TF2628V-650Y6R0-1H
TF2628V-650Y6R0-1H
    TDK(东电化)
    插件
    TF2628V 650Y6R0 1H
TF2628V-650Y6R0-1H 数据手册
(1/13) Common Mode Choke Coils(Line Filters) for AC Power Supply Conformity to RoHS Directive Toroidal Core Type TF Series TDK common mode choke coils(line filters) are used in a wide range of prevention of electromagnetic interference(EMI) and radio frequency interference(RFI) from power supply lines and for prevention of multifunctioning of products such as measuring equipment and system equipment. FEATURES • Wide range of selection. • High impedance at applicable frequency. • High self-resonant frequency. PRODUCT IDENTIFICATION TF (1) (2) V - A (3) (4) Y (5) R (6) - 01 (7) (1) Core shape TF: Toroidal core (2) Dimensional code Width× Depth (3) External shape code V: Vertical type H: Horizontal type (4) High µ material (5) Inductance value  Example) 133:13mH (6) Rated current value Example) 3R0:3.0A (7) Product management number SELECTION CHART Series Configuration Vertical type TF Horizontal type Vertical type (For high frequency) Type Inductance value min. Rated current (A) Handling power∗ L× I2(mH× A2) Weight (g)typ. TF1813V TF2518V TF2721V TF3020V TF3525V TF1713H TF2520H TF2722H TF3022H TF3526H TF2628V-1H TF3524V-1H 2 to 20mH 0.65 to 9mH 1 to 13mH 0.35 to 13mH 0.65 to 20mH 2 to 20mH 0.65 to 9mH 1 to 13mH 0.35 to 13mH 0.65 to 20mH 25 to 65µH 25 to 120µH 0.7 to 3.2 2.5 to 10 2.5 to 10 3 to 20 3 to 20 0.7 to 3.2 2.5 to 10 2.5 to 10 3 to 20 3 to 20 6 to 12 8 to 20 20 50 75 130 195 20 50 75 130 195 3.65 10.8 5 15 20 30 41 5.3 15 20 32 42 18 40 Minimum package quantity (pieces/box) 960 560 460 440 240 960 550 380 320 280 700 320 ∗ Handling power=(Inductance value)× (Current)2. It is possible to design within the range below this value. [Example] The coil for 2A can make even the inductance of 2.5mH or less a product for handling power 10. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (2/13) Horizontal Type TF Series FEATURES • This series uses a high permeability toroidal ferrite core and therefore provide large inductance with a little number of turns. • Therefore its stray capacity is small and it keeps the impedance required to effectively suppress high frequency noises. • Products mounted on a base with fixed leads are easy to insert to circuit boards. TF1713H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 7±0.5 4 2 3 100 A203Y0R7 A153Y1R0 20max. 17.5±0.5 1 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ø0.7 17max. 4 2 3 Impedance (kΩ) 3.5±1 13max. 10 1 Weight: 5.3g typ. A652Y1R6 1 Recommended hole diameter: ø1.2 Dimensions in mm A502Y2R0 A202Y3R2 0.1 0.01 Part No. TF1713H-A203Y0R7-01 TF1713H-A153Y1R0-01 TF1713H-A652Y1R6-01 TF1713H-A502Y2R0-01 TF1713H-A202Y3R2-01 DC resistance (Ω)max. 0.73 0.44 0.19 0.14 0.065 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF1713H-A 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) Inductance (mH)min. 20 15 6.5 5 2 0.1 960pieces/box Rated current Iac(A)max. 0.7 1 1.6 2 3.2 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (3/13) TF2520H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 25max. 2 (11) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 3 3.75±0.75 10 1 1 2 Impedance (kΩ) 20max. Lot No. 4 4 3 1 0.1 Weight: 15g typ. 702Y3R0 502Y4R0 252Y5R0 102Y8R0 651Y10R0 Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (Ω)max. TF2520H-A902Y2R5-01 9 0.12 TF2520H-A702Y3R0-01 7 0.095 TF2520H-A502Y4R0-01 5 0.075 TF2520H-A252Y5R0-01 2.5 0.05 TF2520H-A102Y8R0-01 1 0.025 TF2520H-A651Y10R0-01 0.65 0.02 0.1 1 Frequency (MHz) 10 100 RATINGS Rated current Iac(A)max. 2.5 3 4 5 8 10 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF2520H-A 902Y2R5 (20) 25max. 100 550pieces/box ød (mm) 0.6 0.65 0.7 0.75 0.95 1 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (4/13) TF2722H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 27max. 2 (11) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 3 3.75±0.75 10 1 1 2 Impedance (kΩ) 22max. Lot No. 4 4 3 1 0.1 Weight: 20g typ. 103Y3R0 652Y4R0 422Y5R0 152Y8R0 102Y10R0 Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (mΩ)max. TF2722H-A133Y2R5-01 13 130 TF2722H-A103Y3R0-01 10 90 TF2722H-A652Y4R0-01 6.5 60 TF2722H-A422Y5R0-01 4.2 40 TF2722H-A152Y8R0-01 1.5 20 TF2722H-A102Y10R0-01 1 11 0.1 1 Frequency (MHz) 10 100 RATINGS Rated current Iac(A)max. 2.5 3 4 5 8 10 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF2722H-A 133Y2R5 (20) 27max. 100 380pieces/box ød (mm) 0.65 0.7 0.8 0.9 1 1.2 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (5/13) TF3022H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 30max. 2 (11) 3 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 1 3.75±0.75 Impedance (kΩ) 10 22max. Lot No. (24) 30max. 133Y3R0 802Y4R0 4 1 4 2 3 602Y5R0 1 0.1 Weight: 32g typ. Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 Rated current Iac(A)max. 3 4 5 6 7 8 10 15 20 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF3022H-A 0.1 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (Ω)max. TF3022H-A133Y3R0-01 13 0.1 TF3022H-A802Y4R0-01 8 0.07 TF3022H-A602Y5R0-01 6 0.05 TF3022H-A502Y6R0-01 5 0.04 TF3022H-A402Y7R0-01 4 0.035 TF3022H-A252Y8R0-01 2.5 0.025 TF3022H-A172Y10R0-01 1.7 0.015 TF3022H-A701Y15R0-01 0.7 0.007 TF3022H-A351Y20R0-01 0.35 0.005 502Y6R0 402Y7R0 252Y8R0 172Y10R0 701Y15R0 351Y20R0 ød (mm) 0.75 0.8 0.9 0.95 1 1.1 1.3 1.6 1.7 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. 320pieces/box • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (6/13) TF3526H-A(HORIZONTAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 35max. (11) 2 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 3 100 203Y3R0 123Y4R0 (28) 33max. 103Y5R0 26max. 1 Impedance (kΩ) Lot No. 10 4 1 2 4 1 702Y6R0 602Y7R0 452Y8R0 0.1 3 302Y10R 102Y15R 3.75±0.75 651Y20R0 Weight: 42g typ. Recommended hole diameter: ød+0.5 Dimensions in mm Rated current Iac(A)max. 3 4 5 6 7 8 10 15 20 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF3526H-A 0.1 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (mΩ)max. TF3526H-A203Y3R0-01 20 130 TF3526H-A123Y4R0-01 12 75 TF3526H-A103Y5R0-01 10 55 TF3526H-A702Y6R0-01 7 45 TF3526H-A602Y7R0-01 6 35 TF3526H-A452Y8R0-01 4.5 25 TF3526H-A302Y10R0-01 3 18 TF3526H-A102Y15R0-01 1 6 TF3526H-A651Y20R0-01 0.65 4 0.01 0.01 ød (mm) 0.75 0.85 0.95 1 1.1 1.2 1.3 1.7 1.8 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. 280pieces/box • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (7/13) Vertical Type TF Series 16max. TF1813V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 100 3.5±1 ø0.7 A203Y0R7 A153Y1R0 13max. 18max. 1 4 2 3 1 4 2 3 10 Impedance (kΩ) 7±0.5 14±0.5 Weight: 5g typ. Recommended hole diameter: ø1.2 Dimensions in mm A652Y1R6 1 A502Y2R0 A202Y3R2 0.1 0.01 Part No. TF1813V-A203Y0R7-01 TF1813V-A153Y1R0-01 TF1813V-A652Y1R6-01 TF1813V-A502Y2R0-01 TF1813V-A202Y3R2-01 DC resistance (Ω)max. 0.73 0.44 0.19 0.14 0.065 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF1813V-A 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) Inductance (mH)min. 20 15 6.5 5 2 0.1 960pieces/box Rated current Iac(A)max. 0.7 1 1.6 2 3.2 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (8/13) TF2518V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (10) 1 4 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS A902Y2R5 (13) 18max. 100 ø25max. 2 3 27max. 3.75±0.75 4 1 L1 L2 2 3 Weight: 15g typ. ød Recommended hole diameter: ød+0.5 Dimensions in mm Impedance (kΩ) 10 1 0.1 0.01 0.01 ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (Ω)max. TF2518V-A902Y2R5-01 9 0.12 TF2518V-A702Y3R0-01 7 0.095 TF2518V-A502Y4R0-01 5 0.075 TF2518V-A252Y5R0-01 2.5 0.05 TF2518V-A102Y8R0-01 1 0.025 TF2518V-A651Y10R0-01 0.65 0.02 A252Y5R0 A102Y8R0 A651Y10R0 0.1 1 Frequency (MHz) 10 100 RATINGS Rated current Iac(A)max. 2.5 3 4 5 8 10 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF2518V-A A702Y3R0 A502Y4R0 560pieces/box ød (mm) 0.6 0.65 0.7 0.75 0.95 1 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (9/13) TF2721V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 1 (10) 4 3 28max. 10 Impedance (kΩ) 2 4 1 L1 L2 2 3 Weight: 20g typ. ød Recommended hole diameter: ød+0.5 Dimensions in mm 1 0.1 0.01 0.01 ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (mΩ)max. TF2721V-A133Y2R5-01 13 130 TF2721V-A103Y3R0-01 10 90 TF2721V-A652Y4R0-01 6.5 60 TF2721V-A422Y5R0-01 4.2 40 TF2721V-A152Y8R0-01 1.5 20 TF2721V-A102Y10R0-01 1 11 103Y3R0 652Y4R0 422Y5R0 152Y8R0 102Y10R0 0.1 1 Frequency (MHz) 10 100 RATINGS Rated current Iac(A)max. 2.5 3 4 5 8 10 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF2721V-A 133Y2R5 (15) 21max. 100 ø27max. 3.75±0.75 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 460pieces/box ød (mm) 0.65 0.7 0.8 0.9 1 1.2 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (10/13) TF3020V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (10) 4 31max. 3 10 4 1 L1 L2 2 ød 133Y3R0 802Y4R0 Impedance (kΩ) 2 ø30max. 3.75±0.75 100 (15) 20max. 1 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 3 Weight: 30g typ. 602Y5R0 1 0.1 Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.01 0.1 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance Part No. resistance (mH)min. (Ω)max. TF3020V-A133Y3R0-01 13 0.1 TF3020V-A802Y4R0-01 8 0.07 TF3020V-A602Y5R0-01 6 0.05 TF3020V-A502Y6R0-01 5 0.04 TF3020V-A402Y7R0-01 4 0.035 TF3020V-A252Y8R0-01 2.5 0.025 TF3020V-A172Y10R0-01 1.7 0.015 TF3020V-A701Y15R0-01 0.7 0.007 TF3020V-A351Y20R0-01 0.35 0.005 502Y6R0 402Y7R0 252Y8R0 172Y10R0 701Y15R0 351Y20R0 Rated current Iac(A)max. 3 4 5 6 7 8 10 15 20 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] ød (mm) 0.75 0.8 0.9 0.95 1 1.1 1.3 1.6 1.7 Item Rated voltage(V) Dielectric withstanding voltage(V) Insulation resistance (MΩ) Temperature rise(°C) Operating temperature range(°C) Storage temperature range(°C) Resistance to soldering tenperature∗1 ∗1 ∗2 Standard value 80 to 280 2000 100min. 45max. –20 to +120 Conditions 50Hz/60Hz Between each winding for 1 minute Between each winding for DC.500V With line resistance Including self-temperature rise –20 to +85 260±5°C, 10±1sec Solder bath method 350±5°C, 5sec max. Soldering iron method Pb free solder(Sn-3Ag-0.5Cu) However, this product is not recognized by each regulations. PACKAGING QUANTITIES TF3020V-A 440pieces/box • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (11/13) TF3525V-A(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 1 (18) TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 4 (16) 25max. 100 203Y3R0 123Y4R0 103Y5R0 4 35max. 1 3.75±0.75 10 3 Impedance (kΩ) 2 ø35max. L1 L2 2 3 0.1 Recommended hole diameter: ød+0.5 Dimensions in mm 0.1 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) Rated current Iac(A)max. 3 4 5 6 7 8 10 15 20 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=1kHz] PACKAGING QUANTITIES TF3525V-A 302Y10R0 102Y15R0 651Y20R0 0.01 0.01 DC Inductance Part No. resistance (mH)min. (mΩ)max. TF3525V-A203Y3R0-01 20 130 TF3525V-A123Y4R0-01 12 75 TF3525V-A103Y5R0-01 10 55 TF3525V-A702Y6R0-01 7 45 TF3525V-A602Y7R0-01 6 35 TF3525V-A452Y8R0-01 4.5 25 TF3525V-A302Y10R0-01 3 18 TF3525V-A102Y15R0-01 1 6 TF3525V-A651Y20R0-01 0.65 4 702Y6R0 602Y7R0 452Y8R0 Weight: 41g typ. ød 1 ød (mm) 0.75 0.85 0.95 1 1.1 1.2 1.3 1.7 1.8 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. 240pieces/box • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (12/13) Vertical Type (For High Frequency) TF Series FEATURES • This series is designed to reduce stray capacity between windings by using a single-layer coil construction on Ni-Zn ferrite cores, which offer excellent high frequency characteristics. • This series provides excellent noise suppression for high frequency ranges including the FM band. TF2628V-1H(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM (10) 1 4 (15) 21max. 10 2 3 4 1 28max. 1 Impedance (kΩ) ø27max. L1 L2 2 3 Weight: 18g typ. 5±1 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ød Recommended hole diameter: ød+0.5 Dimensions in mm 0.01 0.001 0.01 Part No. TF2628V-650Y6R0-1H TF2628V-450Y9R0-1H TF2628V-250Y12R0-1H Rated current Iac(A)max. 6 9 12 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=10kHz] PACKAGING QUANTITIES TF2628V-1H 0.1 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) DC Inductance resistance (µH)min. (mΩ)max. 65 20 45 12 25 9 650Y6R0 450Y9R0 250Y12R0 0.1 700pieces/box ød (mm) 0.8 1 1.2 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm (13/13) TF3524V-1H(VERTICAL TYPE WITH TERMINAL BASE) TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM 1 (18) 4 (16) 25max. 10 4 1 35max. 1 3 Impedance (kΩ) 2 ø35max. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS L1 L2 2 3 5±1 Weight: 40g typ. ød 0.01 Recommended hole diameter: ød+0.5 Dimensions in mm 0.001 0.01 Part No. Inductance (µH)min. TF3524V-121Y8R0-1H TF3524V-750Y12R0-1H TF3524V-450Y15R0-1H TF3524V-250Y20R0-1H 120 75 45 25 DC resistance (mΩ)max. 20 10 7 5 0.1 1 Frequency (MHz) 10 100 RATINGS ELECTRICAL CHARACTERISTICS (STANDARD LINE UP) Rated current Iac(A)max. 8 12 15 20 • Measuring equipment of inductance value: LCR meter(HP4261A, HP4263B or equivalent)[f=10kHz] PACKAGING QUANTITIES TF3524V-1H 121Y8R0 750Y12R0 450Y15R0 250Y20R0 0.1 320pieces/box ød (mm) 1 1.3 1.6 1.8 Item Standard value Conditions Rated voltage(V) 80 to 280 50Hz/60Hz Dielectric withstanding Between each winding for 2000 voltage(V) 1 minute Insulation resistance Between each winding for 100min. (MΩ) DC.500V Temperature rise(°C) 45max. With line resistance Operating temperature Including self-temperature –20 to +120 range(°C) rise Storage temperature –20 to +85 range(°C) 260±5°C, 10±1sec Solder bath method Resistance to soldering tenperature∗1 350±5°C, 5sec max. Soldering iron method Applicable safety Electrical Appliance and Material Safety Law ("DENAN"), IEC60065, UL6500, CSA C22.2 standard∗2 ∗1 Pb free solder(Sn-3Ag-0.5Cu) ∗2 However, this product is not recognized by each regulations. • All specifications are subject to change without notice. 001-03 / 20061027 / e93_tf.fm
TF2628V-650Y6R0-1H 价格&库存
很抱歉,暂时无法提供与“TF2628V-650Y6R0-1H”相匹配的价格&库存,您可以联系我们找货
