TF2514VU-102Y2R0-01
TF2514VU-102Y2R0-01
    TDK(东电化)
    TF2514VU-102Y2R0-01
TF2514VU-102Y2R0-01 数据手册
(1/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TDK common mode choke coils(line filters) are used in a wide range of prevention of electromagnetic interference(EMI) and radio frequency interference(RFI) from power supply lines and for prevention of multifunctioning of products such as measuring equipment and system equipment. RATINGS Item Rated voltage Eac(V) Dielectric withstanding voltage Eac(V) Insulation resistance Edc(MΩ) Temperature rise(°C) Operating temperature range(°C) Safety standard Standard value 80 to 280 Conditions Between each winding for 1 minute Between each winding for 100min. 1 minute, Edc 500V With line resistance, each ∗ 45max. line Including self-temperature –20 to +120 rise Japan Electric/Electronic Products Control Law, UL, CSA and IEC conforted(The safety standard is not acquired with the unit only.) 2000 PRODUCT IDENTIFICATION UF V – Y (1) (2) (3) (4) (5) R (6) – 01 (7) (1)Core shape UF: U-type core TF: Toroidal core HF: Square shaped closed magnetic circuit core type Double-square shaped closed magnetic circuit core type (2)Dimensional code(Length×Height) (3)External shape code (4)TDK’s internal code (5)Inductance value Example) 602: 60µH×102=6mH (6)Rated current value Example) 2R5: 2.5A (7)Product management number ∗ Except particular items. • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent) FEATURES • Wide range of selection. • High impedance at applicable frequency. • High self-resonant frequency. SELECTION CHART Series Configuration Horizontal types (Toroidal core) TF Vertical types (Toroidal core) With nano crystallization alloy magnetically soft material(Toroidal core) Multi-section case types (For high frequency) TF1028S TF4825S TF6029S TF2320HU TF2514HU TF2519HU TF3424HU TF4930HU TF1815HU TF4131HU TF6136HU TF1320S TF2528S TF3233S TF1713VU TF1714VU TF2420VU TF2514VU TF3423VU TF4725VU TF1821VU TF2326VU TF2527VU TF3435VU TF2326VU-M TF3435VU-M TF4930HU-M TF6337HU-M Inductance value min. 0.45 to 2.2mH 1, 2mH 1mH 1 to 5mH 0.1mH 1 to 5mH 0.3 to 8mH 1 to 10mH 3 to 10mH 0.7 to 3mH 1, 2mH 1 to 4mH 0.45 to 7mH 0.25 to 10mH 1, 2mH 1 to 15mH 1 to 8mH 0.13 to 12mH 0.5 to 10mH 2 to 10mH 2 to 10mH 1 to 3mH 1 to 3mH 0.3 to 10mH 3 to 10mH 8 to 33mH 6 to 40mH 4 to 10mH Rated current (A) 0.5 to 3 10 to 15 20 to 30 2 to 5 5 to 7 2 to 5 4 to 20 6 to 20 0.3 to 2 10 to 18 15 to 30 1.5 to 3 2.5 to 10 3 to 20 1 to 3 1 to 3 2 to 6 2 to 7 4 to 20 6 to 15 0.3 to 2 2 to 6 2 to 6 4 to 20 3 to 6 4 to 10 6 to 15 15 to 30 Handling power∗ L×I2(mH×A2) 2.5 200 400 25 4.9 25 120 400 12 226.8 900 9 50 130 8 9 36 6.4 200 225 8 36 36 120 170 800 1350 3600 Weight (g)typ. 8 95 205 18 18 16 42 87 6 76 172 6.5 19.5 41 4 6 18 8 45 85 7 19 20 40 20 38 99.8 204.9 Minimum package quantity (pieces/box) 900 120 70 300 300 300 250 120 600 150 75 1000 840 320 2000 2000 800 800 400 90 800 800 800 400 800 400 120 75 TF3329B 8.5 to 15mH 2.5 to 3.5 100 40.5 375 Type • All specifications are subject to change without notice. (2/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type SELECTION CHART Inductance value Rated current Handling power∗ min. (A) L×I2(mH×A2) TF1707VU 20, 100µH 2 to 3 0.9 20, 100µH 2 to 3 0.9 Vertical types(Toroidal core) TF1709VU (For high frequency) TF2326VU-H 30, 50µH 4 to 5 0.75 TF3435VU-H 30 to 60µH 8 to 15 6.75 TF6030T 1 to 7.5mH 5 to 14 160 TF TF6035T 0.2 to 1.6mH 15 to 30 400 TF3524TU 1 to 5mH 3 to 5 50 For three phase TF4333TU 0.5 to 5mH 5 to 15 112.5 lines(Toroidal core) TF5228TU 1 to 5mH 5 to 10 200 TF6332TU 0.5 to 2mH 15 to 25 312.5 TF6340TU 1 to 3mH 10 to 25 625 ∗ Handling power=(Inductance value)×(Current)2. It is possible to design within the range below this value. [Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10. Series Configuration Type Weight (g)typ. 2.5 3.2 19.7 35.8 150 160 40 95.1 109.7 212.1 258.4 Minimum package quantity (pieces/box) 2000 3000 800 400 70 70 200 120 90 75 75 THE LINE-UP OF TDK LINE FILTER Rated current (A) Inductance(mH) 0.1 to 1 1 to 2 2 to 5 5 to 10 10 to 20 1.5 TF2528 2.0 TF2528 TF3233 TF2528 TF3233 TF6035T(Three phase lines) TF4930 TF4930 TF6337 3.0 5.0 10.0 TF2528 TF3233 TF6035T(Three phase lines) 15.0 TF3233 TF6035T(Three phase lines) TF4930 20.0 TF6035T(Three phase lines) TF4930 25.0 TF6035T(Three phase lines) 30.0 TF6035T(Three phase lines) · Classification by application TF6337 TF6337 Displays for TV set and computer Air conditioners(Outdoor machine), microwave ovens Industrial devices, control devices, etc. • All specifications are subject to change without notice. 20 to 40 40min. (3/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type HORIZONAL TYPE TF SERIES FEATURES • This series uses a high permeability toroidal ferrite core and therefore provides large inductance with a little number of turns. • Therefore its stray capacity is small and it keeps the impedance required to effectively suppress high frequency noises. • Products mounted on a base with fixed leads are easy to insert to circuit boards. TF1028S(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1 3 10 4 Impedance (kΩ) 26max. 2 10±0.5 25±0.5 ød 12max. 5±1 29max. 4 1 L1 2 L2 3 1 TF1028S-222Y0R5-01 TF1028S-801Y2R0-01 0.1 Weight: 8g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 0.01 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF1028S-222Y0R5-01 TF1028S-162Y1R3-01 TF1028S-102Y1R5-01 TF1028S-801Y2R0-01 TF1028S-451Y3R0-01 2.2 1.6 1 0.8 0.45 L1-L2 inductance difference (µH)max. 50 50 50 50 50 • All specifications are subject to change without notice. DC resistance (Ω)max. 0.2 0.2 0.1 0.1 0.06 Rated current Iac (A)max. 0.5 1.3 1.5 2 3 Dimensions(mm) ød 0.4 0.4 0.45 0.5 0.6 100 (4/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF4825S(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (35) 2 1 ø4.5 Impedance (kΩ) (15) 10 4 3 ø50max. TF4825S-202Y10R0-01 TF4825S-102Y15R0-01 H max. 0.1 4 1 L1 5±2 1 ød L2 3 2 0.01 0.01 0.1 Weight: 95g typ. Recommended hole diameter: ød+0.4 Dimensions in mm 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF4825S-202Y10R0-01 TF4825S-102Y15R0-01 2 1 L1-L2 inductance difference (µH)max. 50 50 DC resistance (mΩ)max. 20 7.5 TF6029S(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM Rated current Iac (A)max. 10 15 ød H max. 1.3 1.8 28 31 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (50) ø6 10 TF6029S-102Y20R0-01 1 3 Impedance (kΩ) (20) 2 4 ø64max. 1 TF6029S-102Y30R0-02 0.1 H max. 5±2 Dimensions(mm) L1 ød 0.01 4 1 0.01 L2 0.1 1 Frequency (MHz) 10 3 2 Weight: 205g typ. Recommended hole diameter: ød+0.5 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF6029S-102Y20R0-01 TF6029S-102Y30R0-02 1 1 L1-L2 inductance difference (µH)max. 50 50 • All specifications are subject to change without notice. DC resistance (mΩ)max. 5 4 Rated current Iac (A)max. 20 30 Dimensions(mm) ød H max. 2.3 2.6 36 40 100 (5/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF2320HU/TF2514HU(HORIZONTAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (15) H max. øD max. (10) (10) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 4 TF2320HU-502Y2R0-01 (19) (19) 1 TF2320HU-302Y3R0-01 ød 2 3 10 Impedance (kΩ) Weight: 18g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF2320HU-102Y5R0-01 0.1 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF2320HU type TF2320HU-102Y2R0-01 TF2320HU-502Y2R0-01 TF2320HU-302Y3R0-01 TF2320HU-102Y5R0-01 TF2514HU type TF2514HU-101Y5R0-01 TF2514HU-101Y7R0-01 (15) 10 100 Inductance (mH)min. L1-L2 inductance difference (µH)max. DC resistance (mΩ)max. Rated current Iac (A)max. Dimensions(mm) ød øD max. H max. 1 5 3 1 50 100 150 50 100 130 90 50 2 2 3 5 0.5 0.6 0.65 0.8 23 23 23 23 20 20 20 20 0.1 0.1 30 30 40 10 5 7 0.8 1.1 24 25 13 14 TF2519HU(HORIZONTAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø25max. (12) 1 Frequency (MHz) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 19max. (12) 4 2 3 TF2519HU-502Y2R0-01 ød (15) (15) 100 1 10 Impedance (kΩ) Weight: 16g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF2519HU-202Y2R0-01 TF2519HU-502Y2R0-01 TF2519HU-102Y3R0-01 TF2519HU-302Y3R0-01 TF2519HU-102Y5R0-01 2 5 1 3 1 L1-L2 inductance difference (µH)max. 100 150 50 100 50 • All specifications are subject to change without notice. DC resistance (Ω)max. 110 130 70 90 50 TF2519HU-302Y3R0-01 0.01 0.1 1 Frequency (MHz) Rated current Iac (A)max. 2 2 3 3 5 10 Dimensions(mm) ød 0.55 0.55 0.65 0.7 0.8 100 (6/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF3424HU(HORIZONTAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (15) øD max. (22) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS H max. (22) 100 4 2 3 TF3424HU-802Y4R0-01 TF3424HU-302Y7R0-01 ød (21) (21) 1 Impedance (kΩ) 10 Weight: 42g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 1 TF3524HU-102Y15R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF3424HU-802Y4R0-01 TF3424HU-502Y5R0-01 TF3424HU-302Y7R0-01 TF3424HU-102Y10R0-01 TF3424HU-202Y10R0-01 TF3424HU-102Y15R0-01 TF3424HU-301Y20R0-01 8 5 3 1 2 1 0.3 L1-L2 inductance difference (µH)max. 200 150 150 50 80 50 30 • All specifications are subject to change without notice. DC resistance (mΩ)max. 90 80 60 30 40 20 10 Rated current Iac (A)max. 4 5 7 10 10 15 20 Dimensions(mm) ød øD max. H max. 0.8 0.8 1 1.3 1.3 1.5 1.8 31 31 31 33 33 33 34 21 21 21 23 23 23 24 (7/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF4930HU(HORIZONTAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (10) øD max. (26) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS H max. 100 TF4930HU-103Y6R0-01 1 4 2 3 TF4930HU-302Y10R0-01 (35) (35) (26) ød Impedance (kΩ) 10 Weight: 87g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 1 TF4930HU-102Y20R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF4930HU-103Y6R0-01 TF4930HU-202Y10R0-01 TF4930HU-302Y10R0-01 TF4930HU-202Y15R0-01 TF4930HU-502Y15R0-01 TF4930HU-102Y20R0-01 10 2 3 2 5 1 L1-L2 inductance difference (µH)max. 300 150 150 150 200 50 DC resistance (mΩ)max. 60 30 35 25 35 20 TF1815HU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (7) (15) ø0.65max. ød øD max. H max. 1.2 1.3 1.3 1.8 1.5 2 47 47 47 48 48 49 26 26 26 27 27 30 100 4 TF1815HU-103Y0R3-01 TF1815HU-502Y1R0-01 (15) (3.5) (7) 1 Dimensions(mm) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ø17max. 15max. 18max. Rated current Iac (A)max. 6 10 10 15 15 20 2 3 10 Impedance (kΩ) Weight: 6g typ. Recommended hole diameter: ø0.9 to 1.0 Dimensions in mm TF1815HU-302Y2R0-01 1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF1815HU-103Y0R3-01 TF1815HU-502Y0R5-01 TF1815HU-103Y0R5-01 TF1815HU-502Y1R0-01 TF1815HU-103Y1R0-01 TF1815HU-302Y2R0-01 10 5 10 5 10 3 0.1 L1-L2 inductance difference (µH)max. 300 200 300 200 300 150 • All specifications are subject to change without notice. DC resistance (Ω)max. 630 410 550 250 325 95 Rated current Iac (A)max. 0.3 0.5 0.5 1 1 2 0.01 0.1 1 Frequency (MHz) 10 100 (8/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF4131HU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (40) 100 (17) TF4131HU-302Y10R0-01 1 4 2 3 (30) 10 Impedance (kΩ) ød (17) (5) (30) H max. øD max. Weight: 76g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 1 TF4131HU-102Y15R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF4131HU-202Y10R0-01 TF4131HU-302Y10R0-01 TF4131HU-202Y12R0-01 TF4131HU-102Y15R0-01 TF4131HU-701Y18R0-01 2 3 2 1 0.7 L1-L2 inductance difference (µH)max. 100 150 100 50 30 DC resistance (mΩ)max. 20 30 18 15 10 TF6136HU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (60) Rated current Iac (A)max. 10 10 12 15 18 ød øD max. H max. 1.5 1.5 1.5 1.7 1.8 38 39 39 39 41 29 30 30 30 31 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ø61max. 10 (20) 1 4 2 3 (50) (20) 1 TF6136HU-202Y25R0-01 Impedance (kΩ) ød (5) (50) 36max. Dimensions(mm) Weight: 172g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm TF6136HU-102Y30R0-01 0.1 0.01 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF6136HU-202Y15R0-01 TF6136HU-102Y20R0-01 TF6136HU-202Y20R0-01 TF6136HU-202Y25R0-01 TF6136HU-102Y30R0-01 2 1 2 2 1 L1-L2 inductance difference (µH)max. 80 50 80 80 50 • All specifications are subject to change without notice. DC resistance (Ω)max. 20 10 15 15 8 Rated current Iac (A)max. 15 20 20 25 30 Dimensions(mm) ød 1.8 1.8 1.8 2.4 2.4 100 (9/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type VERTICAL TYPE TF SERIES FEATURES • This series uses a high permeability toroidal ferrite core and therefore provides large inductance with a little number of turns. • Therefore its stray capacity is small and it provides the impedance levels required to effectively suppress high frequency noises. • Products mounted on a base with fixed leads are easy to insert to circuit boards. TF1320S(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 13max. ø20max. (20) 100 TF1320S-102Y3R0-01 2 3 4 Impedance (kΩ) 1 15±2 ∗ ød ∗ TF1320S-402Y1R5-01: 5±2 4 1 L1 2 L2 3 10 1 Weight: 6.5g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 0.1 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF1320S-402Y1R5-01 TF1320S-222Y2R0-01 TF1320S-102Y3R0-01 4 2.2 1 L1-L2 inductance difference (µH)max. 100 75 40 • All specifications are subject to change without notice. DC resistance (Ω)max. 0.2 0.1 0.04 Rated current Iac (A)max. 1.5 2 3 Dimensions(mm) ød 0.4 0.5 0.6 100 (10/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF2528S(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (10) 1 100 (15) 21max. 4 TF2528S-702Y2R5-K1 TF2528S-502Y3R0-K1 TF2528S-402Y4R0-K1 28max. 2 3 4 1 5±1 L1 ød 10 Impedance (kΩ) ø27max. L2 1 TF2528S-152Y5R0-K1 TF2528S-801Y8R0-K1 3 2 TF2528S-451Y10R0-K1 0.1 Weight: 19.5g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 0.01 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF2528S-702Y2R5-K1 TF2528S-502Y3R0-K1 TF2528S-402Y4R0-K1 TF2528S-152Y5R0-K1 TF2528S-801Y8R0-K1 TF2528S-451Y10R0-K1 7 5 4 1.5 0.8 0.45 L1-L2 inductance difference (µH)max. 200 150 100 80 50 30 DC resistance (Ω)max. 0.2 0.15 0.1 0.05 0.02 0.015 TF3233S(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 4 2 100 Dimensions(mm) ød 0.6 0.65 0.7 0.8 1 1.1 100 (16) 25max. ø35max. Rated current Iac (A)max. 2.5 3 4 5 8 10 10 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (18) 1 1 Frequency (MHz) TF3233S-502Y5R0-K1 TF3233S-202Y8R0-K1 3 ød Impedance (kΩ) 5±1 35max. 10 4 1 L1 L2 1 TF3233S-102Y10R0-K1 3 2 0.01 0.01 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF3233S-103Y3R0-K1 TF3233S-702Y4R0-K1 TF3233S-502Y5R0-K1 TF3233S-402Y6R0-K1 TF3233S-202Y8R0-K1 TF3233S-102Y10R0-K1 TF3233S-601Y15R0-K1 TF3233S-251Y20R0-K1 10 7 5 4 2 1 0.6 0.25 L1-L2 inductance difference (µH)max. 200 150 100 80 60 30 50 50 • All specifications are subject to change without notice. TF3233S-601Y15R0-K1 0.1 Weight: 41g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm DC resistance (Ω)max. 0.15 0.1 0.05 0.03 0.025 0.02 0.007 0.005 0.1 1 Frequency (MHz) Rated current Iac (A)max. 3 4 5 6 8 10 15 20 10 Dimensions(mm) ød 0.7 0.8 0.9 1 1.2 1.3 1.6 1.8 100 (11/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF1713VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 16.5max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 12.5max. 15 100 4 2 3 TF1713VU-202Y1R0-01 10 Weight: 4g typ. Recommended hole diameter: ød+0.3 Dimensions in mm Impedance (kΩ) ød 1 1 TF1713VU-102Y2R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF1713VU-202Y1R0-01 TF1713VU-102Y2R0-01 TF1713VU-102Y3R0-01 2 1 1 L1-L2 inductance difference (µH)max. 100 50 50 DC resistance (Ω)max. 180 100 70 TF1714VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø16.5max. Rated current Iac (A)max. 1 2 3 Dimensions(mm) ød 0.35 0.4 0.5 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS W max. 15 100 4 2 3 TF1714VU-153Y1R0-01 TF1714VU-502Y1R0-01 10 Weight: 6g typ. Recommended hole diameter: ød+0.3 Dimensions in mm Impedance (kΩ) ød 1 1 TF1714VU-202Y2R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF1714VU-502Y1R0-01 TF1714VU-802Y1R0-01 TF1714VU-103Y1R0-01 TF1714VU-153Y1R0-01 TF1714VU-202Y2R0-01 TF1714VU-102Y3R0-01 5 8 10 15 2 1 • All specifications are subject to change without notice. L1-L2 inductance difference (µH)max. 100 120 150 150 80 50 DC resistance (mΩ)max. 250 325 350 400 85 45 Rated current Iac(A) max. 1 1 1 1 2 3 Dimensions(mm) ød W max. 0.35 0.35 0.35 0.35 0.5 0.6 12 14 14 14 14 12 100 (12/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF2420VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 20max. 15 100 1 4 2 3 TF2430VU-802Y2R0-01 TF2430VU-302Y3R0-01 ød Impedance (kΩ) 10 Weight: 18g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF2420VU-102Y6R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF2420VU-302Y2R0-01 TF2420VU-802Y2R0-01 TF2420VU-302Y3R0-01 TF2420VU-102Y5R0-01 TF2420VU-202Y5R0-01 TF2420VU-102Y6R0-01 3 8 3 1 2 1 L1-L2 inductance difference (µH)max. 150 200 150 50 100 50 DC resistance (mΩ)max. 110 150 100 50 90 30 TF2514VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. Rated current Iac (A)max. 2 2 3 5 5 6 Dimensions(mm) ød øD max. 0.6 0.55 0.65 0.8 0.8 0.9 23 23 23 23 23 23.5 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS W max. 15 100 1 4 2 3 TF2514VU-123Y2R0-01 Impedance (kΩ) 10 ød Weight: 8g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF2514VU-102Y2R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF2514VU-102Y2R0-01 TF2514VU-123Y2R0-01 TF2514VU-101Y5R0-01 TF2514VU-131Y7R0-01 1 12 0.1 0.13 L1-L2 inductance difference (µH)max. 50 150 30 30 • All specifications are subject to change without notice. DC resistance (mΩ)max. 100 120 40 10 Rated current Iac (A)max. 2 2 5 7 Dimensions(mm) ød øD max. H max. 0.5 0.5 0.8 1.1 23 23 24 25 13 13 13 14 (13/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF3423VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS W max. 100 1 4 2 3 TF3423VU-103Y5R0-01 10 Impedance (kΩ) 15 TF3423VU-502Y5R0-01 Weight: 45g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm ød 1 TF3523VU-102Y15R0-01 0.1 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF3423VU-802Y4R0-01 TF3423VU-202Y5R0-01 TF3423VU-502Y5R0-01 TF3423VU-103Y5R0-01 TF3423VU-102Y10R0-01 TF3423VU-102Y15R0-01 TF3423VU-501Y20R0-01 8 2 5 10 1 1 0.5 L1-L2 inductance difference (µH)max. 200 100 150 300 50 50 30 DC resistance (mΩ)max. 90 50 80 100 30 20 10 TF4725VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. Rated current Iac (A)max. 4 5 5 5 10 15 20 1 Frequency (MHz) 10 100 Dimensions(mm) ød øD max. H max. 0.8 0.8 0.8 0.9 1.3 1.5 1.8 31 31 31 31 33 33 34 21 21 21 21 23 23 23 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 25max. 100 TF4725VU-103Y6R0-01 ød 1 4 2 3 10 Impedance (kΩ) 15 TF4725VU-302Y10R0-01 Weight: 85g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 1 TF4725VU-202Y15R0-01 0.1 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF4725VU-103Y6R0-01 TF4725VU-202Y10R0-01 TF4725VU-302Y10R0-01 TF4725VU-202Y15R0-01 10 2 3 2 • All specifications are subject to change without notice. L1-L2 inductance difference (µH)max. 300 100 150 100 DC resistance (mΩ)max. 60 90 50 70 Rated current Iac (A)max. 6 10 10 15 1 Frequency (MHz) 10 Dimensions(mm) ød øD max. 1.2 1.3 1.3 1.8 45 45 45 47 100 (14/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF1821VU(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 17max. 100 21max. 18max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1 4 2 3 TF1821VU-103Y0R3-01 10 Impedance (kΩ) (13) (5) TF1821VU-502Y1R0-01 ø0.7 (10) Weight: 7g typ. Recommended hole diameter: ø0.9 to 1.1 Dimensions in mm 1 TF1821VU-202Y2R0-01 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF1821VU-103Y0R3-01 TF1821VU-502Y0R5-01 TF1821VU-103Y0R5-01 TF1821VU-502Y1R0-01 TF1821VU-103Y1R0-01 TF1821VU-202Y2R0-01 10 5 10 5 10 2 L1-L2 inductance difference (µH)max. 300 200 300 200 300 100 DC resistance (Ω)max. 630 410 550 250 325 85 10 100 100 TF2326VU-302Y2R0-01 1 4 2 3 10 Impedance (kΩ) 26max. (5) (15) 1 Frequency (MHz) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 20max. ød (10) 0.1 Rated current Iac (A)max. 0.3 0.5 0.5 1 1 2 TF2326VU(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. 0.01 Weight: 19g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF2326VU-102Y6R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF2326VU-302Y2R0-01 TF2326VU-302Y3R0-01 TF2326VU-102Y5R0-01 TF2326VU-202Y5R0-01 TF2326VU-102Y6R0-01 3 3 1 2 1 • All specifications are subject to change without notice. L1-L2 inductance difference (µH)max. 150 150 50 100 50 DC resistance (mΩ)max. 120 100 50 90 30 Rated current Iac (A)max. 2 3 5 5 6 Dimensions(mm) ød øD max. 0.6 0.65 0.8 0.8 0.9 23 23 23 23 23.5 100 (15/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF2527VU(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 20max. ød (15) 1 4 2 3 TF2527VU-302Y3R0-01 10 Impedance (kΩ) (10) 100 (5) 27max. ø25max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS Weight: 20g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF2527VU-102Y6R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF2527VU-302Y2R0-01 TF2527VU-102Y3R0-01 TF2527VU-302Y3R0-01 TF2527VU-102Y5R0-01 TF2527VU-102Y6R0-01 3 1 3 1 1 L1-L2 inductance difference (µH)max. 150 50 150 50 50 • All specifications are subject to change without notice. DC resistance (Ω)max. 120 90 110 70 60 Rated current Iac (A)max. 2 3 3 5 6 Dimensions(mm) ød 0.6 0.65 0.65 0.8 0.9 100 (16/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF3435VU(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS W max. 100 H TF3435VU-802Y4R0-01 (16) 2 3 TF3435VU-302Y7R0-01 10 Impedance (kΩ) ød 4 (5) (18) 1 Weight: 40g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 1 TF3535VU-102Y15R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF3435VU-802Y4R0-01 TF3435VU-502Y5R0-01 TF3435VU-103Y5R0-01 TF3435VU-302Y7R0-01 TF3435VU-102Y10R0-01 TF3435VU-202Y10R0-01 TF3435VU-102Y15R0-01 TF3435VU-301Y20R0-01 8 5 10 3 1 2 1 0.3 L1-L2 inductance difference (µH)max. 200 150 300 150 50 80 50 30 • All specifications are subject to change without notice. DC resistance (mΩ)max. 90 100 120 100 30 40 20 10 Rated current Iac (A)max. 4 5 5 7 10 10 15 20 Dimensions(mm) ød øD max. W max. H max. 0.8 0.8 0.9 1 1.3 1.3 1.5 1.8 31 31 31 31 33 33 33 34 21 21 21 21 22 22 22 22 34 34 34 34 34 34 34 35 (17/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type with Nano Crystallization Alloy Magnetically Soft Material TOROIDAL CORE TYPE WITH NANO CRYSTALLIZATION ALLOY MAGNETICALLY SOFT MATERIAL TF SERIES FEATURES • This is a compact filter that provides large inductance due to the use of high permeability alloy with controlled nano-crystalline structures. • Products mounted on a base will come with fixed leads and are therefore easy to insert to circuit boards. TF2326VU-M/TF3435VU-M(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM W max. 100 H max. TF3435VU-303Y4R0-01M 2 (b) (a) 4 3 TF2326VU-103Y3R0-01M 10 (5) ød 1 Impedance (kΩ) øD max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS Weight TF2326VU: 20g typ. TF3435VU: 38g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF2326VU-302Y6R0-01M 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. TF2326VU-M type TF2326VU-103Y3R0-01M TF2326VU-702Y5R0-01M TF2326VU-302Y6R0-01M TF3435VU-M type TF3435VU-303Y4R0-01M TF3435VU-333Y5R0-01M TF3435VU-802Y10R0-1M Inductance (mH)min. L1-L2 inductance difference (µH)max. DC resistance (mΩ)max. Rated current Iac (A)max. Dimensions(mm) ød D max. W max. H max. (a) (b) 10 7 3 300 250 150 100 90 30 3 5 6 0.65 0.8 0.9 23 23 23.5 20 20 20 26 26 26 10 10 10 15 15 15 30 33 8 500 500 250 90 120 40 4 5 10 0.8 0.9 1.3 33 33 35 23 23 23 34 34 34 18 18 18 16 16 16 • All specifications are subject to change without notice. (18/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type with Nano Crystallization Alloy Magnetically Soft Material TF4930HU-M/TF6337HU-M(HORIZONTAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY (10) H max. øD max. CHARACTERISTICS a 1.5max. (a) 100 TF4930HU-403Y6R0-1M 4 ød (b) b 1 TF6337HU-103Y15R0-1M 2 3 Impedance (kΩ) 10 Weight TF4930HU: 99.8g typ. TF6337HU: 204.9g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 1 TF6337HU-402Y30R0-1M 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. TF4930HU-M type TF4930HU-403Y6R0-1M TF4930HU-103Y10R0-1M TF4930HU-602Y15R0-1M TF6337HU-M type TF6337HU-103Y15R0-1M TF6337HU-802Y25R0-1M TF6337HU-402Y30R0-1M Inductance (mH)min. L1-L2 inductance difference (µH)max. DC resistance (mΩ)max. Rated current Iac (A)max. Dimensions(mm) ød øD max. H max. (a) (b) 40 10 6 700 300 150 60 35 25 6 10 15 1.2 1.3 1.8 47 48 48 32 32 35 26 26 26 35 35 35 10 8 4 300 200 150 15 15 10 15 25 30 1.8 2.4 2.4 60 63 63 36 37 37 20 20 20 50 50 50 • All specifications are subject to change without notice. (19/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Separable Case Type MULTI-SECTION CASE TYPE (FOR HIGH FREQUENCY) TF SERIES FEATURES • This series uses six-section windings for each line, which contribute to reduced stray capacity and excellent impedance characteristics in high frequency ranges. TF3329B(FOR HIGH FREQUENCY) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 7.5±0.5 7.5±0.5 1 3 4 1000 10±0.5 2 100 4 1 30max. L1.a T2 L1.b 2 4±1 L 2.a T1 ø1 Impedance (kΩ) ø33max. L 2.b 10 TF3329B-852Y3R5-01 3 1 Weight: 40.5g typ. Recommended hole diameter: ø1.3 Dimensions in mm 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF3329B-153Y2R5-01 TF3329B-103Y3R0-01 TF3329B-852Y3R5-01 15 10 8.5 L1-L2 inductance difference (µH)max. 300 200 170 • All specifications are subject to change without notice. DC resistance (Ω)max. 120 100 70 Rated current Iac (A)max. 2.5 3 3.5 0.01 0.1 1 Frequency (MHz) 10 100 (20/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type VERTICAL TYPE (FOR HIGH FREQUENCY) TF SERIES FEATURES • To reduce stray capacity, this series uses a single layer winding and is designed to suppress high frequency noises. • Base-mounted products with fixed leads are easy to insert. TF1707VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø17max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 7max. 10 1 4 15 TF1707VU-101Y2R0-01 ød 1 3 Impedance (kΩ) 2 Weight: 2.5g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 0.1 TF1707VU-200Y2R0-01 0.01 0.001 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (µH)min. TF1707VU-200Y2R0-01 TF1707VU-101Y2R0-01 TF1707VU-101Y3R0-01 20 100 100 L1-L2 inductance difference (µH)max. 10 20 20 • All specifications are subject to change without notice. DC resistance (Ω)max. 50 40 30 Rated current Iac (A)max. 2 2 3 Dimensions(mm) ød 0.6 0.6 0.65 100 (21/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF1709VU(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø17max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 9max. 10 1 4 15 TF1709VU-101Y2R0-01 2 Weight: 3.2g typ. Recommended hole diameter: ød+0.3 Dimensions in mm Impedance (kΩ) ød 1 3 0.1 TF1709VU-200Y2R0-01 0.01 0.001 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. Inductance (µH)min. TF1709VU-200Y2R0-01 TF1709VU-101Y2R0-01 TF1709VU-101Y3R0-01 20 100 100 L1-L2 inductance difference (µH)max. 10 20 20 DC resistance (Ω)max. 50 40 30 TF2326VU-H/TF3435VU-H(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM øD max. W max. 1 Frequency (MHz) Rated current Iac (A)max. 2 2 3 10 100 Dimensions(mm) ød 0.6 0.6 0.65 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS H 10 1 4 ød (b) 2 1 3 Impedance (kΩ) (a) (5) TF2326VU-500Y4R0-1H Weight TF2326VU: 19.7g typ. TF3435VU: 35.8g typ. Recommended hole diameter: ød+0.3 Dimensions in mm TF3435VU-500Y10R0-1H 0.1 TF3435VU-300Y15R0-1H 0.01 0.001 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. TF2326VU-H type TF2326VU-500Y4R0-1H TF2326VU-300Y5R0-1H TF3435VU-H type TF3435VU-600Y8R0-1H TF3435VU-500Y10R0-1H TF3435VU-300Y15R0-1H Inductance (µH)min. L1-L2 inductance difference (µH)max. DC resistance (mΩ)max. Rated current Iac (A)max. Dimensions(mm) ød D max. W max. H max. (a) (b) 50 30 10 10 25 20 4 5 0.7 0.8 23 23 20 20 26 26 10 10 15 15 60 50 30 10 10 10 16 11 8 8 10 15 1 1.2 1.4 32 33 33 22 22 22 34 34 34 18 18 18 16 16 16 • All specifications are subject to change without notice. (22/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TOROIDAL CORE TYPE FOR THREE PHASE LINES TF SERIES FEATURES • This series uses a high permeability toroidal ferrite core and can handle heavy currents with fewer number of turns. TF6030T(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 12.7±0.5 22.9±0.5 22.9±0.5 ø60max. 3 1 5 4 12.7±0.5 6 7±0.5 36max. 14.6±0.5 5±1 10 Impedance (kΩ) 13.3±0.5 26±0.5 2 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1 TF6030T-102Y14R0-01 0.1 0.01 0.01 0.1 1 Frequency (MHz) 10 ød 2 3 L1 L2 1 Weight: 150g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 4 6 L3 5 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF6030T-752Y5R0-01 TF6030T-162Y10R0-01 TF6030T-102Y14R0-01 7.5 1.6 1 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 150 100 75 • All specifications are subject to change without notice. DC resistance (Ω)max. 0.1 0.02 0.02 Rated current Iac (A)max. 5 10 14 Dimensions(mm) ød 0.9 1.3 1.5 100 (23/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TF6035T(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 12.7±0.5 22.9±0.5 22.9±0.5 13.3±0.5 26±0.5 2 100 3 1 10 5 4 12.7±0.5 6 14.6±0.5 7±0.5 Impedance (kΩ) ø62max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1 TF6035T-162Y15R0-01 TF6035T-102Y20R0-01 TF6035T-501Y25R0-01 TF6035T-201Y30R0-01 36max. 0.1 5±1 0.01 0.01 ød 2 1 Frequency (MHz) 10 100 3 L1 L2 1 Weight: 160g typ. Recommended hole diameter: ød+0.5 Dimensions in mm 4 6 0.1 L3 5 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF6035T-201Y30R0-01 TF6035T-501Y25R0-01 TF6035T-102Y20R0-01 TF6035T-162Y15R0-01 0.2 0.5 1 1.6 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 10 15 20 30 • All specifications are subject to change without notice. DC resistance (Ω)max. 3 5 8 12 Rated current Iac (A)max. 30 25 20 15 Dimensions(mm) ød 2.6 2.3 2 1.8 (24/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TF3524TU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø34.5max. H max. (5) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 ød TF3524TU-502Y3R0-01 ˚ 2 5 3 4 1 6 ø30 1 4 2 5 3 6 10 Impedance (kΩ) 60 60 ˚ 60˚ : Polarity Weight: 40g typ. Recommended hole diameter: ød+0.3 Dimensions in mm 1 TF3524TU-202Y5R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 100 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF3524TU-302Y3R0-01 TF3524TU-502Y3R0-01 TF3524TU-102Y5R0-01 TF3524TU-202Y5R0-01 3 5 1 2 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 150 200 50 150 TF4333TU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø42.5max. H max. (5) DC resistance (mΩ)max. 100 130 50 60 Rated current Iac (A)max. 3 3 5 5 Dimensions(mm) ød H max. 0.8 0.8 1 1 23 23 23 24 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 TF4333TU-502Y5R0-01 ød TF4333TU-302Y7R0-01 2 5 4 3 1 6 ø36 1 4 2 5 3 6 10 : Polarity Weight: 95.1g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm Impedance (kΩ) ˚ 60 60 ˚ 60˚ 1 TF4333TU-102Y10R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF4333TU-502Y5R0-01 TF4333TU-302Y7R0-01 TF4333TU-102Y10R0-01 TF4333TU-501Y15R0-01 5 3 1 0.5 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 200 250 50 30 • All specifications are subject to change without notice. DC resistance (mΩ)max. 55 35 15 8 Rated current Iac (A)max. 5 7 10 15 Dimensions(mm) ød H max. 1.1 1.3 1.5 1.8 31 32 32 33 100 (25/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TF5228TU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø52max. H max. (5) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 3 2 10 6 4 1 ø45 (30) 1 4 2 5 3 6 Impedance (kΩ) 5 60˚ ) (30 (3 0) 60˚ ød TF5228TU-502Y5R0-01 : Polarity 1 Weight: 109.7g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm TF5228TU-202Y10R0-01 0.1 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF5228TU-102Y5R0-01 TF5228TU-502Y5R0-01 TF5228TU-302Y8R0-01 TF5228TU-102Y10R0-01 TF5228TU-202Y10R0-01 1 5 3 1 2 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 50 200 150 50 80 • All specifications are subject to change without notice. DC resistance (mΩ)max. 45 95 40 20 25 Rated current Iac (A)max. 5 5 8 10 10 Dimensions(mm) ød H max. 1 1 1.2 1.3 1.5 26 26 26 26 28 100 (26/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TF6332TU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø63 max. 32max. (5) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 TF6332TU-202Y15R0-01 3 2 6 4 1 1 4 2 5 3 6 : Polarity ø56 (30) Impedance (kΩ) 5 (3 0) 60˚ ) (30 60˚ ød 10 1 TF6332TU-102Y20R0-01 Weight: 212.1g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm 0.1 0.01 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF6332TU-202Y15R0-01 TF6332TU-152Y18R0-01 TF6332TU-102Y20R0-01 TF6332TU-501Y25R0-01 2 1.5 1 0.5 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 80 50 50 30 • All specifications are subject to change without notice. DC resistance (Ω)max. 20 15 8 6 Rated current Iac (A)max. 15 18 20 25 Dimensions(mm) ød 2 2.1 2.3 2.5 100 (27/27) 002-03 / 20030628 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TF6340TU(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM ø63max. 40max. (10) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 TF6340TU-302Y10R0-01 3 2 6 4 1 1 4 2 5 3 6 : Polarity ø56 (30) Weight: 258.4g typ. Recommended hole diameter: ød+0.3 to 0.5 Dimensions in mm Impedance (kΩ) 5 (3 0) 60˚ ) (30 60˚ ød 10 1 TF6340TU-102Y25R0-01 0.1 0.01 0.01 0.1 1 Frequency (MHz) 10 ELECTRICAL CHARACTERISTICS Part No. Inductance (mH)min. TF6340TU-302Y10R0-01 TF6340TU-202Y15R0-01 TF6340TU-102Y20R0-01 TF6340TU-102Y25R0-01 3 2 1 1 L1-L2, L2-L3, L3-L1 inductance difference (µH)max. 150 120 50 50 • All specifications are subject to change without notice. DC resistance (Ω)max. 35 25 10 8 Rated current Iac (A)max. 10 15 20 25 Dimensions(mm) ød 1.5 1.8 2.3 2.4 100
TF2514VU-102Y2R0-01
物料型号:文档列出了TDK公司的EMC组件,特别是TF系列共模扼流圈(线滤波器),用于交流电源的电磁兼容(EMC)问题。
器件简介:共模扼流圈用于抑制电源线上的电磁干扰(EMI)和射频干扰(RFI),防止测量设备和系统设备等产品的多功能干扰。
引脚分配:文档中没有明确提到引脚分配,但是提到了产品的封装信息和安装信息,包括推荐的孔径尺寸。
参数特性: - 额定电压(Eac):80V至280V - 介质耐压(Eac):2000V,每分钟在每个绕组之间 - 绝缘电阻(Edc):最小100MΩ,500V直流电压下,每分钟在每个绕组之间 - 温升:最大45°C,包括线路电阻 - 工作温度范围:-20°C至+120°C - 安全标准:符合日本电子/电气产品控制法、UL、CSA和IEC标准
功能详解:共模扼流圈提供广泛的选择范围,适用于高频下的高阻抗和高自谐振频率,有效抑制高频噪声。
应用信息:适用于多种应用,包括但不限于测量设备、系统设备、空调(室外机)、微波炉、工业设备和控制设备等。
封装信息:文档提供了详细的封装类型、尺寸、重量和最小包装数量等信息。例如,TF1028S系列的封装信息包括水平类型和垂直类型,每种类型都有不同的尺寸和重量。
TF2514VU-102Y2R0-01 价格&库存
很抱歉,暂时无法提供与“TF2514VU-102Y2R0-01”相匹配的价格&库存,您可以联系我们找货
TF2514VU-102Y2R0-01
    • 1+39.61440
    • 200+15.81120
    • 500+15.28200
    • 1000+15.02280
