RSEN SERIES
Multipurpose Single-Phase Filter with Various Variations and Functions
■ FEATURES
Self-tightening screws and an open/close type cover make wiring work easier.
3 to 300A wide range lineup.
Optional low-leakage current characteristic type and DIN rail installation compatible type are also available.
■ SAFETY STANDARDS
UL1283
CSA C22.2 No.8
EN60939-1/-2 (ENEC14)
UL File No. E62388 (Up to 60A)
CSA File No. LR76849 (Up to 60A)
Licence Ref. No. SE/07115-2 (Up to 60A)
■ PRODUCT IDENTIFICATION
RSEN ‒2 *** □
N/A:Standard Type
D :DIN rail installation compatible type (Up to 30A)
L
:Low-leakage current characteristic type (Up to 30A)
LD :Low-leakage current characteristic and DIN rail installation compatible type (Up to 30A)
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAMS
RSEN-2 ***
RSEN-2 *** D
RSEN-2 *** L
1
4
1
4
2
3
2
3
web190111
・All specifications are subject to change without notice.
1
■ ELECTRICAL CHARACTERISTICS
Rated
Rated
Withstand
voltage
current
voltage
(AC/DC) (AC/DC)
Part No.
Insulation
resistance
Leakage
current
Operating
temperature
range
With
derating
over
DC
resistance
(mΩ)
Attenuation frequency range (MHz)
Common mode
Differential mode
at 25dB
at 10dB
at 25dB
Weight
(kg)
RSEN-2003
3A
250 max.
0.1 to 20
0.2 to 30
0.17
RSEN-2006
6A
110 max.
0.1 to 10
0.2 to 30
0.23
RSEN-2010
10A
40 max.
0.2 to 20
0.2 to 30
0.23
RSEN-2016
16A
20 max.
0.3 to 20
0.3 to 30
0.23
RSEN-2020
20A
10 max.
0.4 to 30
0.3 to 30
0.23
RSEN-2030
30A
6 max.
2 to 30
0.4 to 30
0.23
RSEN-2040
40A
6 max.
2 to 10
0.2 to 30
0.87
4 max.
2 to 10
0.2 to 30
0.87
3 max.
2 to 10
0.2 to 30
0.87
3.4 max.
2 to 10
0.1 to 30
3.60
2.7 max.
2 to 10
0.1 to 30
3.80
RSEN-2050
250V
RSEN-2060
50A
60A
55℃
AC.2500V
100MΩ
60s
min.
[Between line [DC.500V/
to ground]
RSEN-2080
80A
RSEN-2100
100A
RSEN-2150
150A
RSEN-2200
200A
RSEN-2250
RSEN-2300
Part No.
Rated
Rated
Withstand
voltage
current
voltage
(AC/DC) (AC/DC)
RSEN-2003L
3A
1min]
-25 to +85℃
2 max.
2 to 10
0.1 to 30
5.80
1.4 max.
0.4 to 30
0.1 to 30
8.40
250A
1 max.
1 to 20
0.1 to 30
8.10
300A
0.7 max.
2 to 20
0.1 to 30
7.80
Insulation
resistance
6A
AC.2500V
100MΩ
RSEN-2010L
10A
60s
min.
RSEN-2016L
max.
[250V/60Hz]
50℃
RSEN-2006L
250V
1.0mA
16A
RSEN-2020L
20A
RSEN-2030L
30A
to ground]
1min]
Leakage
current
Operating
temperature
range
With
derating
over
10μA
max.
-25 to +85℃
55℃
[250V/60Hz]
DC
resistance
(mΩ)
Common mode
Differential mode
Weight
(kg)
at 25dB
at 10dB
at 25dB
250 max.
0.1 to 2
0.2 to 30
0.17
110 max.
0.1 to 2
0.2 to 30
0.22
40 max.
0.1 to 10
0.2 to 30
0.23
20 max.
0.1 to 10
0.2 to 30
0.23
10 max.
0.2 to 10
0.3 to 30
0.23
6 max.
0.3 to 5
0.3 to 30
0.23
■ DERATING GRAPHS
RSEN-2003/2006/2010/2016/2020/2030/
2040/2050/2060
RSEN-2080/2100/2150/2200/2250/2300
100
100
Rated current (%)
120
Rated current (%)
120
80
60
40
–25
–10 0
10 20 30 40 50 60 70 80 90
Ambient temperature Ta (˚C)
80
60
40
–25
–10 0
2
■ MECHANICAL
C
F
E
B
A
D
øG
A
F
D
øG
C
E
B
RSEN-2040/2050/2060
Dimensions in mm
Part No.
RSEN-2003
RSEN-2006
RSEN-2010
RSEN-2016
RSEN-2020
RSEN-2030
RSEN-2040
RSEN-2050
RSEN-2060
A
B
C
D
E
F
φG
Recommended clamping torque
87
52
35
75
43
M4
4.5
1.27N・m
170
90
54
160
80
M5
4.5
2.5N・m
A
B
C
D
E
F
φG
267
161
85
247
135
M8
6.5
290
190
88
270
164
M8
6.5
390
195
103
370
84.5
M10
6.5
Dimensions in mm
Part No.
RSEN-2080
RSEN-2100
RSEN-2150
RSEN-2200
RSEN-2250
RSEN-2300
7.64N・m
11.8N・m
3
RSEN-2080/2100/2150
A
D
E
B
F
øG
Dimensions
C in mm
B
C
D
E
F
φG
52
35
A 75
43
M4
4.5
F
1.27N・m
90
54
80
M5
4.5
2.5N・m
160
C
E
B
E
Part No.
A
RSEN-2003
RSEN-2200/2250/2300
RSEN-2006
RSEN-2010
87
RSEN-2016
RSEN-2020
RSEN-2030
RSEN-2040
RSEN-2050
170
RSEN-2060
D
øG
Dimensions in mm
Part No.
RSEN-2080
RSEN-2100
RSEN-2150
RSEN-2200
RSEN-2250
RSEN-2300
A
B
C
D
E
F
φG
267
161
85
247
135
M8
6.5
290
190
88
270
164
M8
6.5
390
195
103
370
84.5
M10
6.5
A
B
C
D
E
F
G
H
I
J
K
87
52
35
75
43
M4
M4
98
8.4
8.5
3.5
7.64N・m
11.8N・m
Dimensions in mm
Part No.
RSEN-2003D
RSEN-2006D
RSEN-2010D
RSEN-2016D
RSEN-2020D
RSEN-2030D
4
RSEN-2003D/2006D/2010D/2016D/2020D/2030D
10±1
52±1
13±113±1
87±1
6-M4
35±1
43.4±1
(4)
98±1
Dimensions in mm
5
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
RSEN-2006
–10
–10
–20
–20
–30
–30
–40
Attenuation(dB)
Attenuation(dB)
RSEN-2003
Common mode
–50
–60
–70
–80
–100
0.1
1
Frequency(MHz)
10
100
–10
–20
–20
–30
–30
–40
Attenuation(dB)
Attenuation(dB)
–10
Common mode
–50
–60
–70
10
100
Common mode
–60
–70
0.1
1
Frequency(MHz)
10
100
0.1
1
Frequency(MHz)
10
100
RSEN-2030
–20
–20
Attenuation(dB)
–30
Common mode
–40
–50
–60
–70
–30
Common mode
–40
–50
–60
–70
Differential mode
–80
Differential mode
0.1
Differential mode
–90
–100
–10
–90
1
Frequency(MHz)
10
100
RSEN-2040
–100
0.1
1
Frequency(MHz)
10
100
RSEN-2050
–10
–20
–20
–30
Attenuation(dB)
–10
Common mode
–40
–50
–60
–70
–80
Common mode
–30
–40
–50
–60
–70
–80
Differential mode
–90
–100
Frequency(MHz)
–50
–10
–90
1
–40
–100
0.1
–80
Differential mode
RSEN-2020
–80
Differential mode
RSEN-2016
–90
Attenuation(dB)
–70
–100
–80
Attenuation(dB)
–60
–90
RSEN-2010
–100
Common mode
–50
–80
Differential mode
–90
–40
0.1
1
Frequency(MHz)
10
–90
100
–100
Differential mode
0.1
1
Frequency(MHz)
10
100
6
RSEN-2060
RSEN-2080
–10
–10
–20
Common mode
–30
Attenuation(dB)
Attenuation(dB)
–20
–40
–50
–60
–70
–80
–30
–50
–60
–70
–90
–90
–100
–100
1
Frequency(MHz)
10
100
–10
–10
–20
–20
Common mode
–40
–50
–60
–70
Differential mode
–80
Frequency(MHz)
–30
0.1
–60
–70
1
Frequency(MHz)
10
100
–100
Differential mode
0.1
1
Frequency(MHz)
10
100
10
100
RSEN-2250
–10
–20
–20
Attenuation(dB)
Common mode
–40
100
–50
–10
–30
10
Common mode
–40
–90
RSEN-2200
Attenuation(dB)
1
–80
–90
–100
0.1
RSEN-2150
Attenuation(dB)
Attenuation(dB)
RSEN-2100
–30
Differential mode
–80
Differential mode
0.1
Common mode
–40
–50
–60
Differential mode
–70
–80
Common mode
–30
–40
–50
–60
Differential mode
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
10
100
0.1
1
Frequency(MHz)
RSEN-2300
–10
Attenuation(dB)
–20
Common mode
–30
–40
–50
–60
Differential mode
–70
–80
–90
–100
0.1
1
Frequency(MHz)
7
RSEN-2006L
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
RSEN-2003L
Common mode
–40
–50
–60
–70
Differential mode
–80
–40
–50
–60
–70
–90
–90
–100
1
Frequency(MHz)
10
100
RSEN-2010L
–10
–10
Attenuation(dB)
Attenuation(dB)
–40
–50
–60
–70
Differential mode
–80
1
Frequency(MHz)
10
–70
Differential mode
–80
100
RSEN-2020L
0.1
1
Frequency(MHz)
10
100
RSEN-2030L
–10
–10
–40
–50
–60
–70
Differential mode
–80
–30
–40
–50
–60
–70
–90
–90
–100
Frequency(MHz)
10
Differential mode
–80
–100
1
Common mode
–20
Common mode
Attenuation(dB)
Attenuation(dB)
Common mode
–60
–90
0.1
100
–50
–100
–30
10
–40
–90
–20
Frequency(MHz)
–30
–100
0.1
1
–20
Common mode
–30
0.1
RSEN-2016L
–20
Differential mode
–80
–100
0.1
Common mode
–30
100
0.1
1
Frequency(MHz)
10
100
8
很抱歉,暂时无法提供与“RSEN-2006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+153.000501+18.07218
- 10+128.2927610+15.15374
- 50+113.4830550+13.40444
