TFM201208ALC-1R0MTAA
    TDK(东电化)
    功率电感 0805
TFM201208ALC-1R0MTAA 数据手册
TDK Thin Film Technology TDK Thin Film Power inductor TFM201208ALC-TAA series PRODUCTS SHAPE FEATURES •The thickness of this product is 0.8mm,and it is very thin compared with other same kind of products. •This product consists of original fine copper pattern with micro-processing technology . •The coil pattern is coated with metal magnetic material. •Superior DC-Bias characteristics . •This product corresponds to ROHS. Terminal Height Length Width APPLICATIONS DIMENSIONS •Generic use for DC/DC Converter of portable device. •Used for Smart phone, Feature phone, HDD, SSD, etc. Length Width Height Terminal ±0.2 ±0.2 Max. Ref. [mm] [mm] [mm] [mm] 2.0 TFM201208 1.25 0.5 0.8 OPERATING TEMPERATURE RANGE -40 ~ 125 deg.C (Include self temperature rise 40 deg.C) RECOMMENDED LAND PATTERN PRODUCT IDENTIFICATIONS A TFM 2012 08 ALC – R47 M TAA (1) (2) (3) (4) (5) (6) (7) C (1) Series name (2) Product size ( Length , Width ) (3) Product height (4) Product identification (5) Inductance value (6) Inductance tolerance ( M :±20% ) (7) Control mark B TFM201208 A [mm] B [mm] C [mm] 2.4 1.2 1.2 ELECTRICAL CHARACTERISTICS Identification Inductance [mH] Test frequency [MHz] DC Resistance [mOhm] Isat [A] Itemp [A] Max Typ. Max Typ. Max Typ. TFM201208ALC-R47MTAA 0.47 +/-20% 1.0 33 29 4.1 4.3 3.9 4.3 TFM201208ALC-1R0MTAA 1.0 +/-20% 1.0 90 78 2.8 3.1 2.3 2.5 Isat : Depend on the Inductance Saturation. ( -30% Reduction from Initial L Value/ Test Freq. 1MHz ) Itemp : Depend on the Self Temperature Rise. ( 40deg.C Typ. ) 2017.Jun. rev.1 TDK Thin Film Technology TDK Thin Film Power inductor TFM201208ALC-TAA series INDUCTANCE VS.DC SUPERPOSITION CHARACTERISTICS ( 1MHz ) FREQUENCY CHARACTERISTICS Inductance vs. Frequency 2017.Jun. Resistance vs. Frequency rev.1
1. 物料型号: - TFM201208ALC-R47MTAA:0.47 mH,公差±20% - TFM201208ALC-1R0MTAA:1.0 mH,公差±20%
2. 器件简介: - 该产品厚度为0.8mm,与其他同类产品相比非常薄。 - 由原始的精细铜图案和微加工技术构成。 - 线圈图案涂有金属磁性材料。 - 具有优越的直流偏置特性。 - 符合ROHS标准。
3. 引脚分配: - 没有明确指出引脚分配,但提供了尺寸参考,包括长度、宽度、高度和端头尺寸。
4. 参数特性: - 测试频率:1.0 MHz - DC电阻:最大值和典型值分别为33 mOhm和29 mOhm(对于0.47 mH型号),90 mOhm和78 mOhm(对于1.0 mH型号) - Isat(饱和电流):最大值和典型值分别为4.1 A和3.9 A(对于0.47 mH型号),2.8 A和2.3 A(对于1.0 mH型号) - Itemp(自热电流):最大值和典型值分别为4.3 A和4.3 A(对于0.47 mH型号),3.1 A和2.5 A(对于1.0 mH型号)
5. 功能详解: - 该产品适用于便携式设备的DC/DC转换器。 - 用于智能手机、功能手机、硬盘驱动器、固态硬盘等。
6. 应用信息: - 通用于便携式设备的DC/DC转换器。 - 用于智能手机、功能手机、硬盘驱动器、固态硬盘等。
7. 封装信息: - 产品尺寸:长度±0.2 mm,宽度±0.2 mm,最大高度0.8 mm。 - 推荐焊盘图案尺寸:长度2.4 mm,宽度1.2 mm,高度1.2 mm。
8. 操作温度范围: - -40 ~ 125°C(包括自升温40°C)。
TFM201208ALC-1R0MTAA 价格&库存
很抱歉,暂时无法提供与“TFM201208ALC-1R0MTAA”相匹配的价格&库存,您可以联系我们找货
  • 1600+0.58037
  • 4000+0.56828
  • 16400+0.54410
  • 42400+0.51992
  • 134000+0.49574
库存:232738
