TF2628V-451Y10R0-01
TF2628V-451Y10R0-01
    TDK(东电化)
    插件
    TF2628V-451Y10R0-01
TF2628V-451Y10R0-01 数据手册
(1/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TDK common mode choke coils(line filters) are used in a wide range of prevention of electromagnetic interference(EMI) and radio frequency interference(RFI) from power supply lines and for prevention of multifunctioning of products such as measuring equipment and system equipment. RATINGS Item Rated voltage(V) Dielectric withstanding voltage(V) Insulation resistance (MΩ) Temperature rise(°C) Operating temperature range(°C) Safety standard Standard value 80 to 280∗ Conditions Between each winding for 1 minute Between each winding for 100min. 1 minute, Edc 500V With line resistance 45max.∗ Including self-temperature –20 to +120 rise Japan Electric/Electronic Products Control Law, UL, CSA and IEC conforted(The safety standard is not acquired with the unit only.) 2000 PRODUCT IDENTIFICATION UF V – Y (1) (2) (3) (4) (5) R (6) – 01 (7) (1)Core shape UF: U-type core TF: Toroidal core HF: Square shaped closed magnetic circuit core type Double-square shaped closed magnetic circuit core type (2)Dimensional code(Length×Height) (3)External shape code (4)TDK’s internal code (5)Inductance value Example) 602: 60µH×102=6mH (6)Rated current value Example) 2R5: 2.5A (7)Product management number ∗ Except particular items. • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent) FEATURES • Wide range of selection. • High impedance at applicable frequency. • High self-resonant frequency. SELECTION CHART Series Configuration Horizontal types (Toroidal core) TF Vertical types (Toroidal core) Type TF1028S TF2720B TF3524B TF4825S TF6029S TF1320S TF2628V TF3524V Inductance value min. 0.45 to 2.2mH 0.45 to 7mH 0.25 to 10mH 1, 2mH 1mH 1 to 4mH 0.45 to 7mH 0.25 to 10mH Rated current (A) 0.5 to 3 2.5 to 10 3 to 20 10 to 15 20 to 30 1.5 to 3 2.5 to 10 3 to 20 Handling power∗ L×I2(mH×A2) 2.5 50 130 200 400 9 50 130 Multi-section case types TF3329B 8.5 to 15mH 2.5 to 3.5 100 (For high frequency) 25 to 65µH 6 to 12 3.65 Vertical types(Toroidal core) TF2628V-1H (For high frequency) TF3524V-1H 25 to 120µH 8 to 20 10.8 For three phase lines TF6030T 1 to 7.5mH 5 to 14 160 (Toroidal core) TF6035T 0.2 to 1.6mH 15 to 30 400 ∗ Handling power=(Inductance value)×(Current)2. It is possible to design within the range below this value. [Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10. • All specifications are subject to change without notice. Weight (g)typ. 8 20 42 95 205 6.5 19.5 41 Minimum package quantity (pieces/box) 900 400 300 120 70 1000 700 320 40.5 375 18 40 150 160 700 320 70 70 (2/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type HORIZONAL TYPE TF SERIES FEATURES • This series uses a high permeability toroidal ferrite core and therefore provides large inductance with a little number of turns. • Therefore its stray capacity is small and it keeps the impedance required to effectively suppress high frequency noises. • Products mounted on a base with fixed leads are easy to insert to circuit boards. TF1028S(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 2 1 3 4 100 10±0.5 26max. 25±0.5 TF1028S-222Y0R5-01 Impedance (kΩ) ød 12max. 5±1 29max. 4 1 L1 L2 2 TF1028S-162Y1R3-01 10 3 Weight: 8g typ. 1 TF1028S-102Y1R5-01 TF1028S-451Y3R0-01 TF1028S-801Y2R0-01 0.1 Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF1028S-222Y0R5-01 TF1028S-162Y1R3-01 TF1028S-102Y1R5-01 TF1028S-801Y2R0-01 TF1028S-451Y3R0-01 Inductance (mH)min. 2.2 1.6 1 0.8 0.45 DC resistance (Ω)max. 0.2 0.2 0.1 0.1 0.06 Rated current (A)max. 0.5 1.3 1.5 2 3 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF1028S 900pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.4 0.4 0.45 0.5 0.6 1 Frequency (MHz) 10 100 (3/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF2720B(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 27max. 2 (11) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 3 TF2720B-702Y2R5-01 TF2720B-502Y3R0-01 TF2720B-402Y4R0-01 (20) 27max. 100 Lot No. 22max. 1 Impedance (kΩ) 10 4 1 4 2 3 1 TF2720B-451Y10R0-01 TF2720B-801Y8R0-01 0.1 TF2720B-152Y5R0-01 4.5±1 Weight: 20g typ. Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF2720B-702Y2R5-01 TF2720B-502Y3R0-01 TF2720B-402Y4R0-01 TF2720B-152Y5R0-01 TF2720B-801Y8R0-01 TF2720B-451Y10R0-01 Inductance (mH)min. 7 5 4 1.5 0.8 0.45 DC resistance (Ω)max. 0.2 0.15 0.1 0.05 0.02 0.015 Rated current (A)max. 2.5 3 4 5 8 10 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF2720B 400pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.6 0.65 0.7 0.8 1 1.1 1 Frequency (MHz) 10 100 (4/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF3524B(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (11) 34max. 2 3 TF3524B-103Y3R0-01 TF3524B-702Y4R0-01 TF3524B-502Y5R0-01 TF3524B-402Y6R0-01 (28) 33max. 100 Lot No. 26max. 1 Impedance (kΩ) 10 4 1 4 2 3 1 TF3524B-301Y20R0-01 0.1 TF3524B-601Y15R0-01 4.5±1 Weight: 42g typ. TF3524B-102Y10R0-01 TF3524B-202Y8R0-01 Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF3524B-103Y3R0-01 TF3524B-702Y4R0-01 TF3524B-502Y5R0-01 TF3524B-402Y6R0-01 TF3524B-202Y8R0-01 TF3524B-102Y10R0-01 TF3524B-601Y15R0-01 TF3524B-301Y20R0-01 Inductance (mH)min. 10 7 5 4 2 1 0.6 0.3 DC resistance (Ω)max. 0.15 0.1 0.05 0.035 0.025 0.02 0.007 0.005 Rated current (A)max. 3 4 5 6 8 10 15 20 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF3524B 300pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.7 0.8 0.9 1 1.2 1.3 1.6 1.8 1 Frequency (MHz) 10 100 (5/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF4825S(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (35) 2 100 1 TF4825S-202Y10R0-01 (15) ø4.5 Impedance (kΩ) 10 4 3 H max. ø50max. TF4825S-102Y15R0-01 0.1 4 1 L1 5±2 1 ød L2 2 3 0.01 Weight: 95g typ. 0.01 0.1 1 Frequency (MHz) Recommended hole diameter: ød+0.5 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TF4825S-202Y10R0-01 TF4825S-102Y15R0-01 Inductance (mH)min. 2 1 DC resistance (mΩ)max. 20 7.5 Rated current (A)max. 10 15 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF4825S 120pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød H max. 1.3 28 1.8 31 10 100 (6/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF6029S(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (50) 10 ø6 1 3 Impedance (kΩ) (20) 2 4 5±2 H max. ø64max. L1 ød 2 TF6029S-102Y20R0-01 TF6029S-102Y30R0-02 0.1 0.01 4 1 1 L2 0.01 0.1 1 Frequency (MHz) 3 Weight: 205g typ. Recommended hole diameter: ød+0.5 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TF6029S-102Y20R0-01 TF6029S-102Y30R0-02 Inductance (mH)min. 1 1 DC resistance (mΩ)max. 5 4 Rated current (A)max. 20 30 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF6029S 70pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød H max. 2.3 36 2.6 40 10 100 (7/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type VERTICAL TYPE TF SERIES FEATURES • This series uses a high permeability toroidal ferrite core and therefore provides large inductance with a little number of turns. • Therefore its stray capacity is small and it provides the impedance levels required to effectively suppress high frequency noises. • Products mounted on a base with fixed leads are easy to insert to circuit boards. TF1320S(VERTICAL TYPE WITHOUT TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 13max. ø20max. (20) 100 TF1320S-402Y1R5-01 10 2 3 1 L1 2 4 Impedance (kΩ) 1 15±2 ∗ ød ∗ TF1320S-402Y1R5-01: 5±2 4 Weight: 6.5g typ. 3 Recommended hole diameter: ød+0.5 Dimensions in mm L2 1 TF1320S-102Y3R0-01 0.1 0.01 TF1320S-222Y2R0-01 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF1320S-402Y1R5-01 TF1320S-222Y2R0-01 TF1320S-102Y3R0-01 Inductance (mH)min. 4 2.2 1 DC resistance (Ω)max. 0.2 0.1 0.04 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN") • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF1320S 1000pieces/box • All specifications are subject to change without notice. Rated current (A)max. 1.5 2 3 Dimensions(mm) ød 0.4 0.5 0.6 1 Frequency (MHz) 10 100 (8/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF2628V(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (10) 1 5±1 28max. 2 4 1 L1 TF2628V-702Y2R5-01 TF2628V-502Y3R0-01 TF2628V-402Y4R0-01 10 3 Impedance (kΩ) ø27max. ød 100 (15) 21max. 4 1 TF2628V-451Y10R0-01 TF2628V-801Y8R0-01 TF2628V-152Y5R0-01 L2 0.1 3 2 Weight: 20g typ. 0.01 Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF2628V-702Y2R5-01 TF2628V-502Y3R0-01 TF2628V-402Y4R0-01 TF2628V-152Y5R0-01 TF2628V-801Y8R0-01 TF2628V-451Y10R0-01 Inductance (mH)min. 7 5 4 1.5 0.8 0.45 DC resistance (Ω)max. 0.2 0.15 0.1 0.05 0.02 0.015 Rated current (A)max. 2.5 3 4 5 8 10 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF2628V 700pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.6 0.65 0.7 0.8 1 1.1 1 Frequency (MHz) 10 100 (9/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF3524V(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS (18) 4 35max. 2 3 4 1 L1 ød L2 3 2 TF3524V-103Y3R0-01 TF3524V-702Y4R0-01 TF3524V-502Y5R0-01 10 Impedance (kΩ) ø35max. 5±1 100 (16) 25max. 1 1 TF3524V-301Y20R0-01 TF3524V-601Y15R0-01 TF3524V-102Y10R0-01 0.1 TF3524V-202Y8R0-01 Weight: 41g typ. TF3524V-402Y6R0-01 Recommended hole diameter: ød+0.5 or more Dimensions in mm 0.01 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF3524V-103Y3R0-01 TF3524V-702Y4R0-01 TF3524V-502Y5R0-01 TF3524V-402Y6R0-01 TF3524V-202Y8R0-01 TF3524V-102Y10R0-01 TF3524V-601Y15R0-01 TF3524V-301Y20R0-01 Inductance (mH)min. 10 7 5 4 2 1 0.6 0.3 DC resistance (Ω)max. 0.15 0.1 0.05 0.035 0.025 0.02 0.007 0.005 Rated current (A)max. 3 4 5 6 8 10 15 20 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF3524V 320pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.7 0.8 0.9 1 1.2 1.3 1.6 1.8 1 Frequency (MHz) 10 100 (10/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Separable Case Type MULTI-SECTION CASE TYPE (FOR HIGH FREQUENCY) TF SERIES FEATURES • This series uses six-section windings for each line, which contribute to reduced stray capacity and excellent impedance characteristics in high frequency ranges. TF3329B(FOR HIGH FREQUENCY) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 7.5±0.5 7.5±0.5 1 3 4 100 Impedance (kΩ) 10±0.5 2 ø33max. 4 30max. 1 L1.a L 2.a T1 T2 L1.b 4±1 TF3329B-153Y2R5-01 0.1 Recommended hole diameter: ø1.3 Dimensions in mm ELECTRICAL CHARACTERISTICS TF3329B-153Y2R5-01 TF3329B-103Y3R0-01 TF3329B-852Y3R5-01 Inductance (mH)min. 15 10 8.5 DC resistance (Ω)max. 120 100 70 Rated current (A)max. 2.5 3 3.5 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF3329B TF3329B-103Y3R0-01 3 Weight: 40.5g typ. Part No. TF3329B-852Y3R5-01 1 L 2.b 2 ø1 10 375pieces/box • All specifications are subject to change without notice. 0.01 0.1 1 Frequency (MHz) 10 100 (11/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type FEATURES • This series is designed to reduce stray capacity between windings by using a single-layer coil construction on Ni-Zn ferrite cores, which offer excellent high frequency characteristics. • This series provides exellent noise suppression for high frequency ranges including the FM band. TF2628V-1H(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (10) 4 2 1 3 4 1 28max. TF2628V-650Y6R0-1H Impedance (kΩ) ø27max. 5±1 10 (15) 21max. 1 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS L1 L2 3 2 Weight: 18g typ. ød 0.1 TF2628V-450Y9R0-1H 0.01 Recommended hole diameter: ød+0.5 Dimensions in mm TF2628V-250Y12R0-1H 0.001 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF2628V-650Y6R0-1H TF2628V-450Y9R0-1H TF2628V-250Y12R0-1H Inductance (µH)min. 65 45 25 DC resistance (Ω)max. 0.02 0.012 0.009 Rated current (A)max. 6 9 12 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF2628V 700pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.8 1.0 1.2 1 Frequency (MHz) 10 100 (12/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type TF3524V-1H(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 1 (18) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 4 (16) 25max. 10 TF3524V-121Y8R0-1H 1 3 4 1 35max. Impedance (kΩ) 2 ø35max. L1 L2 2 3 5±1 TF3524V-750Y12R0-1H TF3524V-450Y15R0-1H 0.01 Weight: 40g typ. ød 0.1 TF3524V-250Y20R0-1H Recommended hole diameter: ød+0.5 Dimensions in mm 0.001 0.01 0.1 ELECTRICAL CHARACTERISTICS Part No. TF3524V-121Y8R0-1H TF3524V-750Y12R0-1H TF3524V-450Y15R0-1H TF3524V-250Y20R0-1H Inductance (µH)min. 120 75 45 25 DC resistance (Ω)max. 0.02 0.01 0.007 0.005 Rated current (A)max. 8 12 15 20 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF3524V 320pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 1.0 1.3 1.6 1.8 1 Frequency (MHz) 10 100 (13/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TOROIDAL CORE TYPE FOR THREE PHASE LINES TF SERIES FEATURES • This series uses a high permeability toroidal ferrite core and can handle heavy currents with fewer number of turns. TF6030T(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 12.7±0.5 22.9±0.5 22.9±0.5 13.3±0.5 26±0.5 2 3 100 TF6030T-752Y5R0-01 4 12.7±0.5 6 5 Impedance (kΩ) ø60max. 1 1000 14.6±0.5 7±0.5 10 1 0.1 TF6030T-102Y14R0-01 5±1 36max. TF6030T-162Y10R0-01 0.01 0.01 0.1 ød 2 3 L1 L2 Weight: 150g typ. 1 Recommended hole diameter: ød+0.5 Dimensions in mm 4 6 5 L3 ELECTRICAL CHARACTERISTICS Part No. TF6030T-752Y5R0-01 TF6030T-162Y10R0-01 TF6030T-102Y14R0-01 Inductance (mH)min. 7.5 1.6 1 DC resistance (Ω)max. 0.1 0.02 0.02 Rated current (A)max. 5 10 14 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF6030T 70pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 0.9 1.3 1.5 1 Frequency (MHz) 10 100 (14/14) 003-04 / 20050805 / e93_tf.fm EMC Components TF Series Common Mode Choke Coils(Line Filters) for AC Power Supply Toroidal Core Type for 3-Phase TF6035T(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 12.7±0.5 22.9±0.5 22.9±0.5 13.3±0.5 26±0.5 2 3 10 5 4 12.7±0.5 6 Impedance (kΩ) ø62max. 1 100 14.6±0.5 7±0.5 1 TF6035T-162Y15R0-01 TF6035T-102Y20R0-01 TF6035T-501Y25R0-01 TF6035T-201Y30R0-01 36max. 0.1 5±1 0.01 0.01 0.1 ød 2 3 L1 L2 Weight: 160g typ. 1 Recommended hole diameter: ød+0.5 Dimensions in mm 4 6 5 L3 ELECTRICAL CHARACTERISTICS Part No. TF6035T-162Y15R0-01 TF6035T-102Y20R0-01 TF6035T-501Y25R0-01 TF6035T-201Y30R0-01 Inductance (mH)min. 1.6 1 0.5 0.2 DC resistance (mΩ)max. 12 8 5 3 Rated current (A)max. 15 20 25 30 APPLICABLE SAFETY STANDARD Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 • However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF6035T 70pieces/box • All specifications are subject to change without notice. Dimensions(mm) ød 1.8 2 2.3 2.6 1 Frequency (MHz) 10 100
TF2628V-451Y10R0-01 价格&库存
很抱歉,暂时无法提供与“TF2628V-451Y10R0-01”相匹配的价格&库存,您可以联系我们找货
