Thin-film Diplexer
For W-LAN
TFSD Series
Type:
TFSD10055950-5001C1
Issue date:
June 2017
Caution
The products in this catalog will be or have been
stopped production
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/2)
Thin-film Diplexer
For W-LAN
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
TFSD Series TFSD10055950-5001C1
SHAPES AND DIMENSIONS
RECOMMENDED REFLOW SOLDERIG CONDITION
1.0±0.1
Within 10s
2
0.3±0.05
0.3±0.04
2
1
0.27±0.04
0.035±0.035
0.3±0.04
260max.
250±3
230
3
Temperature(˚C)
1
0.035±0.035
0.3±0.05 0.5±0.1
4
3
4
217
180
150
Terminal functions
1 High-band
2 ANTENNA
3 Low-band
4 GND
0.08±0.04
0.235±0.04
Dimensions in mm
More than
45s
60 to 150s
90±30s
Time(s)
* In this product, the recommended soldering condition is ‘reflow’.
Reflow Soldering : Maximum 2 times
0.30
0.76
1.16
0.66
0.30
0.26
RECOMMENDED PC BOARD PATTERNS
Dimensions in mm
The recommended distance to the PCB ground plane is 0.2mm.
Line width be designed to mach 50 characteristic impedance depending on
PCB Material and thickness.
ELECTRICAL CHARACTERISTICS
Item
Insertion loss
Return loss
Attenuation
Th
e
Isolation
Port
Low-band
High-band
ANT
ANT
Low-band
High-band
Low-band
Low-band
High-band
High-band
High-band
High-band
High-band
Temperature range
Frequency range
2400 to 2500MHz
4900 to 5950MHz
2400 to 2500MHz
4900 to 5950MHz
2400 to 2500MHz
4900 to 5950MHz
4800 to 5000MHz
7200 to 7500MHz
824 to 915MHz
1800 to 2500MHz
9800 to 11900MHz
DC to 2500MHz
4900 to 5950MHz
Operating
Storage
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(°C)
(°C)
Minimum value
10
10
10
10
–40
–40
Typical value
0.43
0.49
19.5
20.4
21.4
22.5
23.1
29.2
25.6
24.1
21.0
23.4
23.9
Maximum value
0.5
0.65
+85
+85
• Ta: +25°C
specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
20170623 / tfs_dpx_tfsd10055950_5001c1_en.fm
(2/2)
FREQUENCY CHARACTERISTICS
Low-BAND PORT INSERTION LOSS
1: 2400MHz
0.39dB
2: 2500MHz
0.43dB
2
1.0
1.5
1000
1500
2000
Frequency (MHz)
2500
Low-BAND PORT ATTENUATION
Attenuation(dB)
30
40
60
500
2500
2
1: 4800MHz
23.1dB
2: 5000MHz
26.7dB
3: 7200MHz
29.2dB
4: 7500MHz
36.8dB
3
4500 6500 8500
Frequency (MHz)
Return loss(dB)
50
60
500
2.5
5000
5500
6000
Frequency (MHz)
6500
10
3
4
40
2500
4500 6500 8500
Frequency (MHz)
1: 824MHz
26.4dB
2: 915MHz
25.6dB
3: 1800MHz
24.1dB
6
7 4: 2500MHz
27.5dB
5
5: 9800MHz
29.4dB
6: 11000MHz
21.0dB
7: 1190MHz
23.4dB
10500
1: 2400MHz
21.4dB
2: 2500MHz
22.3dB
1: 4900MHz
22.5dB
2: 5950MHz
26.5dB
10
30
2
40
50
60
1000
Return loss(dB)
2.0
50
500
1500
2000
Frequency (MHz)
2500
10
30
3
70
4500
3000
ANTENNA PORT RETURN LOSS
5000
5500
6000
Frequency (MHz)
4
1: 2400MHz
19.5dB
2: 2500MHz
19.5dB
3: 4900MHz
20.4dB
4: 5950MHz
24.3dB
2
4
5
3
1
2500 3500 4500
Frequency (MHz)
5500
6500
50
500
1500
2500 3500 4500
Frequency (MHz)
5500
1: 500MHz
30.5dB
2: 1500MHz
23.4dB
3: 2500MHz
28.9dB
4: 4900MHz
23.9dB
5: 5950MHz
28.9dB
6500
Th
e
1500
6500
ISOLATION (Low-High)
40
40
50
500
1.5
High-BAND PORT RETURN LOSS
12
30
1.0
Low-BAND PORT RETURN LOSS
10
1: 4900MHz
0.49dB
2: 5950MHz
0.42dB
High-BAND PORT ATTENUATION
4
50
2
1
0.5
3.0
4500
3000
Isolation(dB)
3.0
500
Attenuation(dB)
2.5
Return loss(dB)
2.0
Insertion loss (dB)
1
0.5
High-BAND PORT INSERTION LOSS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Insertion loss (dB)
TFSD10055950-5001C1 价格&库存
很抱歉,暂时无法提供与“TFSD10055950-5001C1”相匹配的价格&库存,您可以联系我们找货
