RTHB SERIES
High Attenuation Three-Phase Filter with Many Current Variations (Rectangular Type)
■ FEATURES
6 to 150A wide range lineup.
Rectangular shape with L2 high attention.
Thin type.
Self-tightening screws and an open/close type cover make wiring work easier.
Terminal block cover included for safety.
■ SAFETY STANDARDS
UL1283
EN60939-1/-2 (ENEC14)
UL File No. E62388
Licence Ref. No. SE/07115-4
■ PRODUCT IDENTIFICATION
RTHB ‒5 ***
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAM
1
6
2
5
3
4
web190111
・All specifications are subject to change without notice.
1
■ ELECTRICAL CHARACTERISTICS
Rated
Rated
voltage
current
(AC/DC) (AC/DC)
Part No.
Withstand
voltage
Insulation
resistance
Leakage
current
Operating
temperature
range
With
derating
over
DC
resistance
(mΩ)
Attenuation frequency range (MHz)
Weight
Common mode Differential mode
at 25dB
at 25dB
(kg)
RTHB-5006
6A
290 max.
0.1 to 30
0.1 to 30
0.75
RTHB-5010
10A
120 max.
0.1 to 20
0.2 to 30
0.78
RTHB-5020
20A
50 max.
0.1 to 20
0.2 to 30
1.10
RTHB-5030
30A
26 max.
0.2 to 20
0.2 to 30
1.10
20 max.
0.2 to 20
0.1 to 30
2.24
14 max.
0.2 to 20
0.2 to 30
2.24
10 max.
0.2 to 20
0.2 to 10
2.24
RTHB-5040
40A
500V
RTHB-5050
50A
RTHB-5060
60A
AC.2500V
100MΩ
60s
min.
2.5mA max.
[250V/60Hz]
-25 to +85℃
[Between line [DC.500V/
to ground]
1min]
50℃
5mA max.
[500V/60Hz]
RTHB-5080
80A
10 max.
0.1 to 10
0.2 to 30
7.70
RTHB-5100
100A
8 max.
0.1 to 10
0.2 to 30
8.20
RTHB-5150
150A
6 max.
0.1 to 10
0.2 to 30
12.50
■ DERATING GRAPH
120
Rated current (%)
100
80
60
40
–25
–10 0
10 20 30 40 50 60 70 80 90
Ambient temperature Ta (˚C)
■ MECHANICAL
A
F
E
B
D
G
øH
C
Dimensions in mm
Part No.
RTHB-5006
RTHB-5010
RTHB-5020
RTHB-5030
RTHB-5040
RTHB-5050
RTHB-5060
RTHB-5080
RTHB-5100
RTHB-5150
A
B
C
D
E
F
G
φH
210
64
100
200
40
M4
M4
4.5
240
64
115
230
40
M4
M4
4.5
300
80
140
285
46
M5
M4
5.5
472
100
205
452
63
M8
M6
6.5
534
100
234
514
63
M8
M6
6.5
Recommended clamping torque
M4:1.27N・m
M5:2.5N・m
M6:4.8N・m
M8:7.64N・m
2
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
RTHB-5010
–10
–10
–20
–20
–30
–30
Attenuation(dB)
Attenuation(dB)
RTHB-5006
–40
–50
Common mode
–60
–70
–80
–100
0.1
1
Frequency(MHz)
10
100
–70
0.1
1
Frequency(MHz)
10
100
RTHB-5030
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
–60
–100
Common mode
–40
–50
–60
Differential mode
–70
–80
–30
Common mode
–40
–50
Differential mode
–60
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTHB-5040
–10
–10
–20
–20
–30
Common mode
–40
–50
Differential mode
–60
0.1
1
Frequency(MHz)
10
100
RTHB-5050
Attenuation(dB)
Attenuation(dB)
Common mode
–90
RTHB-5020
–70
–80
–30
–40
Common mode
–50
Differential mode
–60
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTHB-5060
–10
–10
–20
–20
–30
–30
–40
Differential mode
–50
–60
–70
Common mode
–80
1
Frequency(MHz)
10
100
–50
–60
–80
–90
–100
Frequency(MHz)
10
Differential mode
–70
–100
1
Common mode
–40
–90
0.1
0.1
RTHB-5080
Attenuation(dB)
Attenuation(dB)
Differential mode
–50
–80
Differential mode
–90
–40
100
0.1
1
Frequency(MHz)
10
100
3
RTHB-5150
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
RTHB-5100
Common mode
–40
–50
–60
Differential mode
–70
–80
–30
Common mode
–40
–50
–60
Differential mode
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
0.1
1
Frequency(MHz)
10
100
4
很抱歉,暂时无法提供与“RTHB-5006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1018.08360
- 200+406.22040
- 500+392.64480
- 国内价格 香港价格
- 1+2343.744241+303.59685
