RWS150B-24
RWS150B-24
    TDK(东电化)
    50W至600W单输出通用电源模块
RWS150B-24 数据手册
RWS50B-RWS600B Series https://product.tdk.com/en/power/rws-b www.emea.lambda.tdk.com/rws-b 50W to 600W Single Output General Purpose Power Supplies The RWS50B to RWS6000B AC-DC power supplies are designed to provide solid performance at an economical price. 50, 100, 150, 300 and 600W ratings are available with output voltages from 5V to 48V. All models are certified to IEC62368-1 with UL508 on select models. These 7-year warranty (1) products meet both Class B radiated and conduction EMI standards. The 300W models have a remote on/off option and the 600W have options for remote on/off, parallel operation, DC Good and remote sense. Features Benefits • Seven Year Warranty (1) • Low Cost of Ownership • Conservatively Rated Electrolytic Capacitors • Long Field Life • Class B Conducted and Radiated EMI • Easier System EMC Compliance • UL508 Certified on Select Models • Suitable for Industrial Control Equipment Model Selector Model RWS50B-5 RWS100B-5 RWS150B-5 RWS300B-5 RWS600B-5 RWS50B-12 RWS100B-12 RWS150B-12 RWS300B-12 RWS600B-12 RWS100B-15 RWS150B-15 RWS300B-15 RWS600B-15 RWS50B-24 RWS100B-24 RWS150B-24 RWS300B-24 RWS600B-24 RWS150B-28 RWS300B-36 RWS600B-36 RWS50B-48 RWS100B-48 RWS150B-48 RWS300B-48 RWS600B-48 Voltage (V) Adjustable Range (V) Max Current (A) Max Output Power (W) 5 5 5 5 5 12 12 12 12 12 15 15 15 15 24 24 24 24 24 28 36 36 48 48 48 48 48 4.5 - 5.75 4.5 - 5.75 4.5 - 5.75 4.5 - 5.75 4.5 - 5.75 10.8 - 13.8 10.8 - 13.8 10.8 - 13.8 10.8 - 13.8 10.8 - 13.8 13.5 - 17.25 13.5 - 17.25 13.5 - 17.25 13.5 - 17.25 21.6 - 27.6 21.6 - 27.6 21.6 - 27.6 21.6 - 27.6 21.6 - 27.6 25.2 - 32.2 32.4 - 414 32.4 - 414 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 43.2 - 52.8 10 14 21 50 100 4.3 8.5 13 25 50 6.8 10 20 40 2.2 4.5 6.5 12.5 25 5.4 8.4 16.7 1.1 2.1 3.3 6.3 12.5 50 70 105 250 500 51.6 102 156 300 600 102 150 300 600 52.8 108 156 300 600 151.2 302.4 601.2 52.8 100.8 158.4 302.4 600 Ripple Input & Noise Current (A) (mV) 115/230Vac RWS50B-RWS600B Series 120 120 120 120 120 150 150 150 150 150 150 150 150 150 150 150 150 150 150 180 200 200 200 200 200 200 200 1.0 / 0.65 0.9 / 0.45 1.3 / 0.7 3.1 / 1.6 6.2 / 3.2 1.0 / 0.65 1.2 / 0.6 1.8 / 0.9 3.6 / 1.9 6.6 / 3.6 1.2 / 0.6 1.8 / 0.9 3.6 / 1.9 6.6 / 3.6 1.0 / 0.65 1.2 / 0.6 1.8 / 0.9 3.6 / 1.9 6.6 / 3.6 1.8 / 0.9 3.6 / 1.9 6.6 / 3.6 1.0 / 0.65 1.2 / 0.6 1.8 / 0.9 3.6 / 1.9 6.6 / 3.6 Efficiency (typ)% UL508 115/230Vac Certification 78 / 79 77.5 / 79 77.5 / 79.5 75 / 78.5 74 / 77.5 83 / 84 83 / 84 84.5 / 87.5 79.5 / 82.5 82 / 84.5 84 / 85 84.5 / 87.5 81.5 / 84.5 82 / 84.5 86 / 87 86 / 87.5 86.5 / 89.5 85 / 88 85 / 88.5 86.5 / 89.5 85 / 88 85 / 88.5 87 / 88 86 / 87 86.5 / 89.5 85 / 88 85 / 88.5 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes - 1 RWS50B- 12 / blank /CO2 /FO /R /RFO Output voltage 5, 12, 15, 24, 28, 36, 48 No options Double sided board coating DC Good and parallel (600W only) Remote On/Off (600W only) Remote on/off, DC Good and parallel (600W only) Related Products Type Higher power RWS-B models DIN rail mounting bracket DIN rail mounting bracket DIN rail mounting bracket DIN rail mounting bracket Part Number RWS1000B, RWS1500B DIN-04 DIN-05 DIN-06 DIN-07 Description 1000W to 1500W single output AC-DC power supplies RWS50B DIN rail bracket RWS100B DIN rail bracket RWS150B DIN rail bracket RWS300B DIN rail bracket Specifications Model Input Input Voltage Range (Operating) Nominal Input Voltage Range Input Surge Voltage Input Frequency DC Input Voltage Range Input Current (115/230Vac) Inrush Current at 200Vac (typ) (Cold Start) Leakage Current Power Factor (100/200Vac) Harmonic Compliance Hold Up Time (typ) at 110/220Vac Input Efficiency Conducted & Radiated EMI Immunity Safety Certifications and Markings RWS50B RWS100B RWS150B RWS300B RWS600B Vac 85 - 265 Vac 100 - 240 (Note: Safety certified for 90-264Vac) Vac 300 for 5s Hz 47 - 63 (Note: Safety certified for 50-60Hz only) Vdc RWS50-300B: 120 - 370, RWS600B: 120 - 330 (Note: Safety certified for AC input only) A See model selector table A 36 30 32 34 40 uA 200Vac 2 RWS50B-RWS600B Series Specifications Model RWS50B RWS100B RWS150B RWS300B RWS600B Output Output Voltage Adjustment - See model selector table Switching Frequency kHz 100 120, PFC 65 190, PFC 50-70 Line Regulation mV 5V: 20, 12V: 48, 15V: 60, 24V: 96, 28V: 112, 36V: 144, 48V: 192 Load Regulation mV 5V: 40, 12V: 96, 15V: 120, 24V: 192, 28V: 224, 36V: 288, 48V: 384 External Load Capacitance uF RWS50B; 5-12V, 10,000, 24V: 3,300, 48V: 400, RWS100B-600B: 10,000 Ripple & Noise - See model selector table Temperature Coefficient %/°C 0.02 Minimum Load - No minimum load required Overcurrent Protection % >105. Constant current characteristics Overvoltage Protection % 115-140. Cycle AC line to reset Remote Sense - None See options Remote On/Off - None See options Parallel Operation - None See options Environmental Operating Temperature(2) °C -20 to +70. See note (2) or installation manuals on website Humidity (non condensing) %RH Operating: 30 - 90, storage: 10 - 90 Storage Temperature °C -30 to +75 Cooling - Convection Forced air - internal fan Altitude m 3000 Withstand Voltage (For 1 minute) Vac Input to Ground 2,000, Input to Output 3,000, Output to Ground 500 for 1 minute Vibration (Non operating) - 10-55Hz (Sweep for 1min.) 19.6m/s2 Constant X,Y,Z 1 hour each Shock (Non operating) - Less than 196m/s2, 11ms, ±X, ±Y, ±Z 3 times each Other Weight (Typ) g 230 400 480 900 1600 Size (LxWxH) mm 81.5 x 82 x 34 108 x 94 x 39 128 x 94 x 41 170 x 102 x 41 190 x 120 x 61 Size (LxWxH) Inches 3.21 x 3.23 x 1.34 4.25 x 3.7 x 1.54 5.04 x 3.7 x 1.61 6.7 x 4.02 x 1.61 7.48 x 4.72 x 2.4 Case Material - Metal MTBF - Telcordia SR-332 issue 3* Hours 4,170,949 1,978,533 2,235,743 2,027,824 2,157,340 Warranty yrs 7 (1) Notes See website for detailed specifications, test methods and installation manual *25°C ambient, full load, 24Vdc input (1) The Americas and EMEA regions: 7 years. Other regions: 5 years. See applicable regional terms of sale. (2) RWS50-100B derates linearly above 45°C to 20% load at 70°C, 150B derates above 40°C and 300-600B derates above 50°C to 50% load at 70°C RWS50B-RWS600B Series 3 Outline Drawing RWS50B Outline Drawing RWS100B 4 RWS50B-RWS600B Series Outline Drawing RWS150B Outline Drawing RWS300B RWS50B-RWS600B Series 5 Outline Drawing RWS600B 6 RWS50B-RWS600B Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 tlf.fr-powersolutions@tdk.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 tla.powersolutions@tdk.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 tlf.it-powersolutions@tdk.com www.emea.lambda.tdk.com/it Netherlands tlf.nl-powersolutions@tdk.com TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 tlg.powersolutions@tdk.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 tlc.powersolutions@tdk.com www.lambda.tdk.com.cn Austria Sales Office Tel: +43 2256 655 84 tlg.at-powersolutions@tdk.com TDK-Lambda Singapore Pte Ltd. Switzerland Sales Office Tel: +65 6251 7211 tls.marketing@tdk.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 tlg.ch-powersolutions@tdk.com TDK India Private Limited, Power Supply Division www.emea.lambda.tdk.com/at www.emea.lambda.tdk.com/ch Nordic Sales Office Tel: +91 80 4039-0660 mathew.philip@tdk.com www.sg.lambda.tdk.com Tel: +45 8853 8086 tlg.dk-powersolutions@tdk.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 tlu.powersolutions@tdk.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 tli.powersolutions@tdk.com www.emea.lambda.tdk.com/il-en For Additional Information, please visit https://product.tdk.com/en/power/ RWS50B-RWS600B_260844 August 4th, 2023 V2 RWS50B-RWS600B Series 7
RWS150B-24 价格&库存
很抱歉,暂时无法提供与“RWS150B-24”相匹配的价格&库存,您可以联系我们找货
RWS150B-24
  • 1+441.72000
  • 10+405.00000
库存:7
RWS150B-24
  • 1+591.127611+76.47814
RWS150B-24
    • 1+552.73523
    • 10+541.67574
    • 50+530.84535
    库存:38
    RWS150B-24
      • 1+917.534901+118.70763
      • 2+865.825032+112.01758
      • 3+848.599473+109.78900
      • 4+839.970094+108.67256
      • 5+834.809065+108.00484
      • 9+825.615469+106.81540
      • 10+824.4704110+106.66726
      库存:9
      RWS150B-24
        库存:14
