Pulse transformers
TLA /ALT series
Issue date:
April 2012
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
PULSE TRANSFORMERS
TLA/ALT SERIES
Contents
Page
Pulse Transformers/Pin Terminal Type
TLA-3T101LF(-T) 10BASE-2/5/T .....................................................2
TLA-3T106LF(-T) 10BASE-T............................................................4
TLA-3T107LF(-T) 10BASE-T............................................................4
TLA-3T105LF(-T) 10BASE-T............................................................6
TLA-3T109LF(-T) 10BASE-T............................................................6
TLA-3T110LF(-T) 10BASE-T............................................................6
TLA-3T112LF(-T) 10BASE-T............................................................6
TLA-6T103LF(-T) 10/100BASE-TX ..................................................8
TLA-6T118LF(-T) 10/100BASE-TX ..................................................10
TLA-6T119LF(-T) 10/100BASE-TX ..................................................10
TLA-6T120LF(-T) 10/100BASE-TX ..................................................10
TLA-6T121LF(-T) 10/100BASE-TX ..................................................10
TLA-6T122LF(-T) 10/100BASE-TX ..................................................10
TLA-6T127LF(-T) 10/100BASE-TX, PoE..........................................12
TLA-6T133WLF(-T) 10/100BASE-TX ...............................................14
TLA-6T214ALF(-T) 10/100/1000BASE-T .........................................16
TLA-6T213LF(-T) 10/100/1000BASE-TX........................................18
TLA-7T201LF(-T) 10/100/1000BASE-TX........................................20
TLA-6T406(-T) 10/100BASE-TX .....................................................22
TLA-7T101LF(-T) 10/100/1000BASE-T ..........................................24
Pulse Transformers/Connector Type
TLA-6T776F 10/100BASE-TX.........................................................26
TLA-6T785 10/100BASE-TX...........................................................28
LC Modules
TLA-3M103LF(-T) 10BASE-T ......................................................30
Pulse Transformers/SMD Type
ALT4532 .........................................................................................32
Precautions
The TDK products in this data are intended for usage in general electronics applications (computer, personal equipment, office equipment, measuring equipment, industrial robotics, domestic appliances,
etc.).
They are neither intend nor warranted for usage in equipment that requires extraordinarily high quality
and/or reliability or a malfunction or failure of which may cause loss of human life or bodily injury (atomic
energy control instruments, airplane or spaceship instruments, transportation instrument, traffic signal
instruments, combustion control instrument, medical instruments, all types of safety devices, etc.).
cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and
(2/33)
PULSE TRANSFORMERS TLA/ALT Series
TLA-3T101LF(-T) ISO8802.3(IEEE802.3) 10BASE2/5/-T
GENERAL SPECIFICATIONS
FEATURES
• Product conforming to RoHS directive.
• Can be mounted with lead-free solder (260°C max.).
• 16-pin SMD package(1.27mm=50mil pin pitch).
• Using the high-quality and wide-band ferrite cores for LAN.
• Packaging specification is taping and bulk(TLA-3T101LF-T:
Tape and reel, TLA-3T101LF: Bulk).
Pulse transformer
Port
Operating
Storage
Temperature ranges
Withstanding voltage
SHAPES AND DIMENSIONS
3
1
0 to +70°C
–40 to +85°C
Erms:2000V[60s]
CIRCUIT DIAGRAM
11.6max.
5.9max.
ӹ
TDK∗∗∗
Part No.
Lot No.
6.8typ.
9.2±0.2
Ԁ
0.5typ.
1.27typ.
ӱ
N.C. pins: †‣
Ӹ
0.25typ.
∗∗∗: Country of origin
0.10max.
0.45typ.
Dimensions in mm
RECOMMENDED PC BOARD PATTERN
8.89
3.4
9.8
Primary signal pattern
(connected No.„-‥)
keep out area
1.4
Secondary signal pattern
(connected No.…-)
keep out area
1.27
0.9
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Part No.
Turns ratio
Inductance
(PH)typ.[100kHz]
Leakage inductance
(PH)max.[100kHz]
„-‟[- shorted]
shorted]
․-‥[‧-… shorted]
TLA-3T101LF(-T)
1:1
100
0.25
Inter-winding
stray capacitance
(pF)max.[100kHz]
10
DC resistance
(:)max.
0.35, 0.35
• Ta=25°C
006-02 / 20120414 / edlan_tla.fm
(3/33)
PACKAGING STYLES
Quantity : 1000pieces/reel
2
4
10
11.5
12
5.9
24 ± 0.3
(12.4)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
RECOMMENDED SOLDERING CONDITION
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
RECOMMENDED CONDITION FOR LONG TERM STORE
When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery
within 1year.
Temperature range: +5 to +30°C
Humidity: 60(%)RH max.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
• Temperature is measured at the terminal portion of product
(Using thermocoupler for measurement).
• This profile is reference data we recommend. Please check in
your actual process.
• For reliable soldering, the thickness of solder paste screen
should be over the terminal co-planality.
• The cutted end of terminal has no plating(out of subject of solder
ability).
(4/33)
TLA-3T106LF(-T)/107LF(-T) ISO8802.3(IEEE802.3) 10BASE-T
FEATURES
• Packaging specification is taping and bulk(TLA-3T10 LF-T:
Tape and reel, TLA-3T10 LF: Bulk).
Pulse transformer
Port
Operating
Storage
Temperature ranges
4
4
0 to +70°C
–40 to +85°C
Erms: 2000V[60s]
CIRCUIT DIAGRAM
11.6max.
5.9max.
TDK∗∗∗
Part No.
Lot No.
6.8typ.
9.2±0.2
0.5typ.
1.27typ.
0.25typ.
0.10max.
0.45typ.
Dimensions in mm
8.89
3.4
9.8
(connected No.„-‥)
keep out area
1.4
(connected No.…-)
keep out area
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
Inductance
(PH)min.[100kHz]
Leakage inductance
(PH)max.[100kHz]
„-‟[- shorted]
†-‡[- shorted]
shorted]
․-‥[‧-… shorted]
TLA-3T106LF(-T)
TLA-3T107LF(-T)
1:1
1:1.41
130
130
0.3
0.3
Inter-winding
stray capacitance
(pF)max.[100kHz]
12
12
DC resistance
(:)max.
0.4, 0.4
0.4, 0.5
• Ta=25°C
(5/33)
PACKAGING STYLES
2
4
10
11.5
12
5.9
24 ± 0.3
(12.4)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(6/33)
TLA-3T105LF(-T)/109LF(-T)/110LF(-T)/112LF(-T) ISO8802.3(IEEE802.3) 10BASE-T
FEATURES
LF-T:
LF: Bulk).
11.6max.
Pulse transformer
Common-mode choke
Port
Operating
Storage
Temperature ranges
2
2
1
0 to +70°C
–40 to +85°C
Erms: 2000V[60s]
CIRCUIT DIAGRAM
5.9max.
TDK∗∗∗
Part No.
Lot No.
6.8typ.
9.2±0.2
0.5typ.
1.27typ.
N.C. pins: ‡•
0.25typ.
0.10max.
0.45typ.
Dimensions in mm
8.89
3.4
9.8
(connected No.„-‥)
keep out area
1.4
(connected No.…-)
keep out area
1.27
0.9
Dimensions in mm
Part No.
TLA-3T105LF(-T)
TLA-3T109LF(-T)
TLA-3T110LF(-T)
TLA-3T112LF(-T)
Turns ratio
Inductance
(PH)min.[100kHz]
Leakage inductance
(PH)max.[100kHz]
„-†[- shorted]
-… shorted]
1CT:1CT
1CT:1CT
2CT:1CT
1CT:1CT
1CT:1CT
1CT:1.41CT
1CT:1CT
1CT:2.5CT
130
130
130
130
130
130
130
130
0.3
0.3
0.95
0.35
0.35
0.35
0.35
0.35
Inter-winding
stray capacitance
(pF)max.[100kHz]
12
12
12
12
12
12
12
12
DC resistance
(:)max.
0.5
0.5
0.5
0.5
0.5
0.5
0.85
0.85
• Ta=25°C
(7/33)
PACKAGING STYLES
2
4
10
11.5
12
5.9
24 ± 0.3
(12.4)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(8/33)
TLA-6T103LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX & ATM
FEATURES
• 16-pin SMD package(2.54mm=100mil pin pitch).
• Excellent common-mode noise suppression.
• Inductance is 350μH or greater (f=100kHz, DC bias=8mA).
• Packaging specification is taping and bulk(TLA-6T103LF-T:
Tape and reel, TLA-6T103LF: Bulk).
CIRCUIT DIAGRAM
25.7max.
Pulse transformer
Common-mode choke
Inductor
Port
1CT:1CT
RX
TDK∗∗∗
Part No.
Lot No.
9.3typ.
12.5±0.3
0.8typ.
2.54typ.
Operating
Storage
Temperature ranges
5.95max.
2
2
1
1
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
1CT:1CT
0.25typ.
TX
0.10max.
0.45typ.
Dimensions in mm
N.C. pins: ‡‥…
17.78
5.0
2.54
8.64
13.72
(connected No.„-†, -)
keep out area
(connected No.•-․, ‧-
keep out area
2.54
1.02
Dimensions in mm
Part No.
Turns ratio
TLA-6T103LF(-T)
1CT:1CT
1CT:1CT
Inductance
(PH)min.
[DC bias 8mA, 100kHz]
350
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
25
• Ta=25°C
(9/33)
PACKAGING STYLES
Quantity : 600pieces/reel
4
13.1
6.1
40.4
1.7
(25.9)
2
20.2
16
44 ± 0.3
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
50.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(10/33)
TLA-6T118LF/119LF/120LF/121LF/122LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX
FEATURES
• Excellent common mode noise suppression.
LF-T:
LF: Bulk).
CIRCUIT DIAGRAM
11.6max.
5.9max.
Pulse transformer
Common-mode choke
Port
Operating
Storage
Temperature ranges
2
2
1
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
TDK∗∗∗
Part No.
Lot No.
6.8typ.
9.2±0.2
0.5typ.
1.27typ.
0.25typ.
TX
RX
N.C. pins: ‡•
0.10max.
0.45typ.
Dimensions in mm
8.89
3.4
9.8
(connected No.„-‥)
keep out area
1.4
(connected No.…-)
keep out area
1.27
0.9
Dimensions in mm
Part No.
TLA-6T118LF(-T)
TLA-6T119LF(-T)
TLA-6T120LF(-T)
TLA-6T121LF(-T)
TLA-6T122LF(-T)
Turns ratio
1CT:1CT
1CT:1CT
1.41CT:1CT
1CT:1CT
2CT:1CT
1CT:1CT
1CT:1.41CT
1CT:1CT
1.25CT:1CT
1CT:1CT
Inductance
(PH)min.
350
350
350
350
350
350
350
350
350
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
1
2
1
3.5
1
2.5
1
2
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
25
25
25
25
25
25
25
25
25
• Ta=25°C
(11/33)
PACKAGING STYLES
2
4
10
11.5
12
5.9
24 ± 0.3
(12.4)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(12/33)
TLA-6T127LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX, POWER OVER ETHERNET
FEATURES
• Allowable current is 350mA max.
• Excellent common mode noise suppression under the power
transmission.
• Packaging specification is taping and bulk(TLA-6T127LF-T:
Tape and reel, TLA-6T127LF: Bulk).
CIRCUIT DIAGRAM
11.6max.
5.9max.
Pulse transformer
Common-mode choke
Port
Operating
Storage
Temperature ranges
2
2
1
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
TDK∗∗∗
Part No.
Lot No.
6.8typ.
9.2±0.2
0.5typ.
1.27typ.
TX
0.25typ.
RX
N.C. pins: ‡•
0.10max.
0.45typ.
Dimensions in mm
8.89
3.4
9.8
(connected No.„-‥)
keep out area
1.4
(connected No.…-)
keep out area
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
TLA-6T127LF(-T)
1CT:1CT
1CT:1CT
Inductance
(PH)min.
350
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
25
• Ta=25°C
(13/33)
PACKAGING STYLES
2
4
10
11.5
12
5.9
24 ± 0.3
(12.4)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(14/33)
TLA-6T133WLF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX
FEATURES
• Can be used in the wide range of temperature(–40 to +85°C).
• Packaging specification is taping and bulk(TLA-6T133WLF-T:
Tape and reel, TLA-6T133WLF: Bulk).
CIRCUIT DIAGRAM
11.6max.
5.9max.
Pulse transformer
Common-mode choke
Port
Operating
Storage
Temperature ranges
2
2
1
–40 to +85°C
–40 to +85°C
Erms:1500V[60s]
TDK∗∗∗
Part No.
Lot No.
6.8typ.
9.2±0.2
0.5typ.
1.27typ.
0.25typ.
TX
RX
N.C. pins: ‡•
0.10max.
0.45typ.
Dimensions in mm
8.89
3.4
9.8
(connected No.„-‥)
keep out area
1.4
(connected No.…-)
keep out area
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
TLA-6T133WLF(-T)
1CT:1CT
1CT:1CT
Inductance
(PH)min.
350
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
25
• Ta=25°C
(15/33)
PACKAGING STYLES
2
4
10
11.5
12
5.9
24 ± 0.3
(12.4)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(16/33)
TLA-6T214ALF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T
FEATURES
• Low profile (H)2.1mm max. for note PC application.
• Packaging specification is taping and bulk(TLA-6T214ALF-T:
Tape and reel, TLA-6T214ALF: Bulk).
CIRCUIT DIAGRAM
2.10max.
1CT:1CT
TDK∗∗∗
Part No.
Lot No.
1CT:1CT
8.37typ.
9.47±0.2
Operating
Storage
Temperature ranges
2
2
1
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
0.95typ.
12.70max.
Pulse transformer
Common-mode choke
Port
0.25typ.
TX
1.27typ.
0.10max.
0.45typ.
RX
Dimensions in mm
1.8
10.07
8.89
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
TLA-6T214ALF(-T)
1CT:1CT
1CT:1CT
Inductance
(PH)min.
350
350
Insertion loss
(dB)max.
[0.1 to 125MHz]
1
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
25
• Ta=25°C
(17/33)
PACKAGING STYLES
Quantity : 1500pieces/reel
10
11.5
4
2.2
24±0.3
(13.4)
2
12
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.3
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Dimensions in mm
RECOMMENDED STORE CONDITION
The product is packaged by Anti-humid Al bag, in order to keep a
good solder ability condition and resistance to soldering heat for
products.
• Before aluminum bag opening
Temperature range: +5 to +40°C
Humidity: 90(%)RH max.
Storage period: 1year
• After aluminum bag opening
Storage period: 1week
Time(s)
ability).
(18/33)
TLA-6T213LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T
FEATURES
• 12-pin SMD package(1.27mm=50mil pin pitch).
• Because it is low profile design of 2.2mm max., space saving is
possible and is suitable for notebook PC.
• Packaging specification is taping and bulk(TLA-6T213LF-T:
Tape and reel, TLA-6T213LF: Bulk).
CIRCUIT DIAGRAM
Ӽ
ӻ
Ӻ
ӹ
Ӹ
ӷ
Ӵ
ӵ
Ӷ
1CT:1CT
1CT:1CT
ӷ
2.2max.
TDK∗∗∗
Part No.
Lot No.
8.5typ.
9.47±0.25
Ӽ
Operating
Storage
Temperature ranges
2
2
1
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
0.8typ.
8.4max.
Pulse transformer
Common-mode choke
Port
0.2typ.
TX
0.45typ. 1.27typ.
0.10max.
RX
Dimensions in mm
1.65
10.2
6.35
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
TLA-6T213LF(-T)
1CT:1CT
Inductance
(PH)min.
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
• Ta=25°C
(19/33)
PACKAGING STYLES
2
4
10
7.5
12
2.2
16±0.3
(8.8)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.3
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
22.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Dimensions in mm
products.
Time(s)
ability).
(20/33)
TLA-7T201LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T
FEATURES
• 24-pin SMD package(1.27mm=50mil pin pitch).
• Packaging specification is taping and bulk(TLA-7T201LF-T:
Tape and reel, TLA-7T201LF: Bulk).
CIRCUIT DIAGRAM
Ӵ
ӵ
Ӷ
Ӽ
1CT:1CT
1CT:1CT
1CT:1CT
TDK∗∗∗
Part No.
Lot No.
1CT:1CT
ӽ
8.5typ.
9.47±0.25
Operating
Storage
Temperature ranges
2.2max.
4
4
1[1000BASE-T]
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
0.8typ.
16max.
Pulse transformer
Common-mode choke
Port
0.2typ.
0.45typ. 1.27typ.
0.10max.
Dimensions in mm
1.65
10.2
13.97
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
TLA-7T201LF(-T)
1CT:1CT
Inductance
(PH)min.
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
• Ta=25°C
(21/33)
PACKAGING STYLES
2
4
10
11.5
12
2.2
24±0.3
(16.2)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.3
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Dimensions in mm
products.
Time(s)
ability).
(22/33)
TLA-6T406(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX
FEATURES
• Can be mounted with lead-free solder (250°C max.).
• 40-pin SMD package(1.27mm=50mil pin pitch) for Quad port.
• Packaging specification is taping and bulk(TLA-6T406-T: Tape
and reel, TLA-6T406: Bulk).
5.8max.
1.27typ.
0.25typ.
TX
RX
RX
TX
TX
1CT:1CT
1CT:1CT
1CT:1CT
1CT:1CT
1CT:1CT
1CT:1CT
Part No.
Lot No.
1CT:1CT
TD K ∗∗∗
1CT:1CT
0.8typ.
12.2typ.
15.7±0.25
Operating
Storage
Temperature ranges
8
8
4
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
CIRCUIT DIAGRAM
25.9max.
Pulse transformer
Common-mode choke
Port
RX
RX
TX
∗∗∗ : Country of origin
0.45typ.
0.15max.
Dimensions in mm
24.13typ.(1.27×19)
24.13 (1.27×19)
(connected No.„-‱)
keep out area
8.7
16.2
13.2
1.27
(connected No.′-⁅)
keep out area
0.65
Dimensions in mm
Part No.
Turns ratio
TLA-6T406(-T)
1CT:1CT
1CT:1CT
Inductance
(PH)min.
350
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
40
40
• Ta=25°C
(23/33)
PACKAGING STYLES
Quantity : 500pieces/reel
6
40.4
1.7
(26.3)
2
4
44 ± 0.3
16.1
20.2
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.5 ± 0.05
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
50.4max.
REFLOW SOLDERING
30s max.
250˚C max.
230˚C
Natural
cooling
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Dimensions in mm
products.
Time(s)
ability).
(24/33)
TLA-7T101LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T
FEATURES
• Packaging specification is taping and bulk(TLA-7T101LF-T:
Tape and reel, TLA-7T101LF: Bulk).
CIRCUIT DIAGRAM
15.82max.
Pulse transformer
Common-mode choke
Port
Temperature ranges
Operating
Storage
4
4
1(1000BASE-T)
–40 to +85°C
–40 to +85°C
Erms:1500V[60s]
5.9max.
TDK∗∗∗
Part No.
Lot No.
6.74typ.
9.14±0.2
0.5typ.
1.27typ.
ӱ
0.25typ.
0.45typ.
0.10max.
Dimensions in mm
(connected No. - )
keep out area
3.34
1.4
9.74
13.97
(connected No. - )
keep out area
1.27
0.9
Dimensions in mm
Part No.
Turns ratio
TLA-7T101LF(-T)
1CT:1CT
Inductance
(PH)min.
350
Insertion loss
(dB)max.
[0.1 to 100MHz]
1
Inter-winding
stray capacitance
(pF)max.[100kHz]
25
• Ta=25°C
(25/33)
PACKAGING STYLES
2
4
9.8
11.5
12
5.9
24 ± 0.3
(15.9)
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
30.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(26/33)
TLA-6T776F ISO8802.3(IEEE802.3) 10/100BASE-TX
FEATURES
• Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular
jack.
• Inductance is 200μH or greater (f=100kHz, DC bias=8mA).
• The product features high quality, containing a self-winding
surface-mount pulse transformer and common mode choke.
CIRCUIT DIAGRAM
2.5typ.
16±0.5
Pulse transformer
Common-mode choke
Port
Operating
Storage
Temperature ranges
21.45±0.5
2
2
1
–40 to +85°C
–40 to +85°C
TX
13.85±0.5
3.2typ.
3.2typ.
PCB
Dimensions in mm
CABLE
75Ω
75Ω
RX
75Ω
0.001μF
75Ω
N.C. pin: ․
8-ø0.9
10.92typ.
8.89typ.
3.05typ.
2-ø1.6
1.27typ.
2-ø3.25
21.45typ.
2.54typ.
8.89typ.
11.43typ.
15.75typ.
16.0typ.
Dimensions in mm
Part No.
Turns ratio
TLA-6T776F
1CT:1
1CT:1
Inductance
(PH)min.
200
200
Insertion loss
(dB)max.
[0.1 to 100MHz]
1.5
1.5
• Ta=25°C
(27/33)
PACKAGING STYLES
Tray : 360pieces/box
FLOW SOLDERING
5±1s
255˚C max.
Natural
cooling
130˚C
90˚C
Preheating: 30 to 45s
Time(s)
Preheating: 90 to 130°C for 30 to 45 seconds.
Soldering: 255°C max. 5±1 seconds
• Perform flow soldering from the underside of the board.
• The surface of plastic protrusions inserted into the board may
melt, but this causes no problems with regard to electrical
properties or mounting.
ability).
within 1year.
Humidity: 10 to 75%RH max.
(28/33)
TLA-6T785 ISO8802.3(IEEE802.3) 10/100BASE-TX
FEATURES
jack.
CIRCUIT DIAGRAM
Pulse transformer
Common-mode choke
Port
16±0.5
Operating
Storage
Temperature ranges
18.5±0.5
TX
12±0.5
2
2
1
–40 to +85°C
–40 to +85°C
PCB
CABLE
75Ω
75Ω
18.2±0.5
RX
75Ω
0.001μF
75Ω
Dimensions in mm
N.C. pin: ․
2-ø2.1
3.05typ.
2-ø3.2
8-ø0.9
1.27typ.
8.89typ.
2.54typ.
8.89typ. 4.55typ.
16.0typ.
11.43typ.
Dimensions in mm
Part No.
Turns ratio
TLA-6T785
1CT:1
1CT:1
Inductance
(PH)min.
200
200
Insertion loss
(dB)max.
[0.1 to 100MHz]
1.5
1.5
• Ta=25°C
(29/33)
PACKAGING STYLES
Tray : 500pieces/box
FLOW SOLDERING
5±1s
255˚C max.
Natural
cooling
130˚C
90˚C
Time(s)
ability).
within 1year.
(30/33)
LC Modules
TLA-3M103LF(-T) ISO8802.3(IEEE802.3) 10BASE-T
FEATURES
• 16-pin SMD package (2.54mm=100mil pin pitch).
• Pulse transformer, common-mode choke and low pass filter are
integrated into 16-pin SMD package.
• Packaging specification is taping and bulk(TLA-3M103LF-T:
Tape and reel, TLA-3M103LF: Bulk).
CIRCUIT DIAGRAM
25.7max.
Low pass filter
Pulse transformer
Common-mode choke
Port
Temperature ranges
1CT:1CT
5.95max.
L.P. FILTER
L.P. FILTER
TX
TDK∗∗∗
Part No.
Lot No.
9.5typ.
12.5±0.3
0.8typ.
2.54typ.
Operating
Storage
2
2
2
1
0 to +70°C
–40 to +85°C
Erms:1500V[60s]
1CT:1CT
L.P. FILTER
L.P. FILTER
0.25typ.
RX
0.10max.
0.45typ.
Dimensions in mm
N.C. pins: ‟‡
2.54
13.72
2.54
17.78
1.02
Dimensions in mm
Part No.
TLA-3M103LF(-T)
Insertion loss
(dB)max.[5 to 10MHz]
1
1
Attenuation
(dB)min.[30 to 100MHz]
25
25
Impedance
(:)typ.[5 to 10MHz]
100, 100
100, 100
C.M.R.R.
(dB)min.[1 to 100MHz]
25
25
• Ta=25°C
(31/33)
PACKAGING STYLES
4
13.1
6.1
40.4
1.7
(25.9)
2
20.2
16
44 ± 0.3
ø1.5+0.1, -0
1.75
TAPE DIMENSIONS
0.4
Dimensions in mm
ø330typ.
REEL DIMENSIONS
2±0.5
ø21±0.8
ø13±0.2
50.4max.
REFLOW SOLDERING
30s max.
260˚C max.
230˚C
Natural
cooling
Dimensions in mm
within 1year.
165±15˚C
2˚C/s
120s max.
1 to 2˚C/s
Time(s)
ability).
(32/33)
ALT4532
L
APPLICATIONS
LAN interface portion of various devices such as network devices,
communication devices, and digital home appliances
2
1
5
6
4532 - 201 - T 001
(2)
(3) (4) (5)
Dimensions in mm
(1) Series name
(2) Dimensions LuW
(3) Inductance[at 100kHz/DC bias=8mA]
201 : 200μH min.
(4) Packaging style
T: ø330mm reel taping
(5) TDK internal code
Type
ALT4532-171-T001
ALT4532-201-T001
Reel
ø180mm
1.45
0.7
0.45
–40 to +85°C
–40 to +85°C
PACKAGING STYLE AND QUANTITIES
Packaging style
Taping
T
2.2max.
2.9max.
0.45
1.45
1.1
Quantity
2000 pieces/reel
0.5
Operating
Storage(After mount)
W
3.2±0.2
3.2±0.2
RECOMMENDED PC BORARD PATTERN
SPECIFICATIONS
Temperature range
L
4.5±0.2
4.5±0.2
0.675 1.35
ALT
(1)
4
T
PRODUCT IDENTIFICATION
3
W
FEATURES
• The ALT4532 Series is a wound chip type pulse transformer
developed for LANs.
• Compatible with 10BASE-T, 100BASE-TX, and 1000BASE-T.
• High-quality product with automatic winding.
Dimensions in mm
MEASURING CIRCUIT
4
3
5
2
1
6
Part No.
Turns ratio
ALT4532-171-T001
ALT4532-201-T001
1CT : 1CT
1CT : 1CT
Inductance
(μH)min.
170
200
Insertion loss
(dB)max.
[0.1 to 100MHz]
Inter-winding
stray capacitance
(pF)max.
[100kHz]
2.5
1.5
35
35
(33/33)
TYPICAL ELECTRICAL CHARACTERISTICS
INSERTION LOSS vs. FREQUENCY CHARACTERISTICS
ALT4532-171-T001
ALT4532-201-T001
Insertion loss(dB)
Insertion loss(dB)
–1.0
–2.0
–3.0
–1.0
–2.0
–3.0
–4.0
0.1
1
10
Frequency(MHz)
100
–4.0
0.1
1
10
Frequency(MHz)
100
TYPICAL APPLICATIONS (100BASE-TX)
LAN
IC
LAN
Connector
Pulse transformers
ALT4532-171-T001
ALT4532-201-T001
Common mode filters
ACM2012-201-2P
ACM2012-361-2P
ACM2012-681-2P
ACM2012-102-2P
Note) Peripheral circuits differ depending on the IC used; check the circuits with the application note of the IC, etc.
