SLF10145T-151MR79
SLF10145T-151MR79
    TDK(东电化)
    SMD,10.1x10.1mm
    固定电感器 Nonstandard 150µH ±20% 810mA 420mΩ
SLF10145T-151MR79 数据手册
531_SLF10145 (1/2) Inductors SLF Series SLF10145 Type For Power Line SMD FEATURES • The SLF series are characterized by low profile, low DC resistance, and high current handling capacities. • Because they are magnetically shielded, these parts can be used in high-density mounting configurations. • Flat bottom surface ensures secure, reliable mounting. • Provided in embossed carrier tape packaging for use with automatic mounting machines. APPLICATIONS Portable telephones, personal computers, hard disk drives, and other electronic equipment. SPECIFICATIONS Type SLF6025 SLF6028 SLF7028 SLF7030 SLF7032 SLF7045 SLF10145 SLF12555 SLF12565 SLF12575 Operating temperature range [Including self-temperature rise] –20 to +85°C –20 to +85°C –20 to +85°C –20 to +85°C –20 to +85°C –20 to +85°C –20 to +90°C –20 to +90°C –20 to +105°C –20 to +105°C Storage temperature range [Unit of products] –40 to +85°C –40 to +85°C –40 to +85°C –40 to +85°C –40 to +85°C –40 to +85°C –40 to +90°C –40 to +90°C –40 to +105°C –40 to +105°C RECOMMENDED REFLOW SOLDERING CONDITIONS 5s Natural cooling 40s 150°C 130°C 60 to 120s Preheating Time (s) SLF 7032 T- 220 M R96 -2 (1) (2) (3) (4) (5) (6) (7) (1) Series name (2) Dimensions L×W×T 6.0×6.0×2.5mm 6.0×6.0×2.8mm 7.0×7.0×2.8mm 7.0×7.0×3.0mm 7.0×7.0×3.2mm 7.0×7.0×4.5mm 10.1×10.1×4.5mm 12.5×12.5×5.5mm 12.5×12.5×6.5mm 12.5×12.5×7.5mm 6025 6028 7028 7030 7032 7045 10145 12555 12565 12575 (3) Packaging style T Taping(reel) (4) Inductance value 3.3µH 10µH 3R3 100 (5) Inductance tolerance M N ±20% ±30% (6) Rated current 240±5°C 220±5°C PRODUCT IDENTIFICATION 1R9 R96 1.9A 0.96A (7) TDK internal code (Some products may not have this number. See the main body for details.) PACKAGING STYLE AND QUANTITIES Packaging style Taping Type SLF6025T SLF6028T SLF7028T SLF7030T SLF7032T SLF7045T SLF10145T SLF12555T SLF12565T SLF12575T Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice. Quantity 1000 pieces/reel 1000 pieces/reel 1000 pieces/reel 1000 pieces/reel 1000 pieces/reel 1000 pieces/reel 500 pieces/reel 500 pieces/reel 500 pieces/reel 500 pieces/reel 531_SLF10145 (2/2) Inductors SLF Series SLF10145 Type For Power Line SMD SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN 4.5±0.3 2±0.15 0.15typ. Winding start mark 3±0.1 3.2 2.5 5.6 2.5 10.1±0.3 220 10.1±0.3 6±0.2 Marking (Inductance code) Weight: 1.3g typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Inductance (µH) Inductance tolerance (%) Test frequency L (kHz) DC resistance (Ω)±20% 10 15 22 33 47 68 100 150 220 330 470 680 1000 1500 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 ±20 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0.0364 0.0472 0.0591 0.0815 0.1 0.14 0.2 0.35 0.47 0.68 1.03 1.6 2.8 3.4 Rated current (A)∗ max. Based on inductance change 3 2.4 2.1 1.6 1.4 1.2 1 0.79 0.65 0.54 0.47 0.38 0.32 0.22 Based on temperature rise 2.5 2.2 1.9 1.7 1.5 1.3 1.1 0.81 0.7 0.58 0.47 0.38 0.29 0.26 Part No. SLF10145T-100M2R5 SLF10145T-150M2R2 SLF10145T-220M1R9 SLF10145T-330M1R6 SLF10145T-470M1R4 SLF10145T-680M1R2 SLF10145T-101M1R0 SLF10145T-151MR79 SLF10145T-221MR65 SLF10145T-331MR54 SLF10145T-471MR47 SLF10145T-681MR38 SLF10145T-102MR29 SLF10145T-152MR22 ∗ Rated current: Value obtained when current flows and the temperature has risen to 30°C or when DC current flows and the initial value of inductance has fallen by 10%, whichever is smaller. • Test equipment L:YHP 4194A IMPEDANCE GAIN/PHASE ANALYZER, or equivalent (Measured at 1kHz/0.5V) Rdc:MATSUSHITA VP-2941A DIGITAL MILLIOHM METER, or equivalent 10000 Test circuit L=0.1H C=20000µF A DC 3000 Inductance (µH) 1000 Specimen YHP model-4275A or equivalent Universal bridge TYPICAL ELECTRICAL CHARACTERISTICS INDUCTANCE CHANGE vs. DC SUPERPOSITION CHARACTERISTICS 1000µH 330µH 300 100 100µH 33µH 30 10 10µH 3 1 0.01 0.03 0.1 0.3 1 DC current (A) 3 10 531_SLF10145 990803 Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice.
SLF10145T-151MR79
物料型号:SLF系列,包括SLF6025、SLF6028、SLF7028、SLF7030、SLF7032、SLF7045、SLF10145、SLF12555、SLF12565和SLF12575。
器件简介:SLF系列电感器具有低轮廓、低直流电阻和高电流承载能力。由于磁屏蔽,适用于高密度安装配置。底部平坦,确保安全、可靠的安装。提供用于自动安装机器的压花载带包装。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性:包括工作温度范围、存储温度范围、推荐回流焊接条件、产品识别码和封装样式及数量。
功能详解:文档提供了电感器的尺寸、重量、电气特性,包括电感值、电感公差、测试频率、直流电阻、额定电流等。
应用信息:适用于便携电话、个人电脑、硬盘驱动器和其他电子设备。
封装信息:提供了不同型号的封装样式和每卷的数量。
SLF10145T-151MR79 价格&库存
很抱歉,暂时无法提供与“SLF10145T-151MR79”相匹配的价格&库存,您可以联系我们找货
