TFM322512ALVA3R3MTAA
    TDK(东电化)
    1210(3225公制)
    FIXED IND 3.3UH 2.3A 113MOHM SMD
TFM322512ALVA3R3MTAA 数据手册
I N D U C T O R S Inductors for power circuits Thin-film metal magnetic material TFM-ALVA series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 TFM322512ALVA type FEATURES By using metal magnetic material with high Saturation magnetic flux density the excellent DC bias characteristics needed for inductors for power circuits can be achieved. With the same product shape and terminal structure as general chip parts it has excellent mounting stability characteristics and can also be mounted to general-purpose land patterns. By using a closed magnetic circuit structure leakage flux is minimized. The rated voltage of 40V is realized by design that emphasizes voltage resistance. Operating temperature range: –55 to +150°C (including self-temperature rise) Compliant with AEC-Q200 APPLICATION For automotive (headlights, electronic power steering, meter cluster, ADAS ECU, other) PART NUMBER CONSTRUCTION TFM 322512 ALV A 4R7 M T AA Series name L×W×H dimensions 3.2x2.5x1.2 mm Characteristic type Automotive use Inductance (µH) Inductance tolerance Packaging style Internal code CHARACTERISTICS SPECIFICATION TABLE L L measuring frequency DC resistance Rated current Rated voltage Part No. Isat Itemp (µH) Tolerance (MHz) (m )max. (m )typ. (A)max. (A)typ. (A)max. (A)typ. (V)max. 1.0 ±20% 1 37 30 4.6 5.1 4.0 4.4 40 TFM322512ALVA1R0MTAA 1.5 ±20% 1 57 46 4.0 4.5 3.2 3.5 40 TFM322512ALVA1R5MTAA 2.2 ±20% 1 77 64 3.3 3.6 2.7 3.0 40 TFM322512ALVA2R2MTAA 3.3 ±20% 1 113 97 2.5 2.8 2.3 2.5 40 TFM322512ALVA3R3MTAA 4.7 ±20% 1 151 127 2.2 2.5 1.9 2.1 40 TFM322512ALVA4R7MTAA 6.8 ±20% 1 260 220 1.8 2.1 1.4 1.6 40 TFM322512ALVA6R8MTAA 10 ±20% 1 360 305 1.6 1.8 1.2 1.4 40 TFM322512ALVA100MTAA  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Please contact us for the rated current vs. temperature characteristics (derating) at a product temperature of 85°C or higher. Measurement equipment Measurement item Product No. L 4294A DC resistance Digital Milliohm Meter Rated current Isat 4285A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range Storage temperature range –55 to +150 °C –55 to +150 °C  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. Individual weight 0.052 g Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20200823 inductor_automotive_power_tfm322512alva_en.fm I N D U C T O R S TFM322512ALVA type L FREQUENCY CHARACTERISTICS 100 100 Inductance(µH) 6R8 10 4R7 3R3 2R2 1R5 1R0 1 0.1 0.1 1 10 100 Frequency(MHz) Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. INDUCTANCE VS. DC BIAS CHARACTERISTICS 12.0 10.0 Inductance(µH) 8.0 6.0 100 4.0 6R8 4R7 2.0 3R3 2R2 1R5 0.0 0 1 2 3 4 DC current(A) 5 1R0 6 7 8 Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20200823 inductor_automotive_power_tfm322512alva_en.fm I N D U C T O R S TFM322512ALVA type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 3.20±0.20 1.20max. ø60min. 2.50±0.20 1.0 0.60±0.30 2.0±0.5 8.4 +2.0 –0.0 ø13±0.2 14.4max. ø21±0.8 0.60±0.30 ø180±2.0 Dimensions in mm Dimensions in mm 1.5 +0.1 –0 2.0±0.05 4.0±0.1 2.5 B 8.0±0.2 RECOMMENDED LAND PATTERN 4.0±0.1 A K 3.5±0.1 Sprocket hole 1.75±0.1 TAPE DIMENSIONS Cavity Dimensions in mm 0.8 2.0 0.8 Type TFM322512ALVA Dimensions in mm 160min. A 2.8 Taping B 3.5 K 1.4 200min. RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling 300min. Drawing direction Peak Dimensions in mm 250 to 260°C PACKAGE QUANTITY Temperature 230°C 230°C Package quantity 2000 pcs/reel 180°C 10s max. 150°C 60 to 120s 30 to 50s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20200823 inductor_automotive_power_tfm322512alva_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 20 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20200823 inductor_automotive_power_tfm322512alva_en.fm
物料型号:TFM322512ALVA,符合AEC-Q200标准。
器件简介:使用高饱和磁通密度的金属磁性材料,实现优秀的直流偏置特性,适用于电源电路。具有与通用芯片相同的产品形状和端子结构,确保了出色的安装稳定性。
引脚分配:文档中未明确提供引脚分配信息,但通常这类器件会有端子或焊盘用于连接电路。
参数特性:包括不同的电感值(1.0μH至10μH),公差(+20%),测量频率(1MHz),直流电阻,额定电流(Isat和Itemp),以及额定电压(最大40V)。
功能详解:电感器采用封闭磁路结构以最小化漏磁通,设计上强调了耐电压特性。
应用信息:适用于汽车领域,如前大灯、电子助力转向、仪表盘、ADAS ECU等。
封装信息:尺寸为3.2x2.5x1.2mm,封装风格在零件编号中有体现。还提供了推荐的焊盘图案和回流焊接曲线。
TFM322512ALVA3R3MTAA 价格&库存
很抱歉,暂时无法提供与“TFM322512ALVA3R3MTAA”相匹配的价格&库存,您可以联系我们找货
  • 1+7.684121+0.99196
  • 10+6.2841010+0.81123
  • 25+5.8155725+0.75074
  • 50+5.4834150+0.70787
  • 100+5.16952100+0.66735
  • 250+4.78297250+0.61744
  • 500+4.50967500+0.58216
  • 1000+4.252301000+0.54894
库存:7549
  • 2000+3.895332000+0.50286
  • 4000+3.673574000+0.47423
  • 6000+3.549926000+0.45827
  • 10000+3.4002310000+0.43894
  • 14000+3.3420014000+0.43143
库存:7549
