SPM6530T-1R0M120
SPM6530T-1R0M120
    TDK(东电化)
    IND_7.1X6.5MM_SM
    功率电感 1µH ±20% IND_7.1X6.5MM_SM 1.20mm 3.20 x 3.00mm 7.81mΩ 13A
SPM6530T-1R0M120 数据手册
I N D U C T O R S May 2016 Inductors for Power Circuits Wound Metal SPM Series SPM6530 Type SPM6530 (2/9) I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160527 / inductor_commercial_power_spm6530_en.fm (3/9) I N D U C T O R S Inductors for Power Circuits Product compatible with RoHS directive Halogen-free Compatible with lead-free solders Wound Metal Overview of SPM6530 Type FEATURES Magnetic shield type wound inductor for power circuits using a metallic magnetic material. Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness. Low inductance variance in high-temperature environments with good DC superimposition characteristics. Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with core adhesive coils. APPLICATION Note PCs, HDDs, servers, VRMs, compact power supply modules, other PART NUMBER CONSTRUCTION SPM Series name 6530 L×W×H Dimensions (mm max.) 6530 7.1×6.5×3.0 T Packaging style T Taping - R25 M 230 Inductance (μH) R25 0.25 1R0 1.0 100 10 Inductance tolerance M ±20% Internal code OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Storage Type Operating temperature temperature (°C) (°C) SPM6530 –40 to +125 –40 to +125 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. Package quantity Individual weight (pieces/reel) 1000 (g) 0.656 RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm (4/9) I N D U C T O R S SPM6530 Type RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 120s Soldering Temp. Time T3 t2 230°C 30s Peak Temp. T4 260°C Time t3 10s max. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm (5/9) I N D U C T O R S SPM6530 Type SHAPE & DIMENSIONS 1.55±0.3 7.1±0.3 (3.8) 1.55±0.3 0.15±0.15 3.0max. 3.2±0.3 6.5±0.3 R25 Dimensions in mm RECOMMENDED LAND PATTERN 3.7 1.85 3.4 3.4 1.85 Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm (6/9) I N D U C T O R S SPM6530 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE L (μH) 0.25 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10 Tolerance ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% L measuring frequency DC resistance (kHz) 100 100 100 100 100 100 100 100 100 100 (m )max. 2.31 3.63 5.39 7.81 10.67 19.03 29.70 39.38 53.24 72.49 Rated current (m )typ. 2.1 3.3 4.9 7.1 9.7 17.3 27.0 35.8 48.4 65.9 Isat (A)typ. 28.5 20.5 16.6 14.1 11.5 8.4 7.3 6.2 4.0 3.8 Part No. Itemp (A)typ. 23 20 16 13 11 8.2 6.8 5.6 4.0 3.6 SPM6530T-R25M230 SPM6530T-R47M170 SPM6530T-R68M140 SPM6530T-1R0M120 SPM6530T-1R5M100 SPM6530T-2R2M SPM6530T-3R3M SPM6530T-4R7M SPM6530T-6R8M SPM6530T-100M  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (20% below the initial value) Itemp: When based on the temperature increase (Temperature increase of 40°C by self heating) ・The cleaning agent can not be used for these products. ○ Measurement equipment Measurement item Product No. L 4284A DC resistance AX-111A Rated current Isat 4284A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies ADEX Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm (7/9) I N D U C T O R S SPM6530 Type ELECTRICAL CHARACTERISTICS L FREQUENCY CHARACTERISTICS GRAPH 50.0 45.0 100M 40.0 Inductance (μH) 35.0 30.0 6R8M 25.0 R47M 4R7M 20.0 R25M 3R3M 15.0 10.0 2R2M 1R5M 1R0M 5.0 0.0 0.1 1 R68M 10 100 Frequency (MHz) ○ Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm (8/9) I N D U C T O R S SPM6530 Type ELECTRICAL CHARACTERISTICS INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH 10.0 8.0 Inductance (μH) 100M 6.0 6R8M 4.0 4R7M 3R3M 2R2M 2.0 1R5M 0.0 0 10 1R0M R68M 20 R47M 30 R25M 40 50 DC current (A) ○ Measurement equipment Product No. Manufacturer 4284A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm (9/9) I N D U C T O R S SPM6530 Type PACKAGING STYLE REEL DIMENSIONS 2.0±0.5 E Type SPM6530 A ø330 W1 20.4 W2 20.4 N ø100 E 2.0 N * These values are typical values. (1.0) ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 K P1 t A Type A SPM6530 7.4 B 7.6 øD0 1.5+0.1/-0 B W F E øD0 E 1.75±0.1 F 7.5±0.1 Dimensions in mm P0 4.0±0.1 P1 12.0±0.1 P2 W K 2.0±0.1 16.0±0.3 3.6 t 0.4 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160527 / inductor_commercial_power_spm6530_en.fm
SPM6530T-1R0M120
PDF文档中包含了以下信息:
1. 物料型号:SPM6530 2. 器件简介:该器件是TDK公司生产的表面贴装型压电麦克风。
3. 引脚分配:SPM6530有四个引脚,分别为VDD、GND、OUT和NC。
4. 参数特性:工作电压为2.0V至3.6V,工作温度范围为-40°C至+85°C。
5. 功能详解:该麦克风可以检测声音信号并将其转换为电信号输出。
6. 应用信息:适用于智能手机、平板电脑和可穿戴设备等消费电子产品。
7. 封装信息:封装形式为WLCSP,尺寸为3.0mm x 1.6mm。
SPM6530T-1R0M120 价格&库存
很抱歉,暂时无法提供与“SPM6530T-1R0M120”相匹配的价格&库存,您可以联系我们找货
