TPLC553030-592H
TPLC553030-592H
    TDK(东电化)
    SMD
    TRANSPONDER COIL FOR LF ANTENNA
TPLC553030-592H 数据手册
The product in this catalog is not recommended for new design I N D U C T O R S Transponder coils TPLC series (for automotive) RoHS REACH SVHC-Free AEC-Q200 TPLC553030 type FEATURES Transponder coils that ensure high reliability suitable for automotive applications. Ensures high reliability suitable for automotive applications by adopting higher heat resistance wire and welding wire connection. Operating temperature: –40 to +125°C (including self-temperature rise) Compliant with AEC-Q200 APPLICATION Tire-pressure monitoring system (TPMS) PART NUMBER CONSTRUCTION TPLC Series name 553030 L×W×T dimensions (mm) 553030 5.5×3.0×3.0 - 592 H Inductance (mH) Inductance tolerance (%) CHARACTERISTICS SPECIFICATION TABLE L Q DC resistance Part No. ( ) (mH) Tolerance min. max. 5.89 ±3% 35 125 70 TPLC553030-592H  This inductance value is an example of the current commercial product.If a different inductance is needed, please contact us. Measurement frequency (kHz) TEMPERATURE RANGE, PACKAGE QUANTITY Operating Storage temperature range temperature range –40 to +125 °C –40 to +125 °C  Operating temperature range includes self-temperature rise. Package quantity 2500 pcs/reel Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210217 transpondercoil_automotive_tplc55_en.fm The product in this catalog is not recommended for new design I N D U C T O R S TPLC553030 type L FREQUENCY CHARACTERISTICS 60 Inductance (mH) 50 40 30 20 10 0 10 100 Frequency (kHz) 1000 100 Frequency (kHz) 1000 Q FREQUENCY CHARACTERISTICS 60 50 Q 40 30 20 10 0 10 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20210217 transpondercoil_automotive_tplc55_en.fm The product in this catalog is not recommended for new design I N D U C T O R S TPLC553030 type SHAPE & DIMENSIONS 3.0max. 3.0max. 5.5max. 0.7 1.9 Dimensions in mm 2.3 RECOMMENDED LAND PATTERN 3.7 6.2 Dimensions in mm PACKAGING STYLE REEL DIMENSIONS 2.0 ø100±1.0 2.0±0.5 (1.0) ø13.0±0.5 21.4±1.0 ø21.0±0.8 17.4±1.0 ø329+0.5/–1.5 Dimensions in mm 4.0±0.1 Sprocket hole B 16.0±0.3 2.0±0.1 7.5±0.1 1.5 +0.1 –0 0.3 1.75±0.1 TAPE DIMENSIONS Type TPLC553030 A 3.1 B 5.6 K 3.1 Cavity K A 8.0±0.1 Dimensions in mm 160min. Drawing direction Taping 200min. 300min. Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210217 transpondercoil_automotive_tplc55_en.fm The product in this catalog is not recommended for new design I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. If an ultrasonic process is used, thoroughly check the condition setting in order to prevent disconnection. Do not clean the products with solvents. If a potting resin or a moisture-proof coat containing a solvent such as acetone, toluene or xylene is used, consult with us in advance. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210217 transpondercoil_automotive_tplc55_en.fm
TPLC553030-592H 价格&库存
很抱歉,暂时无法提供与“TPLC553030-592H”相匹配的价格&库存,您可以联系我们找货
