TLA-6T406
TLA-6T406
    TDK(东电化)
    SMD-40P,25.9x12.2mm
    TLA-6T406
TLA-6T406 数据手册
Pulse transformers TLA /ALT series Issue date: April 2012 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. PULSE TRANSFORMERS TLA/ALT SERIES Contents Page Pulse Transformers/Pin Terminal Type TLA-3T101LF(-T) 10BASE-2/5/T .....................................................2 TLA-3T106LF(-T) 10BASE-T............................................................4 TLA-3T107LF(-T) 10BASE-T............................................................4 TLA-3T105LF(-T) 10BASE-T............................................................6 TLA-3T109LF(-T) 10BASE-T............................................................6 TLA-3T110LF(-T) 10BASE-T............................................................6 TLA-3T112LF(-T) 10BASE-T............................................................6 TLA-6T103LF(-T) 10/100BASE-TX ..................................................8 TLA-6T118LF(-T) 10/100BASE-TX ..................................................10 TLA-6T119LF(-T) 10/100BASE-TX ..................................................10 TLA-6T120LF(-T) 10/100BASE-TX ..................................................10 TLA-6T121LF(-T) 10/100BASE-TX ..................................................10 TLA-6T122LF(-T) 10/100BASE-TX ..................................................10 TLA-6T127LF(-T) 10/100BASE-TX, PoE..........................................12 TLA-6T133WLF(-T) 10/100BASE-TX ...............................................14 TLA-6T214ALF(-T) 10/100/1000BASE-T .........................................16 TLA-6T213LF(-T) 10/100/1000BASE-TX........................................18 TLA-7T201LF(-T) 10/100/1000BASE-TX........................................20 TLA-6T406(-T) 10/100BASE-TX .....................................................22 TLA-7T101LF(-T) 10/100/1000BASE-T ..........................................24 Pulse Transformers/Connector Type TLA-6T776F 10/100BASE-TX.........................................................26 TLA-6T785 10/100BASE-TX...........................................................28 LC Modules TLA-3M103LF(-T) 10BASE-T ......................................................30 Pulse Transformers/SMD Type ALT4532 .........................................................................................32 Precautions The TDK products in this data are intended for usage in general electronics applications (computer, personal equipment, office equipment, measuring equipment, industrial robotics, domestic appliances, etc.). They are neither intend nor warranted for usage in equipment that requires extraordinarily high quality and/or reliability or a malfunction or failure of which may cause loss of human life or bodily injury (atomic energy control instruments, airplane or spaceship instruments, transportation instrument, traffic signal instruments, combustion control instrument, medical instruments, all types of safety devices, etc.). • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (2/33) PULSE TRANSFORMERS TLA/ALT Series Pulse Transformers/Pin Terminal Type TLA-3T101LF(-T) ISO8802.3(IEEE802.3) 10BASE2/5/-T GENERAL SPECIFICATIONS FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3T101LF-T: Tape and reel, TLA-3T101LF: Bulk). Pulse transformer Port Operating Storage Temperature ranges Withstanding voltage SHAPES AND DIMENSIONS 3 1 0 to +70°C –40 to +85°C Erms:2000V[60s] CIRCUIT DIAGRAM 11.6max. 5.9max. ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ ӹ TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 Ԁ 0.5typ. 1.27typ. ӱ N.C. pins: †‣
‫‫‬ Ӹ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 … ‭ 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „‟:‭‬ ‡•:‪
 ․‥:‧… Inductance (PH)typ.[100kHz] „-‟ ‡-• ․-‥ Leakage inductance (PH)max.[100kHz] „-‟[‭-‬ shorted] ‡-•[‪-
 shorted] ․-‥[‧-… shorted] TLA-3T101LF(-T) 1:1 100 0.25 Inter-winding stray capacitance (pF)max.[100kHz] „‟-‭‬ ‡•-‪
 ․‥-‧… 10 DC resistance (:)max. „-‟,‭-‬ ‡-•,‪-
 ․-‥,‧-… 0.35, 0.35 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (3/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (4/33) TLA-3T106LF(-T)/107LF(-T) ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3T10 LF-T: Tape and reel, TLA-3T10 LF: Bulk). SHAPES AND DIMENSIONS GENERAL SPECIFICATIONS Pulse transformer Port Operating Storage Temperature ranges Withstanding voltage 4 4 0 to +70°C –40 to +85°C Erms: 2000V[60s] CIRCUIT DIAGRAM 11.6max. 5.9max. ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 … ‭ 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „‟:‭‬ †‡:‫‫‬‪ •‣:
 ․‥:‧… Inductance (PH)min.[100kHz] „-‟ †-‡ •-‣ ․-‥ Leakage inductance (PH)max.[100kHz] „-‟[‭-‬ shorted] †-‡[‫‫‬-‪ shorted] •-‣[
 shorted] ․-‥[‧-… shorted] TLA-3T106LF(-T) TLA-3T107LF(-T) 1:1 1:1.41 130 130 0.3 0.3 Inter-winding stray capacitance (pF)max.[100kHz] „‟-‭‬ †‡-‫‫‬‪ •‣-
 ․‥-‧… 12 12 DC resistance (:)max. „-‟, ‭-‬ †-‡, ‫‫‬-‪ •-‣,
 ․-‥, ‧-… 0.4, 0.4 0.4, 0.5 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (5/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (6/33) TLA-3T105LF(-T)/109LF(-T)/110LF(-T)/112LF(-T) ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3T1 LF-T: Tape and reel, TLA-3T1 LF: Bulk). SHAPES AND DIMENSIONS 11.6max. GENERAL SPECIFICATIONS Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage 2 2 1 0 to +70°C –40 to +85°C Erms: 2000V[60s] CIRCUIT DIAGRAM 5.9max. ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ N.C. pins: ‡•
‪ ‥ 0.25typ. ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 … ‭ 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-3T105LF(-T) TLA-3T109LF(-T) TLA-3T110LF(-T) TLA-3T112LF(-T) Turns ratio „‟†:‭‬‫‫‬ ‣․‥:
‧… Inductance (PH)min.[100kHz] „-† ‣-‥ Leakage inductance (PH)max.[100kHz] „-†[‭-‫ ‫‬shorted] ‣-‥[
-… shorted] 1CT:1CT 1CT:1CT 2CT:1CT 1CT:1CT 1CT:1CT 1CT:1.41CT 1CT:1CT 1CT:2.5CT 130 130 130 130 130 130 130 130 0.3 0.3 0.95 0.35 0.35 0.35 0.35 0.35 Inter-winding stray capacitance (pF)max.[100kHz] „†-‭‫‫‬ ‣‥-
… 12 12 12 12 12 12 12 12 DC resistance (:)max. „-† ‣-‥ 0.5 0.5 0.5 0.5 0.5 0.5 0.85 0.85 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (7/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (8/33) TLA-6T103LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX & ATM FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(2.54mm=100mil pin pitch). • Excellent common-mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T103LF-T: Tape and reel, TLA-6T103LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 25.7max. Pulse transformer Common-mode choke Inductor Port Withstanding voltage 1CT:1CT „ ․ ‟ ‣ RX TDK∗∗∗ Part No. Lot No. 9.3typ. 12.5±0.3 0.8typ. 2.54typ. … Operating Storage Temperature ranges 5.95max. ‭ • † „ 2 2 1 1 0 to +70°C –40 to +85°C Erms:1500V[60s] 1CT:1CT ‥ ‬
 0.25typ. TX ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm N.C. pins: ‡‥…‪ RECOMMENDED PC BOARD PATTERN 17.78 … 5.0 2.54 8.64 13.72 ‭ Primary signal pattern (connected No.„-†, ‫‫‬-‭) keep out area Secondary signal pattern (connected No.•-․, ‧-
) keep out area „ 2.54 ‥ 1.02 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio ‬‫‫‬‭ :
‧ „†‟ : ․•‣ TLA-6T103LF(-T) 1CT:1CT 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz]
-‧ ․-‣ 350 350 Insertion loss (dB)max. [0.1 to 100MHz] ‬‭-
‧ ․‣-„‟ 1 1 Inter-winding stray capacitance (pF)max.[100kHz] ‬‭-
‧ „‟-․‣ 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (9/33) PACKAGING STYLES Quantity : 600pieces/reel 4 13.1 6.1 40.4 1.7 (25.9) 2 20.2 16 44 ± 0.3 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (10/33) TLA-6T118LF/119LF/120LF/121LF/122LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Excellent common mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T1 LF-T: Tape and reel, TLA-6T1 LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 11.6max. 5.9max. Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ 0.25typ. TX RX N.C. pins: ‡•
‪ ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 ‭ … 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-6T118LF(-T) TLA-6T119LF(-T) TLA-6T120LF(-T) TLA-6T121LF(-T) TLA-6T122LF(-T) Turns ratio „‟† : ‭‬‫‫‬ ‣․‥ :
‧… 1CT:1CT 1CT:1CT 1.41CT:1CT 1CT:1CT 2CT:1CT 1CT:1CT 1CT:1.41CT 1CT:1CT 1.25CT:1CT 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ‭-‫‫‬
-… 350 350 350 350 350 350 350 350 350 350 Insertion loss (dB)max. [0.1 to 100MHz] „†-‭‫‫‬
…-‣‥ 1 1 2 1 3.5 1 2.5 1 2 1 Inter-winding stray capacitance (pF)max.[100kHz] „†-‭‫‫‬ ‣‥-
… 25 25 25 25 25 25 25 25 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (11/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (12/33) TLA-6T127LF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX, POWER OVER ETHERNET FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Allowable current is 350mA max. • Excellent common mode noise suppression under the power transmission. • Packaging specification is taping and bulk(TLA-6T127LF-T: Tape and reel, TLA-6T127LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 11.6max. 5.9max. Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ TX 0.25typ. RX N.C. pins: ‡• ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 ‭ … 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „‟† : ‭‬‫‫‬ ‣․‥ :
‧… TLA-6T127LF(-T) 1CT:1CT 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ‭-‫‫‬
-… 350 350 Insertion loss (dB)max. [0.1 to 100MHz] „†-‭‫‫‬
…-‣‥ 1 1 Inter-winding stray capacitance (pF)max.[100kHz] „†-‭‫‫‬ ‣‥-
… 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (13/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (14/33) TLA-6T133WLF(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Can be used in the wide range of temperature(–40 to +85°C). • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Excellent common mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T133WLF-T: Tape and reel, TLA-6T133WLF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 11.6max. 5.9max. Pulse transformer Common-mode choke Port Operating Storage Temperature ranges Withstanding voltage ‭ ‬ ‫‫‬ ‪
 ‧ … „ ‟ † ‡ • ‣ ․ ‥ 2 2 1 –40 to +85°C –40 to +85°C Erms:1500V[60s] … TDK∗∗∗ Part No. Lot No. 6.8typ. 9.2±0.2 ‭ 0.5typ. 1.27typ. „ ‥ 0.25typ. TX RX N.C. pins: ‡•
‪ ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm RECOMMENDED PC BOARD PATTERN 8.89 ‭ … 3.4 9.8 Primary signal pattern (connected No.„-‥) keep out area 1.4 Secondary signal pattern (connected No.…-‭) keep out area „ ‥ 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „‟† : ‭‬‫‫‬ ‣․‥ :
‧… TLA-6T133WLF(-T) 1CT:1CT 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ‭-‫‫‬
… 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (15/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 10 11.5 12 5.9 24 ± 0.3 (12.4) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (16/33) TLA-6T214ALF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package(1.27mm=50mil pin pitch). • Low profile (H)2.1mm max. for note PC application. • Excellent common mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T214ALF-T: Tape and reel, TLA-6T214ALF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 2.10max.
 ‧ … „ ‟ † ‣ ․ ‥ 1CT:1CT TDK∗∗∗ Part No. Lot No. „ Withstanding voltage ‣ ‥ 1CT:1CT ‫‫‬ 8.37typ. 9.47±0.2 ‭ Operating Storage Temperature ranges 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] 0.95typ. 12.70max. Pulse transformer Common-mode choke Port 0.25typ. TX 1.27typ. 0.10max. 0.45typ. RX ∗∗∗: Country of origin Dimensions in mm RECOMMENDED PC BOARD PATTERN 1.8 10.07 8.89 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „†‟:‭‫‬‫‬ ․‣‥:‧
… TLA-6T214ALF(-T) 1CT:1CT 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ‭-‬ ‧-… 350 350 Insertion loss (dB)max. [0.1 to 125MHz] „‟-‭‬ ‧…-․‥ 1 1 Inter-winding stray capacitance (pF)max.[100kHz] „‟-‭‬ ‧…-․‥ 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (17/33) PACKAGING STYLES Quantity : 1500pieces/reel 10 11.5 4 2.2 24±0.3 (13.4) 2 12 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.3 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (18/33) TLA-6T213LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 12-pin SMD package(1.27mm=50mil pin pitch). • Because it is low profile design of 2.2mm max., space saving is possible and is suitable for notebook PC. • Excellent common mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T213LF-T: Tape and reel, TLA-6T213LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM Ӽ ӻ Ӻ ӹ Ӹ ӷ „ ‟ † Ӵ ӵ Ӷ 1CT:1CT ‣ 1CT:1CT ӷ „ Withstanding voltage 2.2max. TDK∗∗∗ Part No. Lot No. 8.5typ. 9.47±0.25 Ӽ Operating Storage Temperature ranges 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] 0.8typ. 8.4max. Pulse transformer Common-mode choke Port 0.2typ. TX 0.45typ. 1.27typ. 0.10max. RX ∗∗∗: Country of origin Dimensions in mm RECOMMENDED PC BOARD PATTERN 1.65 10.2 6.35 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „†‟:
 •‡‣:‥…․ TLA-6T213LF(-T) 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz]
 ‥-․ 350 Insertion loss (dB)max. [0.1 to 100MHz] „‟-
 ‥․-•‣ 1 Inter-winding stray capacitance (pF)max.[100kHz] „‟-
 ‥․-•‣ 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (19/33) PACKAGING STYLES Quantity : 1500pieces/reel 2 4 10 7.5 12 2.2 16±0.3 (8.8) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.3 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 22.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (20/33) TLA-7T201LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 24-pin SMD package(1.27mm=50mil pin pitch). • Because it is low profile design of 2.2mm max., space saving is possible and is suitable for notebook PC. • Excellent common mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-7T201LF-T: Tape and reel, TLA-7T201LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM Withstanding voltage ‵ ‴ ″ ′ ‱ ‰ „ ‟ † Ӵ ӵ Ӷ „   ‫‮‬ ‭ ‬ ‫‫‬ ‪ Ӽ ․ ‥ … ‧
 1CT:1CT 1CT:1CT 1CT:1CT TDK∗∗∗ Part No. Lot No. 1CT:1CT ӽ 8.5typ. 9.47±0.25 Operating Storage Temperature ranges 2.2max. ‵ 4 4 1[1000BASE-T] 0 to +70°C –40 to +85°C Erms:1500V[60s] 0.8typ. 16max. Pulse transformer Common-mode choke Port 0.2typ. ∗∗∗: Country of origin 0.45typ. 1.27typ. 0.10max. Dimensions in mm RECOMMENDED PC BOARD PATTERN 1.65 10.2 13.97 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „†‟:‵″‴ •‡‣:‱′‰ ․…‥: ‭‫‮‬
:‫‬‫‬‪ TLA-7T201LF(-T) 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ‵-‴ ‱-‰  -‫‮‬ ‫‫‬-‪ 350 Insertion loss (dB)max. [0.1 to 100MHz] „‟-‵‴ •‣-‱‰ ․‥- ‫‮‬
-‫‫‬‪ 1 Inter-winding stray capacitance (pF)max.[100kHz] „‟-‵‴ •‣-‱‰ ․‥- ‫‮‬
-‫‫‬‪ 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (21/33) PACKAGING STYLES Quantity : 1500pieces/reel 2 4 10 11.5 12 2.2 24±0.3 (16.2) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.3 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (22/33) TLA-6T406(-T) ISO8802.3(IEEE802.3) 10/100BASE-TX GENERAL SPECIFICATIONS FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (250°C max.). • 40-pin SMD package(1.27mm=50mil pin pitch) for Quad port. • Excellent common-mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-6T406-T: Tape and reel, TLA-6T406: Bulk). SHAPES AND DIMENSIONS Withstanding voltage 5.8max. ⁅ ⁄ ⁃ ⁂ ⁁ ⁀ ‿ ‾ ‽ › ‹ ‸ ‼ ※ ‷ ‶ ‵ ‴ ″ ′ „ 1.27typ. ‟ † ‡ „ 0.25typ. ‱ TX • ‣ RX ․ ‥ … RX ‧
 TX
 ‪ ‫‫‬ TX 1CT:1CT 1CT:1CT 1CT:1CT 1CT:1CT 1CT:1CT 1CT:1CT Part No. Lot No. 1CT:1CT TD K ∗∗∗ 1CT:1CT 0.8typ. ′ 12.2typ. 15.7±0.25 Operating Storage Temperature ranges 8 8 4 0 to +70°C –40 to +85°C Erms:1500V[60s] CIRCUIT DIAGRAM 25.9max. ⁅ Pulse transformer Common-mode choke Port ‬ ‭ RX ‫   ‮‬‰ RX ‱ TX ∗∗∗ : Country of origin 0.45typ. 0.15max. Dimensions in mm 24.13typ.(1.27×19) RECOMMENDED PC BOARD PATTERN 24.13 (1.27×19) ′ Primary signal pattern (connected No.„-‱) keep out area 8.7 16.2 13.2 ⁅ 1.27 Secondary signal pattern (connected No.′-⁅) keep out area „ ‱ 0.65 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „†‟:⁅⁃⁄..... ‡†•:⁂⁃⁁..... TLA-6T406(-T) 1CT:1CT 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ⁅-⁄...... ⁂-⁁...... 350 350 Insertion loss (dB)max. [0.1 to 100MHz] „‟-⁅⁄..... ‡•-⁂⁁..... 1 1 Inter-winding stray capacitance (pF)max.[100kHz] „‟-⁅⁄..... ‡•-⁂⁁..... 40 40 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (23/33) PACKAGING STYLES Quantity : 500pieces/reel 6 40.4 1.7 (26.3) 2 4 44 ± 0.3 16.1 20.2 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.5 ± 0.05 20 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 250˚C max. 230˚C Natural cooling 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Dimensions in mm RECOMMENDED STORE CONDITION The product is packaged by Anti-humid Al bag, in order to keep a good solder ability condition and resistance to soldering heat for products. • Before aluminum bag opening Temperature range: +5 to +40°C Humidity: 90(%)RH max. Storage period: 1year • After aluminum bag opening Temperature range: +5 to +30°C Humidity: 60(%)RH max. Storage period: 1week Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (24/33) TLA-7T101LF(-T) ISO8802.3(IEEE802.3) 10/100/1000BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 24-pin SMD package(1.27mm=50mil pin pitch). • Excellent common-mode noise suppression. • Inductance is 350μH or greater (f=100kHz, DC bias=8mA). • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-7T101LF-T: Tape and reel, TLA-7T101LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 15.82max. Pulse transformer Common-mode choke Port Temperature ranges Operating Storage Withstanding voltage 4 4 1(1000BASE-T) –40 to +85°C –40 to +85°C Erms:1500V[60s] 5.9max. ‪ TDK∗∗∗ Part No. Lot No. 6.74typ. 9.14±0.2 0.5typ. 1.27typ. ‵ ӱ
 0.25typ. ∗∗∗: Country of origin 0.45typ. 0.10max. Dimensions in mm RECOMMENDED PC BOARD PATTERN Primary signal pattern (connected No. - ) keep out area 3.34 1.4 9.74 13.97 Secondary signal pattern (connected No. - ) keep out area 1.27 0.9 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio ‟„† : ‴‵″ •‡‣ : ‱′‰ ‥․… : ‫ ‮‬‭
 : ‫‬‫‬‪ TLA-7T101LF(-T) 1CT:1CT Inductance (PH)min. [DC bias 8mA, 100kHz] ‴-″ ‱-‰ ‫‮‬-‭ ‫‫‬-‪ 350 Insertion loss (dB)max. [0.1 to 100MHz] ‟†-‴″ •‣-‱‰ ‥…-‫‮‬‭
-‫‫‬‪ 1 Inter-winding stray capacitance (pF)max.[100kHz] ‟†-‴″ •‣-‱‰ ‥…-‫‮‬‭
-‫‫‬‪ 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (25/33) PACKAGING STYLES Quantity : 1000pieces/reel 2 4 9.8 11.5 12 5.9 24 ± 0.3 (15.9) ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 30.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (26/33) Pulse Transformers/Connector Type TLA-6T776F ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular jack. • Excellent common mode noise suppression. • Inductance is 200μH or greater (f=100kHz, DC bias=8mA). • The product features high quality, containing a self-winding surface-mount pulse transformer and common mode choke. GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 2.5typ. 16±0.5 Pulse transformer Common-mode choke Port Operating Storage Temperature ranges 21.45±0.5 2 2 1 –40 to +85°C –40 to +85°C TX „ ₷ 13.85±0.5 ‟ ₸ † ‡ ₺ • ₻ 3.2typ. 3.2typ. PCB ‣ Dimensions in mm ‥ CABLE ₼ ․ 75Ω ₷ 75Ω ₾ ₹ RX 75Ω ₽ ₾ 0.001μF 75Ω N.C. pin: ․ RECOMMENDED PC BOARD PATTERN 8-ø0.9 10.92typ. 8.89typ. ‟ ‡ ‣ ‥ „† • ․ 3.05typ. 2-ø1.6 1.27typ. 2-ø3.25 21.45typ. 2.54typ. 8.89typ. 11.43typ. 15.75typ. 16.0typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „†‟:₷₸ ‡‣•:₹₼ TLA-6T776F 1CT:1 1CT:1 Inductance (PH)min. [DC bias 8mA, 100kHz] ₷-₸ ₹-₼ 200 200 Insertion loss (dB)max. [0.1 to 100MHz] „‟-₷₸ ₹₼-‡• 1.5 1.5 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (27/33) PACKAGING STYLES Tray : 360pieces/box RECOMMENDED SOLDERING CONDITION FLOW SOLDERING 5±1s 255˚C max. Natural cooling 130˚C 90˚C Preheating: 30 to 45s Time(s) Preheating: 90 to 130°C for 30 to 45 seconds. Soldering: 255°C max. 5±1 seconds • Perform flow soldering from the underside of the board. • The surface of plastic protrusions inserted into the board may melt, but this causes no problems with regard to electrical properties or mounting. • The cutted end of terminal has no plating(out of subject of solder ability). RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +40°C Humidity: 10 to 75%RH max. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (28/33) TLA-6T785 ISO8802.3(IEEE802.3) 10/100BASE-TX FEATURES • Product conforming to RoHS directive. • Pulse transformer, common mode choke, resistor and high withstanding voltage capacitor are integrated into RJ-45 modular jack. • Excellent common mode noise suppression. • Inductance is 200μH or greater (f=100kHz, DC bias=8mA). • The product features high quality, containing a self-winding surface-mount pulse transformer and common mode choke. GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM Pulse transformer Common-mode choke Port 16±0.5 Operating Storage Temperature ranges 18.5±0.5 TX „ 12±0.5 2 2 1 –40 to +85°C –40 to +85°C ₷ ‟ ₸ † ₹ PCB ₷ • ₻ CABLE ₼ ‣ ․ 75Ω ₾ ₺ 75Ω 18.2±0.5 RX ‡ 75Ω ₽ ₾ ‥ 0.001μF 75Ω Dimensions in mm N.C. pin: ․ RECOMMENDED PC BOARD PATTERN ․ • † „ 2-ø2.1 3.05typ. 2-ø3.2 ‥ ‣ ‡ ‟ 8-ø0.9 1.27typ. 8.89typ. 2.54typ. 8.89typ. 4.55typ. 16.0typ. 11.43typ. Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. Turns ratio „†‟:₷₸ ‡‣•:₹₼ TLA-6T785 1CT:1 1CT:1 Inductance (PH)min. [DC bias 8mA, 100kHz] ₷-₸ ₹-₼ 200 200 Insertion loss (dB)max. [0.1 to 100MHz] „‟-₷₸ ₹₼-‡• 1.5 1.5 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (29/33) PACKAGING STYLES Tray : 500pieces/box RECOMMENDED SOLDERING CONDITION FLOW SOLDERING 5±1s 255˚C max. Natural cooling 130˚C 90˚C Preheating: 30 to 45s Time(s) Preheating: 90 to 130°C for 30 to 45 seconds. Soldering: 255°C max. 5±1 seconds • Perform flow soldering from the underside of the board. • The surface of plastic protrusions inserted into the board may melt, but this causes no problems with regard to electrical properties or mounting. • The cutted end of terminal has no plating(out of subject of solder ability). RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +40°C Humidity: 10 to 75%RH max. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (30/33) LC Modules TLA-3M103LF(-T) ISO8802.3(IEEE802.3) 10BASE-T FEATURES • Product conforming to RoHS directive. • Can be mounted with lead-free solder (260°C max.). • 16-pin SMD package (2.54mm=100mil pin pitch). • Pulse transformer, common-mode choke and low pass filter are integrated into 16-pin SMD package. • Using the high-quality and wide-band ferrite cores for LAN. • Packaging specification is taping and bulk(TLA-3M103LF-T: Tape and reel, TLA-3M103LF: Bulk). GENERAL SPECIFICATIONS SHAPES AND DIMENSIONS CIRCUIT DIAGRAM 25.7max. Low pass filter Pulse transformer Common-mode choke Port Temperature ranges Withstanding voltage 1CT:1CT 5.95max. … „ „ L.P. FILTER ‥ † L.P. FILTER ‣ TX TDK∗∗∗ Part No. Lot No. 9.5typ. 12.5±0.3 0.8typ. 2.54typ. ‭ Operating Storage 2 2 2 1 0 to +70°C –40 to +85°C Erms:1500V[60s] • ․ 1CT:1CT ‥ ‭ L.P. FILTER … ‫‫‬ L.P. FILTER
 0.25typ. RX ∗∗∗: Country of origin 0.10max. 0.45typ. Dimensions in mm
 RECOMMENDED PC BOARD PATTERN ‧ N.C. pins: ‟‡‪‬ 2.54 13.72 2.54 17.78 1.02 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. TLA-3M103LF(-T) Insertion loss (dB)max.[5 to 10MHz] „†-‥‣ …
-‭‫‫‬ 1 1 Attenuation (dB)min.[30 to 100MHz] „†-‥‣ …
-‭‫‫‬ 25 25 Impedance (:)typ.[5 to 10MHz] „-†, ‥-‣ ‭-‫‫‬, …-
 100, 100 100, 100 C.M.R.R. (dB)min.[1 to 100MHz] „†-‥‣ ‭‫‫‬-…
 25 25 • Ta=25°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (31/33) PACKAGING STYLES Quantity : 600pieces/reel 4 13.1 6.1 40.4 1.7 (25.9) 2 20.2 16 44 ± 0.3 ø1.5+0.1, -0 1.75 TAPE DIMENSIONS 0.4 Dimensions in mm ø330typ. REEL DIMENSIONS 2±0.5 ø21±0.8 ø13±0.2 50.4max. RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING 30s max. 260˚C max. 230˚C Natural cooling Dimensions in mm RECOMMENDED CONDITION FOR LONG TERM STORE When it stores for a long term, please avoid place of high temperature and high humidity. Recommend that it uses after the delivery within 1year. Temperature range: +5 to +30°C Humidity: 60(%)RH max. 165±15˚C 2˚C/s 120s max. 1 to 2˚C/s Time(s) • Temperature is measured at the terminal portion of product (Using thermocoupler for measurement). • This profile is reference data we recommend. Please check in your actual process. • For reliable soldering, the thickness of solder paste screen should be over the terminal co-planality. • The cutted end of terminal has no plating(out of subject of solder ability). • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (32/33) Pulse Transformers/SMD Type ALT4532 SHAPES AND DIMENSIONS L APPLICATIONS LAN interface portion of various devices such as network devices, communication devices, and digital home appliances 2 1 5 6 4532 - 201 - T 001 (2) (3) (4) (5) Dimensions in mm (1) Series name (2) Dimensions LuW (3) Inductance[at 100kHz/DC bias=8mA] 201 : 200μH min. (4) Packaging style T: ø330mm reel taping (5) TDK internal code Type ALT4532-171-T001 ALT4532-201-T001 Reel ø180mm 1.45 0.7 0.45 –40 to +85°C –40 to +85°C PACKAGING STYLE AND QUANTITIES Packaging style Taping T 2.2max. 2.9max. 0.45 1.45 1.1 Quantity 2000 pieces/reel 0.5 Operating Storage(After mount) W 3.2±0.2 3.2±0.2 RECOMMENDED PC BORARD PATTERN SPECIFICATIONS Temperature range L 4.5±0.2 4.5±0.2 0.675 1.35 ALT (1) 4 T PRODUCT IDENTIFICATION 3 W FEATURES • The ALT4532 Series is a wound chip type pulse transformer developed for LANs. • Compatible with 10BASE-T, 100BASE-TX, and 1000BASE-T. • High-quality product with automatic winding. • Product conforming to RoHS directive. Dimensions in mm MEASURING CIRCUIT 4 3 5 2 1 6 ELECTRICAL CHARACTERISTICS Part No. Turns ratio „‣‟ : •†‡ ALT4532-171-T001 ALT4532-201-T001 1CT : 1CT 1CT : 1CT Inductance (μH)min. [DC bias 8mA, 100kHz] „-‟ •-‡ 170 200 Insertion loss (dB)max. [0.1 to 100MHz] „‟-•‡ Inter-winding stray capacitance (pF)max. [100kHz] 2.5 1.5 35 35 • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm (33/33) TYPICAL ELECTRICAL CHARACTERISTICS INSERTION LOSS vs. FREQUENCY CHARACTERISTICS ALT4532-171-T001 ALT4532-201-T001 0 Insertion loss(dB) Insertion loss(dB) 0 –1.0 –2.0 –3.0 –1.0 –2.0 –3.0 –4.0 0.1 1 10 Frequency(MHz) 100 –4.0 0.1 1 10 Frequency(MHz) 100 TYPICAL APPLICATIONS (100BASE-TX) LAN IC LAN Connector Pulse transformers ALT4532-171-T001 ALT4532-201-T001 Common mode filters ACM2012-201-2P ACM2012-361-2P ACM2012-681-2P ACM2012-102-2P Note) Peripheral circuits differ depending on the IC used; check the circuits with the application note of the IC, etc. • All specifications are subject to change without notice. 006-02 / 20120414 / edlan_tla.fm
TLA-6T406 价格&库存
很抱歉,暂时无法提供与“TLA-6T406”相匹配的价格&库存,您可以联系我们找货
