SLF10145T-471MR47-H
SLF10145T-471MR47-H
    TDK(东电化)
    SMD,10.1x10.1mm
    固定电感器 Nonstandard 470µH ±20% 470mA 1.236Ω
SLF10145T-471MR47-H 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite SLF-H series (for automotive) Pb RoHS REACH SVHC-Free Lead Free AEC-Q200 SLF10145-H type FEATURES Magnetic shield type wound inductor for power circuits. Product lineup allows for various usages. Operating temperature range: –40 to +125°C (including self-temperature rise) APPLICATION Automotive-related equipment (ECM, airbags, headlights, electronic power steering, meters, ABS, other) Application guides: Automotive (xEV) PART NUMBER CONSTRUCTION SLF 10145 T - Series name L×W×H dimensions 10.1×10.1×4.5 mm Packaging style 3R3 N 3R7 Inductance (µH) Inductance tolerance Rated current (A) - H Internal code CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Isat Isat (µH) Tolerance (kHz) ( ) (A)max. (A)typ. 3.3 ±30% 1 16.1m±20% 4.9 7.1 5.6 ±20% 1 22.0m±20% 3.8 5.7 10 ±20% 1 36.4m±20% 3.0 3.9 15 ±20% 1 47.2m±20% 2.4 3.3 22 ±20% 1 59.1m±20% 2.1 2.7 33 ±20% 1 81.5m±20% 1.6 2.1 47 ±20% 1 0.10±20% 1.4 1.8 68 ±20% 1 0.14±20% 1.2 1.4 100 ±20% 1 0.20±20% 1.0 1.2 150 ±20% 1 0.35±20% 0.79 1.0 220 ±20% 1 0.47±20% 0.65 0.80 330 ±20% 1 0.68±20% 0.54 0.70 470 ±20% 1 1.03±20% 0.47 0.60 680 ±20% 1 1.6±20% 0.38 0.40 1000 ±20% 1 2.8±20% 0.32 0.40 1500 ±20% 1 3.4±20% 0.22 0.30  Isat(max.): When based on the inductance change rate (10% below the initial value) Isat(typ.): When based on the inductance change rate (30% below the initial value) Itemp: When based on the temperature increase (temperature increase of 30°C by self heating) Part No. Itemp (A)typ. 3.7 3.2 2.5 2.2 1.9 1.7 1.5 1.3 1.1 0.81 0.70 0.58 0.47 0.38 0.29 0.26 SLF10145T-3R3N3R7-H SLF10145T-5R6M3R2-H SLF10145T-100M2R5-H SLF10145T-150M2R2-H SLF10145T-220M1R9-H SLF10145T-330M1R6-H SLF10145T-470M1R4-H SLF10145T-680M1R2-H SLF10145T-101M1R0-H SLF10145T-151MR79-H SLF10145T-221MR65-H SLF10145T-331MR54-H SLF10145T-471MR47-H SLF10145T-681MR38-H SLF10145T-102MR29-H SLF10145T-152MR22-H Measurement equipment Measurement item Product No. L 4194A DC resistance VP-2941A Rated current Isat 4284A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Panasonic Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/5) 20181221 inductor_automotive_power_slf10145-h_en.fm I N D U C T O R S SLF10145-H type L FREQUENCY CHARACTERISTICS 100000 10000 152 102 1000 Inductance(µH) 681 471 331 221 151 101 100 680 470 330 220 150 100 10 5R6 3R3 1 1 10 100 1000 10000 100000 Frequency(kHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/5) 20181221 inductor_automotive_power_slf10145-h_en.fm I N D U C T O R S SLF10145-H type INDUCTANCE VS. DC BIAS CHARACTERISTICS 10000 152 1000 102 471 681 331 Inductance(µH) 221 151 101 100 680 470 330 220 150 100 10 5R6 3R3 1 0 2 4 6 DC current(A) 8 10 12 Measurement equipment Product No. Manufacturer 4284A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/5) 20181221 inductor_automotive_power_slf10145-h_en.fm I N D U C T O R S SLF10145-H type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 10.1±0.3 2 (6.1) 2.0±0.15 4.5±0.3 2.0±0.15 ø50min 3±0.1 100 10.1±0.3 2.0±0.5 (1.0) Dimensions in mm ø13.0±0.5 24.4 ø21.0±0.8 30.4max. ø330 Dimensions in mm 1.5 +0.1 –0 2.0±0.05 4.0±0.1 Sprocket hole 5.6 2.5 B 2.5 24.0±0.3 3.2 0.4 1.75±0.1 RECOMMENDED LAND PATTERN 11.5±0.1 TAPE DIMENSIONS Dimensions in mm Cavity K A 16.0±0.1 Dimensions in mm Type SLF10145-H Package quantity Soldering Natural cooling Peak 260°C±3°C Temperature 230°C B 10.5 K 5 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating A 10.5 230°C 500 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –40 to +125 °C –40 to +125 °C 1.3 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 5s 150°C 60 to 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/5) 20181221 inductor_automotive_power_slf10145-h_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 30°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/5) 20181221 inductor_automotive_power_slf10145-h_en.fm
SLF10145T-471MR47-H 价格&库存
很抱歉,暂时无法提供与“SLF10145T-471MR47-H”相匹配的价格&库存,您可以联系我们找货
