TLA-3M601-RS
TLA-3M601-RS
    TDK(东电化)
    Module
    脉冲变压器
TLA-3M601-RS 数据手册
LAN COMPONENTS TLA SERIES(Conformity to RoHS Directive) Contents Page Pulse Transformers TLA-3T101LF(-T) 10BASE-2/5/T .....................................................2 TLA-3T108LF(-T) 10BASE-2/5/T......................................................2 TLA-3T106LF(-T) 10BASE-T............................................................4 TLA-3T107LF(-T) 10BASE-T............................................................4 TLA-3T105LF(-T) 10BASE-T............................................................6 TLA-3T109LF(-T) 10BASE-T............................................................6 TLA-3T110LF(-T) 10BASE-T............................................................6 TLA-3T112LF(-T) 10BASE-T............................................................6 TLA-6T103LF(-T) 10/100BASE-TX ..................................................8 TLA-6T118LF(-T) 10/100BASE-TX ..................................................10 TLA-6T119LF(-T) 10/100BASE-TX ..................................................10 TLA-6T120LF(-T) 10/100BASE-TX ..................................................10 TLA-6T121LF(-T) 10/100BASE-TX ..................................................10 TLA-6T122LF(-T) 10/100BASE-TX ..................................................10 TLA-6T127LF(-T) 10/100BASE-TX, PoE..........................................12 TLA-6T133WLF(-T) 10/100BASE-TX ...............................................14 TLA-6T214ALF(-T) 10/100/1000BASE-T .........................................16 TLA-6T213LF(-T) 10/100/1000BASE-TX........................................18 TLA-7T201LF(-T) 10/100/1000BASE-TX........................................20 TLA-6T404(-T) 10/100BASE-TX .....................................................22 TLA-6T406(-T) 10/100BASE-TX .....................................................24 TLA-7T101LF(-T) 10/100/1000BASE-T ..........................................26 Pulse Transformer, Connector Type TLA-6T718 10/100BASE-TX...........................................................28 TLA-6T719 10/100BASE-TX...........................................................30 TLA-6T720 10/100BASE-TX...........................................................32 TLA-6T717W 10/100BASE-TX .......................................................34 LC Modules TLA-3M103LF(-T) 10BASE-T ......................................................36 TLA-3M601-RS 10BASE-T ..........................................................38 TLA-6M102LF(-T) ATM25 ............................................................39 TLA-6M103LF(-T) ATM25 ............................................................41 IC Cross Reference .........................................................................43 Precautions The TDK products in this data are intended for usage in general electronics applications (computer, personal equipment, office equipment, measuring equipment, industrial robotics, domestic appliances, etc.). They are neither intend nor warranted for usage in equipment that requires extraordinarily high quality and/or reliability or a malfunction or failure of which may cause loss of human life or bodily injury (atomic energy control instruments, airplane or spaceship instruments, transportation instrument, traffic signal instruments, combustion control instrument, medical instruments, all types of safety devices, etc.). • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (2/44) LAN Components TLA Series Conformity to RoHS Directive PULSE TRANSFORMERS TLA-3T101LF(-T)/108LF(-T) ISO8802.3(IEEE802.3) 10BASE2/5/-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3T10 LF-T: Tape and reel, TLA-3T10 LF: Bulk). GENERAL SPECIFICATIONS Pulse transformer Port Operating Storage Temperature ranges Withstanding voltage SHAPES AND DIMENSIONS 3 1 0 to +70°C –40 to +85°C Erms:2000V[60s] CIRCUIT DIAGRAM 11.6max. 5.9max. ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ ӹ TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 Ԁ 0.5typ. 1.27typ. ӱ N.C. pins: †‣
‫‫‬ Ӹ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 … ‭ 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : : Inductance (µH)typ.[100kHz] - - - Leakage inductance (µH)max.[100kHz] -[- shorted] -[- shorted] -[- shorted] TLA-3T101LF(-T) TLA-3T108LF(-T) 1:1 1:1 100 75 0.25 0.25 Inter-winding stray capacitance (pF)max.[100kHz] - - - 10 10 DC resistance (Ω)max. -,- -,- -,- 0.35, 0.35 0.35, 0.35 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (3/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (4/44) TLA-3T106LF(-T)/107LF(-T) ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3T10 LF-T: Tape and reel, TLA-3T10 LF: Bulk). SHAPES AND DIMENSIONS GENERAL SPECIFICATIONS Pulse transformer Port Operating Storage Temperature ranges Withstanding voltage 4 4 0 to +70°C –40 to +85°C Erms: 2000V[60s] CIRCUIT DIAGRAM 11.6max. 5.9max. ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 … ‭ 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : : : Inductance (µH)min.[100kHz] - - - - Leakage inductance (µH)max.[100kHz] -[- shorted] -[- shorted] -[- shorted] -[- shorted] TLA-3T106LF(-T) TLA-3T107LF(-T) 1:1 1:1.41 130 130 0.3 0.3 Inter-winding stray capacitance (pF)max.[100kHz] - - - - 12 12 DC resistance (Ω)max. -, - -, - -, - -, - 0.4, 0.4 0.4, 0.5 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (5/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (6/44) TLA-3T105LF(-T)/109LF(-T)/110LF(-T)/112LF(-T) ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3T1 LF-T: Tape and reel, TLA-3T1 LF: Bulk). SHAPES AND DIMENSIONS 11.6max. GENERAL SPECIFICATIONS Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage 2 2 1 0 to +70°C –40 to +85°C Erms: 2000V[60s] CIRCUIT DIAGRAM 5.9max. ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ N.C. pins: ‡•
‪ ‥ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 … ‭ 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-3T105LF(-T) TLA-3T109LF(-T) TLA-3T110LF(-T) TLA-3T112LF(-T) Turns ratio : : Inductance (µH)min.[100kHz] - - Leakage inductance (µH)max.[100kHz] -[- shorted] -[- shorted] 1CT:1CT 1CT:1CT 2CT:1CT 1CT:1CT 1CT:1CT 1CT:1.41CT 1CT:1CT 1CT:2.5CT 130 130 130 130 130 130 130 130 0.3 0.3 0.95 0.35 0.35 0.35 0.35 0.35 Inter-winding stray capacitance (pF)max.[100kHz] - - 12 12 12 12 12 12 12 12 DC resistance (Ω)max. - - 0.5 0.5 0.5 0.5 0.5 0.5 0.85 0.85 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (7/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (8/44) TLA-6T103LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX & ATM FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(2.54mm=100mil pin pitch). • Excellent common-mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T103LF-T: Tape and reel, TLA-6T103LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 25.7max. Pulse transformer Common-mode choke Inductor Port Withstanding voltage 1CT:1CT 5.95max. 0.8typ. „ ․ ‟ ‣ RX TDK∗∗∗ Part No. Lot No. 9.3typ. 12.5±0.3 … Operating Storage Temperature ranges 2.54typ. ‭ • † „ 2 2 1 1 0 to +70°C –40 to +85°C Erms:1500V[60s] 1CT:1CT ‥ ‬
 0.25typ. TX ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm N.C. pins: ‡‥…‪ RECOMMENDED PC BOARD PATTERN 17.78 … 5.0 2.54 8.64 13.72 ‭ Primary signal pattern (connected No.„-†, ‫‫‬-‭) keep out area Secondary signal pattern (connected No.•-․, ‧-
) keep out area „ 2.54 ‥ 1.02 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio  :   :  TLA-6T103LF(-T) 1CT:1CT 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 Inter-winding stray capacitance (pF)max.[100kHz] - - 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (9/44) PACKAGING STYLES Quantity : 600pieces/reel 4 13.1 6.1 40.4 1.7 (25.9) 2 20.2 16 44 ± 0.3 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (10/44) TLA-6T118LF/119LF/120LF/121LF/122LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T1 LF-T: Tape and reel, TLA-6T1 LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 11.6max. 5.9max. Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ 0.25typ. TX RX N.C. pins: ‡•
‪ ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 ‭ … 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-6T118LF(-T) TLA-6T119LF(-T) TLA-6T120LF(-T) TLA-6T121LF(-T) TLA-6T122LF(-T) Turns ratio  :   :  1CT:1CT 1CT:1CT 1.41CT:1CT 1CT:1CT 2CT:1CT 1CT:1CT 1CT:1.41CT 1CT:1CT 1.25CT:1CT 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 350 350 350 350 350 350 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 2 1 3.5 1 2.5 1 2 1 Inter-winding stray capacitance (pF)max.[100kHz] - - 25 25 25 25 25 25 25 25 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (11/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (12/44) TLA-6T127LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX, POWER OVER ETHERNET FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Allowable current is 350mA max. • Excellent common mode noise suppression under the power transmission. • Packaging specification is taping and bulk(TLA-6T127LF-T: Tape and reel, TLA-6T127LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 11.6max. 5.9max. Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ TX 0.25typ. RX N.C. pins: ‡• ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 ‭ … 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio  :   :  TLA-6T127LF(-T) 1CT:1CT 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 Inter-winding stray capacitance (pF)max.[100kHz] - - 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (13/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (14/44) TLA-6T133WLF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Can be used in the wide range of temperature(–40 to +85°C). • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T133WLF-T: Tape and reel, TLA-6T133WLF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 11.6max. 5.9max. Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ 2 2 1 –40 to +85°C –40 to +85°C Erms:1500V[60s] … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ 0.25typ. TX RX N.C. pins: ‡•
‪ ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 ‭ … 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio  :   :  TLA-6T133WLF(-T) 1CT:1CT 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 Inter-winding stray capacitance (pF)max.[100kHz] - - 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (15/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (16/44) TLA-6T214ALF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Low profile (H)2.1mm max. for note PC application. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T214ALF-T: Tape and reel, TLA-6T214ALF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM „ † Withstanding voltage 2.10max. … ‭ ‬ ‫‫‬
 ‧ … „ ‟ † ‣ ․ ‥ 1CT:1CT ‣ ‥ 1CT:1CT
 TDK∗∗∗ Part No. Lot No. 8.37typ. 9.47±0.2 ‫‫‬ Operating Storage Temperature ranges 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] 0.95typ. 12.70max. ‭ Pulse transformer Common-mode choke Port 0.25typ. TX 1.27typ. 0.10max. 0.45typ. RX ∗∗∗: Country of origin Dimensions in mm RECOMMENDED PC BOARD PATTERN 1.8 10.07 8.89 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : TLA-6T214ALF(-T) 1CT:1CT 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 125MHz] - - 1 1 Inter-winding stray capacitance (pF)max.[100kHz] - - 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (17/44) PACKAGING STYLES Quantity : 1500pieces/reel 10 11.5 4 2.2 24±0.3 (13.4) 2 12 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.3 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (18/44) TLA-6T213LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 12-pin SMD package(1.27mm=50mil pin pitch). • Because it is low profile design of 2.2mm max., space saving is possible and is suitable for notebook PC. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T213LF-T: Tape and reel, TLA-6T213LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM Ӽ ӻ Ӻ ӹ Ӹ ӷ „ ‟ † Ӵ ӵ Ӷ ‣ 1CT:1CT 1CT:1CT TDK∗∗∗ Part No. Lot No. 8.5typ. 9.47±0.25 Withstanding voltage 2.2max. ӷ „ Operating Storage Temperature ranges 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] 0.8typ. 8.4max. Ӽ Pulse transformer Common-mode choke Port 0.2typ. TX 0.45typ. 1.27typ. 0.10max. RX ∗∗∗: Country of origin Dimensions in mm RECOMMENDED PC BOARD PATTERN 1.65 10.2 6.35 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : TLA-6T213LF(-T) 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 Inter-winding stray capacitance (pF)max.[100kHz] - - 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (19/44) PACKAGING STYLES Quantity : 1500pieces/reel 2 4 10 7.5 12 2.2 16±0.3 (8.8) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.3 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 22.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (20/44) TLA-7T201LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 24-pin SMD package(1.27mm=50mil pin pitch). • Because it is low profile design of 2.2mm max., space saving is possible and is suitable for notebook PC. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-7T201LF-T: Tape and reel, TLA-7T201LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM Withstanding voltage ‵ ‴ ″ ′ ‱ ‰ „ ‟ † Ӵ ӵ Ӷ „   ‫‮‬ ‭ ‬ ‫‫‬ ‪ Ӽ ․ ‥ … ‧
 1CT:1CT 1CT:1CT 1CT:1CT TDK∗∗∗ Part No. Lot No. 1CT:1CT ӽ 8.5typ. 9.47±0.25 Operating Storage Temperature ranges 2.2max. ‵ 4 4 1[1000BASE-T] 0 to +70°C –40 to +85°C Erms:1500V[60s] 0.8typ. 16max. Pulse transformer Common-mode choke Port 0.2typ. ∗∗∗: Country of origin 0.45typ. 1.27typ. 0.10max. Dimensions in mm RECOMMENDED PC BOARD PATTERN 1.65 10.2 13.97 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : : : TLA-7T201LF(-T) 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - - - 350 Insertion loss (dB)max. [0.1 to 100MHz] - - - - 1 Inter-winding stray capacitance (pF)max.[100kHz] - - - - 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (21/44) PACKAGING STYLES Quantity : 1500pieces/reel 2 4 10 11.5 12 2.2 24±0.3 (16.2) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.3 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (22/44) TLA-6T404(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (250°C max.). • 40-pin SMD package(1.27mm=50mil pin pitch) for Quad port. • Excellent common-mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T404-T: Tape and reel, TLA-6T404: Bulk). SHAPES AND DIMENSIONS 8 8 4 0 to +70°C –40 to +85°C Erms:1500V[60s] Operating Storage Temperature ranges Withstanding voltage ⁅ ⁄⁃⁂ 5.8max. ⁁ ⁀ ‿‾‽ ‼ ※ ›‹‸ ‷ ‶ ‵‴″ ′ „ „ ‟†‡ 0.25typ. ‱ RX 1.27typ. TX • ‣ 1:1 ․‥… ‧
‪‫‫‬ TX RX RX TX 1CT:1CT 1CT:1CT 1:1 1:1 Part No. Lot No. 1CT:1CT TD K ∗∗∗ 1CT:1CT 0.8typ. 1:1 ′ 12.2typ. 15.7±0.25 Pulse transformer Common-mode choke Port CIRCUIT DIAGRAM 25.9max. ⁅ GENERAL SPECIFICATIONS ‬ ‭ ‫ ‮‬‰ ‱ TX RX ∗∗∗ : Country of origin 0.45typ. 0.15max. Dimensions in mm 24.13typ.(1.27×19) RECOMMENDED PC BOARD PATTERN 24.13 (1.27×19) ′ Primary signal pattern (connected No.„-‱) keep out area 8.7 13.2 16.2 ⁅ 1.27 Secondary signal pattern (connected No.′-⁅) keep out area „ ‱ 0.65 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio :..... :..... TLA-6T404(-T) 1CT:1CT 1:1 Inductance (µH)min. [DC bias 8mA, 100kHz] -...... -...... 350 350 Insertion loss (dB)max. [0.1 to 100MHz] -..... -..... 1 1 Inter-winding stray capacitance (pF)max.[100kHz] -..... -..... 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (23/44) PACKAGING STYLES Quantity : 500pieces/reel 6 40.4 1.7 (26.3) 2 4 44 ± 0.3 16.1 20.2 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.5 ± 0.05 20 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 250˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (24/44) TLA-6T406(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (250°C max.). • 40-pin SMD package(1.27mm=50mil pin pitch) for Quad port. • Excellent common-mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T406-T: Tape and reel, TLA-6T406: Bulk). SHAPES AND DIMENSIONS Operating Storage Temperature ranges Withstanding voltage 8 8 4 0 to +70°C –40 to +85°C Erms:1500V[60s] 5.8max. ⁅ ⁄ ⁃ ⁂ ⁁ ⁀ ‿ ‾ ‽ › ‹ ‸ ‼ ※ ‷ ‶ ‵ ‴ ″ ′ „ 1.27typ. ‟ † ‡ „ 0.25typ. ‱ TX • ‣ RX ․ ‥ … RX ‧
 TX
 ‪ ‫‫‬ TX 1CT:1CT 1CT:1CT 1CT:1CT 1CT:1CT 1CT:1CT 1CT:1CT Part No. Lot No. 1CT:1CT TDK ∗∗∗ 1CT:1CT 0.8typ. ′ 12.2typ. 15.7±0.25 Pulse transformer Common-mode choke Port CIRCUIT DIAGRAM 25.9max. ⁅ GENERAL SPECIFICATIONS ‬ ‭ RX ‫   ‮‬‰ RX ‱ TX ∗∗∗ : Country of origin 0.45typ. 0.15max. Dimensions in mm 24.13typ.(1.27×19) RECOMMENDED PC BOARD PATTERN 24.13 (1.27×19) ′ Primary signal pattern (connected No.„-‱) keep out area 8.7 13.2 16.2 ⁅ 1.27 Secondary signal pattern (connected No.′-⁅) keep out area „ ‱ 0.65 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio :..... :..... TLA-6T406(-T) 1CT:1CT 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] -...... -...... 350 350 Insertion loss (dB)max. [0.1 to 100MHz] -..... -..... 1 1 Inter-winding stray capacitance (pF)max.[100kHz] -..... -..... 40 40 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (25/44) PACKAGING STYLES Quantity : 500pieces/reel 6 40.4 1.7 (26.3) 2 4 44 ± 0.3 16.1 20.2 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.5 ± 0.05 20 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 250˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (26/44) TLA-7T101LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 24-pin SMD package(1.27mm=50mil pin pitch). • Excellent common-mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-7T101LF-T: Tape and reel, TLA-7T101LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 15.82max. Pulse transformer Common-mode choke Port Temperature ranges Operating Storage Withstanding voltage 4 4 1(1000BASE-T) 0 to +70°C –40 to +85°C Erms:1500V[60s] 5.9max. ‪ TDK∗∗∗ Part No. Lot No. 6.74typ. 9.14±0.2 0.5typ. 1.27typ. ‵ ӱ
 0.25typ. ∗∗∗: Country of origin 0.45typ. 0.10max. Dimensions in mm RECOMMENDED PC BOARD PATTERN Primary signal pattern (connected No. - ) keep out area 3.34 1.4 9.74 13.97 Secondary signal pattern (connected No. - ) keep out area 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio  :   :   :   :  TLA-7T101LF(-T) 1CT:1CT Inductance (µH)min. [DC bias 8mA, 100kHz] - - - - 350 Insertion loss (dB)max. [0.1 to 100MHz] - - - - 1 Inter-winding stray capacitance (pF)max.[100kHz] - - - - 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (27/44) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 9.8 11.5 12 5.9 24 ± 0.3 (15.9) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (28/44) TLA-6T718 ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular jack. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 16.0typ. Pulse transformer Common-mode choke Port 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] Operating Storage Temperature ranges Withstanding voltage 21.45typ. TX „ ₷ ‟ ₸ 13.85typ. † ₹ RX ₻ ‣ Dimensions in mm ‥ CABLE ₼ ․ 75Ω ‥ ₺ • 75Ω „ ‡ 3.2typ. ₷ 3.1typ. 3.63typ. PCB ₾ 75Ω ₽ ₾ 0.001µF 75Ω N.C. pin: ․ RECOMMENDED PC BOARD PATTERN[TOP VIEW] 8-ø0.9 10.92typ. 8.89typ. ‟ ‡ ‣ ‥ „† • ․ 3.05typ. 2-ø1.6 1.27typ. 2-ø3.25 21.45typ. 2.54typ. 8.89typ. 11.43typ. 15.75typ. 16.0typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : TLA-6T718 1CT:1 1CT:1 Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (29/44) PACKAGING STYLES Tray : 50pieces/tray RECOMMENDED SOLDERING CONDITION FLOW SOLDERING 5±1s 255˚C max. Natural cooling 130˚C 90˚C Preheating: 30 to 45s Time(s) Preheating: 90 to 130°C for 30 to 45 seconds. Soldering: 255°C max. 5±1 seconds • Perform flow soldering from the underside of the board. • The surface of plastic protrusions inserted into the board may melt, but this causes no problems with regard to electrical properties or mounting. • The cutted end of terminal has no plating(out of subject of solder ability). RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (30/44) TLA-6T719 ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular jack. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 16.0typ. 2.3typ. 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] Operating Storage Temperature ranges Withstanding voltage 21.45typ. TX „ 2.3typ. 2.3typ. Pulse transformer Common-mode choke Port ₷ ‟ ₸ † ₹ PCB ‥ ₺ • ₻ ‣ 75Ω ₽ ‥ ₾ 0.001µF Dimensions in mm CABLE ₼ ․ 75Ω 3.2typ. „ ₷ 3.1typ. 3.63typ. ₾ ‡ 75Ω 13.85typ. RX 75Ω N.C. pin: ․ RECOMMENDED PC BOARD PATTERN[TOP VIEW] 8-ø0.9 10.92typ. 8.89typ. ‟ ‡ ‣ ‥ „† • ․ 3.05typ. 2-ø1.6 1.27typ. 2-ø3.25 21.45typ. 2.54typ. 8.89typ. 11.43typ. 15.75typ. 16.0typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : TLA-6T719 1CT:1 1CT:1 Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (31/44) PACKAGING STYLES Tray : 45pieces/tray RECOMMENDED SOLDERING CONDITION FLOW SOLDERING 5±1s 255˚C max. Natural cooling 130˚C 90˚C Preheating: 30 to 45s Time(s) Preheating: 90 to 130°C for 30 to 45 seconds. Soldering: 255°C max. 5±1 seconds • Perform flow soldering from the underside of the board. • The surface of plastic protrusions inserted into the board may melt, but this causes no problems with regard to electrical properties or mounting. • The cutted end of terminal has no plating(out of subject of solder ability). RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (32/44) TLA-6T720 ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular jack. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. GENERAL SPECIFICATIONS Pulse transformer Common-mode choke Port Withstanding voltage CIRCUIT DIAGRAM 2.3typ. 21.45typ. ₹ RX ‥ ‡ ₺ • ₻ ‣ 75Ω ₽ ‥ Dimensions in mm CABLE ₼ ․ 75Ω 3.2typ. 3.35typ. PCB 3.75typ. ₸ † ₾ „ ₷ ‟ 75Ω 13.3typ. ₷ TX „ 2.3typ. 16.0typ. Operating Storage Temperature ranges SHAPES AND DIMENSIONS 2.3typ. 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] ₾ 0.001µF 75Ω N.C. pin: ․ RECOMMENDED PC BOARD PATTERN[TOP VIEW] 8-ø0.9 10.92typ. 8.89typ. ‟ ‡ ‣ ‥ „† • ․ 3.05typ. 2-ø1.6 1.27typ. 2-ø3.2 21.45typ. 2.54typ. 8.89typ. 11.43typ. 15.75typ. 16.0typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : TLA-6T720 1CT:1 1CT:1 Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (33/44) PACKAGING STYLES Tray : 45pieces/tray RECOMMENDED SOLDERING CONDITION FLOW SOLDERING 5±1s 255˚C max. Natural cooling 130˚C 90˚C Preheating: 30 to 45s Time(s) Preheating: 90 to 130°C for 30 to 45 seconds. Soldering: 255°C max. 5±1 seconds • Perform flow soldering from the underside of the board. • The surface of plastic protrusions inserted into the board may melt, but this causes no problems with regard to electrical properties or mounting. • The cutted end of terminal has no plating(out of subject of solder ability). RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (34/44) TLA-6T717W ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Can be used in the wide range of temperature(–40 to +85°C). • Product conforming to RoHS directive. • Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular jack. • Excellent common mode noise suppression. • Inductance is 350µH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 16.0typ. Pulse transformer Common-mode choke Port 2 2 1 –40 to +85°C –40 to +85°C Erms:1500V[60s] Operating Storage Temperature ranges Withstanding voltage 21.45typ. TX „ ₷ ‟ ₸ 13.85typ. † ₹ RX ₺ • ₻ Dimensions in mm ‥ CABLE ₼ ․ 75Ω 3.2typ. ‥ ‡ ‣ 3.1typ. 3.63typ. „ ₷ 75Ω PCB ₾ 75Ω ₽ ₾ 1000pF 75Ω N.C. pin: ․ RECOMMENDED PC BOARD PATTERN[TOP VIEW] 8-ø0.9 10.92typ. 8.89typ. ‟ ‡ ‣ ‥ „† • ․ 3.05typ. 2-ø1.6 1.27typ. 2-ø3.25 21.45typ. 2.54typ. 8.89typ. 11.43typ. 15.75typ. 16.0typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio : : TLA-6T717W 1CT:1 1CT:1 Inductance (µH)min. [DC bias 8mA, 100kHz] - - 350 350 Insertion loss (dB)max. [0.1 to 100MHz] - - 1 1 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (35/44) PACKAGING STYLES Tray : 50pieces/tray RECOMMENDED SOLDERING CONDITION FLOW SOLDERING 5±1s 255˚C max. Natural cooling 130˚C 90˚C Preheating: 30 to 45s Time(s) Preheating: 90 to 130°C for 30 to 45 seconds. Soldering: 255°C max. 5±1 seconds • Perform flow soldering from the underside of the board. • The surface of plastic protrusions inserted into the board may melt, but this causes no problems with regard to electrical properties or mounting. • The cutted end of terminal has no plating(out of subject of solder ability). RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (36/44) LC MODULES Conformity to RoHS Directive TLA-3M103LF(-T) ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package (2.54mm=100mil pin pitch). • Pulse transformer, common-mode choke and low pass filter are integrated into 16-pin SMD package. • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3M103LF-T: Tape and reel, TLA-3M103LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 25.7max. Low pass filter Pulse transformer Common-mode choke Port Temperature ranges Withstanding voltage 1CT:1CT 5.95max. … „ „ L.P. FILTER ‥ † L.P. FILTER ‣ TX TDK∗∗∗ Part No. Lot No. 9.5typ. 12.5±0.3 0.8typ. 2.54typ. ‭ Operating Storage 2 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] • ․ 1CT:1CT ‥ ‭ L.P. FILTER … ‫‫‬ L.P. FILTER
 0.25typ. RX ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm
 RECOMMENDED PC BOARD PATTERN ‧ N.C. pins: ‟‡‪‬ 2.54 13.72 2.54 17.78 1.02 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-3M103LF(-T) Insertion loss (dB)max.[5 to 10MHz] - - 1 1 Attenuation (dB)min.[30 to 100MHz] - - 25 25 Impedance (Ω)typ.[5 to 10MHz] -, - -, - 100, 100 100, 100 C.M.R.R. (dB)min.[1 to 100MHz] - - 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (37/44) PACKAGING STYLES Quantity : 600pieces/reel 4 13.1 6.1 40.4 1.7 (25.9) 2 20.2 16 44 ± 0.3 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimesions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (38/44) TLA-3M601-RS ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • 10-pin SIP package (2.54mm=100mil pin pitch). • Pulse transformer, common-mode choke and low pass filter are integrated into 10-pin SIP package. • Using the high-quality and wide-band ferrite cores for LAN. • Thin(t=6mm max.) and low profile(H=10.9mm max.). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM Low pass filter Pulse transformer Common-mode choke Port Temperature ranges Operating Storage Withstanding voltage 28max. „ L.P. FILTER ‟ L.P. FILTER TX TDK ∗∗∗ Part No. Lot No. 6max. … ‧ (0.5) (2.54×4) (2.54×3) 10.16 5.08 7.62 22.86±0.3 ‧ 3.5±0.5 10.9max. • „ 2 2 1 1 0 to +70°C –40 to +85°C Erms: 1500V[60s] ․ † L.P. FILTER ‡ L.P. FILTER ‥ RX (0.25) ∗∗∗ : Country of origin Dimensions in mm Tolerance:±0.25 ELECTRICAL CHARACTERISTICS Part No. TLA-3M601-RS Insertion loss (dB)max.[5 to 10MHz] - - 1 1 Attenuation (dB)min.[30 to 100MHz] - - 25 25 Impedance (Ω)typ.[5 to 10MHz] -,- -,- 100, 100 100, 100 C.M.R.R. (dB)min.[30 to 100MHz] - - 30 30 • Ta=25°C PACKAGING STYLES Quantity : 540pieces/box • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (39/44) TLA-6M102LF(-T) ATM25 FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package (2.54mm=100mil pin pitch). • Pulse transformers, common-mode chokes, low pass filter and surge protector are integrated into 16-pin SMD package. • Supports UTP 100Ω transmission cable. • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6M102LF-T: Tape and reel, TLA-6M102LF: Bulk). Withstanding voltage 25.7max. REC + ‬ 5.95max. 0.8typ. RX REC – ‭ TDK∗∗∗ Part No. Lot No. „ ․ TU+ ‧ RU – VCC ‫‫‬ GND † TX+ „ ‥ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ.
 RU+ TX TX– ‟ L.P. FILTER 9.5typ. 12.5±0.3 … SURGE PROTECTOR CIRCUIT DIAGRAM 2.54typ. ‭ Operating Storage Temperature ranges 1 2 2 1 0 to +70°C –40 to +85°C Erms:500V[60s] SURGE PROTECTOR SHAPES AND DIMENSIONS GENERAL SPECIFICATIONS Low pass filter Pulse transformer Common-mode choke Port ‣ TU – N.C. pins: ‡•‥…
‪ Dimensions in mm RECOMMENDED PC BOARD PATTERN 2.54 13.72 2.54 17.78 1.02 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-6M102LF(-T) Insertion loss (dB)max. [0.1 to 17MHz] - - 1.5 1.5 [17 to 25MHz] - - 3 1.5 Attenuation (dB)min. [50 to 100MHz] - - 18 — • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (40/44) PACKAGING STYLES Quantity : 600pieces/reel 4 13.1 6.1 40.4 1.7 (25.9) 2 20.2 16 44 ± 0.3 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimesions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (41/44) TLA-6M103LF(-T) ATM25 FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package (2.54mm=100mil pin pitch). • Pulse transformers, common-mode chokes and low pass filter are integrated into 16-pin SMD package. • Supports STP 150Ω or UTP 100Ω transmission cable. • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6M103LF-T: Tape and reel, TLA-6M103LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 25.7max. Low pass filter Pulse transformer Common-mode choke Port Withstanding voltage † 5.95max. 0.8typ. … TX ‟ ‡ 0.25typ. RX ∗∗∗: Country of origin 0.10max. 0.45typ. L.P. FILTER ‬ ‥ Dimensions in mm ‭ ‥ •
 ‪ „ ․ L.P. FILTER „ TDK∗∗∗ Part No. Lot No. 9.5typ. 12.5±0.3 Operating Storage Temperature ranges 2.54typ. ‭ 2 2 2 1 0 to +70°C –40 to +85°C Erms:500V[60s] … ‧ ‫‫‬ N.C. pins: ‣
 RECOMMENDED PC BOARD PATTERN 2.54 13.72 2.54 17.78 1.02 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-6M103LF(-T) Insertion loss (dB)max. [12kHz] - - 3 3 [16MHz] - - 1 1 [24MHz] - - 1.8 1.8 Attenuation (dB)min. [36MHz] - - 10 10 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (42/44) PACKAGING STYLES Quantity : 600pieces/reel 4 13.1 6.1 40.4 1.7 (25.9) 2 20.2 16 44 ± 0.3 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimesions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (43/44) IC Cross Reference IC manufacturer AMD Interface IC part No. Ports 10/100BASE-TX Am79C874 Am79C875 1 4 TDK part No. TX RX Single Single (Low profile) Quad RJ45 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF TLA-6T404 TLA-6T406 TLA-6T718 TLA-6T719 TLA-6T720 1.25:1 1:1 1:1.41 1:1 TLA-6T122LF (For power down application) TLA-6T121LF 1:1 1:1 TLA-6T118LF TLA-6T406 TLA-6T718 TLA-6T719 TLA-6T720 1:1 1:1 TLA-6T133WLF 1:1 1:1 TLA-6T127LF 1:1 1:1 TLA-7T101LF 1:1.41 1:2.5 1:1 1:1 TLA-3T110LF TLA-3T112LF Am79C973/975 AC101L BCM5241 BCM5226 BCM5208R/5228 BCM5238/5248 BCM5220/5221 BCM5222 BCM1101 BCM1112/1113 BCM1115 BCM5401 BCM5421/S BCM5461/S BCM5703 BCM5705/M BCM5788/M CS8900A(5V) CS8900A(3.3V) 1 1 1 6 8 8 1 2 2 2 1 1 1 1 1 1 1 1 1 10/100BASE-TX CS8952 CS8952T 1 1 1:1 1:1 TLA-6T103LF TLA-6T118LF 10BASE-T DM9008 DM9081 1 8 1:1 1:1 TLA-3M103LF TLA-3M601-RS DM9010 DM9000A 1 1 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF DM9601 DM9102A DM9161 DM9331 1 1 1 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF 1.25:1 1:1 MB86967 1 1:1 1:1 ICS1892 ICS1893AF/AG 1 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF ICS1893BF/BK 1 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF IDT77105 ADM7001 ADM7008 ADM6995L/6996L ADM6996F ADM6999/U/G LXT901A/907A LXT905/908 82559/ER 82562EP/ET/EX/EZ LXT972A/M LXT970A/971A 82551QM/ER 82562GT/GZ/GX LXT973 82551IT LXT974/975 1 1 8 5 4 8 1 1 1 1 1 1 1 1 2 1 4 1:1 1:1 TLA-6M103LF 1:1 1:1 TLA-6T118LF 1:1.14 1:2 1:1 1:1 TLA-3T110LF TLA-3T109LF 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF 1:1 2:1 1:1 1:1 TLA-6T133WLF TLA-6T120LF LXT9785/E 8 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF 82573E/V/L 82572EI 82571EB 82547GI/EI 82546EB/GB 82545EM/GM 82544GC/EI 82541PI/GI/EI/ER 82540EM/EP 1 1 2 1 2 1 1 1 1 1:1 1:1 TLA-7T101LF TLA-7T201LF 10/100BASE-TX Broadcom Turns ratio 10/100BASE-TX (VolP) 10/100/1000BASE-T 10BASE-T CIRRUS LOGIC TLA-6T214ALF TLA-6T213LF TLA-6T717W TLA-7T201LF TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T214ALF TLA-6T213LF TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 DAVICOM 10/100BASE-TX Fujitsu ICS 10BASE-T TLA-6T122LF (For power down application) TLA-3M103LF TLA-3M601-RS TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 10/100BASE-TX IDT ATM25 Infineon (ADMtek) 10/100BASE-TX 10BASE-T 10/100BASE-TX Intel (Level One) 10/100/1000 BASE-T TLA-6T214ALF TLA-6T213LF TLA-6T406 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T717W TLA-6T406 TLA-6T718 TLA-6T719 TLA-6T720 • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm (44/44) Turns ratio TDK part No. TX RX Single Single (Low profile) 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF 1:1 1:1 TLA-7T101LF TLA-7T201LF 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF 1:1 1:1 TLA-6T133WLF 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF KSZ8995XA KSZ8997 KSZ8999 5 8 9 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF TLA-6T406 ML6652 1 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF TLA-6T406 DP83847 DP83816 1 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF DP83848C DP83848M 1 1 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF DP83848H/I/T/YB DP83865 uPD98408 RTL8019AS RTL8029AS RTL8100B/C RTL8139C/D RTL8101L RTL8201BL/CL 1 1 6 1 1 1 1 1 1 1:1 1:1 1:1.52 1:1 1:1 1.36:1 1:1 1:1 TLA-6T133WLF TLA-7T101LF TLA-6M102LF TLA-3M103LF TLA-3M601-RS 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF RTL8201CP RTL8100E/8101E 1 1 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF RTL8208/B 8 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF RTL8110S/SB/SC RTL8169S/SB/SC RTL8211B 1 1 1 1:1 1:1 TLA-7T101LF TLA-7T201LF R4S76190B125BGV 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF R4S76190N125BGV R4S76190W125BGV R4S76190D125BGV 1 1 1 1:1 1:1 TLA-6T133WLF 10BASE-T LAN91C96 1 1:1 1:1 TLA-3M103LF TLA-3M601-RS 1 1 1 1 1 1 1 1 1 1 1 1 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF TLA-6T718 TLA-6T719 TLA-6T720 10/100BASE-TX LAN83C185 LAN91C111 LAN9118 LAN9117 LAN9116 LAN9115 LAN8700 LAN8187 LAN9215 LAN91C111I LAN8700I LAN8171I LAN9218I 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF TLA-6T718 TLA-6T719 TLA-6T720 1:1 1:1 TLA-6T133WLF 78Q2120C 1 1:1 1:1 TLA-6T103LF TLA-6T118LF TLA-6T214ALF TLA-6T213LF 78Q2123 1 1:1 1:1 TLA-6T118LF TLA-6T214ALF TLA-6T213LF 78Q2133 1 1:1 1:1 TLA-6T133WLF IC manufacturer Interface LSI Logic 10/100BASE-TX Marvell 10/100/1000BASE-T MICREL (Kendin) Micro Linear National Semiconductor NEC 10/100BASE-TX 10/100BASE-TX 10/100BASE-TX 10/100/1000BASE-T ATM25 10BASE-T Realtek 10/100BASE-TX 10/100/1000BASE-T Renesas 10/100BASE-TX SMSC Teridian Semiconductor (TDK) IC part No. Ports L80223 L80225 L80227 88E1000/S 88E1010/S 88E1011/S 88E1111 KSZ8001L/S KSZ8721B/BL/BT KSZ8721CL/SL KSZ8001LI KSZ8721BI/BLI/SLI KS8993I 1 1 1 1 1 1 1 1 1 1 1 1 1 KSZ8993 10/100BASE-TX Quad RJ45 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T717W TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T717W TLA-7T201LF TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T406 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T717W TLA-6T717W TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T718 TLA-6T719 TLA-6T720 TLA-6T717W • All specifications are subject to change without notice. 005-03 / 20070822 / edlan_tla.fm
TLA-3M601-RS 价格&库存
很抱歉,暂时无法提供与“TLA-3M601-RS”相匹配的价格&库存,您可以联系我们找货
TLA-3M601-RS
    • 1+84.178651+10.88851
    • 5+40.342355+5.21829
    • 10+34.8648810+4.50978
    • 30+31.2132430+4.03744
    • 50+30.4829150+3.94297
    • 60+30.3003360+3.91935
    • 100+29.93517100+3.87212
    库存:800
    TLA-3M601-RS
      • 1+147.335461+19.05785
      • 3+110.860533+14.33982
      • 4+106.304284+13.75047
      • 5+103.573855+13.39728
      • 9+98.710529+12.76821
      • 10+98.0963810+12.68877
      • 20+95.3659520+12.33559
      库存:170
      TLA-3M601-RS
      库存:800
      TLA-3M601-RS
