RWS300B-24
RWS300B-24
    TDK(东电化)
    RWS300B-24
RWS300B-24 数据手册
RWS-B Series 50-600W Single Output General Purpose Power Supplies Features       Low Cost Wide Range AC Input 85 - 265VAC (300VAC for 5s) UL508 Certification on Select Models Enclosed Construction Compact Size 7 Year Warranty Key Market Segments & Applications Specifications Model AC Input Voltage range (1) DC Input Voltage range Inrush Current (100 / 200VAC) Power Factor (100 / 200VAC) RWS100B RWS150B RWS300B RWS600B 85 - 265VAC (47 - 63Hz), 300VAC for 5 seconds 120 - 370VDC (330VDC for RWS600B)* 18 / 36 15 / 30 16 / 32 17 / 34 20 / 40 Meets EN61000-3-2 (0.95 / 0.9) 1.2 / 0.6 1.8 / 0.9 3.6 / 1.9 6.6 / 3.6 Input Current (115/230VAC) (Typ) A 1.0 / 0.65 (5V: 0.9/0.45) (5V: 1.3/0.7) (5V: 3.1/1.6) (5V: 6.2/3.2) Temperature Coefficient 105%, Constant Current Style Overvoltage Protection V 115-140%, Cycle AC line to reset Hold Up Time (Typ at 100% load) ms 20ms (RWS50B: 15ms at 100VAC input) Leakage Current (max) uA 750uA maximum, typically 175uA at 115VAC, 63Hz Remote Sense No Operating Temperature -20 to +70oC, see note (3) and instruction manual for low temperature derating Storage Temperature -30 to +75°C Operating Humidity (non condensing) %RH 30 - 90%RH Storage Humidity (non condensing) %RH 10 - 90%RH Cooling Convection Internal Fan Withstand Voltage Input to Ground 2kVAC, Input to Output 3kVAC, Output to Ground 500VAC for 1 min. Isolation Resistance >100M at 25°C & 70%RH, Output to Ground 500VDC Vibration (non operating) 10 - 55Hz: 19.6m/s 2 (sweep 1 min) X, Y, Z for 1 hour Shock < 196.1 m/s2 Safety Agency Approvals (2) IEC/EN/UL/CSA60950-1, IEC/EN/UL/CSA62368-1, UL508 and CE Mark Conducted & Radiated EMI EN55011 / EN55022-B, FCC Class B, VCCI-B Line Dips SEMI-F47 (200VAC input) Immunity IEC61000-4-2, -3, -4, -5, -6, -8, -11, IEC61000-6-2 Weight (Typ) g 230 400 480 900 1600 Size (WxHxD) mm 82 x 34 x 81.5 94 x 39 x 108 94 x 41 x 128 102 x 41 x 170 120 x 61 x 190 In 3.23 x 1.34 x 3.2 3.7 x 1.54 x 4.25 3.7 x 1.61 x 5.04 4.02 x 1.61 x 6.7 4.72 x 2.4 x 7.48 MTBF - Telcordia SR-332 issue 3** Hours 4,170,949 1,978,533 2,235,743 2,027,824 2,157,340 Warranty Yrs Seven Years *Safety certified for AC input only RWS50B VAC VDC A - ** 24V output model, 25°C ambiient, full load, 230VAC input Notes: (1) See instruction manual for derating below 115VAC input (2) UL508 & CSA C22.2 No.107.1-01 on RWS50B-5, -12, -24, RWS100B-5, -12, -24, RWS150B-5, -12, -24, RWS300B-12, -15, -24, -36 & -48 RWS600B-24 only (3) RWS50-100B derates linearly above 45oC to 20% load at 70oC, 150B derates above 40oC and 300-600B derates above 50oC to 50% load at 70oC RWS-B Series Output Ratings Model RWS50B-5 RWS100B-5 RWS150B-5 RWS300B-5 RWS600B-5 RWS50B-12 RWS100B-12 RWS150B-12 RWS300B-12 RWS600B-12 RWS100B-15 RWS150B-15 RWS300B-15 RWS600B-15 RWS50B-24 RWS100B-24 RWS150B-24 RWS300B-24 RWS600B-24 RWS150B-28 RWS300B-36 RWS600B-36 RWS50B-48 RWS100B-48 RWS150B-48 RWS300B-48 RWS600B-48 Voltage Adjust Range (V) Max Current (A) Max Output Power Load Reg (mV) Line Reg (mV) Ripple Noise (mV) Efficiency (typ) % 115/230VAC 5V 5V 5V 5V 5V 12V 12V 12V 12V 12V 15V 15V 15V 15V 24V 24V 24V 24V 24V 28V 36V 36V 48V 48V 48V 48V 48V 4.5-5.75V 4.5-5.75V 4.5-5.75V 4.5-5.75V 4.5-5.75V 10.8-13.8V 10.8-13.8V 10.8-13.8V 10.8-13.8V 10.8-13.8V 13.5-17.25V 13.5-17.25V 13.5-17.2V 13.5-17.2V 21.6-27.6V 21.6-27.6V 21.6-27.6V 21.6-27.6V 21.6-27.6V 25.2-32.2V 32.4-41.4 32.4-41.4 43.2-52.8 43.2-52.8 43.2-52.8 43.2-52.8 43.2-52.8 10 14 21 50 100 4.3 8.5 13 25 50 6.8 10 20 40 2.2 4.5 6.5 12.5 25 5.4 8.4 16.7 1.1 2.1 3.3 6.3 12.5 50 70 105 250 500 51.6 102 156 300 600 102 150 300 600 52.8 108 156 300 600 151.2 302.4 601.2 52.8 100.8 158.4 302.4 600 40 40 40 40 70 96 96 96 96 96 120 120 120 120 192 192 192 192 192 224 288 288 384 384 384 384 384 20 20 20 20 20 48 48 48 48 48 60 60 60 60 96 96 96 96 96 112 144 144 192 192 192 192 192 120 120 120 120 120 150 150 150 150 150 150 150 150 150 150 150 150 150 150 180 200 200 200 200 200 200 200 78 / 79 77.5 / 79 77.5 / 79.5 75 / 78.5 74 / 77.5 83 / 84 83 / 84 84.5 / 87.5 79.5 / 82.5 82 / 84.5 84 / 85 84.5 / 87.5 81.5 / 84.5 82 / 84.5 86 / 87 86 / 87.5 86.5 / 89.5 85 / 88 85 / 88.5 86.5 / 89.5 85 / 88 84 / 88.5 87 / 88 86 / 87 86.5 / 89.5 85 / 88 85 / 88/5 Outline Drawing (RWS600B) Options Other TDK-Lambda Industrial Products Suffix Description /CO2 /R /RFO Double Sided Board Coating Remote On/Off (RWS300B only) Remote On/Off, Remote Sense, Parallel Operation, DC Good Signal (RWS600B only) HWS LS RWS1000/1500B 15W to 1500W Single output 25W to 200W Single output low cost 1000W to 1500W Single output (including medical /ME) For Additional Information, please visit https://product.tdk.com/info/en/products/power/index.html Revision B7: Jan 2020
RWS300B-24 价格&库存
很抱歉,暂时无法提供与“RWS300B-24”相匹配的价格&库存,您可以联系我们找货
RWS300B-24
    • 1+1089.267721+141.36707
    • 2+1048.025632+136.01460
    • 3+1034.294813+134.23259
    • 4+1027.412864+133.33944
    • 5+1023.293615+132.80484
    • 9+1015.964999+131.85371
    • 20+1010.9193320+131.19888
    库存:8
    RWS300B-24
      • 1+988.552981+128.29614
      • 2+961.182322+124.74392
      • 3+952.058773+123.55985
      • 4+947.501134+122.96836
      • 5+944.763245+122.61303
      • 7+941.636587+122.20724
      • 9+939.899559+121.98181
      库存:78
      RWS300B-24
        库存:12
