(1/13)
Common Mode Choke Coils(Line Filters) for AC Power Supply
Conformity to RoHS Directive
Toroidal Core Type TF Series
TDK common mode choke coils(line filters) are used in a wide
range of prevention of electromagnetic interference(EMI) and radio
frequency interference(RFI) from power supply lines and for prevention of multifunctioning of products such as measuring equipment and system equipment.
FEATURES
• Wide range of selection.
• High impedance at applicable frequency.
• High self-resonant frequency.
PRODUCT IDENTIFICATION
TF
(1)
(2)
V - A
(3) (4)
Y
(5)
R
(6)
- 01
(7)
(1) Core shape
TF: Toroidal core
(2) Dimensional code
Width× Depth
(3) External shape code
V: Vertical type H: Horizontal type
(4) High µ material
(5) Inductance value
Example) 133:13mH
(6) Rated current value
Example) 3R0:3.0A
(7) Product management number
SELECTION CHART
Series
Configuration
Vertical type
TF
Horizontal type
Vertical type
(For high frequency)
Type
Inductance value
min.
Rated current
(A)
Handling power∗
L× I2(mH× A2)
Weight
(g)typ.
TF1813V
TF2518V
TF2721V
TF3020V
TF3525V
TF1713H
TF2520H
TF2722H
TF3022H
TF3526H
TF2628V-1H
TF3524V-1H
2 to 20mH
0.65 to 9mH
1 to 13mH
0.35 to 13mH
0.65 to 20mH
2 to 20mH
0.65 to 9mH
1 to 13mH
0.35 to 13mH
0.65 to 20mH
25 to 65µH
25 to 120µH
0.7 to 3.2
2.5 to 10
2.5 to 10
3 to 20
3 to 20
0.7 to 3.2
2.5 to 10
2.5 to 10
3 to 20
3 to 20
6 to 12
8 to 20
75
130
195
75
130
195
3.65
10.8
5
15
41
5.3
15
42
18
40
Minimum
package quantity
(pieces/box)
960
560
460
440
240
960
550
380
320
280
700
320
∗ Handling power=(Inductance value)× (Current)2. It is possible to design within the range below this value.
[Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
• All specifications are subject to change without notice.
001-03 / 20061027 / e93_tf.fm
(2/13)
Horizontal Type TF Series
FEATURES
• This series uses a high permeability toroidal ferrite core and
therefore provide large inductance with a little number of turns.
• Therefore its stray capacity is small and it keeps the impedance
required to effectively suppress high frequency noises.
• Products mounted on a base with fixed leads are easy to insert
to circuit boards.
TF1713H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE
SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
7±0.5
4
2
3
100
A203Y0R7
A153Y1R0
20max.
17.5±0.5
1
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE vs. FREQUENCY CHARACTERISTICS
ø0.7
17max.
4
2
3
Impedance (kΩ)
3.5±1
13max.
10
1
Weight: 5.3g typ.
A652Y1R6
1
Recommended hole diameter: ø1.2
Dimensions in mm
A502Y2R0
A202Y3R2
0.1
0.01
Part No.
TF1713H-A203Y0R7-01
TF1713H-A153Y1R0-01
TF1713H-A652Y1R6-01
TF1713H-A502Y2R0-01
TF1713H-A202Y3R2-01
DC resistance
(Ω)max.
0.73
0.44
0.19
0.14
0.065
• Measuring equipment of inductance value:
LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz]
PACKAGING QUANTITIES
TF1713H-A
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
Inductance
(mH)min.
6.5
5
2
0.1
960pieces/box
Rated current
Iac(A)max.
0.7
1
1.6
2
3.2
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
Dielectric withstanding
Between each winding for
2000
voltage(V)
1 minute
Insulation resistance
100min.
(MΩ)
DC.500V
Temperature rise(°C)
45max.
With line resistance
Operating temperature
Including self-temperature
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
260±5°C, 10±1sec Solder bath method
Resistance to
soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method
Applicable safety
Electrical Appliance and Material Safety
Law ("DENAN"), IEC60065, UL6500, CSA C22.2
standard∗2
∗1 Pb free solder(Sn-3Ag-0.5Cu)
∗2 However, this product is not recognized by each regulations.
(3/13)
TF2520H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE
25max.
2
(11)
3
3.75±0.75
10
1
1
2
Impedance (kΩ)
20max.
Lot No.
4
4
3
1
0.1
Weight: 15g typ.
702Y3R0
502Y4R0
252Y5R0
102Y8R0
651Y10R0
Recommended hole diameter: ød+0.5
Dimensions in mm
0.01
0.01
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(Ω)max.
TF2520H-A902Y2R5-01 9
0.12
TF2520H-A702Y3R0-01 7
0.095
TF2520H-A502Y4R0-01 5
0.075
TF2520H-A252Y5R0-01 2.5
0.05
TF2520H-A102Y8R0-01 1
0.025
TF2520H-A651Y10R0-01 0.65
0.02
0.1
1
Frequency (MHz)
10
100
RATINGS
Rated
current
Iac(A)max.
2.5
3
4
5
8
10
TF2520H-A
902Y2R5
(20)
25max.
100
550pieces/box
ød
(mm)
0.6
0.65
0.7
0.75
0.95
1
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
(4/13)
TF2722H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE
27max.
2
(11)
3
3.75±0.75
10
1
1
2
Impedance (kΩ)
22max.
Lot No.
4
4
3
1
0.1
Weight: 20g typ.
103Y3R0
652Y4R0
422Y5R0
152Y8R0
102Y10R0
Dimensions in mm
0.01
0.01
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(mΩ)max.
TF2722H-A133Y2R5-01 13
130
TF2722H-A103Y3R0-01 10
90
TF2722H-A652Y4R0-01 6.5
60
TF2722H-A422Y5R0-01 4.2
40
TF2722H-A152Y8R0-01 1.5
TF2722H-A102Y10R0-01 1
11
0.1
1
Frequency (MHz)
10
100
RATINGS
Rated
current
Iac(A)max.
2.5
3
4
5
8
10
TF2722H-A
133Y2R5
(20)
27max.
100
380pieces/box
ød
(mm)
0.65
0.7
0.8
0.9
1
1.2
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
(5/13)
TF3022H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE
30max.
2
(11)
3
100
1
3.75±0.75
Impedance (kΩ)
10
22max.
Lot No.
(24)
30max.
133Y3R0
802Y4R0
4
1
4
2
3
602Y5R0
1
0.1
Weight: 32g typ.
Dimensions in mm
0.01
0.01
Rated
current
Iac(A)max.
3
4
5
6
7
8
10
15
TF3022H-A
0.1
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(Ω)max.
TF3022H-A133Y3R0-01 13
0.1
TF3022H-A802Y4R0-01 8
0.07
TF3022H-A602Y5R0-01 6
0.05
TF3022H-A502Y6R0-01 5
0.04
TF3022H-A402Y7R0-01 4
0.035
TF3022H-A252Y8R0-01 2.5
0.025
TF3022H-A172Y10R0-01 1.7
0.015
TF3022H-A701Y15R0-01 0.7
0.007
TF3022H-A351Y20R0-01 0.35
0.005
502Y6R0
402Y7R0
252Y8R0
172Y10R0
701Y15R0
351Y20R0
ød
(mm)
0.75
0.8
0.9
0.95
1
1.1
1.3
1.6
1.7
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
320pieces/box
(6/13)
TF3526H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE
35max.
(11)
2
3
100
203Y3R0
123Y4R0
(28)
33max.
103Y5R0
26max.
1
Impedance (kΩ)
Lot No.
10
4
1
2
4
1
702Y6R0
602Y7R0
452Y8R0
0.1
3
302Y10R
102Y15R
3.75±0.75
651Y20R0
Weight: 42g typ.
Dimensions in mm
Rated
current
Iac(A)max.
3
4
5
6
7
8
10
15
TF3526H-A
0.1
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(mΩ)max.
TF3526H-A203Y3R0-01 20
130
TF3526H-A123Y4R0-01 12
75
TF3526H-A103Y5R0-01 10
55
TF3526H-A702Y6R0-01 7
45
TF3526H-A602Y7R0-01 6
35
TF3526H-A452Y8R0-01 4.5
25
TF3526H-A302Y10R0-01 3
18
TF3526H-A102Y15R0-01 1
6
TF3526H-A651Y20R0-01 0.65
4
0.01
0.01
ød
(mm)
0.75
0.85
0.95
1
1.1
1.2
1.3
1.7
1.8
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
260±5°C,
Resistance to
Applicable safety
standard∗2
280pieces/box
(7/13)
Vertical Type TF Series
16max.
TF1813V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE
100
3.5±1
ø0.7
A203Y0R7
A153Y1R0
13max.
18max.
1
4
2
3
1
4
2
3
10
Impedance (kΩ)
7±0.5
14±0.5
Weight: 5g typ.
Dimensions in mm
A652Y1R6
1
A502Y2R0
A202Y3R2
0.1
0.01
Part No.
TF1813V-A203Y0R7-01
TF1813V-A153Y1R0-01
TF1813V-A652Y1R6-01
TF1813V-A502Y2R0-01
TF1813V-A202Y3R2-01
DC resistance
(Ω)max.
0.73
0.44
0.19
0.14
0.065
TF1813V-A
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
Inductance
(mH)min.
6.5
5
2
0.1
960pieces/box
Rated current
Iac(A)max.
0.7
1
1.6
2
3.2
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
(8/13)
TF2518V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE
(10)
1
4
A902Y2R5
(13)
18max.
100
ø25max.
2
3
27max.
3.75±0.75
4
1
L1
L2
2
3
Weight: 15g typ.
ød
Dimensions in mm
Impedance (kΩ)
10
1
0.1
0.01
0.01
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(Ω)max.
TF2518V-A902Y2R5-01 9
0.12
TF2518V-A702Y3R0-01 7
0.095
TF2518V-A502Y4R0-01 5
0.075
TF2518V-A252Y5R0-01 2.5
0.05
TF2518V-A102Y8R0-01 1
0.025
TF2518V-A651Y10R0-01 0.65
0.02
A252Y5R0
A102Y8R0
A651Y10R0
0.1
1
Frequency (MHz)
10
100
RATINGS
Rated
current
Iac(A)max.
2.5
3
4
5
8
10
TF2518V-A
A702Y3R0
A502Y4R0
560pieces/box
ød
(mm)
0.6
0.65
0.7
0.75
0.95
1
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
(9/13)
TF2721V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE
1
(10)
4
3
28max.
10
Impedance (kΩ)
2
4
1
L1
L2
2
3
Weight: 20g typ.
ød
Dimensions in mm
1
0.1
0.01
0.01
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(mΩ)max.
TF2721V-A133Y2R5-01 13
130
TF2721V-A103Y3R0-01 10
90
TF2721V-A652Y4R0-01 6.5
60
TF2721V-A422Y5R0-01 4.2
40
TF2721V-A152Y8R0-01 1.5
TF2721V-A102Y10R0-01 1
11
103Y3R0
652Y4R0
422Y5R0
152Y8R0
102Y10R0
0.1
1
Frequency (MHz)
10
100
RATINGS
Rated
current
Iac(A)max.
2.5
3
4
5
8
10
TF2721V-A
133Y2R5
(15)
21max.
100
ø27max.
3.75±0.75
460pieces/box
ød
(mm)
0.65
0.7
0.8
0.9
1
1.2
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
(10/13)
TF3020V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE
(10)
4
31max.
3
10
4
1
L1
L2
2
ød
133Y3R0
802Y4R0
Impedance (kΩ)
2
ø30max.
3.75±0.75
100
(15)
20max.
1
3
Weight: 30g typ.
602Y5R0
1
0.1
Dimensions in mm
0.01
0.01
0.1
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
DC
Inductance
Part No.
resistance
(mH)min.
(Ω)max.
TF3020V-A133Y3R0-01 13
0.1
TF3020V-A802Y4R0-01 8
0.07
TF3020V-A602Y5R0-01 6
0.05
TF3020V-A502Y6R0-01 5
0.04
TF3020V-A402Y7R0-01 4
0.035
TF3020V-A252Y8R0-01 2.5
0.025
TF3020V-A172Y10R0-01 1.7
0.015
TF3020V-A701Y15R0-01 0.7
0.007
TF3020V-A351Y20R0-01 0.35
0.005
502Y6R0
402Y7R0
252Y8R0
172Y10R0
701Y15R0
351Y20R0
Rated
current
Iac(A)max.
3
4
5
6
7
8
10
15
ød
(mm)
0.75
0.8
0.9
0.95
1
1.1
1.3
1.6
1.7
Item
Rated voltage(V)
voltage(V)
(MΩ)
range(°C)
Storage temperature
range(°C)
Resistance to
∗1
∗2
Standard value
80 to 280
2000
100min.
45max.
–20 to +120
Conditions
50Hz/60Hz
1 minute
DC.500V
rise
–20 to +85
TF3020V-A
440pieces/box
(11/13)
TF3525V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE
1
(18)
4
(16)
25max.
100
203Y3R0
123Y4R0
103Y5R0
4
35max.
1
3.75±0.75
10
3
Impedance (kΩ)
2
ø35max.
L1
L2
2
3
0.1
Dimensions in mm
0.1
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
Rated
current
Iac(A)max.
3
4
5
6
7
8
10
15
TF3525V-A
302Y10R0
102Y15R0
651Y20R0
0.01
0.01
DC
Inductance
Part No.
resistance
(mH)min.
(mΩ)max.
TF3525V-A203Y3R0-01 20
130
TF3525V-A123Y4R0-01 12
75
TF3525V-A103Y5R0-01 10
55
TF3525V-A702Y6R0-01 7
45
TF3525V-A602Y7R0-01 6
35
TF3525V-A452Y8R0-01 4.5
25
TF3525V-A302Y10R0-01 3
18
TF3525V-A102Y15R0-01 1
6
TF3525V-A651Y20R0-01 0.65
4
702Y6R0
602Y7R0
452Y8R0
Weight: 41g typ.
ød
1
ød
(mm)
0.75
0.85
0.95
1
1.1
1.2
1.3
1.7
1.8
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
260±5°C,
Resistance to
Applicable safety
standard∗2
240pieces/box
(12/13)
Vertical Type (For High Frequency) TF Series
FEATURES
• This series is designed to reduce stray capacity between
windings by using a single-layer coil construction on Ni-Zn ferrite
cores, which offer excellent high frequency characteristics.
• This series provides excellent noise suppression for high
frequency ranges including the FM band.
TF2628V-1H(VERTICAL TYPE WITH TERMINAL BASE) TYPE
(10)
1
4
(15)
21max.
10
2
3
4
1
28max.
1
Impedance (kΩ)
ø27max.
L1
L2
2
3
Weight: 18g typ.
5±1
ød
Dimensions in mm
0.01
0.001
0.01
Part No.
TF2628V-650Y6R0-1H
TF2628V-450Y9R0-1H
TF2628V-250Y12R0-1H
Rated
current
Iac(A)max.
6
9
12
LCR meter(HP4261A, HP4263B or equivalent)[f=10kHz]
TF2628V-1H
0.1
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
DC
Inductance
resistance
(µH)min.
(mΩ)max.
65
12
25
9
650Y6R0
450Y9R0
250Y12R0
0.1
700pieces/box
ød
(mm)
0.8
1
1.2
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
Resistance to
Applicable safety
standard∗2
(13/13)
TF3524V-1H(VERTICAL TYPE WITH TERMINAL BASE) TYPE
1
(18)
4
(16)
25max.
10
4
1
35max.
1
3
Impedance (kΩ)
2
ø35max.
L1
L2
2
3
5±1
Weight: 40g typ.
ød
0.01
Dimensions in mm
0.001
0.01
Part No.
Inductance
(µH)min.
TF3524V-121Y8R0-1H
TF3524V-750Y12R0-1H
TF3524V-450Y15R0-1H
TF3524V-250Y20R0-1H
120
75
45
25
DC
resistance
(mΩ)max.
7
5
0.1
1
Frequency (MHz)
10
100
RATINGS
(STANDARD LINE UP)
Rated
current
Iac(A)max.
8
12
15
TF3524V-1H
121Y8R0
750Y12R0
450Y15R0
250Y20R0
0.1
320pieces/box
ød
(mm)
1
1.3
1.6
1.8
Item
Standard value
Conditions
Rated voltage(V)
80 to 280
50Hz/60Hz
2000
voltage(V)
1 minute
100min.
(MΩ)
DC.500V
45max.
–20 to +120
range(°C)
rise
Storage temperature
–20 to +85
range(°C)
260±5°C,
Resistance to
Applicable safety
standard∗2
