SPM5012T-2R2M-LR
SPM5012T-2R2M-LR
    TDK(东电化)
    IND_5.4X5.1MM_SM
    2.2UH ±20% 3.2A 61.5MΩ
SPM5012T-2R2M-LR 数据手册
I N D U C T O R S Inductors for power circuits Wound metal SPM-LR series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free SPM5012-LR type FEATURES Magnetic shield type wound inductor for power circuits using a metallic magnetic material. Low-profile product. Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness. Low inductance variance in high-temperature environments with good DC superimposition characteristics. Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with core adhesive coils. APPLICATION Tablet terminals, note PCs, HDDs, servers, VRMs, compact power supply modules, other Application guides: Smart phones/tablets PART NUMBER CONSTRUCTION SPM 5012 T - Series name L×W×H dimensions 5.4×5.1×1.2 mm Packaging style 1R0 M - Inductance (µH) Inductance tolerance LR Internal code CHARACTERISTICS SPECIFICATION TABLE L L measuring frequency Rated current DC resistance Isat (µH) Tolerance (kHz) (m )max. (m )typ. (A)typ. 0.47 ±20% 100 23.1 21.0 9.0 1.0 ±20% 100 35.2 32.0 7.5 1.5 ±20% 100 46.2 42.0 6.0 2.2 ±20% 100 67.7 61.5 5.8 3.3 ±20% 100 110.0 100.0 4.5 4.7 ±20% 100 155.1 141.0 3.5 6.8 ±20% 100 253.0 230.0 2.9 10.0 ±20% 100 390.5 355.0 2.2  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 5.4 4.4 3.8 3.2 2.5 2.1 1.6 1.3 SPM5012T-R47M-LR SPM5012T-1R0M-LR SPM5012T-1R5M-LR SPM5012T-2R2M-LR SPM5012T-3R3M-LR SPM5012T-4R7M-LR SPM5012T-6R8M-LR SPM5012T-100M-LR Measurement equipment Measurement item Product No. L 4284A DC resistance AX-111A Rated current Isat 4284A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies ADEX Keysight Technologies TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range Storage temperature range –40 to +125 °C –40 to +125 °C  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Individual weight 0.15 g Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210419 inductor_commercial_power_spm5012-lr_en.fm I N D U C T O R S SPM5012-LR type L FREQUENCY CHARACTERISTICS 60 100M Inductance (µH) 50 40 6R8M 30 4R7M 20 3R3M 10 2R2M 1R5M 1R0M R47M 0 0 1 10 100 Frequency (MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 12 Inductance (µH) 10 8 100 6 6R8 4 4R7 3R3 2 2R2 1R5 0 0 2 4 6 DC current (A) 8 1R0 R47 10 12 Measurement equipment Product No. Manufacturer 4284A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20210419 inductor_commercial_power_spm5012-lr_en.fm I N D U C T O R S SPM5012-LR type SHAPE & DIMENSIONS PACKAGING STYLE (3.0) 1.2±0.1 5.4±0.2 1.2±0.1 REEL DIMENSIONS 1.2+0.2/-0.1 1.2max. ø59.3±0.5 2.5±0.1 5.1±0.2 2.2+0.5/-0 Dimensions in mm ø13.3±0.5 12.4±0.1 ø178±1.0 Dimensions in mm 1.5 +0.1 –0 0.3 4.0±0.1 Sprocket hole 1.4 B 12.0±0.2 3.0 2.8 1.4 2.0±0.1 K Dimensions in mm 5.5±0.1 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS Cavity A 8.0±0.1 Dimensions in mm Type SPM5012-LR Package quantity Soldering B 5.7 K 1.5 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating A 5.4 1000 pcs/reel Natural cooling Peak 260°C Temperature 230°C 230°C 180°C 10s max. 150°C 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210419 inductor_commercial_power_spm5012-lr_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210419 inductor_commercial_power_spm5012-lr_en.fm
SPM5012T-2R2M-LR 价格&库存
很抱歉,暂时无法提供与“SPM5012T-2R2M-LR”相匹配的价格&库存,您可以联系我们找货
SPM5012T-2R2M-LR
  • 1000+5.185721000+0.67174
  • 2000+4.890322000+0.63347
  • 3000+4.725543000+0.61213
  • 5000+4.526065000+0.58629
  • 7000+4.399417000+0.56988
  • 10000+4.3031910000+0.55742
库存:329
SPM5012T-2R2M-LR
  • 1+9.532061+1.23474
  • 10+7.8209910+1.01310
  • 100+6.42790100+0.83264
库存:329
