I N D U C T O R S
March 2018
Transponder coils
TPL series
TPL802727
(2/7)
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
If an ultrasonic process is used, thoroughly check the condition setting in order to prevent disconnection.
Do not clean the products with solvents. If a potting resin or a moisture-proof coat containing a solvent such as acetone, toluene or
xylene is used, consult with us in advance.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20180306 / transpondercoil_automotive_tpl80_en.fm
(3/7)
I N D U C T O R S
Product compatible with RoHS directive
AEC-Q200
Transponder coils
Overview of TPL802727 type
FEATURES
Transponder coils that ensure high reliability suitable for automotive applications.
Small size (8 mm in length) and high inductance (18. 52 mH max.) are achieved.
Achieves stable electrical characteristics due to their high SRF design structure.
Ensures high reliability suitable for automotive applications by adopting higher heat resistance wire and welding wire connection.
APPLICATION
Mainly receiving LF antenna coils for the in-car devices shown below
Tire-pressure monitoring system (TPMS)
Keyless entry system
Immobilizer etc.
Other electronic devices
PART NUMBER CONSTRUCTION
TPL
Series name
802727
L×W×H dimensions
(mm)
802727
8.0×2.7×2.7
722
H
Inductance
(mH)
722
7.2
Inductance tolerance
H
±3
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Operating
Storage
temperature
temperature
(°C)
(°C)
TPL802727
–40 to +125
–40 to +125
Operating temperature range includes self-temperature rise.
Package quantity
Type
(pieces/reel)
2,500
RoHS Directive Compliant Product: See the following for more details. https://product.tdk.com/info/en/environment/rohs/index.html
(4/7)
I N D U C T O R S
TPL series
TPL802727 type
SHAPE & DIMENSIONS
2.7±0.2
2.7 –0.1
+0.3
7.85±0.15
0.8
1.9
Dimensions in mm
2.2
RECOMMENDED LAND PATTERN
5.3
9.5
Dimensions in mm
(5/7)
I N D U C T O R S
TPL series TPL802727 type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
L
Q
(mH)
18.52
7.20
4.91
4.50
Tolerance
±3%
±3%
±3%
±3%
min.
40
35
30
30
Measuring frequency
(kHz)
125
125
125
125
DC resistance
max.
240
105
85
80
Part No.
TPL802727-193H
TPL802727-722H
TPL802727-492H
TPL802727-452H
This inductance value is an example of the current commercial product. If a different inductance is needed, please contact us.
(6/7)
I N D U C T O R S
L FREQUENCY CHARACTERISTICS GRAPH
30
125kHz
722H
25
Inductance (mH)
193H
10
492H
5
452H
100
1000
10000
Frequency (kHz)
Q FREQUENCY CHARACTERISTICS GRAPH
75
125kHz
Q
50
193H
722H
25
492H
452H
100
1000
10000
Frequency (kHz)
(7/7)
I N D U C T O R S
TPL series
Packaging style
REEL DIMENSIONS
2.0±0.5
E
W1
21.4±1.0
W2
17.4±1.0
P2
2.0±0.1
W
16.0±0.3
N
ø100±1.0
E
2
N
Type
A
TPL802727 ø329+0.5/–1.5
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
A
B
W
F
E
øD0
t
Dimensions in mm
E
1.75±0.1
F
7.5±0.1
Dimensions in mm
Type
TPL802727
160min.
Drawing direction
A
3.0
Taping
B
8.1
øD0
1.5+0.1/–0
P0
4.0±0.1
P1
8.0±0.1
K
2.9
t
0.3
200min.
300min.
Dimensions in mm
很抱歉,暂时无法提供与“TPL802727-722H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.63633
- 30+3.50829
- 100+3.25221
- 500+2.99613
- 1000+2.86809
