SPMXX20-LR-KIT
SPMXX20-LR-KIT
    TDK(东电化)
    固定 工具箱 140 件(14 个值 - 每个值 10 件) 表面贴装型
SPMXX20-LR-KIT 数据手册
  SPMXX20‐LR‐KIT Power Inductor Sample Kit  Contains case sizes: 3, 4, & 5mm with component height of 2.0mm max.  Wirewound Metal Inductors for Power Circuit Applica ons  Metal Core  TDK’s SPM‐LR series power inductors are magne cally shielded, wire wound  Wire Wound inductors designed for use in power circuits. Their low‐profile makes them ideal for  Shielded  use in applica ons where height is restricted. The SPM‐LR series has low inductance  variance in high‐temperature environments with good DC superimposi on characteris cs, and achieves  large current, low Rdc, and compactness compared to ferrite wound type inductors. A metallic magne c  material is used, and the structure has an integrated molded coil, so hum noise is lower with the SPM‐LR  series inductors than with core adhesive coils. The SPM‐LR series also has a redesigned terminal  construc on, based mainly on material change, and has a DCR improvement anywhere from 4‐50%, depending on case  size and inductance value, as compared with previous SPM series.  Features   Magne cally shielded, wire wound metal inductor   Low‐profile   Large current and low Rdc compared to ferrite wound type inductors   Low inductance variance in high‐temperature environments with good DC superimposi on characteris cs   Opera ng and storage temperature range of –40 to +125°C    Applica ons   Tablet terminals, laptop computers, HDDs, servers, VRMs, compact power supply modules, etc.  Sample Kit Informa on  Size  Thickness  Inductance  Satura on Current  [mm]  [mm] Max.  [µH] ±20%  [A] Max.  0.47 to 4.7µH   9.0 to 2.9A  0.47  to 10µH  14.1 to 2.3A  1.0 to 10µH  14.0 to 3.4A  Series  SPM3020‐LR  3.2 x 3.0  SPM4020‐LR  4.4 x 4.1  SPM5020‐LR  5.4 x 5.1  2.0  Kit contains 70 pieces total—5 pieces each of 14 values  Digi‐Key Part Number:  SPMXX20‐LR‐KIT‐ND  Rev. March 2018    SPMXX20‐LR‐KIT Power Inductor Sample Kit  Contains case sizes: 3, 4, & 5mm with component height of 2.0mm max.  Wire Wound Inductors for Power Circuit Applica ons  Digi‐Key Part Number  SPMXX20‐LR‐KIT‐ND  TDK Part Number  Part Number Descrip on  SPM3020T‐R47M‐LR  3x3x2.0, Inductor, 0.47uH, 20%  SPM3020T‐1R0M‐LR  3x3x2.0, Inductor, 1.0uH, 20%  SPM3020T‐3R3M‐LR  3x3x2.0, Inductor, 3.3uH, 20%  SPM3020T‐4R7M‐LR  3x3x2.0, Inductor, 4.7uH, 20%  SPM4020T‐1R0M‐LR  4x4x2.0, Inductor, 1.0uH, 20%  SPM4020T‐2R2M‐LR  4x4x2.0, Inductor, 2.2uH, 20%  SPM4020T‐3R3M‐LR  4x4x2.0, Inductor, 3.3uH, 20%  SPM4020T‐4R7M‐LR  4x4x2.0, Inductor, 4.7uH, 20%  SPM4020T‐6R8M‐LR  4x4x2.0, Inductor, 6.8uH, 20%  SPM5020T‐1R0M‐LR  5x5x2.0, Inductor, 1.0uH, 20%  SPM5020T‐1R5M‐LR  5x5x2.0, Inductor, 1.5uH, 20%  SPM5020T‐3R3M‐LR  5x5x2.0, Inductor, 3.3uH, 20%  SPM5020T‐4R7M‐LR  5x5x2.0, Inductor, 4.7uH, 20%  SPM5020T‐100M‐LR  5x5x2.0, Inductor, 10uH, 20%  Rev. March 2018
SPMXX20-LR-KIT 价格&库存
很抱歉,暂时无法提供与“SPMXX20-LR-KIT”相匹配的价格&库存,您可以联系我们找货
