SPM5030T-R47M-HZ
SPM5030T-R47M-HZ
    TDK(东电化)
    IND-2P_5.2X5MM_SM
    功率电感 ±20% 11A 470nH 5030 5.20 x 5.00mm 3.00mm 5.39mΩ
SPM5030T-R47M-HZ 数据手册
I N D U C T O R S Inductors for power circuits Wound metal SPM-HZ series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 SPM5030-HZ type FEATURES Magnetic shield type wound inductor for power circuits using a metallic magnetic material. Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness. Low inductance variance in high-temperature environments with good DC superimposition characteristics. –40 to 125°C (including self-temperature rise) Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with ferrite core adhesive coils. Compliant with AEC-Q200 APPLICATION Automotive-related equipment (Car navigation, car audio) PART NUMBER CONSTRUCTION SPM 5030 T R47 M HZ Series name L×W×H dimensions 5.2×5.0×3.0 mm Packaging style Inductance (µH) Inductance tolerance Internal code CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency Rated current DC resistance Isat (µH) Tolerance (kHz) (m )max. (m )typ. (A)typ. 0.47 ±20% 100 5.39 4.90 11.0 0.68 ±20% 100 7.37 6.70 8.9 1.0 ±20% 100 11.5 10.4 8.0 1.5 ±20% 100 18.5 16.8 6.8 2.2 ±20% 100 21.3 19.3 4.8 3.3 ±20% 100 29.5 26.8 4.3 4.7 ±20% 100 49.5 45.0 4.0 5.6 ±20% 100 73.9 67.1 3.6 6.8 ±20% 100 82.0 74.5 3.4 10.0 ±20% 100 159.0 144.5 2.6  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (20% below the initial value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 14.0 13.6 10.4 9.2 8.5 6.5 4.7 4.5 4.2 2.9 SPM5030T-R47M-HZ SPM5030T-R68M-HZ SPM5030T-1R0M-HZ SPM5030T-1R5M-HZ SPM5030T-2R2M-HZ SPM5030T-3R3M-HZ SPM5030T-4R7M-HZ SPM5030T-5R6M-HZ SPM5030T-6R8M-HZ SPM5030T-100M-HZ Measurement equipment Measurement item Product No. L 4284A DC resistance AX-111A Rated current Isat 4284A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies ADEX Keysight Technologies TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range –40 to +125 °C Storage temperature range –40 to +125 °C Individual weight 0.38 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210423 inductor_automotive_power_spm5030-hz_en.fm I N D U C T O R S SPM5030-HZ type L FREQUENCY CHARACTERISTICS 60 100M Inductance (µH) 50 40 30 6R8M 5R6M 20 4R7M R47M R68M 10 3R3M 2R2M 1R5M 0 0.1 1 1R0M 10 100 Frequency (MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 10 Inductance (µH) 8 100M 6 6R8M 5R6M 4 4R7M 2 3R3M 2R2M 0 0 5 1R5M 10 DC current (A) 1R0M R68M R47M 15 20 Measurement equipment Product No. Manufacturer 4284A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20210423 inductor_automotive_power_spm5030-hz_en.fm I N D U C T O R S SPM5030-HZ type SHAPE & DIMENSIONS PACKAGING STYLE 1.15±0.2 5.2±0.3 (2.9) REEL DIMENSIONS 1.15±0.2 2.2+0.5/–0 1.2+0.2/–0.1 (0.15) 3.0max. ø59.3±0.5 2.0±0.2 5.0±0.3 R47 Dimensions in mm ø13.3±0.5 12.4±0.1 ø178±1.0 Dimensions in mm 2.0±0.1 4.0±0.1 Sprocket hole 1.5 B 2.2 12.0±0.2 2.7 2.2 1.5 1.5 +0.1 –0 0.4 5.5±0.1 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS Dimensions in mm K Cavity A 8.0±0.1 Dimensions in mm Type SPM5030-HZ A 5.3 B 5.5 K 3.3 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating Soldering Package quantity 500 pcs/reel Natural cooling Peak 260°C Temperature 230°C 230°C 180°C 10s max. 150°C 120s 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210423 inductor_automotive_power_spm5030-hz_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. Do not use products that have received any excessive mechanical shock such as by being dropped. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Do not expose the products to magnets or magnetic fields. The performance of the product may deteriorate if coating materials are used, thus please assess the situation beforehand by taking this factor into consideration. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210423 inductor_automotive_power_spm5030-hz_en.fm
SPM5030T-R47M-HZ
1. 物料型号:SPM5030-HZ系列,包括不同型号如SPM5030T-R47M-HZ等。 2. 器件简介:该系列电感是用于电源电路的金属屏蔽型绕线电感,使用金属磁性材料制造,相比铁氧体绕线电感,能实现大电流、低直流电阻和小型化。 3. 引脚分配:文档中未明确提供引脚分配信息,但通常这类电感为表面贴装元件,具有端头或引脚用于连接。 4. 参数特性:电感值范围从0.47μH到10.0μH,公差为±20%,测量频率为100kHz,直流电阻和额定电流值随型号而变化。 5. 功能详解:电感在高温环境下具有低电感变化,良好的直流叠加特性,工作温度范围为-40至125°C,包括自温升。使用金属磁性材料,结构为整体模塑线圈,因此哼声低于使用铁氧体芯粘合线圈的产品。 6. 应用信息:适用于汽车相关设备,如车载导航、汽车音响等。 7. 封装信息:电感的尺寸为5.2×5.0×3.0 mm,采用卷带包装,每卷500件。
SPM5030T-R47M-HZ 价格&库存
很抱歉,暂时无法提供与“SPM5030T-R47M-HZ”相匹配的价格&库存,您可以联系我们找货
SPM5030T-R47M-HZ
  • 500+7.51264500+0.97662
  • 1000+7.084341000+0.92094
  • 1500+6.845541500+0.88990
  • 2500+6.556362500+0.85231
  • 3500+6.372803500+0.82845
  • 5000+6.183995000+0.80390
库存:978
SPM5030T-R47M-HZ
  • 1+1.90300
  • 50+1.46300
  • 500+1.35300
库存:861
SPM5030T-R47M-HZ
    库存:1000
    SPM5030T-R47M-HZ
    • 1+2.60810
    • 10+2.20970
    • 30+1.94890
    • 100+1.71780
    • 500+1.55610
    • 1000+1.45800
    库存:1870
    SPM5030T-R47M-HZ
    • 1+13.140321+1.70820
    • 10+10.7778310+1.40109
    • 25+9.9738425+1.29657
    • 50+9.4023750+1.22228
    • 100+8.86513100+1.15244
    • 250+8.20165250+1.06619
    库存:978
