TCM2010H-900-4P
TCM2010H-900-4P
    TDK(东电化)
    CMC 100MA 4LN 90 OHM SMD
TCM2010H-900-4P 数据手册
(1/2) Common Mode Filters(SMD) For HDMI/S-ATA Conformity to RoHS Directive TCM Series TCM2010H Type FEATURES • TCM2010H is thin film common mode filter array type developed for high speed differential signal interfaces, such as HDMITM, SATA. • TCM2010H is the product which constructed with two circuits in a small one chip of L2.0× W1.0mm. • TCM2010H suppress the radiated emission without the distortion of differential signal. • The cut-off frequency of TCM2010H for differential signal mode is 6GHz, so this couldn’t interfere higher-speed differential signals such as HDMITM, S-ATA. PRODUCT IDENTIFICATION TCM (1) 2010 (2) H - 900 - 4P - T (3) (4) (5) (6) (7) (1) Series name (2) Dimensions L× W (3) Product identification number (4) Impedance[at 100MHz] 900: 90Ω (5) Number of line 4P: 4-line (6) Packaging style T: ø180mm reel taping (7) TDK internal code APPLICATIONS HDMITM, S-ATA etc. TEMPERATURE RANGE Operating –25 to +85°C PACKAGING STYLE AND QUANTITIES Packaging style Taping Quantity 4000 pieces/reel 6 5 1 2 3 4 8 7 6 5 1 2 3 4 0.6 7 0.2±0.15 8 0.8±0.1 1.0±0.15 2.0±0.15 0.5±0.1 ・No polarity 0.5 1.8 SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM/RECOMMENDED PC BOARD PATTERN 0.25 Dimensions in mm Weight: 8mg 0.25±0.15 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TCM2010H-900-2P Common mode impedance (Ω) [at 100MHz] 90±25 Cut-off frequency (GHz) 6typ. DC resistance (Ω)max. [1 line] 1 Rated current Idc (mA)max. 100 Rated voltage Edc (V)max. 10 Insulation resistance (MΩ)min. 10 • HDMI™ is trademark of HDMI Licensing, LLC. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20080716 / e9712_tcm2010h.fm (2/2) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 10000 Impedance(Ω) 1000 Common mode 100 Differential mode 10 1 1 10 100 Frequency (MHz) 1000 10000 INSERTION LOSS vs. FREQUENCY CHARACTERISTICS DIFFERENTIAL MODE COMMON MODE 0 0 –5 –10 Scc21(dB) Sdd21(dB) –5 –10 –15 –20 –25 –30 –15 –35 –20 1 10 100 Frequency(MHz) 1000 10000 –40 1 10 100 Frequency(MHz) 1000 10000 • All specifications are subject to change without notice. 001-02 / 20080716 / e9712_tcm2010h.fm
TCM2010H-900-4P 价格&库存
很抱歉,暂时无法提供与“TCM2010H-900-4P”相匹配的价格&库存,您可以联系我们找货
TCM2010H-900-4P
  • 4000+4.965494000+0.64321
