RSEG
RSEG SERIES
Single-Phase Filter with On-board Type
■ FEATURES
Space savings, due to compact dimensions.
Wide range lineup for nominal current.
■ SAFETY STANDARDS
UL1283
UL File No. E62388
CSA C22.2 No.8 (cUL)
UL File No. E62388
EN60939-1/-2 (ENEC14) Licence Ref. No. SE/07115-11
■ PRODUCT IDENTIFICATION
RSEG ‒2 ***
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAM
1
4
2
3
web190111
・All specifications are subject to change without notice.
f_17
RSEG
■ ELECTRICAL CHARACTERISTICS
Rated
Rated
current
voltage
(AC/DC) (AC/DC)
Part No.
RSEG-20R5
0.5A
RSEG-2001
1A
RSEG-2002
2A
250V
RSEG-2003
AC.1500V
60s
3A
RSEG-2004
4A
RSEG-2006
6A
Withstand
voltage
[line - earth]
Insulation
resistance
100MΩ
min.
[DC.500V/
1min]
Leakage
current
Operating
temperature
range
With
derating
over
0.75mA
max.
[250V/60Hz]
-25 to +85℃
55℃
DC
resistance
(mΩ)
Attenuation frequency range (MHz)
Common mode Differential mode
Weight
(g)
at 20dB
at 20dB
400 max.
0.3 to 10
1.5 to 30
14
350 max.
0.3 to 10
1.5 to 30
14
310 max.
0.5 to 20
1.5 to 30
14
150 max.
0.5 to 20
1.5 to 30
≒25
130 max.
1 to 20
1.5 to 30
≒25
100 max.
1 to 20
1.5 to 30
≒25
■ DERATING GRAPH
120
Rated current (%)
100
80
60
40
–25
–10 0 10 20 30 40 50 60 70 80 90
Ambient temperature Ta (℃)
■ MECHANICAL
21
32
(4) 6
6 (4)
3.5
ø0.6
(4.25)
f_18
19.5
5
(3.25)
Dimensions in mm
RSEG
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
RSEG-20R5
–10
–10
Differential mode
–20
–30
–40
–50
–60
–70
–30
–40
–50
–60
–70
Common mode
–80
–90
–90
–100
1
Common mode
–80
–100
0.1
Differential mode
–20
Attenuation(dB)
Attenuation(dB)
RSEG-2001
100
0.1
1
Frequency(MHz)
–10
–10
Differential mode
Attenuation(dB)
Attenuation(dB)
–40
–50
–60
Common mode
–80
–60
1
–80
10
100
0.1
1
Frequency(MHz)
Frequency(MHz)
RSEG-2004
–10
–10
Differential mode
–30
–40
–50
Common mode
–30
–40
–50
–60
–80
–90
–90
1
10
Frequency(MHz)
100
Common mode
–70
–80
0.1
Differential mode
–20
Attenuation(dB)
Attenuation(dB)
RSEG-2006
–100
100
Common mode
–70
–90
–70
10
–50
–100
–60
100
–40
–100
–20
10
–30
–90
0.1
Differential mode
–20
–30
–70
100
RSEG-2003
RSEG-2002
–20
10
Frequency(MHz)
–100
0.1
1
Frequency(MHz)
f_19
f_20
很抱歉,暂时无法提供与“RSEG-20R5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+165.945641+21.49577
- 5+119.271365+15.44982
- 10+110.4950710+14.31298
- 30+104.6359230+13.55401
- 50+103.4674150+13.40265
- 60+103.1690660+13.36401
- 100+102.58895100+13.28886
