SPM5030T-2R2M
SPM5030T-2R2M
    TDK(东电化)
    IND-2P_5.2X5MM_SM
    功率电感 ±20% 4.9A 5030 2.2µH 5.20 x 5.00mm 3.00mm 21.3mΩ
SPM5030T-2R2M 数据手册
I N D U C T O R S Inductors for power circuits Wound metal SPM series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free SPM5030 type FEATURES Magnetic shield type wound inductor for power circuits using a metallic magnetic material. Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness. Low inductance variance in high-temperature environments with good DC superimposition characteristics. Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with core adhesive coils. Operating temperature range: –40 to +125 °C (including self-temperature rise) APPLICATION Note PCs, HDDs, servers, VRMs, compact power supply modules, other PART NUMBER CONSTRUCTION SPM 5030 T - Series name L×W×H dimensions 5.2×5.0×3.0 mm Packaging style R20 M Inductance (µH) Inductance tolerance CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current Isat (µH) Tolerance (kHz) (m )max. (m )typ. (A)typ. 0.20 ±20% 100 2.31 2.10 21.0 0.35 ±20% 100 4.29 3.90 14.9 0.47 ±20% 100 5.94 5.40 11.0 0.75 ±20% 100 9.35 8.50 9.7 1.0 ±20% 100 11.5 10.4 8.5 1.5 ±20% 100 18.5 16.8 6.1 2.2 ±20% 100 21.3 19.3 4.9 3.3 ±20% 100 29.5 26.8 4.3 4.7 ±20% 100 49.5 45.0 3.0  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (20% below the initial value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 22.2 16.6 14.0 11.3 10.1 8.0 6.1 6.0 4.7 SPM5030T-R20M SPM5030T-R35M SPM5030T-R47M SPM5030T-R75M SPM5030T-1R0M SPM5030T-1R5M SPM5030T-2R2M SPM5030T-3R3M SPM5030T-4R7M Measurement equipment Measurement item Product No. L 4284A DC resistance AX-111A Rated current Isat 4284A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies ADEX Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210512 inductor_commercial_power_spm5030_en.fm I N D U C T O R S SPM5030 type L FREQUENCY CHARACTERISTICS 20 18 16 4R7M Inductance (µH) 14 12 3R3M 10 8 2R2M 6 R20M R35M 1R5M 4 1R0M R70M 2 R47M 0 0.1 1 10 100 Frequency (MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 5 4.5 4 3.5 Inductance (µH) 4R7M 3 2.5 3R3M 2 2R2M 1.5 1R5M 1 1R0M R70M 0.5 0 R47M 0 5 10 15 DC current (A) R35M R20M 20 25 30 Measurement equipment Product No. Manufacturer 4284A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20210512 inductor_commercial_power_spm5030_en.fm I N D U C T O R S SPM5030 type SHAPE & DIMENSIONS PACKAGING STYLE 1.15±0.2 5.2±0.3 (2.9) 1.15±0.2 REEL DIMENSIONS 2.2+0.5/–0 1.2+0.2/–0.1 (0.15) 3.0max. ø59.3±0.5 2.0±0.2 5.0±0.3 R20 Dimensions in mm ø13.3±0.5 12.4±0.1 ø178±1.0 Dimensions in mm 1.5 +0.1 –0 0.4 4.0±0.1 Sprocket hole B 12.0±0.2 1.5 2.2 2.7 2.2 1.5 2.0±0.1 Dimensions in mm K 5.5±0.1 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS Cavity A 8.0±0.1 Dimensions in mm Type SPM5030 Package quantity Soldering Natural cooling Peak 260°C Temperature 230°C B 5.5 K 3.3 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating A 5.3 230°C 500 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –40 to +125 °C –40 to +125 °C 0.364 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 10s max. 150°C 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210512 inductor_commercial_power_spm5030_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210512 inductor_commercial_power_spm5030_en.fm
SPM5030T-2R2M
物料型号:SPM5030型
器件简介:这是一种用于电源电路的金属屏蔽型绕线电感,使用金属磁性材料制成。与铁氧体绕线电感相比,它能够实现大电流、低直流电阻和小型化。在高温环境下具有低电感变化率和良好的直流叠加特性。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:提供了不同型号的电感值、公差、测量频率、直流电阻、额定电流Isat(典型值)、Itemp(典型值)等参数。
功能详解:文档中未提供详细的功能解释,但强调了使用金属磁性材料和一体式模压线圈结构,相比使用核心粘合线圈的电感,其哼声更低。
应用信息:适用于个人电脑、硬盘驱动器、服务器、电压调节模块、紧凑型电源模块等。
封装信息:提供了SPM5030型的尺寸(长宽高)、卷带封装样式、推荐回流焊接曲线、包装数量等信息。
SPM5030T-2R2M 价格&库存
很抱歉,暂时无法提供与“SPM5030T-2R2M”相匹配的价格&库存,您可以联系我们找货
SPM5030T-2R2M
  • 500+6.39545500+0.82503
  • 1000+6.030651000+0.77797
  • 1500+5.827301500+0.75174
  • 2500+5.581002500+0.71997
  • 3500+5.424633500+0.69979
  • 5000+5.263825000+0.67905
库存:390
SPM5030T-2R2M
  • 1+11.062791+1.42713
  • 10+9.0866810+1.17221
  • 100+7.47455100+0.96424
库存:390
