TFM201210ALMAR56MTAA
    TDK(东电化)
    560 nH 屏蔽 薄膜 电感器 2.8 A 49 毫欧最大 0805(2012 公制)
TFM201210ALMAR56MTAA 数据手册
I N D U C T O R S Inductors for power circuits Thin-film metal magnetic material TFM-ALMA series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 TFM201210ALMA type FEATURES By using metal magnetic material with high Saturation magnetic flux density the excellent DC bias characteristics needed for inductors for power circuits can be achieved. With the same product shape and terminal structure as general chip parts it has excellent mounting stability characteristics and can also be mounted to general-purpose land patterns. By using a closed magnetic circuit structure leakage flux is minimized. Compliant with AEC-Q200. APPLICATION ADAS ECU, in-Vehicle camera (view camera, sensing camera), radar, meter cluster, automotive communication module Other power supply circuit uses Application guides: Automotive (xEV), Car Infotainment PART NUMBER CONSTRUCTION TFM 201210 ALM A R47 M T AA Series name L×W×H dimensions 2.0×1.25×1.0 mm Characteristic type Automotive use Inductance (µH) Inductance tolerance Packaging style Internal code 特性規格表 L L measuring frequency DC resistance Rated current Rated voltage Part No. Isat Itemp (µH) Tolerance (MHz) (m )max. (m )typ. (A)max. (A)typ. (A)max. (A)typ. (V)max. 0.56 ±20% 1 3.0 3.4 2.8 3.2 20 TFM201210ALMAR56MTAA 49 39 2.2 ±20% 1 1.2 1.4 1.1 1.3 20 TFM201210ALMA2R2MTAA 282 240  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Please contact us for the rated current vs. temperature characteristics (derating) at a product temperature of 85°C or higher. Measurement equipment Measurement item Product No. L 4294A DC resistance Digital Milliohm Meter Rated current Isat 4285A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range Storage temperature range –55 to +150 °C –55 to +150 °C  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Individual weight 15 mg Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210331 inductor_automotive_power_tfm201210alma_en.fm I N D U C T O R S TFM201210ALMA type L FREQUENCY CHARACTERISTICS Inductance(µH) 10 2R2 1 R56 0.1 0.01 0.1 1 10 100 Frequency(MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 2.5 2R2 Inductance(µH) 2 1.5 1 R56 0.5 0 0 1 2 3 DC current(A) 4 5 6 Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20210331 inductor_automotive_power_tfm201210alma_en.fm I N D U C T O R S TFM201210ALMA type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 1.25±0.20 2.00±0.20 1.0max. ø60min. 1.0 2.0±0.5 8.4 +2.0 –0.0 ø13±0.2 14.4max. ø21±0.8 0.50±0.30 ø180±2.0 Dimensions in mm Dimensions in mm 1.5 +0.1 –0.0 2.0±0.05 4.0±0.1 1.25 B 8.0±0.3 RECOMMENDED LAND PATTERN 0.60 1.20 4.0±0.1 A K 3.5±0.1 Sprocket hole 1.75±0.1 TAPE DIMENSIONS Cavity Dimensions in mm 0.60 Dimensions in mm Type TFM201210ALMA 160min. A (1.5) Taping B (2.3) K (1.1) 200min. RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling 300min. Drawing direction Peak Dimensions in mm 250 to 260°C PACKAGE QUANTITY Temperature 230°C 230°C Package quantity 3000 pcs/reel 180°C 10s max. 150°C 60 to 120s 30 to 50s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210331 inductor_automotive_power_tfm201210alma_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210331 inductor_automotive_power_tfm201210alma_en.fm
TFM201210ALMAR56MTAA 价格&库存
很抱歉,暂时无法提供与“TFM201210ALMAR56MTAA”相匹配的价格&库存,您可以联系我们找货
  • 3000+2.174333000+0.28091
  • 6000+2.050456000+0.26491
  • 9000+1.981389000+0.25598
  • 15000+1.8977615000+0.24518
  • 21000+1.8446821000+0.23832
  • 30000+1.8174930000+0.23481
库存:1680
  • 1+4.398171+0.56821
  • 10+3.6016010+0.46530
  • 100+2.95902100+0.38229
  • 1000+2.433301000+0.31437
库存:1680
