I
N
D
U
C
T
O
R
S
March 2015
Inductors for Power Circuits
Wound Metallic Magnetic Material
SPM Series
SPM4012 Type
SPM4012
(2/9)
I
N
D
U
C
T
O
R
S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20150322 / inductor_commercial_power_spm4012_en.fm
(3/9)
I
N
D
U
C
T
O
R
S
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
Overview of SPM4012 Type
FEATURES
Magnetic shield type wound inductor for power circuits using a metallic magnetic material.
Low-profile product.
Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness.
Low inductance variance in high-temperature environments with good DC superimposition characteristics.
Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with core adhesive coils.
APPLICATION
Smart phones, tablet terminals, laptop computers, HDDs, servers, VRMs, compact power supply modules, other
PART NUMBER CONSTRUCTION
SPM
Series name
4012
L×W×H Dimensions
(mm max.)
4012
4.4×4.1×1.2
T
Packaging style
T
Taping
R47
M
Inductance
(μH)
R47
0.47
1R5
1.5
2R2
2.2
Inductance
tolerance
M
±20%
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Storage
Type
Operating temperature
temperature
(°C)
(°C)
SPM4012
–40 to +125
–40 to +125
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
Package quantity
Individual weight
(pieces/reel)
1000
(g)
0.0941
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
I
N
D
U
C
T
O
R
S
SPM4012 Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
120s
Soldering
Temp.
Time
T3
t2
230°C
30s
Peak
Temp.
T4
260°C
Time
t3
10s max.
(5/9)
I
N
D
U
C
T
O
R
S
SPM4012 Type
SHAPE & DIMENSIONS
0.9±0.1
(2.6)
0.9±0.1
0.1±0.1
1.2max.
2.0±0.1
4.1±0.2
4.4±0.2
Dimensions in mm
RECOMMENDED LAND PATTERN
1.65
1.65
2.3
1.65
Dimensions in mm
(6/9)
I
N
D
U
C
T
O
R
S
SPM4012 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
(μH)
0.47
1.00
1.50
2.20
3.30
4.70
Tolerance
±20%
±20%
±20%
±20%
±20%
±20%
L measuring
frequency
DC resistance
Rated current
(kHz)
100
100
100
100
100
100
(m )max.
25.3
41.8
67.9
94.3
141.5
204.7
Idc1
(A)max.
6.0
4.5
3.7
3.3
2.6
2.1
(m )typ.
23
38
59
82
123
178
Part No.
Idc1
(A)typ.
8.0
6.0
4.9
4.4
3.5
2.8
Idc2
(A)typ.
5.6
4.3
3.5
2.9
2.4
2.0
SPM4012T-R47M
SPM4012T-1R0M
SPM4012T-1R5M
SPM4012T-2R2M
SPM4012T-3R3M
SPM4012T-4R7M
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (30% below the initial value)
Idc2: When based on the temperature increase (Temperature increase of 40°C by self heating)
○ Measurement equipment
Measurement item
Product No.
L
4284A
DC resistance
AX-111A
Rated current Idc1
4284A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Agilent Technologies
ADEX
(7/9)
I
N
D
U
C
T
O
R
S
SPM4012 Type
L FREQUENCY CHARACTERISTICS GRAPH
20.0
4R7M
Inductance (μH)
15.0
3R3M
10.0
2R2M
5.0
1R5M
1R0M
R47M
0.0
0.01
0.1
1
Frequency (MHz)
10
100
Product No.
Manufacturer
4294A
(8/9)
I
N
D
U
C
T
O
R
S
SPM4012 Type
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
5
4R7M
4
Inductance (μH)
3R3M
3
2R2M
2
1R5M
1R0M
1
R47M
4
6
DC current (A)
8
10
12
Product No.
Manufacturer
4284A+42841A+42842C
(9/9)
I
N
D
U
C
T
O
R
S
SPM4012 Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
SPM4012
A
ø180
W1
12.4
W2
14.4
N
ø60
E
1.0
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
A
SPM4012 4.35
B
4.65
øD0
1.5+0.1/-0
B
W
F
E
øD0
E
1.75±0.1
F
5.5±0.1
Dimensions in mm
P0
4.0±0.1
P1
8.00±0.1
P2
W
K
2.0±0.1 12.0±0.2 1.35
t
0.25
