSAL-2002AL”相匹配的价格&库存,您可以联系我们找货
RSAL-2002AL
    • 1+37.54080
    • 200+14.97960
    • 500+14.48280
