I N D U C T O R S
Inductors for power circuits
Wound metal
SPM-HZ series (for automotive)
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
AEC-Q200
SPM4030-HZ type
FEATURES
Magnetic shield type wound inductor for power circuits using a metallic magnetic material.
Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness.
Low inductance variance in high-temperature environments with good DC superimposition characteristics. –40 to 125°C (including self-temperature rise)
Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with ferrite core adhesive coils.
Compliant with AEC-Q200
APPLICATION
Automotive-related equipment (Car navigation, car audio)
PART NUMBER CONSTRUCTION
SPM
4030
T
1R0
M
HZ
Series name
L×W×H dimensions
4.1×4.0×3.0 mm
Packaging style
Inductance
(µH)
Inductance
tolerance
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
Measuring
frequency
Rated current
DC resistance
Isat
(µH)
Tolerance
(kHz)
(m )max.
(m )typ.
(A)typ.
1.0
±20%
100
16.17
14.7
4.4
1.5
±20%
100
25.63
23.3
3.6
2.2
±20%
100
39.60
36.0
2.8
3.3
±20%
100
58.63
53.3
2.5
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (20% below the initial value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
8.8
6.7
5.3
4.5
SPM4030T-1R0M-HZ
SPM4030T-1R5M-HZ
SPM4030T-2R2M-HZ
SPM4030T-3R3M-HZ
Measurement equipment
Measurement item
Product No.
L
4284A
DC resistance
AX-111A
Rated current Isat
4284A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
ADEX
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating temperature range
–40 to +125 °C
Storage temperature range
–40 to +125 °C
Individual weight
0.24 g
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20200709
inductor_automotive_power_spm4030-hz_en.fm
I N D U C T O R S
SPM4030-HZ type
L FREQUENCY CHARACTERISTICS
Inductance (µH)
100
3R3M
10
2R2M
1R5M
1R0M
1
0.1
0.1
1
10
100
Frequency (MHz)
Product No.
Manufacturer
4294A
INDUCTANCE VS. DC BIAS CHARACTERISTICS
8
Inductance (µH)
6
4
3R3M
2
2R2M
1R5M
1R0M
10
DC current (A)
15
Product No.
Manufacturer
4284A+42841A+42842C
(2/4)
20200709
I N D U C T O R S
SPM4030-HZ type
SHAPE & DIMENSIONS
PACKAGING STYLE
(1.8)
1.0±0.2
4.1±0.3
1.0±0.2
REEL DIMENSIONS
2.2+0.5/–0
1.2+0.2/–0.1
(0.1)
3.0max.
ø59.3±0.5
4.0±0.3
1.6±0.2
1R0
Dimensions in mm
ø13.3±0.5
12.4±0.1
ø178±1.0
15.1max.
Dimensions in mm
1.5 +0.1
–0
0.40±0.05
4.0±0.1
Sprocket
hole
12.0±0.2
1.8
B
1.9
1.3
1.9
1.8
2.0±0.1
5.5±0.1
RECOMMENDED LAND PATTERN
1.75±0.1
TAPE DIMENSIONS
Dimensions in mm
K
Cavity
A
8.0±0.1
Dimensions in mm
Type
SPM4030-HZ
A
4.4±0.1
B
4.6±0.1
K
3.2±0.1
PACKAGE QUANTITY
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Package quantity
500 pcs/reel
Natural
cooling
Peak
260°C
Temperature
230°C
230°C
180°C
10s max.
150°C
120s
30s
Time
(3/4)
20200709
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
Do not use products that have received any excessive mechanical shock such as by being dropped.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Do not expose the products to magnets or magnetic fields.
The performance of the product may deteriorate if coating materials are used, thus please assess the situation beforehand by taking
this factor into consideration.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment,
telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product
is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications
as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification,
while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and
usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of
the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure,
malfunction or defect could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications
below or for any other use exceeding the range or conditions set forth in this specification sheet.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in this specification, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20200709
很抱歉,暂时无法提供与“SPM4030T-3R3M-HZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.901891+1.54081
- 10+9.8073310+1.26965
- 25+9.0697525+1.17416
- 50+8.5512350+1.10703
- 100+8.06172100+1.04366
- 250+7.45903250+0.96564
- 国内价格 香港价格
- 500+6.83216500+0.88449
- 1000+6.442621000+0.83406
- 1500+6.225401500+0.80593
- 2500+5.962372500+0.77188
- 3500+5.795393500+0.75027
- 5000+5.623585000+0.72802
- 国内价格
- 1+3.09790
- 10+2.44940
- 30+2.09840
- 100+1.83490
- 500+1.65350
- 1000+1.54440
