RSEN-2003
RSEN-2003
    TDK(东电化)
    EMI FILTER 250VAC 3A SCREW TERM
RSEN-2003 数据手册
RSEN SERIES Multipurpose Single-Phase Filter with Various Variations and Functions ■ FEATURES ● ● ● Self-tightening screws and an open/close type cover make wiring work easier. 3 to 300A wide range lineup. Optional low-leakage current characteristic type and DIN rail installation compatible type are also available. ■ SAFETY STANDARDS UL1283 CSA C22.2 No.8 EN60939-1/-2 (ENEC14) UL File No. E62388 (Up to 60A) CSA File No. LR76849 (Up to 60A) Licence Ref. No. SE/07115-2 (Up to 60A) ■ PRODUCT IDENTIFICATION RSEN ‒2 *** □ N/A:Standard Type D :DIN rail installation compatible type (Up to 30A) L :Low-leakage current characteristic type (Up to 30A) LD :Low-leakage current characteristic and DIN rail installation compatible type (Up to 30A) Rated current Number indicating the rated voltage Series name ■ CONFORMITY TO RoHS Directive ■ CIRCUIT DIAGRAMS RSEN-2 *** RSEN-2 *** D RSEN-2 *** L 1 4 1 4 2 3 2 3 web190111 ・All specifications are subject to change without notice. 1 ■ ELECTRICAL CHARACTERISTICS Rated Rated Withstand voltage current voltage (AC/DC) (AC/DC) Part No. Insulation resistance Leakage current Operating temperature range With derating over DC resistance (mΩ) Attenuation frequency range (MHz) Common mode Differential mode at 25dB at 10dB at 25dB Weight (kg) RSEN-2003 3A 250 max. 0.1 to 20 - 0.2 to 30 0.17 RSEN-2006 6A 110 max. 0.1 to 10 - 0.2 to 30 0.23 RSEN-2010 10A 40 max. 0.2 to 20 - 0.2 to 30 0.23 RSEN-2016 16A 20 max. 0.3 to 20 - 0.3 to 30 0.23 RSEN-2020 20A 10 max. 0.4 to 30 - 0.3 to 30 0.23 RSEN-2030 30A 6 max. 2 to 30 - 0.4 to 30 0.23 RSEN-2040 40A 6 max. 2 to 10 - 0.2 to 30 0.87 4 max. 2 to 10 - 0.2 to 30 0.87 3 max. 2 to 10 - 0.2 to 30 0.87 3.4 max. 2 to 10 - 0.1 to 30 3.60 2.7 max. 2 to 10 - 0.1 to 30 3.80 RSEN-2050 250V RSEN-2060 50A 60A 55℃ AC.2500V 100MΩ 60s min. [Between line [DC.500V/ to ground] RSEN-2080 80A RSEN-2100 100A RSEN-2150 150A RSEN-2200 200A RSEN-2250 RSEN-2300 Part No. Rated Rated Withstand voltage current voltage (AC/DC) (AC/DC) RSEN-2003L 3A 1min] -25 to +85℃ 2 max. 2 to 10 - 0.1 to 30 5.80 1.4 max. - 0.4 to 30 0.1 to 30 8.40 250A 1 max. - 1 to 20 0.1 to 30 8.10 300A 0.7 max. - 2 to 20 0.1 to 30 7.80 Insulation resistance 6A AC.2500V 100MΩ RSEN-2010L 10A 60s min. RSEN-2016L max. [250V/60Hz] 50℃ RSEN-2006L 250V 1.0mA 16A RSEN-2020L 20A RSEN-2030L 30A [Between line [DC.500V/ to ground] 1min] Leakage current Operating temperature range With derating over 10μA max. -25 to +85℃ 55℃ [250V/60Hz] DC resistance (mΩ) Attenuation frequency range (MHz) Common mode Differential mode Weight (kg) at 25dB at 10dB at 25dB 250 max. 0.1 to 2 - 0.2 to 30 0.17 110 max. 0.1 to 2 - 0.2 to 30 0.22 40 max. - 0.1 to 10 0.2 to 30 0.23 20 max. - 0.1 to 10 0.2 to 30 0.23 10 max. - 0.2 to 10 0.3 to 30 0.23 6 max. - 0.3 to 5 0.3 to 30 0.23 ■ DERATING GRAPHS RSEN-2003/2006/2010/2016/2020/2030/ 2040/2050/2060 RSEN-2080/2100/2150/2200/2250/2300 100 100 Rated current (%) 120 Rated current (%) 120 80 60 40 20 0 –25 –10 0 10 20 30 40 50 60 70 80 90 Ambient temperature Ta (˚C) 80 60 40 20 0 –25 –10 0 10 20 30 40 50 60 70 80 90 Ambient temperature Ta (˚C) ・All specifications are subject to change without notice. 2 ■ MECHANICAL RSEN-2003/2006/2010/2016/2020/2030 C F E B A D øG A F D øG C E B RSEN-2040/2050/2060 Dimensions in mm Part No. RSEN-2003 RSEN-2006 RSEN-2010 RSEN-2016 RSEN-2020 RSEN-2030 RSEN-2040 RSEN-2050 RSEN-2060 A B C D E F φG Recommended clamping torque 87 52 35 75 43 M4 4.5 1.27N・m 170 90 54 160 80 M5 4.5 2.5N・m A B C D E F φG Recommended clamping torque 267 161 85 247 135 M8 6.5 290 190 88 270 164 M8 6.5 390 195 103 370 84.5 M10 6.5 Dimensions in mm Part No. RSEN-2080 RSEN-2100 RSEN-2150 RSEN-2200 RSEN-2250 RSEN-2300 7.64N・m 11.8N・m ・All specifications are subject to change without notice. 3 RSEN-2080/2100/2150 A D E B F øG Dimensions C in mm B C D E F φG Recommended clamping torque 52 35 A 75 43 M4 4.5 F 1.27N・m 90 54 80 M5 4.5 2.5N・m 160 C E B E Part No. A RSEN-2003 RSEN-2200/2250/2300 RSEN-2006 RSEN-2010 87 RSEN-2016 RSEN-2020 RSEN-2030 RSEN-2040 RSEN-2050 170 RSEN-2060 D øG Dimensions in mm Part No. RSEN-2080 RSEN-2100 RSEN-2150 RSEN-2200 RSEN-2250 RSEN-2300 A B C D E F φG 267 161 85 247 135 M8 6.5 290 190 88 270 164 M8 6.5 390 195 103 370 84.5 M10 6.5 A B C D E F G H I J K 87 52 35 75 43 M4 M4 98 8.4 8.5 3.5 Recommended clamping torque 7.64N・m 11.8N・m Dimensions in mm Part No. RSEN-2003D RSEN-2006D RSEN-2010D RSEN-2016D RSEN-2020D RSEN-2030D ・All specifications are subject to change without notice. 4 RSEN-2003D/2006D/2010D/2016D/2020D/2030D 10±1 52±1 13±113±1 87±1 6-M4 35±1 43.4±1 (4) 98±1 Dimensions in mm ・All specifications are subject to change without notice. 5 ■ ATTENUATION vs. FREQUENCY CHARACTERISTICS RSEN-2006 0 0 –10 –10 –20 –20 –30 –30 –40 Attenuation(dB) Attenuation(dB) RSEN-2003 Common mode –50 –60 –70 –80 –100 0.1 1 Frequency(MHz) 10 100 –10 –20 –20 –30 –30 –40 Attenuation(dB) Attenuation(dB) 0 –10 Common mode –50 –60 –70 10 100 Common mode –60 –70 0.1 1 Frequency(MHz) 10 100 0.1 1 Frequency(MHz) 10 100 RSEN-2030 0 –20 –20 Attenuation(dB) –30 Common mode –40 –50 –60 –70 –30 Common mode –40 –50 –60 –70 Differential mode –80 Differential mode 0.1 Differential mode –90 –100 –10 –90 1 Frequency(MHz) 10 100 RSEN-2040 –100 0.1 1 Frequency(MHz) 10 100 RSEN-2050 0 –10 –20 –20 –30 Attenuation(dB) 0 –10 Common mode –40 –50 –60 –70 –80 Common mode –30 –40 –50 –60 –70 –80 Differential mode –90 –100 Frequency(MHz) –50 –10 –90 1 –40 0 –100 0.1 –80 Differential mode RSEN-2020 –80 Differential mode RSEN-2016 0 –90 Attenuation(dB) –70 –100 –80 Attenuation(dB) –60 –90 RSEN-2010 –100 Common mode –50 –80 Differential mode –90 –40 0.1 1 Frequency(MHz) 10 –90 100 –100 Differential mode 0.1 1 Frequency(MHz) 10 ・All specifications are subject to change without notice. 100 6 RSEN-2060 RSEN-2080 0 0 –10 –10 –20 Common mode –30 Attenuation(dB) Attenuation(dB) –20 –40 –50 –60 –70 –80 –30 –50 –60 –70 –90 –90 –100 –100 1 Frequency(MHz) 10 100 0 –10 –10 –20 –20 Common mode –40 –50 –60 –70 Differential mode –80 Frequency(MHz) –30 0.1 –60 –70 1 Frequency(MHz) 10 100 –100 Differential mode 0.1 1 Frequency(MHz) 10 100 10 100 RSEN-2250 0 –10 –20 –20 Attenuation(dB) 0 Common mode –40 100 –50 –10 –30 10 Common mode –40 –90 RSEN-2200 Attenuation(dB) 1 –80 –90 –100 0.1 RSEN-2150 0 Attenuation(dB) Attenuation(dB) RSEN-2100 –30 Differential mode –80 Differential mode 0.1 Common mode –40 –50 –60 Differential mode –70 –80 Common mode –30 –40 –50 –60 Differential mode –70 –80 –90 –90 –100 –100 0.1 1 Frequency(MHz) 10 100 10 100 0.1 1 Frequency(MHz) RSEN-2300 0 –10 Attenuation(dB) –20 Common mode –30 –40 –50 –60 Differential mode –70 –80 –90 –100 0.1 1 Frequency(MHz) ・All specifications are subject to change without notice. 7 RSEN-2006L 0 0 –10 –10 –20 –20 –30 Attenuation(dB) Attenuation(dB) RSEN-2003L Common mode –40 –50 –60 –70 Differential mode –80 –40 –50 –60 –70 –90 –90 –100 1 Frequency(MHz) 10 100 RSEN-2010L 0 –10 –10 Attenuation(dB) Attenuation(dB) –40 –50 –60 –70 Differential mode –80 1 Frequency(MHz) 10 –70 Differential mode –80 100 RSEN-2020L 0.1 1 Frequency(MHz) 10 100 RSEN-2030L 0 0 –10 –10 –40 –50 –60 –70 Differential mode –80 –30 –40 –50 –60 –70 –90 –90 –100 Frequency(MHz) 10 Differential mode –80 –100 1 Common mode –20 Common mode Attenuation(dB) Attenuation(dB) Common mode –60 –90 0.1 100 –50 –100 –30 10 –40 –90 –20 Frequency(MHz) –30 –100 0.1 1 –20 Common mode –30 0.1 RSEN-2016L 0 –20 Differential mode –80 –100 0.1 Common mode –30 100 0.1 1 Frequency(MHz) 10 ・All specifications are subject to change without notice. 100 8
RSEN-2003 价格&库存
很抱歉,暂时无法提供与“RSEN-2003”相匹配的价格&库存,您可以联系我们找货
