I
N
D
U
C
T
O
R
S
May 2016
Inductors for Power Circuits
Wound Metal
SPM Series
SPM6530 Type
SPM6530
(2/9)
I
N
D
U
C
T
O
R
S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20160527 / inductor_commercial_power_spm6530_en.fm
(3/9)
I
N
D
U
C
T
O
R
S
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
Wound Metal
Overview of SPM6530 Type
FEATURES
Magnetic shield type wound inductor for power circuits using a metallic magnetic material.
Compared to ferrite wound type inductors, it is possible to achieve large current, low Rdc, and compactness.
Low inductance variance in high-temperature environments with good DC superimposition characteristics.
Metallic magnetic material is used, and the structure has an integrated molded coil, so hum noise is lower than with core adhesive coils.
APPLICATION
Note PCs, HDDs, servers, VRMs, compact power supply modules, other
PART NUMBER CONSTRUCTION
SPM
Series name
6530
L×W×H Dimensions
(mm max.)
6530
7.1×6.5×3.0
T
Packaging style
T
Taping
R25
M
230
Inductance
(μH)
R25
0.25
1R0
1.0
100
10
Inductance
tolerance
M
±20%
Internal
code
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Storage
Type
Operating temperature
temperature
(°C)
(°C)
SPM6530
–40 to +125
–40 to +125
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
Package quantity
Individual weight
(pieces/reel)
1000
(g)
0.656
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
I
N
D
U
C
T
O
R
S
SPM6530 Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
120s
Soldering
Temp.
Time
T3
t2
230°C
30s
Peak
Temp.
T4
260°C
Time
t3
10s max.
(5/9)
I
N
D
U
C
T
O
R
S
SPM6530 Type
SHAPE & DIMENSIONS
1.55±0.3
7.1±0.3
(3.8)
1.55±0.3
0.15±0.15
3.0max.
3.2±0.3
6.5±0.3
R25
Dimensions in mm
RECOMMENDED LAND PATTERN
3.7
1.85
3.4
3.4
1.85
Dimensions in mm
(6/9)
I
N
D
U
C
T
O
R
S
SPM6530 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
(μH)
0.25
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
10
Tolerance
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
L measuring
frequency
DC resistance
(kHz)
100
100
100
100
100
100
100
100
100
100
(m )max.
2.31
3.63
5.39
7.81
10.67
19.03
29.70
39.38
53.24
72.49
Rated current
(m )typ.
2.1
3.3
4.9
7.1
9.7
17.3
27.0
35.8
48.4
65.9
Isat
(A)typ.
28.5
20.5
16.6
14.1
11.5
8.4
7.3
6.2
4.0
3.8
Part No.
Itemp
(A)typ.
23
13
11
8.2
6.8
5.6
4.0
3.6
SPM6530T-R25M230
SPM6530T-R47M170
SPM6530T-R68M140
SPM6530T-1R0M120
SPM6530T-1R5M100
SPM6530T-2R2M
SPM6530T-3R3M
SPM6530T-4R7M
SPM6530T-6R8M
SPM6530T-100M
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (20% below the initial value)
Itemp: When based on the temperature increase (Temperature increase of 40°C by self heating)
・The cleaning agent can not be used for these products.
○ Measurement equipment
Measurement item
Product No.
L
4284A
DC resistance
AX-111A
Rated current Isat
4284A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
ADEX
(7/9)
I
N
D
U
C
T
O
R
S
SPM6530 Type
L FREQUENCY CHARACTERISTICS GRAPH
50.0
45.0
100M
40.0
Inductance (μH)
35.0
30.0
6R8M
25.0
R47M
4R7M
20.0
R25M
3R3M
15.0
10.0
2R2M
1R5M
1R0M
5.0
0.0
0.1
1
R68M
10
100
Frequency (MHz)
Product No.
Manufacturer
4294A
(8/9)
I
N
D
U
C
T
O
R
S
SPM6530 Type
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
10.0
8.0
Inductance (μH)
100M
6.0
6R8M
4.0
4R7M
3R3M
2R2M
2.0
1R5M
0.0
1R0M
R68M
R47M
30
R25M
40
50
DC current (A)
Product No.
Manufacturer
4284A+42841A+42842C
(9/9)
I
N
D
U
C
T
O
R
S
SPM6530 Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
Type
SPM6530
A
ø330
W1
20.4
W2
20.4
N
ø100
E
2.0
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
Type
A
SPM6530 7.4
B
7.6
øD0
1.5+0.1/-0
B
W
F
E
øD0
E
1.75±0.1
F
7.5±0.1
Dimensions in mm
P0
4.0±0.1
P1
12.0±0.1
P2
W
K
2.0±0.1 16.0±0.3 3.6
t
0.4
很抱歉,暂时无法提供与“SPM6530T-6R8M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.17840
- 100+1.29950
- 500+0.90960
- 1000+0.64970
- 2000+0.61720
- 10000+0.57170
- 国内价格
- 5+1.17807
- 50+0.94878
- 150+0.85050
- 1000+0.72782
- 国内价格
- 5+1.06898
- 50+0.86093
- 200+0.77175
- 400+0.76017
- 1000+0.66042
