SL1215-100K3R6
SL1215-100K3R6
    TDK(东电化)
    SL1215-100K3R6 - Inductors For Power Line Radial - TDK Electronics
SL1215-100K3R6 数据手册
(1/2) 001-01 / 20030730 / e532_sl1215.fm Inductors For Power Line Radial FEATURES • This is a low Rdc, best for the power supply line. • There is a series of many types from low inductance to high inductance in large current. APPLICATIONS Televisions, CRT displays, printers, and various types of electronic products. SPECIFICATIONS Operating temperature range Storage temperature range Terminal strength ∗ SL Series SL1215 Type PRODUCT IDENTIFICATION SL 1215 - 100 K 3R6 (1) (2) (3) (4) (5) (1)Series name (2)Dimensions Type 1215 Dimension ø12×14.5mm Lead pitch 11mm (10 to 100µH for wire type) 7.5mm (150 to 5600µH for lead type) –40 to +85°C [Including self-temperature rise] –40 to +85°C [Unit of products] 9.8N min.∗ (3)Inductance value 100 102 10µH 1000µH Only for lead type specification. Wire type’s specification depends on the vibration test. (4)Inductance tolerance K ±10% (5)Rated current 3R6 R20 3.6A 0.2A PACKAGING STYLE AND QUANTITIES Packaging style Bulk Quantity 100 pieces/tray • All specifications are subject to change without notice. (2/2) 001-01 / 20030730 / e532_sl1215.fm Inductors For Power Line Radial SHAPES AND DIMENSIONS WIRE TYPE (10 to 100µH) Winding start mark ø12 ± 0.5 SL Series SL1215 Type LEAD TYPE (150 to 5600 µH) Winding start mark ø12 ± 0.5 Dimensions in before soldering (0.5max.) 5 ±1 14.5 ± 0.5 Soldering ø0.6 to 0.8 11typ. ø0.8 ± 0.05 7.5 ± 0.8 5 ±1 14.5 ± 0.5 Weight: 7g typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) 10 15 22 33 47 68 100 150 220 330 470 680 1000 1500 2200 3300 5600 Inductance tolerance ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% ±10% DC resistance (Ω)max. 0.019 0.022 0.031 0.044 0.059 0.073 0.1 0.15 0.26 0.32 0.48 0.73 0.96 1.4 2.5 3.3 6.4 Rated current(A)∗max. Based on inductance change 9.8 8.9 7.2 6 4.9 4.2 3.4 2.8 1.9 1.8 1.6 1.3 1.1 0.9 0.7 0.6 0.47 Based on temperature rise 3.6 3.3 2.8 2.3 2 1.8 1.5 1.3 1 0.91 0.72 0.58 0.51 0.42 0.31 0.27 0.2 Part No. SL1215-100K3R6 SL1215-150K3R3 SL1215-220K2R8 SL1215-330K2R3 SL1215-470K2R0 SL1215-680K1R8 SL1215-101K1R5 SL1215-151K1R3 SL1215-221K1R0 SL1215-331KR91 SL1215-471KR72 SL1215-681KR58 SL1215-102KR51 SL1215-152KR42 SL1215-222KR31 SL1215-332KR27 SL1215-562KR20 Lead wire style Wire type Wire type Wire type Wire type Wire type Wire type Wire type Lead type Lead type Lead type Lead type Lead type Lead type Lead type Lead type Lead type Lead type ∗ Rated current: Value obtained when current flows and self-temperature has risen to 25°C. • Test equipment Inductance:LCR METER YHP4261A, or equivalent Rdc: MILLIOHM METER VP-2941A MATSUSHITA, or equivalent TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 10000 3000 1000 Test circuit L=0.1H C=20000µF A DC Specimen 2200µH YHP model-4261A or equivalent 1000µH 470µH Inductance (µH) 300 100 220µH 100µH 47µH 30 10 22µH 10µH 3 1 0.1 0.3 1 3 10 DC current (A) 30 • All specifications are subject to change without notice. Universal bridge 100
SL1215-100K3R6 价格&库存
很抱歉,暂时无法提供与“SL1215-100K3R6”相匹配的价格&库存,您可以联系我们找货
