I N D U C T O R S
Inductors for power circuits
Wound metal
SPM-HZ series (for automotive)
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
AEC-Q200
SPM10054-HZ type
FEATURES
Magnetic shield type wound inductor for power circuits using a metallic magnetic material.
Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness.
Low inductance variance in high-temperature environments with good DC superimposition characteristics. –40 to 125°C (including self-temperature rise)
Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with ferrite core adhesive coils.
Compliant with AEC-Q200
APPLICATION
Automotive-related equipment (Car navigation, car audio, electronic power steering, headlights, other)
Application guides: Automotive (xEV), Car Infotainment
PART NUMBER CONSTRUCTION
SPM
10054
T
Series name
L×W×H dimensions
10.7×10.0×5.4 mm
Packaging style
R47
M
Inductance
(µH)
Inductance
tolerance
HZ
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
Measuring
frequency
Rated current
DC resistance
Isat
(µH)
Tolerance
(kHz)
(m )max.
(m )typ.
(A)typ.
0.47
±20%
100
1.62
1.47
34.9
0.68
±20%
100
2.09
1.90
29.0
1.0
±20%
100
2.64
2.40
24.0
1.5
±20%
100
5.39
4.90
16.0
2.5
±20%
100
6.58
5.98
11.8
3.3
±20%
100
7.81
7.10
10.2
4.7
±20%
100
12.15
11.04
8.8
6.8
±20%
100
17.77
16.15
8.3
10.0
±20%
100
24.31
22.10
6.2
15.0
±20%
100
33.93
30.84
4.9
22.0
±20%
100
52.58
47.80
4.0
33.0
±20%
100
82.13
74.66
3.5
47.0
±20%
100
121.15
110.13
3.1
68.0
±20%
100
162.87
148.06
2.3
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (20% below the nominal value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
36.0
32.0
27.5
20.0
19.0
16.2
14.3
11.0
10.6
8.6
6.2
5.3
4.4
3.7
SPM10054T-R47M-HZ
SPM10054T-R68M-HZ
SPM10054T-1R0M-HZ
SPM10054T-1R5M-HZ
SPM10054T-2R5M-HZ
SPM10054T-3R3M-HZ
SPM10054T-4R7M-HZ
SPM10054T-6R8M-HZ
SPM10054T-100M-HZ
SPM10054T-150M-HZ
SPM10054T-220M-HZ
SPM10054T-330M-HZ
SPM10054T-470M-HZ
SPM10054T-680M-HZ
Measurement equipment
Measurement item
Product No.
L
4284A
DC resistance
AX-111A
Rated current Isat
4284A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
ADEX
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating temperature range
–40 to +125 °C
Storage temperature range
–40 to +125 °C
Individual weight
2.99 g
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20180704
inductor_automotive_power_spm10054-hz_en.fm
I N D U C T O R S
SPM10054-HZ type
L FREQUENCY CHARACTERISTICS
1000
680
470
220
100
150
100
Inductance (µH)
6R8
4R7
3R3
10
2R5
1R5
1R0
R68
R47
1
0.1
0.1
1
10
100
Frequency (MHz)
Product No.
Manufacturer
4294A
INDUCTANCE VS. DC BIAS CHARACTERISTICS
100
680M
470M
Inductance (µH)
330M
220M
150M
10
100M
6R8M
4R7M
3R3M
2R5M
1R5M
1
1R0M
R68M
R47M
0.1
DC current (A)
40
50
60
Product No.
Manufacturer
4284A+42841A+42842C
(2/4)
20180704
I N D U C T O R S
SPM10054-HZ type
SHAPE & DIMENSIONS
PACKAGING STYLE
(6.7)
2.0±0.2
10.7±0.5
2.0±0.2
REEL DIMENSIONS
2.2
2.3±0.1
(0.15)
5.4max.
ø100±0.2
4.2±0.3
10.0±0.4
1R0
Dimensions in mm
ø13.0±0.5
24.5±0.2
ø20.2
ø330
RECOMMENDED LAND PATTERN
Dimensions in mm
3.8
6.1
3.8
4.0±0.1
Sprocket
hole
B
24.0±0.3
2.0±0.1
Cavity
K
A
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
1.75±0.1
1.5 +0.1
–0
0.50±0.05
Dimensions in mm
11.5±0.1
4.8
TAPE DIMENSIONS
16.0±0.1
Dimensions in mm
Natural
cooling
Peak
Type
SPM10054-HZ
A
10.5±0.1
B
11.5±0.1
K
5.6±0.1
260°C
Temperature
230°C
230°C
PACKAGE QUANTITY
Package quantity
500 pcs/reel
180°C
10s max.
150°C
120s
30s
Time
(3/4)
20180704
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20180704
很抱歉,暂时无法提供与“SPM10054T-2R5M-HZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+17.90429
- 10+16.44489
- 25+14.04816
- 50+12.55317
- 100+10.76156
- 250+10.16831
- 国内价格 香港价格
- 500+6.86552500+0.85378
- 1000+6.797471000+0.84532
- 2500+6.729432500+0.83685
- 5000+6.662215000+0.82849
- 国内价格
- 1+4.54680
- 10+3.78000
- 30+3.39120
- 100+3.01320
