E M C
C o m p o n e n t s
Common mode filters
Ultra high-speed differential signal line (HDMI, DVI, DisplayPort, USB3.0, etc.)
TCM-S series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
TCM0403S type
FEATURES
This product is a thin-film common mode filter with a wide frequency range that can be used for high-speed differential signal interfaces
such as USB3.0 and DisplayPort.
Has EMC suppression by achieving wide frequency range (6GHz and higher) differential mode transmission while ensuring common
mode impedance with virtually no affect on the high-speed differential transmission line signal.
Lineup includes 0403 (L0.45×W0.30×T0.23mm), the industry's smallest thin-film common mode filter.
Operating temperature range: –25 to +85°C
APPLICATION
Noise countermeasure for ultra-high-speed differential interfaces (HDMI, DVI, DisplayPort, USB3.0, etc.) for mobile devices and general
consumer products such as smart phones, tablets, digital cameras, and portable music players.
Application guides: Smart phones/tablets
PART NUMBER CONSTRUCTION
TCM
0403
S
Series name
L×W×T dimensions
0.45×0.3×0.23 mm
Product
internal code
350
Impedance
() at 100MHz
2P
Number of
lines
T
210
Packaging style
Internal
code
CHARACTERISTICS SPECIFICATION TABLE
Common mode
impedance
[at 100MHz]
Tolerance
35
±12
DC resistance
[1 line]
( )max.
3.0±30%
Cutoff
frequency
Rated current
Rated voltage
Insulation
resistance
(GHz)typ.
7.0
(A)max.
0.05
(V)max.
5
(M )min.
10
Part No.
TCM0403S-350-2P-T210
Measurement equipment
Measurement item
Product No.
Common mode impedance
4291A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20181101
cmf_commercial_signal_tcm0403s_en.fm
E M C
C o m p o n e n t s
TCM0403S type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
Impedance (Ω)
1000
350 Common mode
100
350 Differential mode
10
1
1
10
100
Frequency (MHz)
1000
10000
Product No.
Manufacturer
4991A
INSERTION LOSS VS. FREQUENCY CHARACTERISTICS
5
Insertion loss (dB)
10
350 Common mode
15
30
35
40
1
10
100
Frequency (MHz)
1000
10000
Product No.
Manufacturer
E5071B
(2/4)
20181101
E M C
C o m p o n e n t s
TCM0403S type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
0.30±0.02
4
2
3
E
2.0±0.5
0.325
+1
ø60 –0
0.125±0.03
0.23±0.02
0.08typ.
0.45±0.02
1
1.0
9+0.3
ø13±0.2
0.075±0.03
ø21±0.8
Dimensions in mm
13+1.4
+0
ø180 –3
Dimensions in mm
RECOMMENDED LAND PATTERN
3
Sprocket
hole
1.5 +0.1
–0.0
2.0±0.5
4.0±0.1
8.0±0.3
B
0.60
3.5±0.05
2
0.20
4
0.20
1
1.75±0.1
TAPE DIMENSIONS
0.45
0.15
0.15
Dimensions in mm
A
K
Cavity
2.0±0.5
CIRCUIT DIAGRAM
1
4
2
3
Type
TCM0403S
160min.
A
0.40
Taping
Dimensions in mm
B
0.55
K
0.27
200min.
• No polarity
300min.
Drawing direction
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Dimensions in mm
Natural
cooling
PACKAGE QUANTITY
Package quantity
Peak
10,000 pcs/reel
245°C
Temperature
230°C
230°C
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Storage
temperature range
temperature range
–25 to +85 °C
–25 to +85 °C
The storage temperature range is for after the assembly.
180°C
Individual
weight
0.2 mg
5s max.
150°C
60 to 120s
10 to 30s
Time
(3/4)
20181101
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 70% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20181101
很抱歉,暂时无法提供与“TCM0403S-350-2P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+2.5979710000+0.33768
- 20000+2.4791920000+0.32224
- 国内价格 香港价格
- 1+5.742471+0.74638
- 10+4.7135210+0.61265
- 25+4.3604325+0.56675
- 50+4.1115250+0.53440
- 100+3.87574100+0.50376
- 250+3.58539250+0.46602
- 500+3.38061500+0.43940
- 1000+3.187571000+0.41431
- 2500+3.034542500+0.39442
