RTHN SERIES
High-Attenuation Three-Phase Filter with Many Current Variations (Thin Type)
■ FEATURES
6 to 300A wide range lineup.
High attenuation, thin type with L2.
● Low-profile design.
Self-tightening screws and an open/close
type cover make wiring work easier.
● Terminal block cover included for safety.
■ SAFETY STANDARDS
UL1283
EN60939-1/-2 (ENEC14)
UL File No. E62388 (Up to 150A)
Licence Ref. No. SE/07115-4
■ PRODUCT IDENTIFICATION
RTHN ‒5 ***
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAM
1
6
2
5
3
4
web190111
・All specifications are subject to change without notice.
1
■ ELECTRICAL CHARACTERISTICS
Part No.
Rated
Rated
voltage
current
(AC/DC) (AC/DC)
Withstand
voltage
Insulation
resistance
Leakage
current
Operating
temperature
range
With
derating
over
DC
resistance
(mΩ)
Attenuation frequency range (MHz)
Weight
Common mode Differential mode
at 25dB
at 25dB
(kg)
RTHN-5006
6A
290 max.
0.1 to 10
0.2 to 30
0.7
RTHN-5010
10A
120 max.
0.1 to 10
0.2 to 30
0.7
RTHN-5020
20A
RTHN-5030
30A
RTHN-5040
40A
RTHN-5050
50A
RTHN-5060
500V
60A
AC.2500V
100MΩ
60s
min.
[Between line [DC.500V/
50 max.
0.1 to 10
0.2 to 30
1.0
2.5mA
26 max.
0.2 to 10
0.2 to 30
1.0
max.
20 max.
0.2 to 10
0.2 to 30
2.1
[250V/60Hz]
14 max.
0.2 to 10
0.2 to 30
2.0
10 max.
0.2 to 10
0.2 to 30
2.0
5mA
10 max.
0.1 to 10
0.2 to 30
7.0
max.
8 max.
0.1 to 10
0.2 to 30
7.5
[500V/60Hz]
-25 to +85℃
50℃
RTHN-5080
80A
RTHN-5100
100A
RTHN-5150
150A
6 max.
0.1 to 10
0.2 to 30
11.6
RTHN-5200
200A
4 max.
0.3 to 10
0.2 to 30
15.8
RTHN-5250
250A
3 max.
0.3 to 10
0.2 to 30
15.0
RTHN-5300
300A
2 max.
0.5 to 6
0.2 to 30
14.3
to ground]
1min]
■ DERATING GRAPH
120
Rated current (%)
100
80
60
40
–25
–10 0
10 20 30 40 50 60 70 80 90
Ambient temperature Ta (˚C)
2
■ MECHANICAL
RTHN-5006/5010/5020/5030/5040/5050/5060/5080/5100/5150
C
F
E
B
A
G
øH
D
RTHN-5200/5250/5300
F
C
E
B
E
A
øH
G
D
Part No.
RTHN-5006
RTHN-5010
RTHN-5020
RTHN-5030
RTHN-5040
RTHN-5050
RTHN-5060
RTHN-5080
RTHN-5100
RTHN-5150
RTHN-5200
RTHN-5250
RTHN-5300
Part No.
RTHN-5400
RTHN-5600
RTHN-5A00
φH
Dimensions in mm
A
B
C
D
E
F
G
210
95
50
195
78
M4
M4
240
105
55
225
85
M4
M4
300
128
68
280
102
M5
M4
430
161
85
410
135
M8
M6
473
190
88
453
164
M8
M6
593
195
103
573
84.5
M10
M8
A
610
630
716
B
C
D
E
F
G
φH
Recommended clamping torque
300
160
210
275
M12
9.0
11.8N・m
14.0N・m
φ10.5-1
φ13-2
4.5
M4:1.27N・m
5.5
M5:2.5N・m
M6:4.8N・m
M8:7.64N・m
6.5
M10:11.8N・m
Dimensions in mm
3
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
RTHN-5010
–10
–10
–20
–20
–30
–30
–40
Attenuation(dB)
Attenuation(dB)
RTHN-5006
Common mode
–50
–60
–70
–80
–100
0.1
1
Frequency(MHz)
10
100
–70
0.1
1
Frequency(MHz)
10
100
RTHN-5030
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
–60
–100
Common mode
–40
–50
–60
Differential mode
–70
–80
–30
Common mode
–40
–50
Differential mode
–60
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTHN-5040
–10
–10
–20
–20
–30
Common mode
–40
–50
Differential mode
–60
0.1
1
Frequency(MHz)
10
100
RTHN-5050
Attenuation(dB)
Attenuation(dB)
Common mode
–90
RTHN-5020
–70
–80
–30
Common mode
–40
–50
Differential mode
–60
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTHN-5060
–10
–10
Attenuation(dB)
–40
Differential mode
–50
1
Frequency(MHz)
10
100
–20
Common mode
–30
0.1
RTHN-5080
–20
Attenuation(dB)
Differential mode
–50
–80
Differential mode
–90
–40
–60
–70
–80
–30
Common mode
–40
–50
–60
Differential mode
–70
–80
–90
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
0.1
1
Frequency(MHz)
10
100
4
RTHN-5150
–10
–10
–20
–20
–30
Attenuation(dB)
Attenuation(dB)
RTHN-5100
Common mode
–40
–50
–60
Differential mode
–70
–80
–30
–50
–60
–80
–90
–100
–100
0.1
1
Frequency(MHz)
10
100
RTHN-5200
–10
–10
–20
–20
–30
Common mode
–40
0.1
1
Frequency(MHz)
10
100
RTHN-5250
Attenuation(dB)
Attenuation(dB)
Differential mode
–70
–90
–50
–60
–70
–80
–30
Common mode
–40
–50
–60
–70
–80
–90
–100
Common mode
–40
–90
Differential mode
0.1
1
Frequency(MHz)
10
100
–100
Differential mode
0.1
1
Frequency(MHz)
10
100
RTHN-5300
–10
Attenuation(dB)
–20
Common mode
–30
–40
–50
–60
Differential mode
–70
–80
–90
–100
0.1
1
Frequency(MHz)
10
100
5
很抱歉,暂时无法提供与“RTHN-5006”相匹配的价格&库存,您可以联系我们找货
