RTEN SERIES
Multipurpose Three-Phase Filter with Many Current Variations
■ FEATURES
■ SAFETY STANDARDS
6 to 300A wide range lineup.
Small due to L1, light and thin.
● Low-profile design.
UL1283
EN60939-1/-2
(ENEC14)
UL File No. E62388 (Up to 200A)
Licence Ref. No. SE/07115-5 (Up to 60A)
Licence Ref. No. SE/07115-4 (From 80A)
Self-tightening screws and an open/close type cover
make wiring work easier.
● Terminal block cover included for safety.
DIN rail installation compatible type is also available.
■ PRODUCT IDENTIFICATION
RTEN ‒5 *** □
N/A:Standard Type
D :DIN rail installation compatible type (Up to 30A)
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAM
1
6
2
5
3
4
web190111
・All specifications are subject to change without notice.
1
■ ELECTRICAL CHARACTERISTICS
Rated
Rated
Withstand
voltage
current
voltage
(AC/DC)(AC/DC)
Part No.
Insulation
resistance
Leakage
current
Operating
temperature
range
With
derating
over
DC
resistance
(mΩ)
Attenuation frequency range (MHz)
Common mode
Weight
Differential mode
at 25dB
at 10dB
at 25dB
(kg)
RTEN-5006
6A
145 max.
0.2 to 10
0.2 to 30
0.36
RTEN-5010
10A
60 max.
0.2 to 10
0.2 to 30
0.36
RTEN-5020
20A
25 max.
0.3 to 8
0.2 to 30
0.56
RTEN-5030
30A
2.5mA
13 max.
0.5 to 8
0.2 to 30
0.56
RTEN-5040
40A
max.
10 max.
0.3 to 7
0.2 to 30
1.10
7 max.
0.5 to 7
0.2 to 30
1.10
5 max.
0.7 to 5
0.2 to 30
1.10
5mA
5 max.
0.3 to 5
0.2 to 5
3.90
max.
4 max.
0.3 to 5
0.2 to 5
4.20
[500V/60Hz]
3 max.
0.3 to 5
0.2 to 5
6.50
RTEN-5050
RTEN-5060
50A
500V
60A
AC.2500V
100MΩ
60s
min.
[Between line [DC.500V/
[250V/60Hz]
-25 to +85℃
50℃
RTEN-5080
80A
RTEN-5100
100A
RTEN-5150
150A
RTEN-5200
200A
2 max.
0.5 to 5
0.2 to 5
9.20
RTEN-5250
250A
1.5 max.
0.5 to 10
0.2 to 5
8.70
RTEN-5300
300A
1 max.
0.5 to 10
0.2 to 5
8.30
to ground]
1min]
■ DERATING GRAPH
120
Rated current (%)
100
80
60
40
–25
–10 0
10 20 30 40 50 60 70 80 90
Ambient temperature Ta (˚C)
2
■ MECHANICAL
RTEN-5006/5010
A
C
B
E
F
G
øH
D
RTEN-5020/5030/5040/5050/5060
F
E
B
A
G
D
Part No.
RTEN-5006
RTEN-5010
RTEN-5020
RTEN-5030
RTEN-5040
RTEN-5050
RTEN-5060
Part No.
RTEN-5080
RTEN-5100
RTEN-5150
RTEN-5200
RTEN-5250
RTEN-5300
C
øH
A
B
C
D
E
F
G
φH
120
63
42
110
53
M4
M4
4.5
140
70
42
130
60
M4
M4
4.5
Dimensions in mm
Recommended clamping torque
M4:1.27N・m
M5:2.5N・m
170
90
54
160
80
M5
M4
4.5
A
B
C
D
E
F
G
φH
267
161
85
247
135
M8
M6
6.5
290
190
88
270
164
M8
M6
6.5
390
195
103
370
84.5
M10
M8
6.5
A
B
C
D
E
F
Dimensions in mm
M6:4.8N・m
M8:7.64N・m
M10:11.8N・m
Dimensions in mm
Part No.
to change
without notice.
G ・All specifications
H
I are subject
J
K
3
A
F
D
G
øH
C
E
B
RTEN-5080/5100/5150
B
C
D
E
F
G
φH
63
42
110
53
M4
M4
4.5
70
42
130A
60
M4
M4
4.5
160
80
90
54
Dimensions in mm
M4:1.27N・m
F
C
M5:2.5N・m
M5
M4
4.5
E
B
E
Part No.
A
RTEN-5200/5250/5300
RTEN-5006
120
RTEN-5010
RTEN-5020
140
RTEN-5030
RTEN-5040
RTEN-5050
170
RTEN-5060
øH
G
D
Part No.
RTEN-5080
RTEN-5100
RTEN-5150
RTEN-5200
RTEN-5250
RTEN-5300
Dimensions in mm
A
B
C
D
E
F
G
φH
267
161
85
247
135
M8
M6
6.5
290
190
88
270
164
M8
M6
6.5
390
195
103
370
84.5
M10
M8
6.5
A
B
C
D
E
F
G
H
I
J
K
120
63
42
110
53
8.4
6
3.5
70
42
130
60
M4
127
140
M4
8.4
12.5
3.5
M6:4.8N・m
M8:7.64N・m
M10:11.8N・m
Dimensions in mm
Part No.
RTEN-5006D
RTEN-5010D
RTEN-5020D
RTEN-5030D
4
RTEN-5006D/5010D
(3)
10±1
16.4±116.4±1
120±1
63±1
(3)
6-M4
42±1
50.2±1
M4
(4)
127±1
RTEN-5020D/5030D
(3)
10±1
16.4±116.4±1
140±1
70±1
(3)
6-M4
M4
42±1
50.4±1
(4)
Dimensions in mm
5
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
RTEN-5010
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
RTEN-5006
Common mode
–40
–50
Differential mode
–60
–70
–80
–30
–50
–70
–80
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
0.1
1
Frequency(MHz)
10
100
RTEN-5030
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
RTEN-5020
Common mode
–40
–50
–60
Differential mode
–70
–80
–30
Common mode
–40
–50
Differential mode
–60
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTEN-5040
–10
–10
–20
–20
–30
Common mode
–40
0.1
1
Frequency(MHz)
10
100
RTEN-5050
Attenuation(dB)
Attenuation(dB)
Differential mode
–60
–90
–50
Differential mode
–60
–70
–80
Common mode
–30
–40
–50
Differential mode
–60
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTEN-5060
–10
–10
–20
–40
Attenuation(dB)
Common mode
–30
0.1
Differential mode
–50
–60
–70
–80
Frequency(MHz)
10
100
10
100
Common mode
–30
–40
–50
–60
–70
Differential mode
–80
–90
–90
–100
–100
0.1
1
RTEN-5080
–20
Attenuation(dB)
Common mode
–40
1
Frequency(MHz)
10
100
0.1
1
Frequency(MHz)
6
RTEN-5100
–10
–10
–20
–20
Common mode
–30
Attenuation(dB)
Attenuation(dB)
RTEN-5150
–40
–50
–60
–70
Differential mode
–80
–40
–50
–60
–70
–90
–90
–100
1
Frequency(MHz)
10
100
RTEN-5200
–10
–10
Attenuation(dB)
Attenuation(dB)
–20
Common mode
–30
–40
–50
–60
–70
–80
–100
0.1
1
Frequency(MHz)
10
100
1
Frequency(MHz)
10
100
Common mode
–30
–40
–50
–60
–70
–80
Differential mode
–90
0.1
RTEN-5250
–20
Differential mode
–80
–100
0.1
Common mode
–30
Differential mode
–90
10
100
10
100
–100
0.1
1
Frequency(MHz)
RTEN-5300
–10
Common mode
Attenuation(dB)
–20
–30
–40
–50
–60
–70
Differential mode
–80
–90
–100
0.1
1
Frequency(MHz)
7
很抱歉,暂时无法提供与“RTEN-5010”相匹配的价格&库存,您可以联系我们找货
