531_SLF6028
(1/2)
Inductors
SLF Series SLF6028 Type
For Power Line
SMD
FEATURES
• The SLF series are characterized by low profile, low DC
resistance, and high current handling capacities.
• Because they are magnetically shielded, these parts can be
used in high-density mounting configurations.
• Flat bottom surface ensures secure, reliable mounting.
• Provided in embossed carrier tape packaging for use with
automatic mounting machines.
APPLICATIONS
Portable telephones, personal computers, hard disk drives, and
other electronic equipment.
SPECIFICATIONS
Type
SLF6025
SLF6028
SLF7028
SLF7030
SLF7032
SLF7045
SLF10145
SLF12555
SLF12565
SLF12575
Operating temperature
range
[Including self-temperature rise]
–20 to +85°C
–20 to +85°C
–20 to +85°C
–20 to +85°C
–20 to +85°C
–20 to +85°C
–20 to +90°C
–20 to +90°C
–20 to +105°C
–20 to +105°C
Storage temperature
range
[Unit of products]
–40 to +85°C
–40 to +85°C
–40 to +85°C
–40 to +85°C
–40 to +85°C
–40 to +85°C
–40 to +90°C
–40 to +90°C
–40 to +105°C
–40 to +105°C
RECOMMENDED REFLOW SOLDERING CONDITIONS
5s
Natural
cooling
40s
150°C
130°C
60 to 120s
Preheating
Time (s)
SLF 7032 T- 220 M R96 -2
(1)
(2) (3) (4) (5) (6) (7)
(1) Series name
(2) Dimensions L×W×T
6.0×6.0×2.5mm
6.0×6.0×2.8mm
7.0×7.0×2.8mm
7.0×7.0×3.0mm
7.0×7.0×3.2mm
7.0×7.0×4.5mm
10.1×10.1×4.5mm
12.5×12.5×5.5mm
12.5×12.5×6.5mm
12.5×12.5×7.5mm
6025
6028
7028
7030
7032
7045
10145
12555
12565
12575
(3) Packaging style
T
Taping(reel)
(4) Inductance value
3.3µH
10µH
3R3
100
(5) Inductance tolerance
M
N
±20%
±30%
(6) Rated current
240±5°C
220±5°C
PRODUCT IDENTIFICATION
1R9
R96
1.9A
0.96A
(7) TDK internal code
(Some products may not have this number. See the main body
for details.)
PACKAGING STYLE AND QUANTITIES
Packaging style
Taping
Type
SLF6025T
SLF6028T
SLF7028T
SLF7030T
SLF7032T
SLF7045T
SLF10145T
SLF12555T
SLF12565T
SLF12575T
Specifications which provide more details for the proper and safe use of the described product are available upon request.
All specifications are subject to change without notice.
Quantity
1000 pieces/reel
1000 pieces/reel
1000 pieces/reel
1000 pieces/reel
1000 pieces/reel
1000 pieces/reel
500 pieces/reel
500 pieces/reel
500 pieces/reel
500 pieces/reel
531_SLF6028
(2/2)
Inductors
For Power Line
SMD
SHAPES AND DIMENSIONS/RECOMMENDED PC BOARD PATTERN
Winding start mark
2.8±0.2
2±0.1
2.2
4
1.5
4typ.
(0.05typ.)
(0.9)
220
Marking
(Inductance code)
6±0.2
1.5
6±0.2
Weight: 0.3g typ.
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Rated current (A)∗
Part No.
Based on inductance
Based on
change
temperature rise
4.7
±20
1
0.0284
1.6max.
2.5typ.
SLF6028T-4R7M1R6
6.8
±20
1
0.0354
1.5max.
2.2typ.
SLF6028T-6R8M1R5
10
±20
1
0.0532
1.3max.
1.8typ.
SLF6028T-100M1R3
15
±20
1
0.0745
1max.
1.4typ.
SLF6028T-150M1R0
22
±20
1
0.104
0.77max.
1.3typ.
SLF6028T-220MR77
33
±20
1
0.148
0.69max.
1.1typ.
SLF6028T-330MR69
47
±20
1
0.21
0.59max.
0.92typ.
SLF6028T-470MR59
68
±20
1
0.29
0.5max.
0.78typ.
SLF6028T-680MR50
100
±20
1
0.43
0.42max.
0.64typ.
SLF6028T-101MR42
∗ Rated current: Value obtained when current flows and the temperature has risen to 25°C or when DC current flows and the initial value of inductance has
fallen by 30%, whichever is smaller.
• Test equipment Inductance: YHP 4194A IMPEDANCE GAIN/PHASE ANALYZER, or equivalent (Test frequency: 1kHz/0.5V)
Rdc: DIGITAL MILLIOHM METER VP-2941A MATSUSHITA, or equivalent
Inductance
(µH)
Inductance
tolerance (%)
Test frequency
L (kHz)
DC resistance
(Ω)±20%
10000
Test circuit L=0.1H C=20000µF
A
DC
3000
Specimen
YHP model-4275A or equivalent
LCR meter
TYPICAL ELECTRICAL CHARACTERISTICS
INDUCTANCE CHANGE vs. DC SUPERPOSITION
CHARACTERISTICS
Inductance (µH)
1000
300
100
30
33µH
22µH
15µH
10
10µH
3
1
0.01 0.03
0.1
0.3
1
DC current (A)
3
10
531_SLF6028
990803
很抱歉,暂时无法提供与“SLF7032T-101MR45-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 264+3.47012
- 1193+3.28876
- 2385+3.20412
