TFSC06054125-2120A1X 数据手册
R F
C o m p o n e n t s
March 2018
Thin-Film Directional Coupler
For 2400-2500MHz / 5150-5850MHz
0.65x0.5mm [EIA 0202]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
SHAPES AND DIMENSIONS
[Top view]
0.25±0.02
0.65±0.04
(3)
(1)
(2)
Marking
0.025±0.025
0.50±0.04
(4)
[Bottom view]
0.20±0.04
0.1±0.04
0.25±0.04
0.025±0.025
Terminal functions
1 Coupling port
2 50 terminate
3 Output port
4 Input port
Dimensions in mm
0.20±0.04
RECOMMENDED LAND PATTERN
0.20
0.30
0.20
0.25
0.20
0.30
Dimensions in mm
Line width be designed to match 50 characteristic
impedance depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20180314 / tfs_coupler_tfsc06054125-2120a1x_en.fm
RF Components
ELECTRICAL CHARACTERISTICS
Frequency Range
(MHz)
Item
Coupling Factor (dB)
Insertion Loss (dB)
Return Loss (dB)
Directivity (dB)
2400 to 2500
5150 to 5850
2400 to 2500
5150 to 5850
2400 to 2500
5150 to 5850
2400 to 2500
5150 to 5850
Power Handling (W)
Characteristic Impedance ()
Min.
Typ.
Max.
18.6
12
20.83
19.08
16
12.8
0.07
0.34
35.8
23.7
19.9
23.8
50 (Nominal)
0.2
0.5
3
・Ta: +25°C±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
FREQUENCY CHARACTERISTICS
COUPLING
0.0
5
0.5
10
Coupling(dB)
Insertion Loss(dB)
INSERTION LOSS
1.0
2.0
2000
15
2500
3000
3500
4000
4500
Frequency (MHz)
5000
5500
25
2000
6000
RETURN LOSS
2500
3000
3500
4000
4500
Frequency (MHz)
5000
5500
6000
3000
3500
4000
4500
Frequency (MHz)
5000
5500
6000
3000
3500
4000
4500
Frequency (MHz)
5000
5500
6000
ISOLATION
10
Isolation(dB)
Return Loss(dB)
30
40
40
50
2000
50
2500
3000
3500
4000
4500
Frequency (MHz)
5000
5500
60
2000
6000
2500
DIRECTIVITY
Directivity(dB)
40
50
60
2000
2500
RF Components
PACKAGING STYLE
REEL DIMENSIONS
ø60
+1.0
0.0
2.0±0.5
9.0 +1.0
0.0
ø13±0.2
ø21±0.8
11.4±1.0
ø180 –3.0
Dimensions in mm
TAPE DIMENSIONS
G
H
T
C
B
D
E
J
A
K
F
Dimensions in mm
A
0.63±0.03
B
0.81±0.03
C
8.0±0.2
D
E
3.5±0.05 1.75±0.1
F
2.0±0.05
G
2.0±0.05
H
4.0±0.1
J
ø1.5+0.1/0
K
0.34±0.03
T
0.20±0.05
PACKAGE QUANTITY
Standard package quantity
(pieces/reel)
10,000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
TFSC06054125-2120A1X 价格&库存
很抱歉,暂时无法提供与“TFSC06054125-2120A1X”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.18720
- 100+0.95310
- 500+0.86580
