RSEL SERIES
Compact Multipurpose Type
■ FEATURES
Wire type and faston terminal type are available with the same shape.
Optional low-leakage current characteristic type is also available.
■ SAFETY STANDARDS
UL1283
CSA C22.2 No.8
EN60939-1/-2 (ENEC14)
■ PRODUCT IDENTIFICATION
RSEL ‒2 *** □ □
L :Low-leakage current characteristic type
W :Wire type (AWG20)
A :Lug terminal type (Faston #110)
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAMS
RSEL-2 *** W
RSEL-2 *** A
RSEL-2 *** WL
RSEL-2 *** AL
1
4
1
4
2
3
2
3
Faston® is a registered trademark of TE Connectivity.
web231206
・All specifications are subject to change without notice.
1
■ ELECTRICAL CHARACTERISTICS
Part No.
Rated
Rated
Withstand
voltage
current
voltage
(AC/DC)(AC/DC)
Insulation
resistance
Leakage
current
Operating
temperature
range
With
derating
over
DC
resistance
(mΩ)
Attenuation frequency range (MHz)
Weight
Common mode Differential mode
at 25dB
at 25dB
(g)
RSEL-20R5W
0.5A
700 max.
0.2 to 10
0.3 to 30
58
RSEL-2001W
1A
600 max.
0.3 to 10
0.5 to 30
58
RSEL-2002W
2A
250 max.
0.5 to 10
0.5 to 30
61
RSEL-2003W
3A
AC.2500V
150 max.
0.5 to 10
0.5 to 30
61
RSEL-2006W
6A
60s
80 max.
1 to 10
1 to 30
61
0.5A
[Between line
700 max.
0.2 to 10
0.3 to 30
43
RSEL-2001A
1A
to ground]
600 max.
0.3 to 10
0.5 to 30
43
RSEL-2002A
2A
250 max.
0.5 to 10
0.5 to 30
46
RSEL-2003A
3A
150 max.
0.5 to 10
0.5 to 30
46
RSEL-2006A
6A
80 max.
1 to 10
1 to 30
46
Part No.
Rated
Rated
Withstand
voltage
current
voltage
(AC/DC)(AC/DC)
RSEL-20R5A
250V
100MΩmin.
1.0mA
[DC.500V/
max.
1min]
[250V/60Hz]
Insulation
resistance
Leakage
current
-25 to+85℃
Operating
temperature
range
55℃
With
derating
over
DC
resistance
(mΩ)
Weight
at 15dB
at 25dB
(g)
RSEL-20R5WL
0.5A
700 max.
0.1 to 5
0.3 to 30
56
RSEL-2001WL
1A
600 max.
0.1 to 5
0.5 to 30
56
RSEL-2002WL
2A
250 max.
0.1 to 5
0.5 to 30
59
RSEL-2003WL
3A
AC.2500V
150 max.
0.1 to 5
0.5 to 30
59
RSEL-2006WL
6A
60s
80 max.
1 to 30
1 to 30
59
700 max.
0.1 to 5
0.3 to 30
41
600 max.
0.1 to 5
0.5 to 30
41
250V
100MΩmin.
10μA
[DC.500V/
max.
1min]
[250V/60Hz]
-25 to +85℃
55℃
0.5A
[Between line
RSEL-2001AL
1A
to ground]
RSEL-2002AL
2A
250 max.
0.1 to 5
0.5 to 30
44
RSEL-2003AL
3A
150 max.
0.1 to 5
0.5 to 30
44
RSEL-2006AL
6A
80 max.
1 to 30
1 to 30
44
RSEL-20R5AL
■ DERATING GRAPH
120
Rated current (%)
100
80
60
40
–25
–10 0
10 20 30 40 50 60 70 80 90
Ambient temperature Ta (˚C)
2
■ MECHANICAL
RSEL-20R5/2001/2002/2003/2006W(L)
A
E
B
D
F
C
G1
RSEL-20R5/2001/2002/2003/2006A(L)
A
E
B
D
F
C
G2
Dimensions in mm
Part No.
RSEL-20R5W(L)
RSEL-2001W(L)
RSEL-2002W(L)
RSEL-2003W(L)
RSEL-2006W(L)
RSEL-20R5A(L)
RSEL-2001A(L)
RSEL-2002A(L)
RSEL-2003A(L)
RSEL-2006A(L)
A
B
C
D
E
F
G1
G2
45
50
3.5
4.5
300
45
50
3.5
4.5
9
3
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
RSEL-2001W/A
–10
–10
–20
–20
–30
–30
–40
Attenuation(dB)
Attenuation(dB)
RSEL-20R5W/A
Common mode
–50
–60
–70
–80
–100
0.1
1
Frequency(MHz)
–70
10
100
–100
Differential mode
0.1
–10
–10
–20
–20
–30
–30
–40
Common mode
–50
–60
–70
–80
–40
0.1
Frequency(MHz)
10
100
10
100
Common mode
–50
–60
–70
–80
Differential mode
–90
1
RSEL-2003W/A
Attenuation(dB)
Attenuation(dB)
–60
–90
RSEL-2002W/A
–100
Common mode
–50
–80
Differential mode
–90
–40
1
Frequency(MHz)
Differential mode
–90
10
100
10
100
–100
0.1
1
Frequency(MHz)
RSEL-2006W/A
–10
Attenuation(dB)
–20
–30
Common mode
–40
–50
–60
Differential mode
–70
–80
–90
–100
0.1
1
Frequency(MHz)
4
RSEL-2001WL/AL
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
RSEL-20R5WL/AL
Common mode
–40
–50
–60
–70
–80
–100
0.1
1
Frequency(MHz)
–60
–70
10
100
–100
–10
–20
–20
–30
Attenuation(dB)
–10
Common mode
–40
–50
–60
–70
–80
0.1
1
1
Frequency(MHz)
10
–30
Frequency(MHz)
10
100
Common mode
–40
–50
–60
–70
–80
Differential mode
–90
0.1
Differential mode
RSEL-2003WL/AL
–100
Common mode
–50
–90
RSEL-2002WL/AL
Attenuation(dB)
–40
–80
Differential mode
–90
–30
Differential mode
–90
100
–100
0.1
1
Frequency(MHz)
10
100
RSEL-2006WL/AL
–10
Attenuation(dB)
–20
–30
Common mode
–40
–50
–60
–70
–80
Differential mode
–90
–100
0.1
1
Frequency(MHz)
10
100
5
很抱歉,暂时无法提供与“RSEL-20R5AL”相匹配的价格&库存,您可以联系我们找货
