SD1209TT-A1
SD1209TT-A1
    TDK(东电化)
    插件,D=12mm
    tdk 电磁蜂鸣器 无源 尺寸:D12.0 x H9.0 (mm)
SD1209TT-A1 数据手册
Electromagnetic Buzzers Pin terminal Without oscillator circuit SD series Issue date: February 2013 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/4) Electromagnetic Buzzers Pin Terminal SD Series Conformity to RoHS Directive SD1209T3-A1, SD1209T5-A1, SD1209TT-A1(Applicable to automobile) / ø12mm TYPE FEATURES SHAPES AND DIMENSIONS • These high reliability electromagnetic buzzers are applicable to Sound release hole automobile equipment. • Compact, pin terminal type electromagnetic buzzer with 2048Hz output. • Pin type terminal construction enables direct mounting onto printed circuit boards. 3.2 APPLICATIONS Clocks, travel watches, keyboards, toys, various alarms of automobile equipment. FREQUENCY CHARACTERISTICS Around 2000Hz 9 5.5 Weight: 2g • The longer pin is the + side. Dimensions in mm SPECIFICATIONS Part No. SD1209T3-A1 SD1209T5-A1 Rated voltage Eo-p(V) 3 5 Operating voltage Eo-p(V) 1 to 4 3 to 6 Drive conditions:Rated voltage, square wave form [duty 50%] Frequency(Hz) 2048 2048 Sound pressure(dB(A)/10cm)min. 80 80 Current Io-p(mA)max. 100 60 DC resistance()typ. 30 90 Terminal construction Pin terminal Pin terminal Operating temperature range –40 to +85°C Storage temperature range –40 to +85°C 100 Sound pressure (dB (A) /10cm) 5 ø12 0.5 90 80 70 SD1209TT-A1 12 6 to 15 2048 85 100 120 Pin terminal • Please ask us for details which is designed another operating rated frequency. 60 3000 SD160701, SD160709 / ø16mm TYPE FEATURES • These are thin-type electromagnetic buzzers with a height of only 7mm. They provide output over a relatively wide band, making them suitable for music. • Pin type terminal construction enables direct mounting onto printed circuit boards. SHAPES AND DIMENSIONS Sound release hole 3.2 0.5 APPLICATIONS Travel watches, keyboards, handy-type equipment, toys. FREQUENCY CHARACTERISTICS Around 4000Hz 5 2000 Frequency (Hz) ø16 1000 7 5.5 •The longer pin is the + side. Weight: 3.5g Dimensions in mm 100 Sound pressure (dB (A) /10cm) SPECIFICATIONS Part No. SD160701 SD160709 Rated voltage Eo-p(V) 3 5 Operating voltage Eo-p(V) 1 to 5 3 to 9 Drive conditions:Rated voltage, square wave form [duty 50%] Drive frequency(Hz) 4096 4096 Sound pressure(dB(A)/10cm)min. 80 80 Current Io-p(mA)max. 60 70 DC resistance()typ. 50 70 Terminal construction Pin terminal Pin terminal Operating temperature range –10 to +70°C Storage temperature range –20 to +80°C 90 80 70 60 3000 4000 Frequency (Hz) 5000 • Please ask us for details which is designed another operating rated frequency. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-03 / 20130201 / ec211_sd.fm (2/4) SHAPES AND DIMENSIONS Sound release hole 0.5 14 5.5 •The longer pin is the + side. Weight: 4g Dimensions in mm SPECIFICATIONS 100 Part No. SD1614T5-B1 SD1614TT-B1 Rated voltage Eo-p(V) 5 12 Operating voltage Eo-p(V) 3 to 6 6 to 15 Drive conditions: Rated voltage, square wave form [duty 50%] Drive frequency(Hz) 2048 2048 Sound pressure(dB(A)/10cm)min. 85 85 Current Io-p(mA)max. 80 100 DC resistance()typ. 70 120 Terminal construction Pin terminal Pin terminal Operating temperature range –10 to +70°C Storage temperature range –20 to +80°C 80 70 60 1000 2000 Frequency (Hz) 3000 SD1614TT-B3M(Applicable to automobile) / ø16mm TYPE FEATURES • These high reliability electromagnetic buzzers are applicable to automobile equipment. • Pin type terminal construction enables direct mounting onto printed circuit boards. • Please ask us for details which is designed another operating rated frequency. • Products with 5mm terminal pitch are also available. Please substitute -B1 at the end of part number to -A1 in this case. SHAPES AND DIMENSIONS Sound release hole 0.5 APPLICATIONS Various alarms of automobile equipment. FREQUENCY CHARACTERISTICS Around 2000Hz 3.8 + Positive mark 7.6 90 ø16 Sound pressure (dB (A) /10cm) + Positive mark 7.6 APPLICATIONS Office equipment, electronic games, toys, home appliances, keyboards. FREQUENCY CHARACTERISTICS Around 2000Hz 3.2 ø16 SD1614T5-B1, SD1614TT-B1 / ø16mm TYPE FEATURES • These low-cost electromagnetic buzzers are suited to a wide range of applications. • Pin type terminal construction enables direct mounting onto printed circuit boards. 14 3.8 •The longer pin is the + side. Weight: 4g Dimensions in mm 100 Sound pressure (dB (A) /10cm) SPECIFICATIONS Part No. SD1614TT-B3M Rated voltage Eo-p(V) 12 Operating voltage Eo-p(V) 6 to 15 Drive conditions: Rated voltage, square wave form [duty 50%] Drive frequency(Hz) 2048 Sound pressure(dB(A)/10cm)min. 85 Current Io-p(mA)max. 100 DC resistance()typ. 120 Terminal construction Pin terminal Operating temperature range –40 to +85°C Storage temperature range –40 to +85°C 90 80 70 60 1000 2000 Frequency (Hz) 3000 • Please ask us for details which is designed another operating rated frequency. • Products with 5mm terminal pitch are also available. Part No.: SD1614TT-A5M • All specifications are subject to change without notice. 006-03 / 20130201 / ec211_sd.fm (3/4) SHAPES AND DIMENSIONS Sound release hole 0.5 + Positive mark 100 7.6 APPLICATIONS Various alarms of automobile equipment. FREQUENCY CHARACTERISTICS Around 2000Hz 3.2 ø16 SD1614T5-B5M(Applicable to automobile) / ø16mm TYPE FEATURES • These high reliability electromagnetic buzzers are applicable to automobile equipment. • Pin type terminal construction enables direct mounting onto printed circuit boards. 14 5.5 •The longer pin is the + side. Sound pressure (dB (A) /10cm) Weight: 4g Dimensions in mm SPECIFICATIONS 90 80 70 60 1000 2000 Frequency (Hz) 3000 Part No. SD1614T5-B5M Rated voltage Eo-p(V) 5 Operating voltage Eo-p(V) 3 to 6 Drive conditions: Rated voltage, square wave form [duty 50%] Drive frequency(Hz) 2048 Sound pressure(dB(A)/10cm)min. 85 Current Io-p(mA)max. 80 DC resistance()typ. 70 Terminal construction Pin terminal Operating temperature range –40 to +85°C Storage temperature range –40 to +85°C • Please ask us for details which is designed another operating rated frequency. • All specifications are subject to change without notice. 006-03 / 20130201 / ec211_sd.fm (4/4) D SAFETY PRECAUTIONS FOR USING TDK ELECTROMAGNETIC BUZZER Please be sure to read the specifications of TDK Electromagnetic Buzzer(hereinafter referred to as “the buzzer”) before use. • Please pay sufficient attentions to the warnings for safe • When performing dip soldering directly for installing on a printed designing when using the buzzer. circuit board, be careful so that smoke from the flux, or other Incorrect usage may cause smoke or fire. foreign materials, will not get into the sound emission hole. • Do not make sound on the buzzer when it is close to ears. • Do not clean(excluding products that can be cleaned). Listening to the buzzer when it is close to ears, or continuant lis• With regards to devices in which the consumers can touch the tening to it for an extended period, may result in hearing disorbuzzer, thoroughly warn consumers not to put foreign materials ders. (such as needles, hairpins, garbage, etc.) into the sound Thoroughly warn consumers not to turn on the sound when the emission hole. buzzer is close to ears. • As the buzzer uses a coil, it has an inductive load. • Do not exceed the rated operation voltage range when using the Protect the drive circuit by putting the diodes in parallel into the buzzer. buzzer. If it is exceeded beyond the rated operation voltage, a built-in coil • Do not reconfigure the buzzer. may generate heat, resulting in deterioration of the coil, which • Sound pressure changes depending on the shape of the part to may cause a drop in sound pressure or a change in the terminal be installed in a device, or the installation location. resistance value. Check the buzzer in the mounted condition. If a rare short circuit occurs due to heat generated in the built-in • The buzzer has polarities. coil, a large electrical current flows to the equipment used, posWhen installing, be careful not to make a mistake with the polarsibly causing it to emit smoke or fire. ities. Incorrect polarities will cause the following irregularities. • The buzzer is a magnetic type sounder. • Without circuit type: Differences in sound pressure will be Do not use it for any other purpose than a sound generation. created. • Do not use the buzzer in other than atmospheric air. • With circuit type: No sound will be generated. • Do not use the buzzer in the following environments (excluding • Frequencies other than the rated frequency will change the cases in which countermeasures are taken). characteristics (sound pressure), and may cause wide • Corrosive gases (Cl2, NH3, SOx, NOx, etc.) unevenness. • Places to be exposed to dust. • As the buzzer uses a magnet, it generates a surrounding • Places where rain, fog, salt water, and the like will get on the magnetic field. buzzer. When designing a device, etc., confirm that there are no irregu• After installing the buzzer when designing an apparatus, confirm larities due to the magnetic field. that there are no abnormalities by performing a reliability • The characteristics of the buzzer may change because of the evaluation test. influence of an outside magnetic field. • Do not exceed the rated operating temperature range when Check the buzzer in the mounted condition, and take measures using the buzzer. such as shielding, etc. • Do not use for an extended period at relative humidity in excess • Because of deterioration or damage, maintain in rated storage of 90% (maximum wet-bulb temperature of 38°C). temperature range, avoid environments where there are sudden • When using the buzzer for a safety device or warning device, temperature changes, direct sunlight, corrosive gases and dust, take all surest measures such as providing a safety circuit or the and store wrapped in order to avoid applying stresses. joint use of another sounder with equivalent characteristics in order to prevent accidents. RECOMMENDED OPERATING CIRCUIT EXAMPLE • The buzzer may be influenced by electromagnetic waves, V CC Buzzer voltage changes, and ripple voltage. Check the buzzer in the mounted condition, and take measures such as safety circuits, shielding, etc. • If the buzzer is molded or secured by adhesives, thermal Oscillator circuit Q expansion stresses from the mold or adhesive agent may cause R deterioration in a soldered terminal part. Before molding or securing an adhesive, consider the type, amount, hardening conditions, adhesive properties, etc., of the sealing material, and confirm the reliability. • Do not apply vibrations or shocks (such as dropping) larger than the specified. • Do not bend the terminal pin when soldering to install on a circuit board. • Do not apply larger than the specified force to the terminal pin. • Do not apply force to the terminal pin at high temperatures (when soldering). • When soldering a terminal pin, perform the soldering in clean conditions without contamination or rust in order to avoid poor connections. • All specifications are subject to change without notice. 006-03 / 20130201 / ec211_sd.fm
SD1209TT-A1 价格&库存
很抱歉,暂时无法提供与“SD1209TT-A1”相匹配的价格&库存,您可以联系我们找货
SD1209TT-A1
  • 1+8.41320
  • 10+7.05240
  • 30+6.37200
  • 100+5.69160
  • 500+5.02200
  • 800+4.80600
