TFSC06054125-2113A1X
    TDK(东电化)
    薄膜定向耦合器
TFSC06054125-2113A1X 数据手册
R F C o m p o n e n t s March 2017 Thin-Film Directional Coupler For 2400-2500MHz / 4900-5850MHz TFSC06054125-2113A1X 0.65x0.5mm [EIA 0202]* * Dimensions Code JIS[EIA] RF Components Thin-Film Directional Coupler Conformity to RoHS Directive For 2400-2500MHz / 4900-5850MHz TFSC06054125-2113A1X SHAPES AND DIMENSIONS [Top view] 0.25±0.05 0.65±0.04 (3) (1) (2) Marking 0.025±0.025 0.50±0.04 (4) [Bottom view] 0.20±0.04 0.25±0.04 0.10±0.04 0.025±0.025 0.20±0.04 Terminal functions 1 Coupling 2 50 terminate 3 Output 4 Input 0.20±0.04 Dimensions in mm RECOMMENDED LAND PATTERN 0.20 0.30 0.20 0.25 0.20 0.30 Dimensions in mm Line width be designed to match 50 characteristic impedance depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170301 / rf_coupler_tfsc06054125-2113a1x_en.fm RF Components TFSC06054125-2113A1X ELECTRICAL CHARACTERISTICS Item Coupling Factor (dB) Insertion Loss (dB) Return Loss (dB) Directivity (dB) Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 4900 to 5850 2400 to 2500 4900 to 5850 2400 to 2500 4900 to 5850 2400 to 2500 4900 to 5850 17.5 11.0 — — 17.69 17.69 15 15 19.0 12.5 0.11 0.41 27.3 20.8 21.5 21.3 50 (Nominal) 20.5 14.0 0.25 0.50 — — — — Characteristic Impedance () ・Ta: +25°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 MSL Moisture Sensitivity Level (MSL) 1 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170301 / rf_coupler_tfsc06054125-2113a1x_en.fm RF Components TFSC06054125-2113A1X FREQUENCY CHARACTERISTICS INSERTION LOSS COUPLING 5 0.0 10 0.4 Coupling(dB) Insertion Loss (dB) 0.2 0.6 15 20 0.8 1.0 2000 2500 3000 3500 4000 4500 Frequency (MHz) 5000 5500 25 2000 6000 0 0 10 10 20 20 30 3500 4000 4500 Frequency (MHz) 5000 5500 6000 3000 3500 4000 4500 Frequency (MHz) 5000 5500 6000 3000 3500 4000 4500 Frequency (MHz) 5000 5500 6000 30 40 40 50 2000 3000 ISOLATION Isolation(dB) Return loss(dB) RETURN LOSS 2500 2500 3000 3500 4000 4500 Frequency (MHz) 5000 5500 50 2000 6000 2500 DIRECTIVITY 0 Directivity(dB) 10 20 30 40 50 2000 2500 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170301 / rf_coupler_tfsc06054125-2113a1x_en.fm RF Components TFSC06054125-2113A1X PACKAGING STYLE REEL DIMENSIONS ø60–0.0 +1.0 2.0±0.5 9.0 +1.0 –0.0 ø13±0.2 ø21±0.8 11.4±1.0 +0 ø180 –3.0 Dimensions in mm TAPE DIMENSIONS G H t C B D E J A K F Dimensions in mm A 0.63±0.03 B 0.81±0.03 C 8.0±0.2 D E 3.5±0.05 1.75±0.1 F 2.0±0.05 G 2.0±0.05 H 4.0±0.1 J 1.5+0.1/-0 K 0.34±0.03 t 0.20±0.05 PACKAGE QUANTITY Standard package quantity (pieces/reel) 10,000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170301 / rf_coupler_tfsc06054125-2113a1x_en.fm RF Components TFSC06054125-2113A1X RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170301 / rf_coupler_tfsc06054125-2113a1x_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20170301 / rf_coupler_tfsc06054125-2113a1x_en.fm
TFSC06054125-2113A1X 价格&库存
很抱歉,暂时无法提供与“TFSC06054125-2113A1X”相匹配的价格&库存,您可以联系我们找货
    • 1+0.65610
    • 10+0.53752
    • 30+0.48665
    • 100+0.42326
    • 500+0.39496
    • 1000+0.37800
    库存:1021
      • 5+0.59535
      • 50+0.44159
      • 2000+0.43717
      • 4000+0.42843
      • 10000+0.41558
      库存:9600
      库存:7390
