TFM252010GHM-R47MTAA
    TDK(东电化)
    SMD,2.5x2mm
    功率电感 470nH ±20% IND_2.5X2MM_SM 1.00mm 2.50 x 2.00mm 4.6A
TFM252010GHM-R47MTAA 数据手册
パワーインダクタ Power inductor 車載用パワーインダクタ CLF-D シリーズ Power inductor CLF-D series for automotive  Magnetic shield type wound inductor for power circuits.  It can be used at a wide temperature range. –55~+150°C (Including self-temperature rise)  1 to 470μH, wide E-6 Series lineup allows for various usages. 大電流、低抵抗薄膜パワーインダクタ TFM-GHMシリーズ High current, low DCR thin film power inductor TFM-GHM series  Small case size (2520 & 2016 [mm] Case size), Low Profile (1.0mm Max)  Inductance line up 0.47uH ~ 2.2uH  High DC Bias characteristics are realized with metal core. 金属磁性材料使用 巻線型インダクタ VLS-HBXシリーズ Wound inductor using a metallic magnetic material, VLS-HBX series  Magnetic shield type wound inductor using a metallic magnetic material.  Magnetically shielded configuration allowing for high-density mounting.  The optimal structural design and metallic material was achieved high current, low Rdc, high efficiency. CEATEC2014-11 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 車載用パワーインダクタ New CLF-D シリーズ Power inductor CLF-D series for automotive Features  Magnetic shield type wound inductor for power circuits.  It can be used at a wide temperature range. –55~+150°C (Including self-temperature rise)  1 to 470μH, wide E-6 Series lineup allows for various usages. Major Applications  Equipment used for automobiles (ECM, airbags, headlights, electronic power steering, meters, ABS, other) CharacteristicsSpecifications Examples Ls (uH) CLF7045NIT series Inductance saturation curve 8 7 6 5 4 3 2 1 0 1R0N 3R3N 0 2000 4000 6000 100M 330M 60 2R2N 6R8N 8000 DC current (mA) 80 Ls (uH) 1R5N 4R7N 10000 150M 470M 220M 680M 40 20 0 0 500 1000 1500 2000 2500 3000 3500 4000 4500 DC current (mA) Ls(uH) 600 101M 331M 400 151M 471M 221M 200 0 0 CEATEC2014-11 200 400 600 800 1000 DC Current (mA) 1200 1400 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 車載用パワーインダクタ New CLF-D シリーズ Power inductor CLF-D series for automotive Features  Magnetic shield type wound inductor for power circuits.  It can be used at a wide temperature range. –55~+150°C (Including self-temperature rise)  1 to 470μH, wide E-6 Series lineup allows for various usages. Major Applications  Equipment used for automobiles (ECM, airbags, headlights, electronic power steering, meters, ABS, other) CharacteristicsSpecifications Examples Product name L at100kHz (uH) RDC(Ω) Idc1 (A) Idc2 (A) CLF7045NIT-1R0N-D 1.0 ±30% 0.009±30% 6.7 4.8 CLF7045NIT-1R5N-D 1.5 ±30% 0.010±30% 5.5 4.5 CLF7045NIT-2R2N-D 2.2 ±30% 0.013±30% 4.2 4.1 CLF7045NIT-3R3N-D 3.3 ±30% 0.016±30% 3.5 3.7 CLF7045NIT-4R7N-D 4.7 ±30% 0.018±30% 3.1 3.3 CLF7045NIT-6R8N-D 6.8 ±30% 0.022±30% 2.5 3.1 CLF7045NIT-100M-D 10 ±20% 0.033±20% 2.1 2.6 CLF7045NIT-150M-D 15 ±20% 0.048±20% 1.7 2.0 CLF7045NIT-220M-D 22 ±20% 0.069±20% 1.4 1.8 CLF7045NIT-330M-D 33 ±20% 0.097±20% 1.1 1.6 CLF7045NIT-470M-D 47 ±20% 0.130±20% 0.97 1.4 CLF7045NIT-680M-D 68 ±20% 0.170±20% 0.81 1.1 CLF7045NIT-101M-D 100 ±20% 0.270±20% 0.61 0.86 CLF7045NIT-151M-D 150 ±20% 0.450±20% 0.53 0.72 CLF7045NIT-221M-D 220 ±20% 0.630±20% 0.47 0.57 CLF7045NIT-331M-D 330 ±20% 0.800±20% 0.36 0.49 CLF7045NIT-471M-D 470 ±20% 1.200±20% 0.28 0.41 CEATEC2014-11 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 車載用パワーインダクタ New CLF-D シリーズ Power inductor CLF-D series for automotive Features  Magnetic shield type wound inductor for power circuits.  It can be used at a wide temperature range. –55~+150°C (Including self-temperature rise)  1 to 470μH, wide E-6 Series lineup allows for various usages. Major Applications  Equipment used for automobiles (ECM, airbags, headlights, electronic power steering, meters, ABS, other) CharacteristicsSpecifications Examples Powertrain Control Field Diesel Engine ECU Hybrid Vehicle ECU Body Control field Power Source Control ECU Battery ECU Gasoline Engine ECU Air-bag ECU Safety Driving Field Network Gateway ECU ABS ECU Electric Power Steering ECU Pre-Clash Seat Belt ECU CLF7045NIT CEATEC2014-11 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 大電流、低抵抗薄膜パワーインダクタ TFM-GHMシリーズ High current, low DCR thin film power inductor TFM-GHM series Features  Small case size (2520 & 2016 [mm] Case size), Low Profile (1.0mm Max)  Inductance line up 0.47uH ~ 2.2uH  High DC Bias characteristics are realized with metal core. Major Applications  Used for Smart phone, Tablet, etc  For Power circuit module Characteristics Specifications Examples Inductance vs. DC Bias 3.0 TFM2016 Inductance [uH] 2.5 2.2uH 1.0uH 0.47uH 2.0 1.5 1.0 0.5 0.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 Idc [A] 3.0 TFM2520 Inductance [uH] 2.5 2.2uH 1.0uH 0.47uH 2.0 1.5 1.0 0.5 0.0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 Idc [A] CEATEC2014-11 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 大電流、低抵抗薄膜パワーインダクタ TFM-GHMシリーズ High current, low DCR thin film power inductor TFM-GHM series Features  Small case size (2520 & 2016 [mm] Case size), Low Profile (1.0mm Max)  Inductance line up 0.47uH ~ 2.2uH  High DC Bias characteristics are realized with metal core. Major Applications  Used for Smart phone, Tablet, etc  For Power circuit module Characteristics Specifications Examples Characteristics Size [mm] 2.0 x 1.6 2.5 x 2.0 Rated current Inductance DCR [uH] [mOhm] Idc-1 [A] Idc2 [A] Identification TFM201610GHM-R47MTAA 0.47 32 5.0 3.9 TFM201610GHM-1R0MTAA 1.0 50 3.8 3.1 TFM201610GHM-2R2MTAA 2.2 142 2.6 1.9 TFM252010GHM-R47MTAA 0.47 20 4.8 4.6 TFM252010GHM-1R0MTAA 1.0 45 4.0 3.2 TFM252010GHM-2R2MTAA 2.2 85 3.5 2.3 Idc-1 : Depend on the Inductance Saturation. (-30% Reduction from Nominal value). Idc-2 : Depend on the self temperature rise. (40deg.C Max.) Dimensions T W L Size L W T 2016 2.0 +/-0.2 1.6 +/-0.2 1.0 Max 2520 2.5 +/-0.2 2.0 +/-0.2 1.0 Max CEATEC2014-11 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 大電流、低抵抗薄膜パワーインダクタ TFM-GHMシリーズ High current, low DCR thin film power inductor TFM-GHM series Features  Small case size (2520 & 2016 [mm] Case size), Low Profile (1.0mm Max)  Inductance line up 0.47uH ~ 2.2uH  High DC Bias characteristics are realized with metal core. Major Applications  Used for Smart phone, Tablet, etc  For Power circuit module Characteristics Specifications Examples Power circuit Efficiency data Efficiency [%] 100 (3.7V In / 1.8V Out / 4MHz Switching) TFM2016 90 80 70 60 50 40 0.1 1 10 100 1000 Load Current [mA] TFM2016 L=1.0uH Competitor's Inductor Efficiency [%] 100 TFM2520 90 80 70 60 50 40 0.1 1 10 100 1000 Load Current [mA] TFM2520 L=1.0uH Competitor's Inductor CEATEC2014-11 Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 金属磁性材料使用 巻線型インダクタ VLS-HBXシリーズ Wound inductor using a metallic magnetic material, VLS-HBX series Features  Magnetic shield type wound inductor using a metallic magnetic material.  Magnetically shielded configuration allowing for high-density mounting.  The optimal structural design and metallic material was achieved high current, low Rdc, high efficiency. Major Applications  Smart phones, tablet terminals  Other portable device Characteristics Specifications Examples 3.2 Inductance(μH) 1.6 VLS201610HBX-2R2M VLS201610HBX-1R5M 0.8 VLS201610HBX-1R0M VLS201610HBX-R68M VLS201610HBX-R47M 0.4 VLS201610HBX-R33M 0.2 VLS201610HBX-R24M 0.1 0 1 2 3 4 5 6 7 8 DC Bias(A) INDUCTANCE vs. DC BIAS CHARACTERISTICS 3.2 VLS252010HBX-2R2M Inductance(μH) 1.6 VLS252010HBX-1R5M VLS252010HBX-1R0M 0.8 VLS252010HBX-R68M VLS252010HBX-R47M 0.4 VLS252010HBX-R33M 0.2 VLS252010HBX-R24M 0.1 0 CEATEC2014-11 1 2 3 4 5 6 7 8 DC Bias(A) INDUCTANCE vs. DC BIAS CHARACTERISTICS Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 金属磁性材料使用 巻線型インダクタ VLS-HBXシリーズ Wound inductor using a metallic magnetic material, VLS-HBX series Features  Magnetic shield type wound inductor using a metallic magnetic material.  Magnetically shielded configuration allowing for high-density mounting.  The optimal structural design and metallic material was achieved high current, low Rdc, high efficiency. Major Applications  Smart phones, tablet terminals  Other portable device Characteristics Specifications Examples VLS201610HBX Electrical Characteristics Test Freq. (MHz) 1 1 1 1 1 1 1 L (μH) 0.24 0.33 0.47 0.68 1.0 1.5 2.2 Tol. ±20% ±20% ±20% ±20% ±20% ±20% ±20% DC Resistance (Ω) max. typ. 0.030 0.023 0.039 0.031 0.041 0.034 0.053 0.044 0.072 0.060 0.116 0.097 0.170 0.142 Rated DC Current*(A) Idc1 Idc2 max. typ. max. typ. 4.81 5.15 3.74 4.40 4.42 4.79 2.85 3.35 3.50 4.00 2.81 3.30 3.10 3.53 2.47 2.90 2.50 2.90 2.13 2.50 2.00 2.20 1.63 1.92 1.70 1.90 1.45 1.70 TDK Identification VLS201610HBX-R24M VLS201610HBX-R33M VLS201610HBX-R47M VLS201610HBX-R68M VLS201610HBX-1R0M VLS201610HBX-1R5M VLS201610HBX-2R2M *Rated DC current ; The lower value between Idc1 and Idc2 Idc 1 : Depend on the Inductance Saturation. (-30% Reduction from Initial L Value) Idc 2 : Depend on the Self Temperature Rise (40deg.C Typ.) VLS252010HBX Electrical Characteristics L (μH) 0.24 0.33 0.47 0.68 1.0 1.5 2.2 Tol. ±20% ±20% ±20% ±20% ±20% ±20% ±20% Test Freq. (MHz) 1 1 1 1 1 1 1 DC Resistance (Ω) max. typ. 0.029 0.022 0.031 0.025 0.035 0.029 0.048 0.040 0.065 0.054 0.094 0.078 0.120 0.100 Rated DC Current*(A) Idc1 Idc2 max. typ. max. typ. 6.55 7.10 3.91 4.60 5.03 5.46 3.74 4.40 4.53 5.25 3.32 3.90 3.62 4.17 2.98 3.50 3.22 3.57 2.55 3.00 2.70 3.00 2.02 2.38 2.30 2.60 1.76 2.07 TDK Identification VLS252010HBX-R24M VLS252010HBX-R33M VLS252010HBX-R47M VLS252010HBX-R68M VLS252010HBX-1R0M VLS252010HBX-1R5M VLS252010HBX-2R2M *Rated DC current ; The lower value between Idc1 and Idc2 Idc 1 : Depend on the Inductance Saturation. (-30% Reduction from Initial L Value) Idc 2 : Depend on the Self Temperature Rise (40deg.C Typ.) VLS201610HBX Dimensions VLS252010HBX Dimensions 1.0mm Max 1.0mm Max 2.0+/0.2mm CEATEC2014-11 1.6+/0.2mm 2.5+/-0.2mm 2.0+/0.2mm Magnetics Business Group: 03-6852-7229 パワーインダクタ Power inductor 金属磁性材料使用 巻線型インダクタ VLS-HBXシリーズ Wound inductor using a metallic magnetic material, VLS-HBX series Features  Magnetic shield type wound inductor using a metallic magnetic material.  Magnetically shielded configuration allowing for high-density mounting.  The optimal structural design and metallic material was achieved high current, low Rdc, high efficiency. Major Applications  Smart phones, tablet terminals  Other portable device Characteristics Specifications Examples  Power Inductor for DC-DC converter of the smartphone Buck converter Input voltage>Output voltage Switching component Switch ON Power inductor + DC input Switch OFF (Connected to control circuit) Diode + Capacitor DC output - CEATEC2014-11 Magnetics Business Group: 03-6852-7229
TFM252010GHM-R47MTAA 价格&库存
很抱歉,暂时无法提供与“TFM252010GHM-R47MTAA”相匹配的价格&库存,您可以联系我们找货
  • 1+5.701501+0.73770
  • 10+4.6594010+0.60290
  • 100+3.83300100+0.49590
  • 500+2.70700500+0.35030
  • 1000+2.587201000+0.33480
  • 3000+2.575303000+0.33320
库存:3639
    • 3000+2.844203000+0.36713
    • 6000+2.682306000+0.34623
    • 9000+2.592019000+0.33458
    • 15000+2.4827115000+0.32047
    • 21000+2.4475721000+0.31594
    库存:2000
    • 5+0.84594
    • 50+0.66268
    • 600+0.65605
    • 1200+0.64293
    • 3000+0.62364
    库存:1858
    • 1+5.763971+0.74402
    • 10+4.7043910+0.60725
    • 100+3.87001100+0.49954
    • 1000+3.182771000+0.41084
    库存:2000
    • 3000+0.76174
    • 15000+0.73756
    • 33000+0.71337
    库存:44489
