I
N
D
U
C
T
O
R
S
April 2016
Inductors for Power Circuits
Wound Ferrite
SLF Series
SLF7045 Type
SLF7045
(2/9)
I
N
D
U
C
T
O
R
S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 30°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20160411 / inductor_commercial_power_slf7045_en.fm
(3/9)
I
N
D
U
C
T
O
R
S
Product compatible with RoHS directive
Compatible with lead-free solders
Wound Ferrite
Overview of SLF7045 Type
FEATURES
Magnetic shield type wound inductor for power circuits.
Product lineup allows for various usages.
APPLICATION
Thin-screen TV, LCDs, AV equipment, gaming equipment, other electrical devices
PART NUMBER CONSTRUCTION
SLF
Series name
7045
T
L×W×H Dimensions
(mm)
7045
7.0×7.0×4.5
Packaging style
T
Taping
3R3
M
2R5
Inductance
(μH)
3R3
3.3
100
10
101
100
Inductance
tolerance
M
±20%
N
±30%
Rated current
(A)
R47
0.47
2R5
2.5
150
15
PF
Internal code
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Package quantity
Operating
Storage
Type
temperature
temperature
(pieces/reel)
(°C)
(°C)
SLF7045
–40 to +105
–40 to +105
1000
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
Individual weight
(g)
0.6
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
I
N
D
U
C
T
O
R
S
SLF7045 Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
30s
Peak
Temp.
T4
250°C
Time
t3
5s
(5/9)
I
N
D
U
C
T
O
R
S
SLF7045 Type
SHAPE & DIMENSIONS
2±0.1
7±0.2
4R7
7±0.2
4.9
0.9
4.5±0.3
0.9
Dimensions in mm
2.2
RECOMMENDED LAND PATTERN
1.5
4.8
1.5
Dimensions in mm
(6/9)
I
N
D
U
C
T
O
R
S
SLF7045 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
L measuring frequency
(μH)
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
330
470
680
1000
Tolerance
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
(kHz)
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
DC resistance
Rated current
( )±20%
0.02
0.03
0.039
0.036
0.052
0.061
0.096
0.125
0.175
0.25
0.34
0.52
0.74
1.05
1.48
2.28
Isat
(A)max.
2.5
2
1.7
1.3
1.1
0.9
0.82
0.75
0.6
0.5
0.4
0.33
0.25
0.22
0.2
0.14
Part No.
Itemp
(A)max.
2.3
2.1
1.74
1.78
1.53
1.34
1.09
0.92
0.77
0.65
0.55
0.45
0.37
0.31
0.27
0.25
SLF7045T-3R3M2R5-PF
SLF7045T-4R7M2R0-PF
SLF7045T-6R8M1R7-PF
SLF7045T-100M1R3-PF
SLF7045T-150M1R1-PF
SLF7045T-220MR90-PF
SLF7045T-330MR82-PF
SLF7045T-470MR75-PF
SLF7045T-680MR60-PF
SLF7045T-101MR50-PF
SLF7045T-151MR40-PF
SLF7045T-221MR33-PF
SLF7045T-331MR25-PF
SLF7045T-471MR22-PF
SLF7045T-681MR20-PF
SLF7045T-102MR14-PF
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (10% below the initial value)
Itemp: When based on the temperature increase (Temperature increase of 20°C by self heating)
○ Measurement equipment
Measurement item
Product No.
L
4194A
DC resistance
VP-2941A
Rated current Isat
4284A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Panasonic
(7/9)
I
N
D
U
C
T
O
R
S
SLF7045 Type
L FREQUENCY CHARACTERISTICS GRAPH
10000
1000
102M
681M
471M
331M
Inductance(μH)
221M
151M
100
101M
680M
470M
330M
220M
150M
10
100M
6R8M
4R7M
3R3M
1
1
10
100
1000
Frequency(kHz)
10000
100000
1000000
Product No.
Manufacturer
4294A
(8/9)
I
N
D
U
C
T
O
R
S
SLF7045 Type
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
10000
1000
102M
681M
471M
331M
Inductance(μH)
221M
151M
100
101M
680M
470M
330M
220M
150M
10
100M
6R8M
4R7M
3R3M
1
2
3
DC current(A)
Product No.
Manufacturer
4284A+42841A+42842C
(9/9)
I
N
D
U
C
T
O
R
S
SLF7045 Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
SLF7045
A
ø330
W1
16.4
W2
22.4
N
ø50
E
2
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
SLF7045
A
7.4
B
7.6
øD0
1.5+0.1/-0
B
W
F
E
øD0
E
1.75±0.1
F
7.5±0.1
Dimensions in mm
P0
P1
P2
W
K
4.0±0.1 12.0±0.1 2.0±0.05 16.0±0.3 4.8
t
0.4
SLF7045T-470MR75-PF 价格&库存
很抱歉,暂时无法提供与“SLF7045T-470MR75-PF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.66457
- 50+1.34179
- 200+1.20344
- 400+1.18539
- 1000+1.03083
- 国内价格
- 10+3.69710
- 100+2.20550
- 500+1.54390
- 1000+1.10270
- 2000+1.04760
- 10000+0.97040
- 国内价格
- 5+1.83443
- 50+1.47871
- 150+1.32624
- 1000+1.13602
- 2000+1.05135
- 5000+1.00045
- 国内价格 香港价格
- 1000+3.856851000+0.49785
- 2000+3.636972000+0.46946
- 3000+3.514303000+0.45363
- 5000+3.365835000+0.43447
