RSEL-2003A
RSEL-2003A
    TDK(东电化)
    RSEL-2003A
RSEL-2003A 数据手册
RSEL SERIES Compact Multipurpose Type ■ FEATURES ● ● Wire type and faston terminal type are available with the same shape. Optional low-leakage current characteristic type is also available. ■ SAFETY STANDARDS UL1283 CSA C22.2 No.8 EN60939-1/-2 (ENEC14) UL File No. E62388 CSA File No. LR76849 Licence Ref. No. SE/07115-1 ■ PRODUCT IDENTIFICATION RSEL ‒2 *** □ □ L :Low-leakage current characteristic type W :Wire type (AWG20) A :Lug terminal type (Faston #110) Rated current Number indicating the rated voltage Series name ■ CONFORMITY TO RoHS Directive ■ CIRCUIT DIAGRAMS RSEL-2 *** W RSEL-2 *** A RSEL-2 *** WL RSEL-2 *** AL 1 4 1 4 2 3 2 3 ● Faston® is a registered trademark of TE Connectivity. web190111 ・All specifications are subject to change without notice. 1 ■ ELECTRICAL CHARACTERISTICS Part No. Rated Rated Withstand voltage current voltage (AC/DC)(AC/DC) Insulation resistance Leakage current Operating temperature range With derating over DC resistance (mΩ) Attenuation frequency range (MHz) Weight Common mode Differential mode at 25dB at 25dB (g) RSEL-20R5W 0.5A 700 max. 0.2 to 10 0.3 to 30 58 RSEL-2001W 1A 600 max. 0.3 to 10 0.5 to 30 58 RSEL-2002W 2A 250 max. 0.5 to 10 0.5 to 30 61 RSEL-2003W 3A AC.2500V 150 max. 0.5 to 10 0.5 to 30 61 RSEL-2006W 6A 60s 80 max. 1 to 10 1 to 30 61 0.5A [Between line 700 max. 0.2 to 10 0.3 to 30 43 RSEL-2001A 1A to ground] 600 max. 0.3 to 10 0.5 to 30 43 RSEL-2002A 2A 250 max. 0.5 to 10 0.5 to 30 46 RSEL-2003A 3A 150 max. 0.5 to 10 0.5 to 30 46 RSEL-2006A 6A 80 max. 1 to 10 1 to 30 46 Part No. Rated Rated Withstand voltage current voltage (AC/DC)(AC/DC) RSEL-20R5A 250V 100MΩmin. 1.0mA [DC.500V/ max. 1min] [250V/60Hz] Insulation resistance Leakage current -25 to+85℃ Operating temperature range 55℃ With derating over DC resistance (mΩ) Attenuation frequency range (MHz) Weight Common mode Differential mode at 15dB at 25dB (g) RSEL-20R5WL 0.5A 700 max. 0.1 to 5 0.3 to 30 56 RSEL-2001WL 1A 600 max. 0.1 to 5 0.5 to 30 56 RSEL-2002WL 2A 250 max. 0.1 to 5 0.5 to 30 59 RSEL-2003WL 3A AC.2500V 150 max. 0.1 to 5 0.5 to 30 59 RSEL-2006WL 6A 60s 80 max. 1 to 30 1 to 30 59 700 max. 0.1 to 5 0.3 to 30 41 600 max. 0.1 to 5 0.5 to 30 41 250V 100MΩmin. 10μA [DC.500V/ max. 1min] [250V/60Hz] -25 to +85℃ 55℃ 0.5A [Between line RSEL-2001AL 1A to ground] RSEL-2002AL 2A 250 max. 0.1 to 5 0.5 to 30 44 RSEL-2003AL 3A 150 max. 0.1 to 5 0.5 to 30 44 RSEL-2006AL 6A 80 max. 1 to 30 1 to 30 44 RSEL-20R5AL ■ DERATING GRAPH 120 Rated current (%) 100 80 60 40 20 0 –25 –10 0 10 20 30 40 50 60 70 80 90 Ambient temperature Ta (˚C) ・All specifications are subject to change without notice. 2 ■ MECHANICAL RSEL-20R5/2001/2002/2003/2006W(L) A E B D F C G1 RSEL-20R5/2001/2002/2003/2006A(L) A E B D F C G2 Dimensions in mm Part No. RSEL-20R5W(L) RSEL-2001W(L) RSEL-2002W(L) RSEL-2003W(L) RSEL-2006W(L) RSEL-20R5A(L) RSEL-2001A(L) RSEL-2002A(L) RSEL-2003A(L) RSEL-2006A(L) A B C D E F G1 G2 45 50 20 40 3.5 4.5 300 - 45 50 20 40 3.5 4.5 - 9 ・All specifications are subject to change without notice. 3 ■ ATTENUATION vs. FREQUENCY CHARACTERISTICS RSEL-2001W/A 0 0 –10 –10 –20 –20 –30 –30 –40 Attenuation(dB) Attenuation(dB) RSEL-20R5W/A Common mode –50 –60 –70 –80 –100 0.1 1 Frequency(MHz) –70 10 100 –100 Differential mode 0.1 0 –10 –10 –20 –20 –30 –30 –40 Common mode –50 –60 –70 –80 –40 0.1 Frequency(MHz) 10 100 10 100 Common mode –50 –60 –70 –80 Differential mode –90 1 RSEL-2003W/A 0 Attenuation(dB) Attenuation(dB) –60 –90 RSEL-2002W/A –100 Common mode –50 –80 Differential mode –90 –40 1 Frequency(MHz) Differential mode –90 10 100 10 100 –100 0.1 1 Frequency(MHz) RSEL-2006W/A 0 –10 Attenuation(dB) –20 –30 Common mode –40 –50 –60 Differential mode –70 –80 –90 –100 0.1 1 Frequency(MHz) ・All specifications are subject to change without notice. 4 RSEL-2001WL/AL 0 0 –10 –10 –20 –20 –30 Attenuation(dB) Attenuation(dB) RSEL-20R5WL/AL Common mode –40 –50 –60 –70 –80 –100 0.1 1 Frequency(MHz) –60 –70 10 100 –100 –10 –20 –20 –30 Attenuation(dB) 0 –10 Common mode –40 –50 –60 –70 –80 0.1 1 1 Frequency(MHz) 10 –30 Frequency(MHz) 10 100 Common mode –40 –50 –60 –70 –80 Differential mode –90 0.1 Differential mode RSEL-2003WL/AL 0 –100 Common mode –50 –90 RSEL-2002WL/AL Attenuation(dB) –40 –80 Differential mode –90 –30 Differential mode –90 100 –100 0.1 1 Frequency(MHz) 10 100 RSEL-2006WL/AL 0 –10 Attenuation(dB) –20 –30 Common mode –40 –50 –60 –70 –80 Differential mode –90 –100 0.1 1 Frequency(MHz) 10 100 ・All specifications are subject to change without notice. 5
RSEL-2003A 价格&库存
很抱歉,暂时无法提供与“RSEL-2003A”相匹配的价格&库存,您可以联系我们找货
RSEL-2003A
  • 1+131.714881+17.08990
  • 10+107.5000610+13.94805
  • 25+99.1495425+12.86457
  • 50+93.2654550+12.10112
  • 100+87.73044100+11.38296
  • 250+81.28855250+10.54713
库存:4
RSEL-2003A
    • 1+33.41520
    • 200+13.33800
    • 500+12.89520
