RTEN-5030D
RTEN-5030D
    TDK(东电化)
    RTEN-5030D
RTEN-5030D 数据手册
RTEN SERIES Multipurpose Three-Phase Filter with Many Current Variations ■ FEATURES ● ■ SAFETY STANDARDS 6 to 300A wide range lineup. Small due to L1, light and thin. ● Low-profile design. ● UL1283 (Up to 200A) EN60939-1/-2 (ENEC14) Self-tightening screws and an open/close type cover make wiring work easier. ● Terminal block cover included for safety. ● ● DIN rail installation compatible type is also available. ■ PRODUCT IDENTIFICATION RTEN ‒5 *** □ N/A:Standard Type D :DIN rail installation compatible type (Up to 30A) Rated current Number indicating the rated voltage Series name ■ CONFORMITY TO RoHS Directive ■ CIRCUIT DIAGRAM 1 6 2 5 3 4 web231206 ・All specifications are subject to change without notice. 1 ■ ELECTRICAL CHARACTERISTICS Rated Rated Withstand voltage current voltage (AC/DC)(AC/DC) Part No. Insulation resistance Leakage current Operating temperature range With derating over DC resistance (mΩ) Attenuation frequency range (MHz) Common mode Weight Differential mode at 25dB at 10dB at 25dB (kg) RTEN-5006 6A 145 max. 0.2 to 10 - 0.2 to 30 0.36 RTEN-5010 10A 60 max. 0.2 to 10 - 0.2 to 30 0.36 RTEN-5020 20A 25 max. 0.3 to 8 - 0.2 to 30 0.56 RTEN-5030 30A 2.5mA 13 max. 0.5 to 8 - 0.2 to 30 0.56 RTEN-5040 40A max. 10 max. 0.3 to 7 - 0.2 to 30 1.10 7 max. 0.5 to 7 - 0.2 to 30 1.10 5 max. 0.7 to 5 - 0.2 to 30 1.10 5mA 5 max. 0.3 to 5 - 0.2 to 5 3.90 max. 4 max. 0.3 to 5 - 0.2 to 5 4.20 [500V/60Hz] 3 max. 0.3 to 5 - 0.2 to 5 6.50 RTEN-5050 RTEN-5060 50A 500V 60A AC.2500V 100MΩ 60s min. [Between line [DC.500V/ [250V/60Hz] -25 to +85℃ 50℃ RTEN-5080 80A RTEN-5100 100A RTEN-5150 150A RTEN-5200 200A 2 max. 0.5 to 5 - 0.2 to 5 9.20 RTEN-5250 250A 1.5 max. - 0.5 to 10 0.2 to 5 8.70 RTEN-5300 300A 1 max. - 0.5 to 10 0.2 to 5 8.30 to ground] 1min] ■ DERATING GRAPH 120 Rated current (%) 100 80 60 40 20 0 –25 –10 0 10 20 30 40 50 60 70 80 90 Ambient temperature Ta (˚C) ・All specifications are subject to change without notice. 2 ■ MECHANICAL RTEN-5006/5010 A C B E F G øH D RTEN-5020/5030/5040/5050/5060 F E B A G D Part No. RTEN-5006 RTEN-5010 RTEN-5020 RTEN-5030 RTEN-5040 RTEN-5050 RTEN-5060 Part No. RTEN-5080 RTEN-5100 RTEN-5150 RTEN-5200 RTEN-5250 RTEN-5300 C øH A B C D E F G φH 120 63 42 110 53 M4 M4 4.5 140 70 42 130 60 M4 M4 4.5 Dimensions in mm Recommended clamping torque M4:1.27N・m M5:2.5N・m 170 90 54 160 80 M5 M4 4.5 A B C D E F G φH 267 161 85 247 135 M8 M6 6.5 290 190 88 270 164 M8 M6 6.5 390 195 103 370 84.5 M10 M8 6.5 A B C D E F Dimensions in mm Recommended clamping torque M6:4.8N・m M8:7.64N・m M10:11.8N・m Dimensions in mm Part No. to change without notice. G ・All specifications H I are subject J K 3 RTEN-5080/5100/5150 C A E B F G φH D B C D E F G φH 63 42 110 53 M4 M4 4.5 70 42 130A 60 M4 M4 4.5 160 80 90 54 Dimensions in mm Recommended clamping torque M4:1.27N・m F C M5:2.5N・m M5 M4 4.5 E B E Part No. A RTEN-5200/5250/5300 RTEN-5006 120 RTEN-5010 RTEN-5020 140 RTEN-5030 RTEN-5040 RTEN-5050 170 RTEN-5060 øH G D Part No. RTEN-5080 RTEN-5100 RTEN-5150 RTEN-5200 RTEN-5250 RTEN-5300 Dimensions in mm A B C D E F G φH 267 161 85 247 135 M8 M6 6.5 290 190 88 270 164 M8 M6 6.5 390 195 103 370 84.5 M10 M8 6.5 A B C D E F G H I J K 120 63 42 110 53 8.4 6 3.5 70 42 130 60 M4 127 140 M4 - 8.4 12.5 3.5 Recommended clamping torque M6:4.8N・m M8:7.64N・m M10:11.8N・m Dimensions in mm Part No. RTEN-5006D RTEN-5010D RTEN-5020D RTEN-5030D ・All specifications are subject to change without notice. 4 RTEN-5006D/5010D (3) 10±1 16.4±116.4±1 120±1 63±1 (3) 6-M4 42±1 50.2±1 M4 (4) 127±1 RTEN-5020D/5030D (3) 10±1 16.4±116.4±1 140±1 70±1 (3) 6-M4 42±1 M4 50.4±1 (4) Dimensions in mm *Please see the next page: "Precautions of DIN rail mounting". ・All specifications are subject to change without notice. 5 Precautions of DIN rail mounting When installing on a DIN rail, secure a space with a depth of 14 mm or more from the top of the rail. If there is no depth space, the tip of the DIN attachment and the installation surface may interfere and it may not be possible to install it. Secure a space of 14 mm or more from the top of the rail. If a space of 14 mm or more cannot be secured from the top of the rail, Top of the rail the tip of the DIN attachment and the installation surface will interfere. 14 mm or more ・All specifications are subject to change without notice. 6 ■ ATTENUATION vs. FREQUENCY CHARACTERISTICS RTEN-5010 0 0 –10 –10 –20 –20 –30 Attenuation(dB) Attenuation(dB) RTEN-5006 Common mode –40 –50 Differential mode –60 –70 –80 –30 –50 –70 –80 –90 –100 –100 0.1 1 Frequency(MHz) 10 100 0.1 1 Frequency(MHz) 10 100 RTEN-5030 0 0 –10 –10 –20 –20 –30 Attenuation(dB) Attenuation(dB) RTEN-5020 Common mode –40 –50 –60 Differential mode –70 –80 –30 Common mode –40 –50 Differential mode –60 –70 –80 –90 –90 –100 –100 0.1 1 Frequency(MHz) 10 100 RTEN-5040 0 0 –10 –10 –20 –20 –30 Common mode –40 0.1 1 Frequency(MHz) 10 100 RTEN-5050 Attenuation(dB) Attenuation(dB) Differential mode –60 –90 –50 Differential mode –60 –70 –80 Common mode –30 –40 –50 Differential mode –60 –70 –80 –90 –90 –100 –100 0.1 1 Frequency(MHz) 10 100 RTEN-5060 0 –10 –10 –20 –40 Attenuation(dB) Common mode –30 0.1 Differential mode –50 –60 –70 –80 Frequency(MHz) 10 100 10 100 Common mode –30 –40 –50 –60 –70 Differential mode –80 –90 –90 –100 –100 0.1 1 RTEN-5080 0 –20 Attenuation(dB) Common mode –40 1 Frequency(MHz) 10 100 0.1 1 Frequency(MHz) ・All specifications are subject to change without notice. 7 RTEN-5100 0 –10 –10 –20 –20 Common mode –30 Attenuation(dB) Attenuation(dB) RTEN-5150 0 –40 –50 –60 –70 Differential mode –80 –40 –50 –60 –70 –90 –90 –100 1 Frequency(MHz) 10 100 RTEN-5200 0 –10 –10 Attenuation(dB) Attenuation(dB) –20 Common mode –30 –40 –50 –60 –70 –80 –100 0.1 1 Frequency(MHz) 10 100 1 Frequency(MHz) 10 100 Common mode –30 –40 –50 –60 –70 –80 Differential mode –90 0.1 RTEN-5250 0 –20 Differential mode –80 –100 0.1 Common mode –30 Differential mode –90 10 100 10 100 –100 0.1 1 Frequency(MHz) RTEN-5300 0 –10 Common mode Attenuation(dB) –20 –30 –40 –50 –60 –70 Differential mode –80 –90 –100 0.1 1 Frequency(MHz) ・All specifications are subject to change without notice. 8
RTEN-5030D 价格&库存
很抱歉,暂时无法提供与“RTEN-5030D”相匹配的价格&库存,您可以联系我们找货
RTEN-5030D
    • 1+882.672191+114.18713
    • 2+838.716572+108.50080
    • 3+824.070243+106.60607
    • 4+816.751224+105.65924
    • 5+812.353165+105.09029
    • 9+804.536259+104.07905
    • 10+803.5570610+103.95238
    库存:1
