Inductors for Power Circuits
Radial lead
TSL series
Type:
TSL0709
TSL0808
TSL1112
TSL1315
Issue date:
September 2011
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
I
N
D
U
C
T
O
R
S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 30°C, Humidity: 10 to 75%
RH or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
(1/8)
Radial Lead
TSL Series TSL0709
FEATURES
• The TSL series feature low DC resistance and high current handling capacities, making them ideal for power supply line applications.
• These parts are manufactured to a high degree of dimensional
accuracy using non-flammable material (UL94V-0).
• Available in tape packaging to support automated mounting
machines.
• It is a product conforming to RoHS directive.
PRODUCT IDENTIFICATION
TSL 0709 RA- 1R0 M 5R0 - PF
(1) (2) (3) (4) (5) (6) (7)
(1)Series name
(2)Dimensions
0709
ø7.7×9.5mm (lead pitch 5mm)
(3)Packaging style
APPLICATIONS
Televisions, VCRs, personal computers, and other electronic
equipment.
RA
S
Taping(Ammo-pack)
Bulk
(4)Inductance value
SPECIFICATIONS
Operating temperature range
Storage temperature range
Terminal tensile strength
Flow soldering condition
–40 to +85°C
[Including self-temperature rise]
–40 to +85°C[Unit of products]
9.8N min.
260°C /10 seconds
1R0
100
1µH
10µH
(5)Inductance tolerance
K
M
±10%
±20%
(6)Rated current
5R0
R66
5A
0.66A
(7)Lead-free compatible product
PF
PACKAGING STYLE AND QUANTITIES
Packaging style
Taping
(Ammo-pack)
Bulk
Quantity
1000 pieces/box
500 pieces/10tray
001-02 / 20110925 / e532_tsl
(2/8)
5±1 9.5±0.1
ø7.7±0.3
SHAPES AND DIMENSIONS
ø0.65±0.05
Weight: 1.1g
5+2, –1
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Rated current(A)∗1max.
Test
Self-resonant DC
Part No.
frequency
frequency
resistance Based on inductance Based on
L/Q (Hz)
(MHz)min.
(Ω)max.
change
temperature rise
1
±20%
10
1k/7.96M
70
0.006
6.6
5
TSL0709 ∗2-1R0M5R0-PF
1.5
±20%
10
1k/7.96M
56
0.008
5.4
4.3
TSL0709 -1R5M4R3-PF
2.2
±20%
10
1k/7.96M
45
0.011
4
3.7
TSL0709 -2R2M3R7-PF
3.3
±20%
10
1k/7.96M
36
0.018
3.6
2.9
TSL0709 -3R3M2R9-PF
4.7
±20%
10
1k/7.96M
29
0.022
3.1
2.6
TSL0709 -4R7M2R6-PF
6.8
±20%
10
1k/7.96M
24
0.028
2.5
2.3
TSL0709 -6R8M2R3-PF
10
±10%
1k/2.52M
19
0.043
2.1
1.9
TSL0709 -100K1R9-PF
15
±10%
1k/2.52M
15
0.056
1.7
1.6
TSL0709 -150K1R6-PF
22
±10%
1k/2.52M
12
0.086
1.4
1.3
TSL0709 -220K1R3-PF
33
±10%
1k/2.52M
9.4
0.14
1.1
1
TSL0709 -330K1R0-PF
47
±10%
1k/2.52M
7.6
0.17
0.96
0.94
TSL0709 -470KR94-PF
68
±10%
1k/2.52M
6.2
0.28
0.79
0.73
TSL0709 -680KR73-PF
100
±10%
1k/796k
5
0.33
0.66
0.67
TSL0709 -101KR66-PF
150
±10%
1k/796k
4
0.56
0.53
0.52
TSL0709 -151KR52-PF
220
±10%
1k/796k
3.2
0.72
0.44
0.46
TSL0709 -221KR44-PF
330
±10%
1k/796k
2.5
1.1
0.36
0.37
TSL0709 -331KR36-PF
470
±10%
1k/796k
2
1.7
0.3
0.3
TSL0709 -471KR30-PF
680
±10%
1k/796k
1.7
2.3
0.25
0.26
TSL0709 -681KR25-PF
1000
±10%
70
1k/252k
1.3
4.3
0.2
0.19
TSL0709 -102KR19-PF
1500
±10%
50
1k/252k
1.3
5
0.17
0.16
TSL0709 -152KR16-PF
∗1 Rated current: Value obtained when current flows and the temperature has risen to 25°C or when DC current flows and the initial value of inductance has
fallen by 20%, whichever is smaller.
∗2
: Please specify packaging style, S(Bulk) or RA(Taping).
Inductance
(µH)
Inductance
tolerance
Q min.
Test circuit L=0.1H C=20000µF
A
DC
Specimen
10000
3000
1000µH
1000
YHP model-4275A
or equivalent
Universal
bridge
TYPICAL ELECTRICAL CHARACTERISTICS
INDUCTANCE CHANGE vs. DC SUPERPOSITION
CHARACTERISTICS
330µH
Inductance (µH)
300
100µH
100
33µH
30
10µH
10
3.3µH
3
1
1µH
0.3
0.1
0.01 0.03
0.1
0.3
1
DC current (A)
3
10
(3/8)
Radial Lead
TSL Series TSL0808
FEATURES
machines.
TSL 0808 RA- 3R3 M 3R8 - PF
(1)Series name
(2)Dimensions
0808
ø8.5×8.3mm (lead pitch 5mm)
(3)Packaging style
APPLICATIONS
equipment.
RA
S
Taping(Ammo-pack)
Bulk
(4)Inductance value
SPECIFICATIONS
–40 to +85°C
9.8N min.
260°C /10 seconds
3R3
100
3.3µH
10µH
K
M
±10%
±20%
(6)Rated current
3R8
R67
3.8A
0.67A
PF
Packaging style
Taping
(Ammo-pack)
Bulk
Quantity
1000 pieces/box
500 pieces/10tray
(4/8)
ø0.62±0.05
5±1
8.3±0.5 ø8.5±0.3
Weight: 1.5g
5+0.8, –0.5
Dimensions in mm
Inductance
(µH)
Inductance
tolerance
Q
min.
2.2
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
330
470
680
1000
1500
2200
3300
4700
±20%
±20%
±20%
±20%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±5%
10
10
10
10
15
15
15
30
30
50
50
50
Test
frequency
L/Q (Hz)
1k/7.96M
1k/7.96M
1k/7.96M
1k/7.96M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/796k
1k/796k
1k/796k
1k/796k
1k/796k
1k/796k
1k/252k
1k/252k
1k/252k
1k/252k
1k/252k
Self-resonant
frequency
(MHz)min.
45
34
27
22
17
13
10
8
6.5
5.4
4.4
3.6
2.9
2.4
2
1.6
1.3
1.1
0.88
0.71
0.68
DC
resistance
(Ω )max.
0.015
0.017
0.021
0.025
0.031
0.042
0.07
0.092
0.13
0.16
0.25
0.4
0.53
0.78
1
1.5
2.2
3.5
6.4
8.5
12.2
Rated current (A)∗1max.
change
temperature rise
5.6
3.9
4.5
3.8
3.8
3.5
3.2
3.1
2.6
2.7
2.1
2.4
1.7
1.9
1.4
1.5
1.2
1.3
1
1.1
0.8
0.94
0.67
0.73
0.54
0.64
0.45
0.52
0.38
0.46
0.32
0.37
0.26
0.3
0.21
0.25
0.17
0.21
0.14
0.16
0.15
0.13
Part No.
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
TSL0808
∗2-2R2M3R9-PF
-3R3M3R8-PF
-4R7M3R5-PF
-6R8M3R1-PF
-100K2R6-PF
-150K2R1-PF
-220K1R7-PF
-330K1R4-PF
-470K1R2-PF
-680K1R0-PF
-101KR80-PF
-151KR67-PF
-221KR54-PF
-331KR45-PF
-471KR38-PF
-681KR32-PF
-102KR26-PF
-152KR21-PF
-222KR17-PF
-332KR14-PF
-472JR13-PF
∗1
fallen by 10%, whichever is smaller.
∗2
300
Inductance(µH)
YHP model-4275A
or equivalent
100
10000
68µH
47µH
33µH
22µH
15µH
10µH
30
10
3
1
A
DC
Specimen
3000
1000
Inductance(µH)
A
DC
Specimen
Universal
bridge
1000
1000µH
YHP model-4275A
or equivalent
Universal
bridge
CHARACTERISTICS
680µH
470µH
330µH
220µH
150µH
100µH
300
100
30
0.01 0.03
0.1
0.3
1
DC current(A)
3
10
10
0.01 0.03
0.1
0.3
1
DC current(A)
3
10
(5/8)
Radial Lead
TSL Series TSL1112
FEATURES
machines.
TSL 1112 RA- 3R3 M 5R9 - PF
(1)Series name
(2)Dimensions
1112
ø11.2×12.2mm (lead pitch 5mm)
(3)Packaging style
APPLICATIONS
equipment.
RA
S
Taping(Ammo-pack)
Bulk
(4)Inductance value
SPECIFICATIONS
–40 to +85°C
9.8N min.
260°C /10 seconds
3R3
100
3.3µH
10µH
J
K
M
±5%
±10%
±20%
(6)Rated current
5R9
R56
5.9A
0.56A
PF
Packaging style
Taping
(Ammo-pack)
Bulk
Quantity
500 pieces/box
400 pieces/8tray
(6/8)
5±1 12.2±0.3 ø11.2±0.3
ø0.65±0.05
5+1, –0.5
Weight: 3.3g
Dimensions in mm
Inductance
(µH)
Inductance
tolerance
Q
min.
1.0
2.2
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
330
470
680
1000
1500
2200
3300
4700
6800
10000
15000
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
15
15
10
10
10
30
10
30
30
30
50
Test
frequency
L/Q (Hz)
1k/7.96M
1k/7.96M
1k/7.96M
1k/7.96M
1k/7.96M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/796k
1k/796k
1k/796k
1k/796k
1k/796k
1k/796k
1k/252k
1k/252k
1k/252k
1k/252k
1k/252k
1k/252k
1k/79.6k
1k/79.6k
Self-resonant
frequency
(MHz)min.
144
70
36
28
18
16
12
9.5
7
5.8
4.7
3.8
3.1
2.5
2
1.6
1.3
1.1
0.82
0.76
0.64
0.54
0.45
0.38
0.29
DC
resistance
(Ω)max.
0.058
0.073
0.01
0.015
0.016
0.025
0.029
0.04
0.062
0.075
0.13
0.16
0.26
0.33
0.52
0.66
1.1
1.4
2.4
3.2
4.9
7.6
9.8
18
24
change
temperature rise
14
7.7
10
6.7
8.8
5.9
7.2
4.8
6.1
4.6
5
3.7
4.2
3.4
3.4
2.9
2.8
2.3
2.3
2.1
1.9
1.6
1.6
1.4
1.3
1.1
1.1
1
0.88
0.82
0.75
0.72
0.61
0.56
0.51
0.5
0.43
0.38
0.35
0.33
0.28
0.26
0.24
0.21
0.2
0.18
0.17
0.14
0.13
0.12
Part No.
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
TSL1112
∗2-1R0M7R7-PF
-2R2M6R7-PF
-3R3M5R9-PF
-4R7M4R8-PF
-6R8M4R6-PF
-100M3R7-PF
-150M3R4-PF
-220K2R9-PF
-330K2R3-PF
-470K2R1-PF
-680K1R6-PF
-101K1R4-PF
-151K1R1-PF
-221K1R0-PF
-331KR82-PF
-471KR72-PF
-681KR56-PF
-102JR50-PF
-152JR38-PF
-222JR33-PF
-332JR26-PF
-472JR21-PF
-682JR18-PF
-103JR14-PF
-153JR12-PF
∗1
∗2
CHARACTERISTICS
10000µH
10000
3300µH
3000
1000µH
Inductance (µH)
1000
Test circuit
Universal bridge
C=20000µF
L=0.1H
A
DC Specimen
YHP model-4255A
or equivalent
330µH
300
100µH
100
33µH
30
10µH
10
3.3µH
3
1
0.01 0.03
0.1
0.3
1
DC current (A)
3
10
(7/8)
Radial Lead
TSL Series TSL1315
FEATURES
machines.
TSL 1315 RA- 100 K 5R1 - PF
(1)Series name
(2)Dimensions
1315
ø14×17mm (lead pitch 7.5mm)
(3)Packaging style
APPLICATIONS
equipment.
RA
S
Taping(Ammo-pack)
Bulk
(4)Inductance value
SPECIFICATIONS
–40 to +85°C
9.8N min.
260°C /10 seconds
100
102
10µH
1000µH
J
K
±5%
±10%
(6)Rated current
5R1
R99
5.1A
0.99A
PF
Packaging style
Taping
(Ammo-pack)
Bulk
Quantity
200 pieces/box
50 pieces/pack
(8/8)
5±0.5 17max.
ø14max.
ø0.8±0.05
7.5±0.5
Weight: 7.5g
Dimensions in mm
Inductance
(µH)
Inductance
tolerance
Q
typ.
10
15
22
33
47
68
100
150
220
330
470
680
1000
1500
2200
3300
4700
6800
10000
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±10%
±5%
±5%
±5%
±5%
±5%
±5%
±5%
70
70
60
50
50
40
50
50
40
30
30
30
30
40
40
40
40
30
70
Test
frequency
L/Q (Hz)
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/2.52M
1k/796k
1k/796k
1k/796k
1k/796k
1k/796k
1k/796k
1k/252k
1k/252k
1k/252k
1k/252k
1k/252k
1k/252k
1k/79.6k
Self-resonant
frequency
(MHz)min.
19
12
7.6
6.9
5.6
4.4
3.3
2.6
2.2
1.8
1.5
1.2
1
0.83
0.7
0.6
0.43
0.38
0.3
DC
resistance
(Ω )max.
0.023
0.028
0.035
0.043
0.052
0.068
0.097
0.14
0.2
0.3
0.43
0.61
1
1.3
2
3.1
4.4
6.5
10
change
temperature rise
12
5.1
9.5
4.5
8.2
4.2
6.8
3.7
5.7
3.4
4.8
3
3.9
2.5
3.2
2.1
2.7
1.7
2.1
1.4
1.8
1.1
1.5
0.99
1.2
0.78
1
0.68
0.83
0.55
0.69
0.44
0.58
0.37
0.46
0.3
0.4
0.24
Part No.
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
TSL1315
∗2-100K5R1-PF
-150K4R5-PF
-220K4R2-PF
-330K3R7-PF
-470K3R4-PF
-680K3R0-PF
-101K2R5-PF
-151K2R1-PF
-221K1R7-PF
-331K1R4-PF
-471K1R1-PF
-681KR99-PF
-102JR78-PF
-152JR68-PF
-222JR55-PF
-332JR44-PF
-472JR37-PF
-682JR30-PF
-103JR24-PF
∗1
∗2
100000
A
DC
Specimen
30000
10000µH
10000
YHP model-4275A
or equivalent
3300µH
3000
Inductance (µH)
LCR
meter
CHARACTERISTICS
1000µH
1000
330µH
220µH
150µH
100µH
68µH
47µH
33µH
22µH
300
100
30
15µH
10
10µH
5
0.01 0.03
0.1
0.3
1
DC current (A)
3
10
