TFM252012ALVA1R5MTAA 数据手册
I N D U C T O R S
Inductors for power circuits
Thin-film metal magnetic material
TFM-ALVA series (for automotive)
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
AEC-Q200
TFM252012ALVA type
FEATURES
By using metal magnetic material with high Saturation magnetic flux density the excellent DC bias characteristics needed for inductors
for power circuits can be achieved.
With the same product shape and terminal structure as general chip parts it has excellent mounting stability characteristics and can also
be mounted to general-purpose land patterns.
By using a closed magnetic circuit structure leakage flux is minimized.
The rated voltage of 40V is realized by design that emphasizes voltage resistance.
Operating temperature range: –55 to +150°C (including self-temperature rise)
Compliant with AEC-Q200
APPLICATION
For automotive (headlights, electronic power steering, meter cluster, ADAS ECU, other)
PART NUMBER CONSTRUCTION
TFM
252012
ALV
A
4R7
M
T
AA
Series name
L×W×H dimensions
2.5×2.0×1.2 mm
Characteristic
type
Automotive
use
Inductance
(µH)
Inductance
tolerance
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
L measuring
frequency
DC resistance
Rated current
Rated
voltage
Part No.
Isat
Itemp
(µH)
Tolerance (MHz)
(m )max. (m )typ.
(A)max. (A)typ.
(A)max. (A)typ.
(V)max.
1.0
±20%
1
42
35
4.2
4.7
3.7
4.1
40
TFM252012ALVA1R0MTAA
1.5
±20%
1
60
52
3.3
3.9
3.1
3.3
40
2.2
±20%
1
84
75
2.8
3.3
2.6
2.8
40
TFM252012ALVA2R2MTAA
3.3
±20%
1
140
124
2.1
2.5
2.0
2.2
40
TFM252012ALVA3R3MTAA
4.7
±20%
1
200
180
1.9
2.2
1.6
1.8
40
TFM252012ALVA4R7MTAA
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the initial L value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Please contact us for the rated current vs. temperature characteristics (derating) at a product temperature of 85°C or higher.
Measurement equipment
Measurement item
Product No.
L
4294A
DC resistance
Digital Milliohm Meter
Rated current Isat
4285A+42841A+42842C
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Storage temperature range
–55 to +150 °C
–55 to +150 °C
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
Individual weight
35 mg
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20200823
inductor_automotive_power_tfm252012alva_en.fm
I N D U C T O R S
TFM252012ALVA type
L FREQUENCY CHARACTERISTICS
Inductance(µH)
100
10
4R7
3R3
2R2
1R5
1R0
1
0.1
0.1
1
10
100
Frequency(MHz)
Product No.
Manufacturer
4294A
INDUCTANCE VS. DC BIAS CHARACTERISTICS
5
Inductance(µH)
4
3
4R7
2
3R3
2R2
1
1R5
2
3
4
5
1R0
6
7
DC current(A)
Product No.
Manufacturer
4285A+42841A+42842C
(2/4)
20200823
I N D U C T O R S
TFM252012ALVA type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
2.50±0.20
1.20max.
ø60min.
2.00± 0.20
1.0
0.60±0.30
2.0±0.5
8.4 +2.0
–0.0
ø13±0.2
14.4max.
0.60± 0.30
ø21±0.8
ø180±2.0
Dimensions in mm
Dimensions in mm
1.5 +0.1
–0.0
2.0±0.05
4.0±0.1
2.0
B
8.0+/–2.0
RECOMMENDED LAND PATTERN
3.5±0.1
Sprocket
hole
1.75±0.1
TAPE DIMENSIONS
4.0±0.1
A
K
Cavity
Dimensions in mm
0.7
1.5
0.7
Type
TFM252012ALVA
Dimensions in mm
160min.
A
2.2
Taping
B
2.7
K
1.3
200min.
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
300min.
Drawing direction
Peak
Dimensions in mm
250 to 260°C
PACKAGE QUANTITY
Temperature
230°C
230°C
Package quantity
3000 pcs/reel
180°C
10s max.
150°C
60 to 120s
30 to 50s
Time
(3/4)
20200823
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment,
telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product
is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications
as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification,
while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and
usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of
the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure,
malfunction or defect could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications
below or for any other use exceeding the range or conditions set forth in this specification sheet.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in this specification, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20200823
TFM252012ALVA1R5MTAA 价格&库存
很抱歉,暂时无法提供与“TFM252012ALVA1R5MTAA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+2.612493000+0.33807
- 6000+2.463756000+0.31883
- 9000+2.380819000+0.30809
- 15000+2.2803815000+0.29510
- 21000+2.2277821000+0.28829
- 国内价格
- 1+3.52101
- 100+2.93418
- 500+2.66743
- 1000+2.44719
- 3000+2.29783
- 国内价格 香港价格
- 1+5.214001+0.67472
- 10+4.3207910+0.55914
- 100+3.55471100+0.46000
- 1000+2.923491000+0.37832
