SPM6545VT-470M-D
SPM6545VT-470M-D
    TDK(东电化)
    IND_7X6.5MM_SM
    固定电感器 Nonstandard 47µH ±20% 2.1A 229mΩ
SPM6545VT-470M-D 数据手册
I N D U C T O R S Inductors for power circuits Wound metal SPM-VT-D series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 SPM6545VT-D type FEATURES Metal composite type wound inductor for power circuits using a metallic magnetic material. Compared to ferrite wound type inductors, low Rdc and miniaturization can be realized due to superior DC superimposition characteristics of metallic magnetic materials. Vibration resistance of 30 G due to vibration resistance structure Operating temperature range: –55 to +155°C (including self-temperature rise) Compliant with AEC-Q200 APPLICATION Automotive-related equipment (LED, ECM, ADAS, BCM etc.) PART NUMBER CONSTRUCTION SPM6545VT - Series name 4R7 M Inductance (µH) Inductance tolerance - D Internal code CHARACTERISTICS SPECIFICATION TABLE L (µH) Tolerance Measuring frequency DC resistance (kHz) (m )typ. Part No. Tolerance Isat (A)typ. (L=–20%) (L=–30%) 1.0 ±20% 100 5.6 ±10% 17.9 23.9 4.7 ±20% 100 22.0 ±10% 10.9 14.8 10 ±20% 100 52.3 ±10% 7.1 9.6 15 ±20% 100 72.0 ±10% 4.6 6.2 22 ±20% 100 94.6 ±10% 3.9 5.2 33 ±20% 100 132 ±10% 3.2 4.4 68 ±20% 100 340 ±10% 2.9 3.9 Isat: Based on the rate of change from the initial value of the inductance with DC current Itemp: Based on self-temperature rise due to DC current (rated current) Itemp (A)typ. (T=40deg.C) 13.3 6.7 4.3 3.7 3.2 2.7 1.7 SPM6545VT-1R0M-D SPM6545VT-4R7M-D SPM6545VT-100M-D SPM6545VT-150M-D SPM6545VT-220M-D SPM6545VT-330M-D SPM6545VT-680M-D Measurement equipment Measurement item Product No. L 4285A DC resistance 3541 * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies HIOKI Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20190912 inductor_automotive_power_spm6545vt-d_en.fm I N D U C T O R S SPM6545VT-D type L FREQUENCY CHARACTERISTICS 1000 Inductance(µH) 100 680 330 220 150 10 100 4R7 1 0.1 1R0 1 10 100 1000 10000 100000 Frequency(kHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. L VS. DC BIAS CHARACTERISTICS 100 680 330 Inductance(µH) 220 10 150 100 4R7 1 1R0 0.1 0 10 20 DCcurrent(A) 30 40 Measurement equipment Product No. Manufacturer 4284A+42841A Keysight Technologie * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20190912 inductor_automotive_power_spm6545vt-d_en.fm I N D U C T O R S SPM6545VT-D type SHAPE & DIMENSIONS 7.0±0.4 PACKAGING STYLE REEL DIMENSIONS 1.5±0.2 2.0 4.5max. ø100 6.5±0.4 3.0±0.2 2.0±0.5 (1.0) Dimensions in mm ø13.0±0.5 17.5 ø21.0±0.8 21.5 ø330 Dimensions in mm 1.5 +0.1 –0 4.0±0.1 Sprocket hole 16.0±0.3 2.0±0.1 B 3.3 0.4 7.5±0.1 RECOMMENDED LAND PATTERN 1.75±0.1 TAPE DIMENSIONS 3.6 8.2 Cavity K A Dimensions in mm 12.0±0.1 Dimensions in mm Type SPM6545VT-D A 6.85 B 7.35 K 5.1 PACKAGE QUANTITY RECOMMENDED REFLOW PROFILE Preheating Soldering Package quantity Natural cooling Peak 245°C Temperature 230°C 230°C 1000 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –55 to +155 °C –55 to +155 °C 1.0 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 180°C 150°C 60 to 120s 10 to 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20190912 inductor_automotive_power_spm6545vt-d_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. Do not use products that have received any excessive mechanical shock such as by being dropped. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Do not expose the products to magnets or magnetic fields. The performance of the product may deteriorate if coating materials are used, thus please assess the situation beforehand by taking this factor into consideration. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20190912 inductor_automotive_power_spm6545vt-d_en.fm
SPM6545VT-470M-D 价格&库存
很抱歉,暂时无法提供与“SPM6545VT-470M-D”相匹配的价格&库存,您可以联系我们找货
SPM6545VT-470M-D
    • 1+6.83640
    • 10+5.56200
    • 30+4.91400
    • 100+4.10400
    • 500+3.72600
    • 1000+3.53160
    库存:3933
    SPM6545VT-470M-D
    • 1+10.217701+1.32574
    • 10+8.3787310+1.08714
    • 25+7.7535225+1.00602
    • 50+7.3094450+0.94840
    • 100+6.89178100+0.89421
    • 250+6.37619250+0.82731
    • 500+6.01212500+0.78007
    库存:4113
    SPM6545VT-470M-D
    • 1+10.132471+1.31468
    • 10+8.2998910+1.07691
    • 100+6.82658100+0.88575
    库存:4113
    SPM6545VT-470M-D
    • 1000+5.507181000+0.71456
    • 2000+5.193532000+0.67386
    • 3000+5.018543000+0.65115
    • 5000+4.806735000+0.62367
    • 7000+4.672317000+0.60623
    • 10000+4.6014410000+0.59704
    库存:4113
